High Current, High Frequency, Power Inductors
HCP0704 Series
Applications:
SMD Device
HF
FREE
Environmental Data:
• Storage temperature range: -40°C to +155°C
• Operating temperature range: -40°C to +155°C
(Range is application specific)
• Solder reflow temperature: J-STD-020D compliant
Description:
HALOGEN
Voltage Regulator Module (VRM)
Multi-phase regulators
Desktop and servers
Base station equipment
Notebook regulators
Data networking and storage systems
Point-of-load modules
Battery power systems
DCR sensing
Halogen free
155°C maximum total temperature operation
6.8 x 6.8 x 4.2mm surface mount package
Powder iron core material
Magnetically shielded, low EMI
High temperature core material eliminates thermal aging issues
High current carrying capacity, low core losses
Controlled DCR tolerance for sensing circuits
Inductance range from 0.40μH to 4.7μH
Current range from 5.0 to 27 amps
Frequency range up to 2MHz
RoHS compliant
Packaging:
• Supplied in tape-and-reel packaging, 1000 parts per reel,
13” diameter reel
Product Specifications
Part Number6
HCP0704-R40-R
HCP0704-R60-R
HCP0704-1R0-R
HCP0704-1R8-R
HCP0704-2R3-R
HCP0704-3R3-R
HCP0704-4R7-R
OCL1 ± 25% (μH)
FLL2 Min. (μH)
Irms3 (Amps)
0.40
0.60
1.00
1.80
2.30
3.30
4.70
0.28
0.42
0.7
1.26
1.56
2.31
3.29
17
14
12
8.5
7.5
6.0
5.0
Isat4 @ 25°C (Amps)
27
21
17
13
11.5
9.5
8.0
DCR (mΩ) @ 20°C
K-factor5
3.2 ±10%
4.5 ±10%
6.2 ±10%
11.0 ±10%
16.5 ±10%
25.0 ±10%
29.5 ±10%
383.1
313.5
265.3
202.8
164.2
149.9
127.7
1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.10Vrms, 0.0Adc
2 Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1
4 Isat: Peak current for approximately 20% rolloff at +25°C.
5 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI : (Gauss), K: (K-factor
3 Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is
necessary for AC currents. PCB pad layout, trace thickness and width, air-flow and proximity of
other heat generating components will affect the temperature rise. It is recommended the part
temperature not exceed 155°C under worst case operating conditions verified in the end
application.
from table), L: (inductance in μH), ΔI (peak-to-peak ripple current in amps).
6 Part Number Definition: HCP0704-xxx-R
• HCP0704 = Product code and size
• xxx= Inductance value in μH, R = decimal point. If no “R” is present, then
third character = # of zeros
• “-R” suffix = RoHS compliant
0209
BU-SB09086
Page 1 of 4
Data Sheet: 4348
Dimensions - mm
T op V iew
R ecom m ended P ad Layout
B ottom V iew
S ide V iew
H C P 0704-R 40 to 2R 3= 1.20 +/- 0.2
H C P 0704-3R 3 to 4R 7= 1.00 +/- 0.2
H C P 0704-R 40 to 1R 0= 4.20 m ax
H C P 0704-1R 8 to 4R 7= 4.00 m ax
7.60
6.80 M ax
2.50(2x)
1
w w llyy R
H C P0704
xxx
3.3±0.3
6.80 M ax 1
S chem atic
2
2
4.00(2x)
1
2
The nominal DCR test point is in the middle of the terminal
xxx = Inductance value in μH. (R = Decimal point). If no “R” is present, then last character is # of zeros
Part Marking: HCP0704
wwllyy = Date code
R = Revision level
Packaging Information - mm
1.5 Dia
min.
4.0
2.0
1.5 Dia.
+0.1/-0.0
1.75
A
Section A-A
1
7.5
HCP0704
xxx
wwllyy R
7.50
16.0
±0.3
2
HCP0704-R40 to 1R0= 4.2
HCP0704-1R8 to 4R7= 4.0
A
6.9
User direction of feed
12.0
Supplied in tape-and-reel packaging, 1000 parts per reel, 13” diameter reel.
Temperature Rise vs. Total Loss
60
Te mpe ta ture R is e (°C)
50
40
30
0.4
0.6
0.8
1
Tota l Los s (W)
0209
BU-SB09086
Page 2 of 4
Data Sheet: 4348
1.2
1.4
Core Loss
Core Los s v s . B p-p
5 0 0 kHz 1 0 0 kHz
1 MHz
2 5 0 kHz
C ore L os s ( W )
10
1
0. 1
0. 01
0. 001
10
100
1000
10000
B p-p (G aus s )
Inductance Characteristics
% o f O C L v s % o f I sat
100%
80%
% o f O CL
25°C
60%
40%
20%
0%
0%
20%
40%
60%
80%
100%
120%
140%
% o f I sat
0209
BU-SB09086
Page 3 of 4
Data Sheet: 4348
160%
Solder Reflow Profile
TP
TC -5°C
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Package
Thickness
Temperature
TL
Preheat
A
T smax
Table 1 - Standard SnPb Solder (T c)
tP
t
Volume
mm3
350
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
25°C
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020D
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
100°C
150°C
• Temperature max. (Tsmax)
150°C
200°C
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
Time 25°C to Peak Temperature
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
North America
Cooper Electronic Technologies
1225 Broken Sound Parkway NW
Suite F
Boca Raton, FL 33487-3533
Tel: 1-561-998-4100
Fax: 1-561-241-6640
Toll Free: 1-888-414-2645
Cooper Bussmann
P.O. Box 14460
St. Louis, MO 63178-4460
Tel: 1-636-394-2877
Fax: 1-636-527-1607
Europe
Cooper (UK) Limited
Burton-on-the-Wolds
Leicestershire • LE12 5TH UK
Tel: +44 (0) 1509 882 737
Fax: +44 (0) 1509 882 786
Avda. Santa Eulalia, 290
08223
Terrassa, (Barcelona), Spain
Tel: +34 937 362 812
+34 937 362 813
Fax: +34 937 362 719
Asia Pacific
1 Jalan Kilang Timor
#06-01 Pacific Tech Centre
Singapore 159303
Tel: +65 278 6151
Fax: +65 270 4160
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann
reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to
change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the
Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
© 2009 Cooper Bussmann
S t . L o u i s, M O 6 3 1 7 8
w w w. c o o p e r bu s s m a n n . c o m
0209
BU-SB09086
Page 4 of 4
Data Sheet: 4348
很抱歉,暂时无法提供与“HCP0704-4R7-R”相匹配的价格&库存,您可以联系我们找货
