BC856-Q; BC857-Q; BC858-Q
65 V, 100 mA PNP general-purpose transistors
Rev. 2 — 21 February 2022
Product data sheet
1. General description
PNP general-purpose transistors in a small SOT23 (TO-236AB), Surface-Mounted Device (SMD)
plastic package.
Table 1. Product overview
Type number
Package
BC856-Q
NPN complement
Nexperia
JEDEC
SOT23
TO-236AB
BC846-Q
BC856A-Q
BC846A-Q
BC856B-Q
BC846B-Q
BC857-Q
BC847-Q
BC857A-Q
BC847A-Q
BC857B-Q
BC847B-Q
BC857C-Q
BC847C-Q
BC858B-Q
BC848B-Q
2. Features and benefits
Low current (max. 100 mA)
Low voltage (max. 65 V)
Qualified according to AEC-Q101 and recommended for use in automotive applications
3. Applications
General-purpose switching and amplification
Nexperia
4. Quick reference data
Table 2. Quick reference data
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
BC856-Q; BC856A-Q;
BC856B-Q
-65
V
BC857-Q; BC857A-Q;
BC857B-Q; BC857C-Q
-45
V
BC858B-Q
-30
V
IC
collector current
-100
mA
ICM
peak collector current
-200
mA
hFE
DC current gain
BC856-Q
125
475
BC857-Q
125
800
125
250
220
475
420
800
BC856A-Q; BC857A-Q
VCE = 5 V; IC = 2 mA
BC856B-Q; BC857B-Q;
BC858B-Q
BC857C-Q
5. Pinning information
Table 3. Pinning information
Pin
Symbol
Descrition
1
B
base
2
E
emitter
3
C
collector
Simlified outline
Graphic symbol
3
C
B
E
1
sym132
2
6. Ordering information
Table 4. Ordering information
Type number
Package
BC856-Q
Name
Description
Version
TO-236AB
plastic surface-mounted package; 3 leads
SOT23
BC856A-Q
BC856B-Q
BC857-Q
BC857A-Q
BC857B-Q
BC857C-Q
BC858B-Q
BC856-Q_BC857-Q_BC858-Q
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2022. All rights reserved
2 / 13
Nexperia
7. Marking
Table 5. Marking codes
Type number
Marking code
BC856-Q
[1]
3D%
BC856A-Q
[1]
3A%
BC856B-Q
[1]
3B%
BC857-Q
[1]
3H%
BC857A-Q
[1]
3E%
BC857B-Q
[1]
3F%
BC857C-Q
[1]
3G%
BC858B-Q
[1]
3K%
[1]
% = placeholder for manufacturing site code
8. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
VCBO
collector-base voltage
open emitter
VCEO
Min
Max
Unit
BC856-Q; BC856A-Q;
BC856B-Q
-80
V
BC857-Q; BC857A-Q;
BC857B-Q; BC857C-Q
-50
V
BC858B-Q
-30
V
BC856-Q; BC856A-Q;
BC856B-Q
-65
V
BC857-Q; BC857A-Q;
BC857B-Q; BC857C-Q
-45
V
BC858B-Q
-30
V
open base
VEBO
emitter-base voltage
-5
V
IC
collector current
-100
mA
ICM
-200
mA
IBM
peak base current
-200
mA
Ptot
total power dissipation
[1] -
250
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-65
150
°C
Tstg
storage temperature
-65
150
°C
[1]
open collector
Tamb ≤ 25 °C
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided, 35 μm copper, tin-plated and standard footprint.
Product data sheet
3 / 13
Nexperia
9. Thermal characteristics
Table 7. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
in free air
[1]
thermal resistance from
junction to ambient
Min
[1] -
Typ
Max
Unit
500
K/W
Device mounted on an FR4 PCB; single-sided, 35 µm copper; tin-plated and standard footprint.
aaa-028968
103
duty cycle =
1
Zth(j-a)
(K/W)
0.5
102
0.75
0.33
0.2
0.1
0.05
10
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, single-sided, 35 μm copper, tin-plated and standard footprint
Fig. 1.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
Product data sheet
4 / 13
Nexperia
10. Characteristics
Table 8. Characteristics
Symbol
Parameter
Conditions
V(BR)CBO
collector-base breakdown voltage
BC856-Q; BC856A-Q;
BC856B-Q
BC857-Q; BC857A-Q;
BC857B-Q; BC857C-Q
IC = -100 µA; IE = 0 A
BC858B-Q
V(BR)CEO
Min
Typ
Max
Unit
-80
V
-50
V
-30
V
-65
V
-45
V
-30
V
collector-emitter breakdown voltage
BC856-Q; BC856A-Q;
BC856B-Q
BC857-Q; BC857A-Q;
BC857B-Q; BC857C-Q
IC = -2 mA; IB = 0 A
BC858B-Q
V(BR)EBO
emitter-base
breakdown voltage
IC = 0 A; IE = -100 µA
-5
V
ICBO
collector-base
cut-off current
VCB = -30 V; IE = 0 A
-1
-15
nA
VCB = -30 V; IE = 0 A; Tj = 150 °C
-4
µA
IEBO
emitter-base
cut-off current
VEB = -5 V; IC = 0 A
-100
nA
hFE
DC current gain
BC856-Q
125
475
BC857-Q
125
800
125
250
220
475
BC856A-Q; BC857A-Q
BC856B-Q; BC857B-Q;
BC858B-Q
VCE = -5 V; IC = -2 mA
BC857C-Q
VCEsat
VBEsat
VBE
420
800
IC = -10 mA; IB = -0.5 mA
-75
-300
mV
IC = -100 mA; IB = -5 mA
[1] -
-250
-650
mV
base-emitter saturation IC = -10 mA; IB = -0.5 mA
voltage
[1] -
-700
mV
[1] -
-850
mV
collector-emitter
saturation voltage
base-emitter voltage
-600
-650
-750
mV
VCE = -5 V; IC = -10 mA
-820
mV
Cc
collector capacitance
VCB = -10 V; IE = ie = 0 A; f = 1 MHz
4.5
pF
fT
transition frequency
VCE = -5 V; IC = -10 mA; f = 100 MHz
100
MHz
NF
noise figure
IC = -200 µA; VCE = -5 V; RS = 2 kΩ;
f = 1 kHz; B = 200Hz
2
10
dB
[1]
pulsed; tp ≤ 300 μs; δ ≤ 0.02
Product data sheet
5 / 13
Nexperia
aaa-028117
400
hFE
(1)
mgt712
- 1200
VBE
(mV)
- 1000
300
(1)
- 800
(2)
200
100
(2)
- 600
(3)
- 400
(3)
- 200
-1
-10
-102
IC (mA)
-103
VCE = -5 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 2.
