629WC/630WC SERIES
Waterproof D-Sub Connectors: Power Combo, Right Angle
Features:
Signal, along with power contacts within one connector
Space saving on the PCB and I/O designs
Available in various pin out configurations
Pin and socket contact mating design with P.C. tail termination
Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating
retention
Mounting options include threaded hole with #4-40UNC or M3, with or without boardlocks
D-shaped connector mating outline provides polarization
IP Rating: IP67
Specifications:
Power Only
Insulator Material
PBT+30% GF, UL 94V-0, Color: Black
Contact Material
Copper Alloy
Contact Plating
Selective Gold (See Ordering Code) over Nickel
Shell Material and Plating
Steel with Ni or Tin Plating
Sealing compound
Epoxy
O-ring Material
Silicone
Current Rating (Power Contacts)
10 amps, 20 amps, 30 amps, 40 amps
Current Rating (Signal Contacts)
Combination
5 amps
Voltage Rating
125 V
Contact Resistance
(Power Contacts)
1 Milliohms maximum
Contact Resistance
(Signal Contacts)
10 Milliohms maximum
Insulation Resistance
5000 megaohms minimum
Dielectric Withstanding Voltage
1000 V AC rms at Sea Level
Operating Temperature
-25°C To +85°C
Mating Cycle
500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating
IP Rating
IP67
Ordering Code:
629W2W2-240-1N2
SERIES:
629: PLUG (PIN)
630: RECEPTACLE (SOCKET)
MOUNTING OPTIONS:
2 - #4-40 UNC THREADED RIVET
3 - #4-40 UNC THREADED RIVET WITH BRACKET & BOARDLOCKS
4 - #4-40 UNC THREADED RIVET WITH BRACKET
A - M3 THREADED RIVET
B - M3 THREADED RIVET WITH BRACKET & BOARDLOCKS
C - M3 THREADED RIVET WITH BRACKET
CONNECTOR TYPE:
W - WATERPROOF
LAYOUT:
POWER ONLY
COMBINATION
SIZE 9 CONTACT SHELL
2W2
2WK2
5W1
SIZE 15 CONTACT SHELL
3W3
3WK3
7W2
11W1
SIZE 25 CONTACT SHELL
5W5
9W4
13W3 17W2 21W1
8W8
2WK2
TOTAL NO.OF POWER CONTACT
TOTAL NO.OF CONTACT
MALE FEMALE COMBINATION
CONTACT PLATING THICKNESS:
2 - GOLD FLASH PLATING
1 - 5 MICROINCHES OF GOLD PLATING
3 - 15 MICROINCHES OF GOLD PLATING
6 - 30 MICROINCHES OF GOLD PLATING
TAIL TYPE:
40 - PC TAIL
www.edac.net
SHELL PLATING:
N - NICKEL
T - TIN
CURRENT RATING:
1 - 10A
2 - 20A
3 - 30A
4 - 40A
customerservice@edac.net
629WC/630WC SERIES
R/A PCB Power Contacts:
Mounting Options:
#4-40 UNC THREADED RIVIT
CODE: 2
M3 THREADED RIVIT
CODE: A
www.edac.net
WITH BRACKET
CODE: 3
CODE: 4
M3 THREADED RIVIT WITH
CODE: B
M3 THREADED RIVIT
WITH BRACKET
CODE: C
629WC/630WC SERIES
WATERPROOF POWER COMBO D-SUB
25.00
6.72
2W2/2WK2
5W1
33.30
13.70
2.54
5W5
47.05
47.05
ØD
Ø1
30.47
2.54
2.77
6.45
10.25
8.12
2.54
6.45
8.12
30
3.
10.25
33.24
Ø
30
3.
ØD
Ø
19.39
6.45
10.25
8.12
2.77
13W3
9W4
27.70
2.77
Ø1
.10
2.54
6.45
8.12
ØD
30
3.
5.54
4.16
Ø
30
3.
2.77
7.79
2.54
47.14
29.05
14.51
ØD
Ø
10.25
8.38
6.86
10.25
8.12
6.45
10.25
8.12
30
3.
D
6.74 7.79
30
3.
14.48
14.48
ØD
Ø
Ø
30
3.
.10
Ø1
Ø
16.62
Ø
47.05
47.05
SHELL SIZE 3(B)
5.54
33.30
19.39
2.77
D
7W2
3W3/3WK3
11W1
21W1
17W2
www.edac.net
Ø
.30
Ø3
8.12
10.25
10.25
6.45
ØD
Ø3
.30
SHELL SIZE 2(A)
2.77
10.25
6.85 6.85
6.45
33.30
Current Rating
D(mm)
10.25
8.30
ØD
6.45
8.12
10.25
30
3.
Ø3
.30
.10
Ø1
Ø
11.04
2.54
25.00
8.12
SHELL SIZE 1(E)
RIGHT ANGLE PCB SOLDER LAYOUT
10A
2.2
20A
3.3
30A
3.7
40A
4.2
很抱歉,暂时无法提供与“629W3W3-240-3NA”相匹配的价格&库存,您可以联系我们找货
