Stackpole Electronics, Inc.
WCB / WCBF / NWCB Series
Resistive Product Solutions
Welded Ceramic Housed Axial Leaded Wirewound Resistor
Features:
Welded element on ceramic core
Low noise, high reliability compared to fiberglass core wirewounds
Fireproof power wirewound
High thermal conductivity
NWCB – Non-inductively Ayrton Perry winding
Body standoffs available; add “F” after WCB
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Ohmic Range (Ω) and Tolerance
Type/Code
Power Rating (W)
@ 70ºC
WCB5, WCBF5
5
1 - 10K
0.1 - 10K
1 - 15K
0.1 - 15K
1 - 20K
0.1 - 20K
WCB7, WCBF7
7
WCB10, WCBF10
10
WCB15, WCBF15
15
WCB20, WCBF20
WCB25, WCBF25
25
NWCB5
5
NWCB7
7
NWCB10
10
NWCB15
15
NWCB20
NWCB25
25
TCR (ppm/ºC)
0.5%
1%
0.1Ω to 10Ω = ± 50 ppm/ºC
> 10Ω = ± 20 ppm/ºC
5%
0.1 - 4.7K
0.1 - 7.5K
0.1 - 10K
Max Voltage Rating = √ P*R
Mechanical Specifications
Type/Code
A
Body Length
B
Height
C
Width
D
Lead Diameter
E
(WCBF only)
WCB5, WCBF5, NWCB5
0.875 ± 0.039
22.23 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.410 ± 0.039
10.41 ± 0.99
1.500 ± 0.250 inches
38.10 ± 6.35
mm
WCB7, WCBF7, NWCB7
1.400 ± 0.039
35.56 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.450 ± 0.039
11.43 ± 0.99
38.10 ± 6.35
mm
WCB10, WCBF10, NWCB10
1.875 ± 0.039
47.63 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.375 ± 0.039
9.53 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.470 ± 0.039
11.94 ± 0.99
38.10 ± 6.35
mm
WCB15, WCBF15, NWCB15
1.875 ± 0.039
47.63 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.610 ± 0.039
15.49 ± 0.99
38.10 ± 6.35
mm
WCB20, NWCB20
2.500 ± 0.039
63.50 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
38.10 ± 6.35
mm
WCBF20
2.355 ± 0.039
59.82 ± 0.99
0.570 ± 0.039
14.48 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.660 ± 0.039
16.76 ± 0.99
38.10 ± 6.35
mm
WCB25, NWCB25
2.500 ± 0.039
63.50 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.500 ± 0.039
12.70 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
38.10 ± 6.35
mm
WCBF25
2.355 ± 0.039
59.82 ± 0.99
0.570 ± 0.039
14.48 ± 0.99
0.036 ± 0.002
0.91 ± 0.05
0.660 ± 0.039
16.76 ± 0.99
38.10 ± 6.35
mm
Rev Date: 5/17/2023
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
F
Lead Length
Unit
www.seielect.com
marketing@seielect.com
Performance Characteristics
Test
Test Results
Moisture Resistance
Thermal Shock
Load Life @ 70C - 1000 hours
Resistance to Soldering Heat
Short Time Overload - 5 X Pn for 5 seconds
Dielectric Withstanding Voltage
Operating Temperature Range: -55C to +275C
± 5%
± 2%
± 5%
± 2%
± 2%
± 2%
Power Derating Curve:
Recommended Soldering Condition
Flow Soldering:
- Pre-heating: 110°C MAX
- Peak temperature/duration: 260°C
within 10 seconds (1st, 2nd wave total)
- Temperature profile (see chart on the right)
Iron Soldering:
- 380°C, 5 seconds, once/terminal
Rev Date: 5/17/2023
2
www.seielect.com
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
WCB
WCBF
Description
Ceramic Housed with Axial Leads
Wirewound Resistor
Wirewound Resistor
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Axial
Yes
100% Matte Sn
Jan-06
06/01
Axial
Yes
100% Matte Sn
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
W
Product Series
WCB
Standard
WCBF
With standoff
NWCB
Non-inductive
C
B
Power Rating
Code
(W)
5
5
7
7
10
10
15
15
25
5
J
B
Tolerance
Code
Tol
D
0.5%
F
1%
J
5%
Rev Date: 5/17/2023
Code
B
3
1
Packaging
Description
Size
5
7, 10
Bulk
15
R
Resistance Value
Quantity
500
250
200
200
200
Four characters with
the multiplier used as
the decimal holder.
0.1 ohm = R100
33 ohm = 33R0
3.32 Kohm = 3K32
www.seielect.com
很抱歉,暂时无法提供与“WCB15JB4K00”相匹配的价格&库存,您可以联系我们找货
