Technical Data 4342
Effective June 2020
Supersedes June 2017
FP1107R
High frequency, high current power inductors
Applications
Product features
High current carrying capacity
Low core loss, magnetically shielded
Tight tolerance DCR for sensing circuits
Magnetically shielded
Inductance range from 70 nH to 510 nH
Current range from 42 A to 140 A
Frequency range up to 2 MHz
11 mm x 7.2 mm and 11.2 mm x 8.0 mm
footprint surface mount package in 6.5 mm, 7.2
and 7.5 mm heights
Ferrite core material
Moisture sensitivity level (MSL): 1
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
High power density
Data networking and storage systems
Graphics cards and battery power systems
Point-of-load modules
DCR Sensing circuits
Environmental compliance and general
specifications
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020
(latest revision) compliant
HALOGEN
Pb HF
FREE
FP1107R
Technical Data 4342
Effective June 2020
Product Specifications
OCL1
(nH) ±10%
FLL2 (nH)
minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
Isat36
(A)
Isat47
(A)
DCR (mΩ)
@ +20°C
K-factor8
FP1107R1-R07-R
70
50
55
140
na
na
123
0.29 ±8%
361.1
FP1107R1-R12-R
120
86
55
90
na
na
72
0.29 ±8%
361.1
FP1107R1-R15-R
150
108
55
70
na
na
56
0.29 ±8%
361.1
FP1107R1-R23-R
230
166
55
45
na
na
36
0.29 ±8%
361.1
FP1107R1-R30-R
300
217
55
35
na
na
28
0.29 ±8%
361.1
FP1107R1-R40-R
400
288
55
25
na
na
0.29 ±8%
361.1
FP1107R1-R51-R
510
364
55
18
na
na
14.5
0.29 ±8%
361.1
FP1107R2-R07-R
70
50
42
140
na
na
123
0.47 ±6.4%
363.3
FP1107R2-R12-R
120
86
42
90
na
na
72
0.47 ±6.4%
363.3
FP1107R2-R15-R
150
108
42
70
na
na
56
0.47 ±6.4%
363.3
FP1107R2-R23-R
230
166
42
45
na
na
36
0.47 ±6.4%
363.3
FP1107R2-R30-R
300
217
42
35
na
na
28
0.47 ±6.4%
363.3
FP1107R2-R40-R
400
288
42
25
na
na
0.47 ±6.4%
363.3
FP1107R2-R51-R
510
364
42
18
na
na
14.5
0.47 ±6.4%
363.3
180
130
50
62
55
53
50
0.29 ±5%
361
FP1107R5-R070-R
70
50
55
140
na
na
123
0.29 ±5%
361.1
FP1107R5-R120-R
120
86
55
90
na
na
72
0.29 ±5%
361.1
FP1107R5-R150-R
150
108
55
70
na
na
56
0.29 ±5%
361.1
FP1107R5-R230-R
230
166
55
45
na
na
36
0.29 ±5%
361.1
FP1107R5-R300-R
300
217
55
35
na
na
28
0.29 ±5%
361.1
FP1107R5-R400-R
400
288
55
25
na
na
0.29 ±5%
361.1
FP1107R5-R510-R
510
364
55
18
na
na
14.5
0.29 ±5%
361.1
Part number9
R1 version
R2 version
R4 version
FP1107R4-R180-R
R5 version
1. Open circuit inductance (OCL) Test parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full load inductance (FLL) Test parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
2
www.eaton.com/electronics
4. Isat1: Peak current for approximately 20% rolloff @ +25 °C
5. Isat2: Peak current for approximately 20% rolloff @ +85 °C
6. Isat3: Peak current for approximately 20% rolloff @ +100 °C
7. Isat4: Peak current for approximately 20% rolloff @ +125 °C
8. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3. Bp-p:(Gauss),
K: (K-factor from table), L: (Inductance in nH), Symbol I (Peak to peak ripple current in Amps).
