2R-5-SST4.2 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
■ Stable breakdown voltage
■ High insulation resistance
■ Low capacitance (≤1pF)
■ High holdover voltage
■ Large absorbing transient current capability
■ Micro-Gap Design
■ Size: 5.0mm*4.2mm
■ Square ceramic tube for SMD
■ Storage and operating temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E244458& E327997
Applications
■ Repeaters, Modems
■ Telephone Interface, Line cards
■ Data communication equipment
■ Line test equipment
Part Number Code
2
M
R
Electrical
Characteristics
K:3KA
L: 5KA
Electrode Numbers
2R: 2 Electrodes
Revision: GDT-2R-5-SST4.2 SERIES-001(A1)
5
Lead Type
M: SMD
DC
Spark-over
Voltage
SST4.2:
Internal Control Code
Dimensions
5: 5.0mm×4.2mm
2/5
http://brightking.pulseelectronics.com
2R-5-SST4.2 SERIES
Dimensions
B
Dimension (mm)
1.1
Symbol
D
5.0
D
4.8
T
Recommended Pad Size
Spec.
Tolerance
D
5.0
±0.2
T
4.2
±0.3
B
0.5
±0.1
Electrical Characteristics
Part
Number
Type
①
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
100V/s
1000V/μs
8/20μs
±5times
Test
Voltage
Minimum
Insulation
Resistance
(V)
(V)
(KA)
DC(V)
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(pF)
2RL075M-5
SST4.2
75±20%
700
5.0
25
1.0
1.0
None
2RL090M-5
SST4.2
90±20%
650
5.0
50
1.0
1.0
None
2RL120M-5
SST4.2
120±20%
700
5.0
50
1.0
1.0
None
2RL150M-5
SST4.2
150±20%
700
5.0
100
1.0
1.0
None
2RL230M-5
SST4.2
230±20%
700
5.0
100
1.0
1.0
None
2RL250M-5
SST4.2
250±20%
700
5.0
100
1.0
1.0
None
2RL300M-5
SST4.2
300±20%
800
5.0
100
1.0
1.0
None
2RL350M-5
SST4.2
350±20%
850
5.0
100
1.0
1.0
None
2RL400M-5
SST4.2
400±20%
900
5.0
100
1.0
1.0
None
2RL470M-5
SST4.2
470±20%
1000
5.0
250
1.0
1.0
None
2RL600M-5
SST4.2
600±20%
1200
5.0
250
1.0
1.0
None
2RK800M-5
SST4.2
800±20%
1600
3.0
250
1.0
1.0
None
2RK1000M-5
SST4.2
1000±20%
1800
3.0
500
1.0
1.0
None
Notes:① Specific code by request.
Electrical Ratings
Items
DC Spark-over
Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
To meet
the specified
Maximum Impulse
The maximum impulse spark-over voltage is measured with voltage ramp
Spark-over Voltage
dv/dt=1000V/μs.
3/5
value
2R-5-SST4.2 SERIES
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval time.
Crest value
Current (%)
100
90
Impulse
Discharge Current
50
20µs
10
8µs
Time
Impulse Width
Insulation
The resistance of gas tube shall be measured between two electrodes.
Resistance
The capacitance of gas tube shall be measured between two electrodes.
Capacitance
Test frequency: 1MHz
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
Peak Temperature (TP)
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
260℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
4/5
2R-5-SST4.2 SERIES
Packaging
Tape
Dimension (mm)
Symbol
P2
D0
t0
E
P1
B0
W
F
P0
K0
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.10
P2
2.00
±0.10
D0
1.55
±0.10
E
1.75
±0.10
F
7.50
±0.10
A0
5.30
±0.10
B0
4.50
±0.10
K0
5.40
±0.10
t0
0.40
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
A0
Reel
t
D
d
L
Quantity: 800pcs
5/5
很抱歉,暂时无法提供与“2RL075M-5-SST4.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.48170
- 50+1.78400
- 100+1.37730
- 200+1.15870
- 300+1.05200
- 800+0.70860
