MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KXJ
Series
160 to 500Vdc, long life, 105℃
KXL
・Downsized and Longer life from current KXG series
Downsized
・Endurance with ripple current : 8,000 to 12,000 hours at 105℃
・Rated voltage range : 160 to 500V, Capacitance range : 6.8 to 680µF
KXJ
・For electronic ballast circuits and other long life applications
Downsized
・Non solvent resistant type
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
KXQ
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
–40 to +105℃ (160 to 450Vdc)
-25 to +105℃ (500Vdc)
160 to 500Vdc
±20% (M)
(at 20℃, 120Hz)
After 1 minute
After 5 minutes
CV≦1000
I=0.1CV+40
I=0.03CV+15
CV>1000
I=0.04CV+100
I=0.02CV+25
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃)
Rated voltage (Vdc)
160 to 250V
350 to 500V
tanδ (Max.)
0.20
0.24
(at 20℃, 120Hz)
Rated voltage (Vdc)
160 to 250V
350, 400V
420 to 500V
Z(−25℃)/Z(+20℃)
3
5
6
Z(−40℃)/Z(+20℃)
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied(the peak voltage shall not exceed the rated voltage) for the specified time at 105℃.
Rated voltage (Vdc)
160 to 450V
500V
16L to 20L:10,000hours, 25L to 50L:12,000hours φ10:8,000hours, φ12.5 to φ18:10.000hours
Time
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
F±0.5
Code : E
φD'
φd
Sleeve (PET : Brown)
F±0.5
●Terminal
φD
φd
F
φD'
L'
Vent
15min.
4min.
(φ10)
(φ12.5 to φ18)
L'
10
0.6
5.0
12.5 14.5 16
0.6 0.8 0.8
5.0 7.5 7.5
φD+0.5max.
L+1.5max.
18
0.8
7.5
Gas escaped end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KX J AAA E AA AAA M AAA S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 6.8µF:6R8,10µF:100,100µF:101)
Lead forming·taping code
T erminal code
Voltage code (ex. 160V:161,400V:401)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
KXJSeries
◆STANDARD RATINGS
WV
(Vdc)
160
200
Cap
(µF)
Case size
tanδ
φD×L(mm)
39
56
82
82
100
120
120
150
150
150
180
180
180
180
220
220
220
270
270
270
270
330
330
330
330
390
390
470
470
470
470
470
560
560
680
680
27
47
56
68
82
100
100
100
120
120
120
120
150
150
150
180
180
180
220
220
220
220
270
270
270
270
270
330
330
330
390
390
470
470
470
560
10×16
10×20
10×25
10×30
12.5×20
10×35
14.5×20
10×40
10×45
12.5×25
10×50
12.5×30
14.5×25
16×20
12.5×35
16×25
18×20
12.5×40
12.5×45
14.5×31.5
14.5×35.5
12.5×50
14.5×40
16×31.5
18×25
14.5×45
16×35.5
14.5×50
16×40
16×45
18×31.5
18×35.5
16×50
18×40
18×45
18×50
10×16
10×20
10×25
10×30
12.5×20
10×35
12.5×25
14.5×20
10×40
10×45
12.5×30
16×20
10×50
12.5×35
14.5×25
14.5×31.5
16×25
18×20
12.5×40
12.5×45
14.5×35.5
18×25
12.5×50
14.5×40
14.5×45
16×31.5
16×35.5
14.5×50
16×40
18×31.5
16×45
18×35.5
16×50
18×40
18×45
18×50
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
Rated ripple
current
(mArms/105℃, 120Hz)
245
315
415
445
575
570
675
665
695
765
785
885
890
855
1,040
1,020
990
1,190
1,230
1,170
1,210
1,400
1,385
1,350
1,290
1,545
1,500
1,735
1,700
1,730
1,660
1,715
1,920
1,905
2,130
2,145
200
290
345
405
520
520
625
615
595
620
725
695
720
860
810
955
925
895
1,075
1,110
1,095
1,050
1,265
1,250
1,290
1,220
1,250
1,450
1,425
1,395
1,575
1,565
1,755
1,745
1,770
1,945
Part No.
