Effective April 2014
Supersedes October 2002
Technical Data 2010
BBS Series
13⁄32˝ x 1-3/8˝ 600Vac Fast-acting supplemental fuses
Description
Dimensions - in
Fast-acting supplemental fuse.
For superior protection, Bussmann recommends
upgrading to Low-Peak Class CC fuses. See data
sheet # 1023.
Catalog symbol / color code
BBS - Black (600Vac max voltage 1/10 to 6A)
- Green (250Vac max voltage 7 to 10A)
- Purple (48Vac max voltage 12 to 30A)
Ratings
600Vac
1/10 to 6A
Fuse
Amp
Range
Interrupting Rating at
System Voltage
Agency
Information
600
Vac
250
Vac
48
Vac
UL
CSA
10kA
X
X
7 to 10
10kA
X
X
12 to 30*
1/10 to 6
* For interrupting rating, cointact factory.
250Vac
7 to 10A
Features
Color coded for 600Vac (Black) 250Vac (Green)
and 48Vac (Purple) for maximum voltage ratings
Fiber tube construction
Nickel-plated brass endcaps.
Typical applications
Control circuits
Gaseous vapor fixtures
HID ballasts
Electronic circuits
Hand-held meters
Series
CE
UL Listed, Std. 248-14 (1/10-6A@600Vac,
7-10A@250Vac), Guide JDYX, File E19180
CSA Certified, C22.2 No. 248.14
(1/10-6A@600Vac, 7-10A@250Vac),
Class 1422-01, File 53787
Description
Data Sheet #
Blocks
BMM Series
BM Series
1-, 2- & 3-Pole modular
blocks with optional
covers
10235
1-, 2- & 3-Pole blocks
1104
DIN-Rail Holders / Switches
Catalog numbers (amps)
48Vac
12 to 30A
1.38"
(±0.031)
Recommended fuse blocks/fuse holders
Agency information
0.41"
(±0.004)
CCP-_-30M
1-, 2- & 3-Pole switch
1157
CHM Series
1-, 2- & 3-Pole
3185
1109
BBS-1/10
BBS-8/10
BBS-4
BBS-15
BBS-2/10
BBS-1
BBS-5
BBS-20
Optima NG
3-Pole protection
module
BBS-1/4
BBS-1-1/2
BBS-6
BBS-25
Optima
3-Pole holder
1102
BBS-4/10
BBS-1-6/10
BBS-7
BBS-30
Optima
3-Pole holder + switch
1103
BBS-1/2
BBS-1-8/10
BBS-8
Panel Mount Holders
BBS-6/10
BBS-2
BBS-10
HPF-L
1-Pole holder
2114
BBS-3/4
BBS-3
BBS-12
HPS-L
1-Pole holder
2113
In-line
Carton quantity
HEH
Amps
Qty.
1/10 to 30
10
1-Pole holder
2124
Fuseclips
1A3400, 5956 &
5960 Series
PCB Fuseclips
SAMI-7
Finger-safe fuse cover
2132
Fuse Covers
1204
BBS Series
600Vac Fast-Acting Supplemental Fuses
Technical Data 2010
Effective April, 2014
3
5
6
7
2
3/4
1
100
4/10
Time-current characteristic curves – average melt
Amp Rating
Time in Seconds
10
1
200
Current in Amps
100
10
0.4
0.01
1
0.1
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document
are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue
or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton’s Bussmann Business
114 Old State Road
Ellisville, MO 63021
United States
www.Bussmann.com
© 2014 Eaton
All Rights Reserved
Publication No. 2010 - BU-SB14287
April 2014
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“BBS-1/2”相匹配的价格&库存,您可以联系我们找货
