ONLINE CATALOG
SWITCHCRAFT, INC. 5555 N. Elston Ave.
Chicago, IL 60630 • 773 792-2700 • FAX: 773 792-2129
www.switchcraft.com
EN3™ MINI WEATHERTIGHT CONNECTOR SERIES
EN3™ CORD CONNECTOR
1.568
[39.83]
0.64
REF
0.703 dia.
[17.86]
PIN #1
INDICATOR
Cord Connector Contact Arrangements
Shown from rear of connector
2
3
2
3
3
3
2
4
2
4
4
1
5
1
5
4
4
2
3
5
3
5
1
8
3
2
1
6
1
2
6
7
3
2
* 7 and 8 pin not available in
crimp male, cord male and panel
female
2
1
3
2
DIMENSIONS ARE FOR REFERENCE ONLY
1
Inch
(mm)
NOTE: Contact your Switchcraft Representative for price and delivery.
1
2
6
7
1
ONLINE CATALOG
www.switchcraft.com
EN3™ PANEL MOUNT CONNECTOR
3/16"
(4.76)
31/64"
(12.30)
Inch
(mm)
Panel Connector Contact Arrangements – Shown from front of connector
2
3
3
3
2
2
3
4
2
4
4
4
2
3
5
3
5
1
8
23
1
4
1
5
1
6
5
1
2
6
7
2
3
panel female
2
1
232
1
Inch
(mm)
1
2
6
7
1
ONLINE CATALOG
www.switchcraft.com
EN3™ INLINE CONNECTOR
1.625
(41.27)
CLOSED ENTRY
CONTACT SYSTEM
DOUBLE SEAL
In-Line Connector Contact Arrangements
23
1
3
3
2
3
2
4
2
1
4
1
5
1
4
4
4
5
3
5
3
2
8
1
32
6
5
6
2
1
3
2
in-line female
1
2
1
32
Inch
(mm)
7
6
2
1
7
Switchcraft
Page 1 of 2
SERIES
EN3™ WITH SOLDER CONTACTS
EN3™ WITH CRIMP CONTACTS
EN3™ WITH PC CONTACTS
EN3™ IN-LINE CONNECTOR
http://www.switchcraft.com/products/connectors-28.html
07/07/2006
Switchcraft
Page 2 of 2
EN3™ OVERMOLDED CONNECTOR
07/07/2006
EN3 Series Specifications
Company
A
GENERAL FEATURES AND BENEFITS
• Great all-purpose connector “weather” or not sealing feature is required.
• Superior leakage protection. Contact area is double-sealed for excellent moisture and chemical resistance when mated to
Switccraft’s connectors.
• Integral O-ring and gasket. O-ring is molded onto cord housing assembly and gasket is molded onto panel housing assembly to prevent leakage and
eliminate need for additional O-rings and gaskets.
• Reduced part count for reduced labor to assemble.
• No Grommets. Cable clamp assembly features living hinges, which snap easily onto and support the cable.
• Thermoplastic rubber body simulates closed entry contact system to prevent probe damage or accidental loss of spring retention due to misaligned or
bent pins.
• Abrasion-resistant thermoplastic boot provides strain relief and accepts cable diameter .195” to .265”.
• Housing rated UL 94V-O against flammability.
• Panel connector shell features a positioning keyway to prevent misalignments and a polarizing single “D” design for proper panel mounting and to
prevent rotational movement.
• 2-8 pins.
• Exceeds Coast Guard specifications for water tightness (CFR 46 Part 110.20).
• Optional cap covers panel housing assembly when not in use.
• Exceeds enclosure rating IP16/IP18 when not mated or covered and IP66/IP68 when mated or covered (IEC 529).
• Exceeds enclosure rating 6P at 1000V when mated or covered (NEMA 250).
APPLICATIONS
• Process Control Communications
• Marine Electronics Transportation
• Medical Instrumentation General Industrial Electronics
• Geothermal Instrumentation Harsh Environments
MATERIALS
• Cord and panel connector shells, contact locking disk, and cable clamp assembly: Thermoplastic polymer glass fiber, flame retardant
• Coupling ring: Nylon
• Rear boot and connector shell interior: Thermoplastic rubber
• Contacts: Copper base alloy gold-plated over nickel underplate
SPECIFICATIONS
MECHANICAL
• Shock: Mil-Std 202 Method 213B, condition K
• Vibration: Mil-Std 202 Method 201
• Life: 600 insertion/withdrawal cycles (minimum)
ELECTRICAL
• Voltage Rating (sea level): Tested at 600 VRMS
• Insulation Resistance: 100 megohms (minimum) at 77° F
• Contact Resistance: 5 milliohms (maximum)
• Current Rating: 7.5 Amps (#20 contact) 6.5 Amps (#20 contact) - 7 and 8 Pin 13.0 Amps (#16 contact) - 2 and 3 Pin
ENVIRONMENTAL
• Temperature Limits: -40°C to +65°C (non-operating)
• Moisture Resistance: Mil-Std 202 Method 106F
• Insulation Resistance: Mil-Std 202 Method 302 condition B
• Thermal Shock: Mil-Std 202 Method 107G
• Salt Spray: Mil-Std 202 Method 101D condition B
RATINGS
• IP16/IP18 CFR 46 Part 110.20
• IP66/IP68 UL 94V-O
• NEMA 250 (6P)
• Patent 5,485,673 File 36049
love
.com
A
Company
很抱歉,暂时无法提供与“EN3P4M-F”相匹配的价格&库存,您可以联系我们找货