EKXJ161E□□390MJ16S
EKXJ161E□□560MJ20S
EKXJ161E□□820MJ25S
EKXJ161E□□820MJ30S
EKXJ161E□□101MK20S
EKXJ161E□□121MJ35S
EKXJ161E□□121MU20S
EKXJ161E□□151MJ40S
EKXJ161E□□151MJ45S
EKXJ161E□□151MK25S
EKXJ161E□□181MJ50S
EKXJ161E□□181MK30S
EKXJ161E□□181MU25S
EKXJ161E□□181ML20S
EKXJ161E□□221MK35S
EKXJ161E□□221ML25S
EKXJ161E□□221MM20S
EKXJ161E□□271MK40S
EKXJ161E□□271MK45S
EKXJ161E□□271MUN3S
EKXJ161E□□271MUP1S
EKXJ161E□□331MK50S
EKXJ161E□□331MU40S
EKXJ161E□□331MLN3S
EKXJ161E□□331MM25S
EKXJ161E□□391MU45S
EKXJ161E□□391MLP1S
EKXJ161E□□471MU50S
EKXJ161E□□471ML40S
EKXJ161E□□471ML45S
EKXJ161E□□471MMN3S
EKXJ161E□□471MMP1S
EKXJ161E□□561ML50S
EKXJ161E□□561MM40S
EKXJ161E□□681MM45S
EKXJ161E□□681MM50S
EKXJ201E□□270MJ16S
EKXJ201E□□470MJ20S
EKXJ201E□□560MJ25S
EKXJ201E□□680MJ30S
EKXJ201E□□820MK20S
EKXJ201E□□101MJ35S
EKXJ201E□□101MK25S
EKXJ201E□□101MU20S
EKXJ201E□□121MJ40S
EKXJ201E□□121MJ45S
EKXJ201E□□121MK30S
EKXJ201E□□121ML20S
EKXJ201E□□151MJ50S
EKXJ201E□□151MK35S
EKXJ201E□□151MU25S
EKXJ201E□□181MUN3S
EKXJ201E□□181ML25S
EKXJ201E□□181MM20S
EKXJ201E□□221MK40S
EKXJ201E□□221MK45S
EKXJ201E□□221MUP1S
EKXJ201E□□221MM25S
EKXJ201E□□271MK50S
EKXJ201E□□271MU40S
EKXJ201E□□271MU45S
EKXJ201E□□271MLN3S
EKXJ201E□□271MLP1S
EKXJ201E□□331MU50S
EKXJ201E□□331ML40S
EKXJ201E□□331MMN3S
EKXJ201E□□391ML45S
EKXJ201E□□391MMP1S
EKXJ201E□□471ML50S
EKXJ201E□□471MM40S
EKXJ201E□□471MM45S
EKXJ201E□□561MM50S
WV
(Vdc)
220
250
Cap
(µF)
Case size
tanδ
φD×L(mm)
27
39
56
56
68
82
82
100
100
100
120
120
120
120
150
150
150
180
180
180
220
220
220
220
220
270
270
270
270
330
330
330
390
390
390
470
22
33
47
47
56
68
68
82
82
82
100
100
100
100
120
120
120
150
150
150
180
180
180
180
180
220
220
220
220
270
270
270
330
330
330
390
10×16
10×20
10×25
10×30
12.5×20
10×35
14.5×20
10×40
10×45
12.5×25
10×50
12.5×30
14.5×25
16×20
12.5×35
16×25
18×20
12.5×40
12.5×45
14.5×31.5
12.5×50
14.5×35.5
14.5×40
16×31.5
18×25
14.5×45
14.5×50
16×35.5
18×31.5
16×40
16×45
18×35.5
16×50
18×40
18×45
18×50
10×16
10×20
10×25
10×30
12.5×20
10×35
14.5×20
10×40
10×45
12.5×25
10×50
12.5×30
14.5×25
16×20
12.5×35
16×25
18×20
12.5×40
12.5×45
14.5×31.5
12.5×50
14.5×35.5
14.5×40
16×31.5
18×25
14.5×45
14.5×50
16×35.5
18×31.5
16×40
16×45
18×35.5
16×50
18×40
18×45
18×50
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
Rated ripple
current
(mArms/105℃, 120Hz)
200
265
345
370
475
470
555
545
565
625
645
725
725
695
860
845
815
975
1,005
955
1,145
1,095
1,130
1,100
1,050
1,285
1,315
1,245
1,260
1,425
1,450
1,440
1,600
1,590
1,620
1,785
185
240
315
340
430
430
505
495
515
565
585
660
665
635
770
755
730
890
920
870
1,035
990
1,020
995
950
1,160
1,185
1,125
1,135
1,285
1,310
1,300
1,475
1,460
1,485
1,625
Part No.
