C5/C6 - SERIES
0.92" DIAMETER
SPECIFICATIONS AND ORDERING INFORMATION
1.0 AMP @ 28 VDC
The C5 Series offers a very economical and lightweight design. Standard
features include 30° indexing up to 12 positions, solder lug terminals, fixed
stops, and both internal and external seals for washability.
The C6 Series offers the same features in an unsealed design.
C
SPECIFICATIONS
ELECTRICAL
MECHANICAL
Current and Voltage Rating: Make and break resistive load
1 amp @ 28 VDC; 1 amp @ 125 VAC.
Current Carrying Capacity: 5 amps.
Dielectric Strength: 1,000 VAC between current carrying parts and
ground.
Contact Resistance: Average initial 20 milliohms.
Insulation Resistance: In excess of 10,000 megohms.
Materials and Finishes: All parts utilize non-corrosive materials
as standard.
Terminals and Contacts: Brass with silver plate as standard.
Insulation: Polyester.
Index: Molded live spring detent.
Index Life: 10,000 cycles minimum.
Index Torque: Switches have lowest practical torque consistent
with crisp detenting and smooth, reliable operation.
Index Angles: Positive 30° standard.
Index Stops: Fixed standard, adjustable, or continuous available.
Stop Strength: 4.5 in. lbs. minimum.
Hardware: Mounting nut and lockwasher are shipped assembled.
STANDARD PART NUMBER
C5 - SOLDER LUG TERMINALS
C5 - P.C. TERMINALS
SWITCHES - 30° INDEX - ADJUSTABLE STOPS - SET @ 2 POS. - SEALED
ACTIVE
POLES/
POLES POSITIONS SECTION
01
02-12
02
02-06
03
02-04
04
02-03
C6 - UNSEALED
01
02-12
02
02-06
03
02-04
04
02-03
NO. OF
SECTIONS
NONSHORTING
FIG.
1
2
3
4
1
1
1
1
C5P0112N - A
C5P0206N - A
C5P0304N - A
C5P0403N - A
CE
CJ
CL
CM
1
2
3
4
1
1
1
1
C6P0112N - A
C6P0206N - A
C6P0304N - A
C6P0403N - A
CE
CJ
CL
CM
ACTIVE
POLES/
01
02-12
02
02-06
03
02-04
04
02-03
C6 - UNSEALED
01
02-12
02
02-06
03
02-04
04
02-03
NO. OF
SECTIONS
NONSHORTING
FIG.
1
2
3
4
1
1
1
1
C5P0112N - RA
C5P0206N - RA
C5P0304N - RA
C5P0403N - RA
CE
CJ
CL
CM
1
2
3
4
1
1
1
1
C6P0112N - RA CE
C6P0206N - RA CJ
C6P0304N - RA CL
C6P0403N - RA CM
* FIGURES ARE SHOWN ON PAGE 55.
DIMENSIONS
STANDARD CONSTRUCTION
• ELECTRONIC PRODUCTS
UNIT OF ELECTRO SWITCH CORP.
12
2010 Yonkers Road
Raleigh, NC 27604
Telephone: (888) ROTARYS or (919) 833-0707
Fax: (800) 909-9171 or (919) 833-8016
C5/C6 - SERIES
ADDITIONAL OPTIONS AND
How to Order Additional Options:
2 DIGIT
SERIES
INSULATION
TYPE
C5
P - POLYESTER
SEALED
C6
TOTAL
POLES
P - POLYESTER
UNSEALED
ACTIVE
POSITIONS
CONTACT
TYPE
01
02
03
04
12
06
04
03
- MAX
- MAX
- MAX
- MAX
N - NON SHORTING
01
02
03
04
12
06
04
03
N - NON SHORTING
TERMINAL
TYPE
INDEX
ANGLE
STOP
TYPE
L - SOLDER LUG
R - REAR P.C.
SHAFT/
BUSHING
SHAFT
FLAT
SEE
CHART
"A"
SEE
CHART
"B"
(SPECIFY) (SPECIFY)
(SPECIFY)
F - FIXED
A - ADJ.
C - CONT.
MAX
MAX
MAX
MAX
CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS
C
ADDITIONAL OPTIONS
N
P
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
SHAFT AND FLAT OPTIONS
TERMINAL TYPES
L
SHAFT AS VIEWED
WITH NON-TURN LUG
AT 9 O'CLOCK AND
SHAFT IN EXTREME
CCW POSITION .
14
15
R
1 1/2
SLOTTED
Y
PRINTED CIRCUIT BOARD TERMINAL PATTERNS
1-POLE
2-POLE
3-POLE
1
1
1
4-POLE
1
1
1
1
1
1
1
1 = 1ST POSITION
CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS.
2010 Yonkers Road
Raleigh, NC 27604
13
很抱歉,暂时无法提供与“C5P0403N-A..”相匹配的价格&库存,您可以联系我们找货
