08-Serie FM-A_07-Serie FM-A 05/11/14 14:59 Page30
FM series
Snap-in rocker switches - panel cut-out 19 x 13 (.750 x .508)
Distinctive features and specifications
UG1410A
❑ Illuminated and non-illuminated
❑ For class II appliances
❑ VDE and UL approved
❑ Protection against moisture by double-shell case
When the switch is submitted to moisture (drops,
condensation), the double-shell case conducts the liquid
outside, thus protecting the contact area and terminals.
The light dripping inside the equipment resulting from
this should be evacuated by adequate arrangement on
back of panel.
D
❑ Protection by boot
In case of sand or splashing water, the best protection consists of insulating the rocker from
these aggressive elements. This can be achieved with transparent PVC boot U5720. Order
separately, see section H.
AGENCY APPROVALS
EN 61058-1
Availability : functions 1 and 6
Marking : approved models are standard marked.
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
Packaging unit : 50 pieces.
The company reserves the right to change specifications without notice.
D-30
www.apem.com
APEM
08-Serie FM-A_07-Serie FM-A 05/11/14 14:59 Page31
FM series
Single pole - non-illuminated
• Approved ratings (functions 1 and 6 ) :
VDE : 10(4)A 250VAC T85°C - UL : 6A 250VAC & 125VAC T65°C
• Max. contact rating :
- functions 1 and 6 : see above.
- function 3 : 4A 250VAC
- functions 8 and 9 : 6A 250VAC
• Initial contact resistance : 20mΩ max.
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength : - functions 1 and 6 : 2.500 Vrms between terminals
- functions 3, 8 and 9 : 1.500 Vrms between terminals
• Electrical life at full load : 10 000 cycles
FM
C
• Panel cut-out :
Panel thickness
Dim. Y
Dim. Z
0,75 to 1,25 mm
19,2 +0/-0,1
12,9 +0,15/-0
1,25 to 2 mm
19,4 +0/-0,1
12,9 +0,15/-0
2 to 3 mm
19,8 +0/-0,1
12,9 +0,15/-0
A
Electrical functions
SERIES
• Operating temperature :
-20°C to +85°C
• Case, frame, rocker : PA6/6
• Contacts : silver
• Terminals : silver plated
1
3
6
8
9
ON
OFF
MOM OFF
ON
ON
ON OFF MOM
ON OFF ON
A
Silver
Terminals
Frame colour
2
Black
Others : on
request.
1
2
3
4
5
6
7
7/1
9
Blue
Black (std)
Green
Grey
Yellow
Red (std)
Ivory
White
Orange
Lamp
None
Lens colour
Marking *
No lens
D
000 None
001
I
004
I 0 II
005
ON
002
I
C Non illum.
Concave
Rocker colours
OFF
2 Solder lug
8 Quick-conn.
9 Straight PC
(funct. 1 & 6)
Rocker
Contacts
* Colour of marking : white for black rockers - black for other colours - Other : on request.
0.80
(.031)
ON
OFF
MOM OFF
ON
ON
ON OFF MOM
ON OFF ON
3
2
7.00
(.275)
1
12.80
(.504)
7.00
(.275)
18.80
(.740)
21.00
(.827)
Y
Z
15.00
(.591)
FMC1
FMC3
FMC6
FMC8
FMC9
2-3
8.00
(.315)
1-2
9.30
(.366)
12.50
(.492)
4.80
(.189)
1.50
(.059)
Single throw and double throw switch
Shown with quick-connect terminals
2.80x0.80
(.11x.031)
2
Solder lug
APEM
4.70x0.80
(.185x.031)
8
Quick-connect
1.20 x 0.80
(.047 x .031)
13.00
(.512)
7.00
(.275)
1.30
(.051)
3.10
(.122)
5.20
(.204)
TERMINALS
9
Straight PC (functions 1 and 6 only)
www.apem.com
D-31
08-Serie FM-A_07-Serie FM-A 05/11/14 14:59 Page32
FM series
Single pole - illuminated
• Lens : PC
• Contacts : silver
• Lamp terminal : no plating
• Fluorescent lamp for blue or green lens,
neon lamp for other colours
• Panel cut-out :
• Approved ratings :
• LED types available :
3,3V (4V max.) 10mA LED (resistor to be series connected by the user)
5V or 12V LED with integrated resistor
• Dielectric strength : 2.500 Vrms between terminals
• Operating temperature: - 20°C to + 85°C
• Case, frame and rocker : PA6/6
FM
L
1
Electr. function
SERIES
1
D
L
8
ON
OFF
Panel thickness
Dim. Y
Dim. Z
0,75 to 1,25 mm
19,2 +0/-0,1
12,9 +0,15/-0
1,25 to 2 mm
19,4 +0/-0,1
12,9 +0,15/-0
2 to 3 mm
19,8 +0/-0,1
12,9 +0,15/-0
A
Rocker colour
Contacts
A
Rocker
Terminals
Illumin.
concave
8 Quick-connect
Silver
Frame colour
2
Black
Others : on
request.
1
2
3
4
5
6
7
7/1
9
Blue
Black (std)
Green
Grey
Yellow
Red (std)
Ivory
White
Orange
Lens
colour
Lamp
Blue *
Green *
Yellow
Red
Translucent
Orange
1
3
5
6
8
9
* w. fluorescent
lamp
** Resistor value = supply voltage - LED forward voltage
LED forward current
220V neon
220V fluor.
110V neon
110V fluor.
000 None
LED 3,3V 10mA
LED 5V
A
B
C
D
E
F
G
H
J
K
L
Blue
Red/green
Green
Yellow
White
Red
Orange
No resistor**
001
N Green
P Yellow
Q Red
LED 12V
T Green
U Yellow
V Red
9.30
(.366)
12.50
(.492)
4.80
(.189)
1.50
(.059)
Illuminated switches - quick-connect terminals
Marking *
ON
OFF
0.80
(.031)
3
2
1
7.00
(.275)
7.00
(.275)
1
8.00
(.315)
FML1
2
3
12.80
(.504)
18.80
(.740)
21.00
(.827)
Y
For LED models, terminal 2 = cathode (-), terminal 3 = anode (+)
D-32
www.apem.com
Z
15.00
(.591)
AUTRES OPTIONS : voir Guide de Codification sur page ci-
APEM
很抱歉,暂时无法提供与“FMC32A2200000”相匹配的价格&库存,您可以联系我们找货