EKXJ221E□□270MJ16S
EKXJ221E□□390MJ20S
EKXJ221E□□560MJ25S
EKXJ221E□□560MJ30S
EKXJ221E□□680MK20S
EKXJ221E□□820MJ35S
EKXJ221E□□820MU20S
EKXJ221E□□101MJ40S
EKXJ221E□□101MJ45S
EKXJ221E□□101MK25S
EKXJ221E□□121MJ50S
EKXJ221E□□121MK30S
EKXJ221E□□121MU25S
EKXJ221E□□121ML20S
EKXJ221E□□151MK35S
EKXJ221E□□151ML25S
EKXJ221E□□151MM20S
EKXJ221E□□181MK40S
EKXJ221E□□181MK45S
EKXJ221E□□181MUN3S
EKXJ221E□□221MK50S
EKXJ221E□□221MUP1S
EKXJ221E□□221MU40S
EKXJ221E□□221MLN3S
EKXJ221E□□221MM25S
EKXJ221E□□271MU45S
EKXJ221E□□271MU50S
EKXJ221E□□271MLP1S
EKXJ221E□□271MMN3S
EKXJ221E□□331ML40S
EKXJ221E□□331ML45S
EKXJ221E□□331MMP1S
EKXJ221E□□391ML50S
EKXJ221E□□391MM40S
EKXJ221E□□391MM45S
EKXJ221E□□471MM50S
EKXJ251E□□220MJ16S
EKXJ251E□□330MJ20S
EKXJ251E□□470MJ25S
EKXJ251E□□470MJ30S
EKXJ251E□□560MK20S
EKXJ251E□□680MJ35S
EKXJ251E□□680MU20S
EKXJ251E□□820MJ40S
EKXJ251E□□820MJ45S
EKXJ251E□□820MK25S
EKXJ251E□□101MJ50S
EKXJ251E□□101MK30S
EKXJ251E□□101MU25S
EKXJ251E□□101ML20S
EKXJ251E□□121MK35S
EKXJ251E□□121ML25S
EKXJ251E□□121MM20S
EKXJ251E□□151MK40S
EKXJ251E□□151MK45S
EKXJ251E□□151MUN3S
EKXJ251E□□181MK50S
EKXJ251E□□181MUP1S
EKXJ251E□□181MU40S
EKXJ251E□□181MLN3S
EKXJ251E□□181MM25S
EKXJ251E□□221MU45S
EKXJ251E□□221MU50S
EKXJ251E□□221MLP1S
EKXJ251E□□221MMN3S
EKXJ251E□□271ML40S
EKXJ251E□□271ML45S
EKXJ251E□□271MMP1S
EKXJ251E□□331ML50S
EKXJ251E□□331MM40S
EKXJ251E□□331MM45S
EKXJ251E□□391MM50S
□□ : Enter the appropriate lead forming or taping code.
KXJSeries
◆STANDARD RATINGS
WV
(Vdc)
350
400
Cap
(µF)
Case size
tanδ
φD×L(mm)
12
22
27
27
33
39
47
47
47
56
56
56
68
68
68
68
82
82
82
100
100
100
100
100
120
120
120
150
150
150
150
180
180
180
220
220
10
18
22
27
27
33
39
39
39
39
47
47
56
56
56
56
68
68
68
82
82
82
82
82
100
100
100
120
120
120
120
120
150
150
180
220
10×16
10×20
10×25
10×30
12.5×20
10×35
10×40
12.5×25
14.5×20
10×45
12.5×30
16×20
10×50
12.5×35
14.5×25
18×20
12.5×40
14.5×31.5
16×25
12.5×45
12.5×50
14.5×35.5
16×31.5
18×25
14.5×40
14.5×45
16×35.5
14.5×50
16×40
16×45
18×31.5
16×50
18×35.5
18×40
18×45
18×50
10×16
10×20
10×25
10×30
12.5×20
10×35
10×40
10×45
12.5×25
14.5×20
12.5×30
16×20
10×50
12.5×35
14.5×25
18×20
12.5×40
14.5×31.5
16×25
12.5×45
12.5×50
14.5×35.5
16×31.5
18×25
14.5×40
14.5×45
16×35.5
14.5×50
16×40
16×45
18×31.5
18×35.5
16×50
18×40
18×45
18×50
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
Rated ripple
current
(mArms/105℃, 120Hz)
135
200
240
255
330
325
375
425
420
425
495
475
485
580
545
550
655
645
625
750
770
740
740
710
835
860
830
980
960
975
940
1,090
1,065
1,080
1,210
1,220
125
180
215
255
300
300
340
355
390
385
455
435
440
525
495
500
600
585
570
680
700
670
670
640
760
785
760
875
860
875
840
870
995
985
1,095
1,220
Part No.
