5 x 20mm Fast-acting Glass Tube Fuses
GMA Series
Dimensions - mm
38.10mm
10
±.38)
.3
5.54mm
(±.20)
21.10mm
0m
(±.81)
81
5.2mm
(+0.1/-0.2)
38.10mm
0m
(±.3
38)
0.65mm
(REF)
Description
• Ratings above 6.3A have a 0.8mm diameter lead
• With TR2 packaging code, lead wire length is 19.05mm
• Fast-acting, low breaking capacity
• Optional axial leads available
• 5 x 20mm physical size
• Glass tube, silver-plated (63mA-315mA) and nickelplated (500mA-15A) brass endcap construction
• Designed to UL/CSA 248-14
Electrical Characteristics
Rated Current % of Amp Rating
Opening Time
100%
None
63mA - 15A
135%
60 minutes maximum
200%
2 minutes maximum
Agency Information
UL Listed, Guide JDYX, File E19180, 63mA-6A
UL Recognized, Guide JDYX2, File E19180, 7-15A
CSA Certified, Class 1422-01, File 53787, 63mA-6A
PSE Approval, 1A-15A
Ordering
• Specify packaging, product, and option code
Specifications
Product Code
GMA-63-R
GMA-100-R
GMA-125-R
GMA-200-R
GMA-250-R
GMA-300-R
GMA-315-R
GMA-500-R
GMA-600-R
GMA-750-R
GMA-800-R
GMA-1-R
GMA-1.25-R
GMA-1.5-R
GMA-1.6-R
GMA-2-R
GMA-2.5-R
GMA-3-R
GMA-3.15-R
GMA-3.5-R
GMA-4-R
GMA-5-R
GMA-6-R
GMA-7-R
GMA-8-R
GMA-10-R
GMA-15-R
Amp
Rating
63mA
100mA
125mA
200mA
250mA
300mA
315mA
500mA
600mA
750mA
800mA
1
1.25
1.5
1.6
2
2.5
3
3.15
3.5
4
5
6
7
8
10
15
Voltage
Rating
Vac
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
125
125
125
125
125
125
125
125
125
Interrupting
Rating (amps)*
250Vac
125Vac
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
100
10,000
100
10,000
100
10,000
100
10,000
100
10,000
100
10,000
10,000
10,000
10,000
10,000
10,000
200
200
200
150
Typical DC Cold
Resistance
Ω)**
(Ω
15.750
7.840
4.895
2.500
1.735
0.906
0.839
0.454
0.256
0.186
0.170
0.163
0.122
0.090
0.080
0.066
0.046
0.039
0.036
0.030
0.026
0.021
0.017
0.012
0.009
0.006
0.004
Typical
Pre-Arc I2t
Vac†
0.00024
0.0001
0.0024
0.001
0.018
0.019
0.019
0.15
0.32
0.47
0.70
0.48
0.84
1.6
2.0
3.1
4.9
8.8
9.7
13
19
29
45
150
280
280
950
Maximum
Voltage
Drop (mV)‡
4700
4300
2600
3400
2200
470
450
230
200
200
180
300
290
270
260
250
240
215
210
210
205
200
180
110
110
110
100
Interrupting ratings: Interrupting ratings for 63mA - 6A were measured at 70% - 80% power factor on AC. The interrupting ratings for 7A - 15A were measured at 100% power factor on AC.
DC Cold Resistance (Measured at
很抱歉,暂时无法提供与“GMA-125MA-R”相匹配的价格&库存,您可以联系我们找货