9. Part Number Definition: FP1107Rx-Rxxx-R
FP1107R= Product code and size
x= Version indicator
-Rxxx= Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Technical Data 4342
FP1107R
Effective June 2020
Dimensions (mm)
FP1107R1, R2, R5
R ecom m ended P ad Layout
7.2 m ax
A
1.90
+/-0.15
b
S chem atic
2.1
1
3.1
1107R x
R xx
11.0
m ax
5.0
5.8 typ
xxxx
B
2
a
Dimension A
Dimension B
FP1107R1, R5
7.5 maximum
FP1107R1, R5
2.5 ±0.2
FP1107R2
7.2 maximum
FP1107R2
2.2 ±0.2
Part marking: 1107Rx (x = Version indicator), Rxxx = Inductance value in uH (R= decimal point)
xxxx= lot code
Tolerances are ±0.15 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1016 millimeters
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Traces or vias underneath the inductor is not recommended
FP1107R4
Recommended pad layout
b
8.0 max
2.70
2.2 nom
11.2 max
6.3 nom
5.70
a
FP1107Rx
Rxxx
xxxx
Schematic
6.5
max
2.4 nom
2.70
Part marking: FP1107Rx (x = Version indicator), Rxxx = Inductance value in uH (R= decimal point)
xxxx= lot code
All soldering surfaces to be coplanar within 0.1millimeters
3
FP1107R
Technical Data 4342
Effective June 2020
Packaging information (mm)
FP1107R1, R2 Supplied in tape and reel packaging , 640 parts per 13” diameter reel
FP1107R5
Supplied in tape and reel packaging , 600 parts per 13” diameter reel
1.5 dia.
4.0
2.0
1.75
1
11.5
11.2
24
+/-0.3
1107Rx
Rxx
xxxx
2
7.6
1.5 dia.
12.0
Section A-A
Section B-B
User direction of feed
7.4
FP1107R4 Supplied in tape and reel packaging , 750 parts per 13” diameter reel
D0
T
B0
W
FP1107Rx
Rxxx
xxxx
P1
K0
P2
D1
P0
F
W±0.3 24.00
F±0.1 11.50
E1 ±0.1 1.75
P0±0.1 4.00
P1±0.1 12.00
P2±0.1 2.00
D0 0.1
1.50
0.0
1.50
D1 0.1
0.0
A0±0.1 8.3
A1±0.1
B0±0.1 11.5
B1±0.1
K0±0.1 6.7
T±0.05 0.4
E1
User Direction of Unreeling
A0
4
Technical Data 4342
FP1107R
Effective June 2020
Temperature rise vs. total loss
FP1107R1, R2, R5
FP1107R4
70
80
Temperature rise (°C)
60
60
40
40
30
FP1107R1, R5
FP1107R2
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
2.2
10
2.4
Total loss (W)
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Total loss (W)
Core loss vs. Bp-p
1 MHz
FP1107R1, R2, R5
FP1107R4
1
10
500 kHz
300 kHz
200 kHz
1
0.1
Core loss (W)
Co re L o ss (W )
100 kHz
0 .1
0.01
3.0 MHz
1 MHz
700 kHz
2.0 MHz
0 .0 1
0.001
1.5 MHz
0 .0 0 1
100
1000
10000
0.0001
100
B p - p (G a u ss)
1000
10000
Bp-p (Gauss)
Inductance characteristics
FP1107R4-R180-R
FP1107R1, R2, R5
200
100%
180
-40°C
80%
160
+ 25°C
Inductance (nH)
% of OCL
140
60%
40%
+ 125°C
120
100
80
-40 °C
60
20%
+25 °C
+85 °C
40
0%
0%
20%
40%
60%
80%
% o f I sa t1
100%
120%
140%
+100 °C
+125 °C
60
80
100
120
Idc (A)
5
FP1107R
Technical Data 4342
Effective June 2020
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1107R2-R30-R”相匹配的价格&库存,您可以联系我们找货