EKXJ351E□□120MJ16S
EKXJ351E□□220MJ20S
EKXJ351E□□270MJ25S
EKXJ351E□□270MJ30S
EKXJ351E□□330MK20S
EKXJ351E□□390MJ35S
EKXJ351E□□470MJ40S
EKXJ351E□□470MK25S
EKXJ351E□□470MU20S
EKXJ351E□□560MJ45S
EKXJ351E□□560MK30S
EKXJ351E□□560ML20S
EKXJ351E□□680MJ50S
EKXJ351E□□680MK35S
EKXJ351E□□680MU25S
EKXJ351E□□680MM20S
EKXJ351E□□820MK40S
EKXJ351E□□820MUN3S
EKXJ351E□□820ML25S
EKXJ351E□□101MK45S
EKXJ351E□□101MK50S
EKXJ351E□□101MUP1S
EKXJ351E□□101MLN3S
EKXJ351E□□101MM25S
EKXJ351E□□121MU40S
EKXJ351E□□121MU45S
EKXJ351E□□121MLP1S
EKXJ351E□□151MU50S
EKXJ351E□□151ML40S
EKXJ351E□□151ML45S
EKXJ351E□□151MMN3S
EKXJ351E□□181ML50S
EKXJ351E□□181MMP1S
EKXJ351E□□181MM40S
EKXJ351E□□221MM45S
EKXJ351E□□221MM50S
EKXJ401E□□100MJ16S
EKXJ401E□□180MJ20S
EKXJ401E□□220MJ25S
EKXJ401E□□270MJ30S
EKXJ401E□□270MK20S
EKXJ401E□□330MJ35S
EKXJ401E□□390MJ40S
EKXJ401E□□390MJ45S
EKXJ401E□□390MK25S
EKXJ401E□□390MU20S
EKXJ401E□□470MK30S
EKXJ401E□□470ML20S
EKXJ401E□□560MJ50S
EKXJ401E□□560MK35S
EKXJ401E□□560MU25S
EKXJ401E□□560MM20S
EKXJ401E□□680MK40S
EKXJ401E□□680MUN3S
EKXJ401E□□680ML25S
EKXJ401E□□820MK45S
EKXJ401E□□820MK50S
EKXJ401E□□820MUP1S
EKXJ401E□□820MLN3S
EKXJ401E□□820MM25S
EKXJ401E□□101MU40S
EKXJ401E□□101MU45S
EKXJ401E□□101MLP1S
EKXJ401E□□121MU50S
EKXJ401E□□121ML40S
EKXJ401E□□121ML45S
EKXJ401E□□121MMN3S
EKXJ401E□□121MMP1S
EKXJ401E□□151ML50S
EKXJ401E□□151MM40S
EKXJ401E□□181MM45S
EKXJ401E□□221MM50S
WV
(Vdc)
420
450
Cap
(µF)
Case size
tanδ
φD×L(mm)
6.8
12
15
18
22
27
27
27
27
33
33
33
39
39
47
47
47
56
56
56
68
68
68
68
68
82
82
82
100
100
100
100
120
120
120
150
6.8
12
15
18
18
22
27
27
27
27
33
33
33
39
39
39
47
47
47
56
56
56
56
68
68
68
68
82
82
82
82
100
100
120
120
150
10×16
10×20
10×25
10×30
12.5×20
10×35
10×40
12.5×25
14.5×20
10×45
12.5×30
16×20
10×50
14.5×25
12.5×35
16×25
18×20
12.5×40
12.5×45
14.5×31.5
12.5×50
14.5×35.5
14.5×40
16×31.5
18×25
14.5×45
16×35.5
18×31.5
14.5×50
16×40
16×45
18×35.5
16×50
18×40
18×45
18×50
10×16
10×20
10×25
10×30
12.5×20
10×35
10×40
10×45
12.5×25
14.5×20
12.5×30
14.5×25
16×20
10×50
12.5×35
18×20
12.5×40
14.5×31.5
16×25
12.5×45
14.5×35.5
16×31.5
18×25
12.5×50
14.5×40
14.5×45
16×35.5
14.5×50
16×40
16×45
18×31.5
16×50
18×35.5
18×40
18×45
18×50
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
Rated ripple
current
(mArms/105℃, 120Hz)
105
150
185
215
285
275
290
340
335
335
400
385
375
435
505
500
480
570
590
560
670
640
660
645
615
750
725
730
845
825
840
835
935
930
945
1,060
105
150
185
215
255
250
290
305
340
335
400
400
385
375
460
440
525
515
500
590
580
585
560
670
660
680
660
765
750
760
730
855
835
930
945
1,060
Part No.