- 10- 1
-1
VCE = -5 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
BC856A-Q; BC857A-Q: DC current gain as a
function of collector current; typical values
mgt713
- 104
VCEsat
(mV)
- 103
Fig. 3.
BC856A-Q; BC857A-Q: Base-emitter voltage as
a function of collector current; typical values
mgt714
- 1200
VBEsat
(mV)
- 1000
(1)
(2)
- 800
(3)
- 600
- 102
- 400
(1)
- 200
(3) (2)
- 10
- 10- 1
-1
- 10
- 102
IC (mA)
- 103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 4.
Product data sheet
-1
- 10
- 102
IC (mA)
- 103
IC/IB = 20
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
BC856A-Q; BC857A-Q: Collector-emitter
saturation voltage as a function of collector
- 102
- 103
IC (mA)
- 10
Fig. 5.
BC856A-Q; BC857A-Q: Base-emitter saturation
voltage as a function of collector current;
typical values
6 / 13
Nexperia
aaa-028118
600
(1)
hFE
400
mgt716
- 1200
VBE
(mV)
- 1000
(1)
- 800
(2)
(2)
- 600
200
(3)
- 400
(3)
- 200
-1
-10
-102
IC (mA)
-103
VCE = -5 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 6.
- 10- 1
-1
- 102
- 103
IC (mA)
- 10
VCE = -5 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
BC856B-Q; BC857B-Q; BC858B-Q: DC current
gain as a function of collector current; typical
values
mgt717
- 104
VCEsat
(mV)
- 103
Fig. 7.
BC856B-Q; BC857B-Q; BC858B-Q: Base-emitter
typical values
mgt718
- 1200
VBEsat
(mV)
- 1000
- 800
(1)
(2)
- 600
(3)
- 102
- 400
(1)
- 200
(3) (2)
- 10
- 10- 1
-1
- 10
- 102
IC (mA)
- 103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 8.
Product data sheet
- 10
- 102
IC (mA)
- 103
IC/IB = 20
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
BC856B-Q; BC857B-Q; BC858B-Q: Collectoremitter saturation voltage as a function of
-1
Fig. 9.
7 / 13
Nexperia
aaa-028119
1000
hFE
(1)
800
mgt720
- 1200
VBE
(mV)
- 1000
(1)
- 800
600
(2)
(2)
- 600
400
200
(3)
- 400
(3)
- 200
-1
-10
-102
IC (mA)
-103
VCE = -5 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
-1
- 10
- 102
- 103
IC (mA)
VCE = -5 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Fig. 10. BC857C-Q: DC current gain as a function of
mgt721
- 104
VCEsat
(mV)
- 103
Fig. 11. BC857C-Q: Base-emitter voltage as a function
mgt722
- 1200
VBEsat
(mV)
- 1000
- 800
(1)
(2)
- 600
(3)
- 102
- 400
(1)
- 200
(3) (2)
- 10
- 10- 1
-1
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
- 10
- 102
IC (mA)
- 103
-1
- 10
- 102
IC (mA)
- 103
IC/IB = 20
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Fig. 12. BC857C-Q: Collector-emitter saturation voltage Fig. 13. BC857C-Q: Base-emitter saturation voltage as a
as a function of collector current; typical values
Product data sheet
8 / 13
Nexperia
11. Test information
11.1. Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
12. Package outline
Table 9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
0.15
0.09
18-03-12
Fig. 14. Package outline SOT23 (TO-236AB)
Product data sheet
9 / 13
Nexperia
13. Soldering
Table 10. Soldering
3.3
2.9
1.9
solder lands
3
solder resist
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig. 15. Reflow soldering footprint SOT23 (TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig. 16. Wave soldering footprint SOT23 (TO-236AB)
Product data sheet
10 / 13
Nexperia
14. Revision history
Table 11. Revision history
Document ID
Release date
BC856-Q_BC857-Q_BC858-Q v.2 20220221
Modifications:
Product data sheet
Change
notice
Supersedes
Product data sheet
BC856-Q_BC857-Q_BC858-Q v.1
Quick reference data: BC856-Q corrected to BC856B-Q at hFE
Limiting values and Characteristics: Product names changed to detailed
descriptions
BC856-Q_BC857-Q_BC858-Q v.1 20210624
Data sheet status
Product data sheet
11 / 13
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
Product data sheet
12 / 13
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................2
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 3
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 5
11. Test information.......................................................... 9
11.1. Quality information..................................................... 9
12. Package outline.......................................................... 9
13. Soldering................................................................... 10
14. Revision history........................................................11
15. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 21 February 2022
Product data sheet
13 / 13