EKXJ421E□□6R8MJ16S
EKXJ421E□□120MJ20S
EKXJ421E□□150MJ25S
EKXJ421E□□180MJ30S
EKXJ421E□□220MK20S
EKXJ421E□□270MJ35S
EKXJ421E□□270MJ40S
EKXJ421E□□270MK25S
EKXJ421E□□270MU20S
EKXJ421E□□330MJ45S
EKXJ421E□□330MK30S
EKXJ421E□□330ML20S
EKXJ421E□□390MJ50S
EKXJ421E□□390MU25S
EKXJ421E□□470MK35S
EKXJ421E□□470ML25S
EKXJ421E□□470MM20S
EKXJ421E□□560MK40S
EKXJ421E□□560MK45S
EKXJ421E□□560MUN3S
EKXJ421E□□680MK50S
EKXJ421E□□680MUP1S
EKXJ421E□□680MU40S
EKXJ421E□□680MLN3S
EKXJ421E□□680MM25S
EKXJ421E□□820MU45S
EKXJ421E□□820MLP1S
EKXJ421E□□820MMN3S
EKXJ421E□□101MU50S
EKXJ421E□□101ML40S
EKXJ421E□□101ML45S
EKXJ421E□□101MMP1S
EKXJ421E□□121ML50S
EKXJ421E□□121MM40S
EKXJ421E□□121MM45S
EKXJ421E□□151MM50S
EKXJ451E□□6R8MJ16S
EKXJ451E□□120MJ20S
EKXJ451E□□150MJ25S
EKXJ451E□□180MJ30S
EKXJ451E□□180MK20S
EKXJ451E□□220MJ35S
EKXJ451E□□270MJ40S
EKXJ451E□□270MJ45S
EKXJ451E□□270MK25S
EKXJ451E□□270MU20S
EKXJ451E□□330MK30S
EKXJ451E□□330MU25S
EKXJ451E□□330ML20S
EKXJ451E□□390MJ50S
EKXJ451E□□390MK35S
EKXJ451E□□390MM20S
EKXJ451E□□470MK40S
EKXJ451E□□470MUN3S
EKXJ451E□□470ML25S
EKXJ451E□□560MK45S
EKXJ451E□□560MUP1S
EKXJ451E□□560MLN3S
EKXJ451E□□560MM25S
EKXJ451E□□680MK50S
EKXJ451E□□680MU40S
EKXJ451E□□680MU45S
EKXJ451E□□680MLP1S
EKXJ451E□□820MU50S
EKXJ451E□□820ML40S
EKXJ451E□□820ML45S
EKXJ451E□□820MMN3S
EKXJ451E□□101ML50S
EKXJ451E□□101MMP1S
EKXJ451E□□121MM40S
EKXJ451E□□121MM45S
EKXJ451E□□151MM50S
KXJSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
500
Case size
tanδ
φD×L(mm)
6.8
8.2
10
12
15
15
15
18
18
22
22
27
33
39
10 × 20
10 × 25
10 × 30
12.5× 20
10× 35
10 × 40
12.5 × 25
10× 45
12.5× 30
10 ×50
12.5 × 35
12.5 ×40
12.5× 45
12.5× 50
Rated ripple
current
(mArms/105℃, 120Hz)
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
90
110
130
135
170
175
165
190
190
230
220
260
285
330
Part No.
EKXJ501E□□6R8MJ20S
EKXJ501E□□8R2MJ25S
EKXJ501E□□100MJ30S
EKXJ501E□□120MK20S
EKXJ501E□□150MJ35S
EKXJ501E□□150MJ40S
EKXJ501E□□150MK25S
EKXJ501E□□180MJ45S
EKXJ501E□□180MK30S
EKXJ501E□□220MJ50S
EKXJ501E□□220MK35S
EKXJ501E□□270MK40S
EKXJ501E□□330MK45S
EKXJ501E□□390MK50S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
(160 to 450Vdc)
Capacitance(µF)
Frequency(Hz)
6.8 to 82
100 to 680
120
1.00
1.00
(500Vdc)
1k
1.75
1.67
10k
2.25
2.05
100k
2.50
2.25
Capacitance(µF)
Frequency(Hz)
6.8 to 22
27 to 39
120
1.00
1.00
1k
1.78
1.75
10k
2.30
2.25
100k
2.59
2.50
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
