HEF4015B
Dual 4-bit static shift register
Rev. 8 — 21 November 2011
Product data sheet
1. General description
The HEF4015B is a dual edge-triggered 4-bit static shift register (serial-to-parallel
converter). Each shift register has a serial data input (D), a clock input (CP), four fully
buffered parallel outputs (Q0 to Q3) and an overriding asynchronous master reset input
(MR). Information present on D is shifted to the first register position, and all the data in
the register is shifted one position to the right on the LOW-to-HIGH transition of CP. A
HIGH on MR clears the register and forces Q0 to Q3 to LOW, independent of CP and D.
The clock input’s Schmitt trigger action makes the input highly tolerant of slower clock rise
and fall times.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Tolerant of slow clock rise and fall times
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C.
Complies with JEDEC standard JESD 13-B
3. Applications
Serial-to-parallel converter
Buffer stores
General purpose register
4. Ordering information
Table 1.
All types operate from 40 C to +85 C.
Type number
Package
Name
Description
Version
HEF4015BP
DIP16
plastic dual in-line package; 16 leads (300 mil)
SOT38-4
HEF4015BT
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4015B
NXP Semiconductors
5. Functional diagram
1Q0 5
7 1D
9 1CP
SHIFT
REGISTER
4 BITS
1Q1 4
1Q2 3
1Q3 10
6 1MR
2Q0 13
15 2D
1 2CP
SHIFT
REGISTER
4 BITS
2Q1 12
2Q2 11
2Q3 2
14 2MR
001aae560
Fig 1.
Functional diagram
Q1
Q0
D
D
Q
FF 1
CP
CD
D
Q
FF 2
CP
CD
Q2
D
Q
FF 3
CP
CD
Q3
D
Q
FF 4
CP
CD
CP
MR
001aae562
Fig 2.
Logic diagram for one register
HEF4015B
Product data sheet
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2011. All rights reserved.
2 of 15
HEF4015B
NXP Semiconductors
6. Pinning information
6.1 Pinning
HEF4015B
2CP
1
16 VDD
2Q3
2
15 2D
1Q2
3
14 2MR
1Q1
4
13 2Q0
1Q0
5
12 2Q1
1MR
6
11 2Q2
1D
7
10 1Q3
VSS
8
9
1CP
001aae561
Fig 3.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Q0 to 1Q3
5, 4, 3, 10
parallel output
2Q0 to 2Q3;
13, 12, 11, 2
parallel output
1MR, 2MR
6, 14
master reset input (active HIGH)
1D, 2D
7, 15
serial data input
VSS
8
ground supply voltage
1CP, 2CP
9, 1
clock input (LOW-to-HIGH edge-triggered)
VDD
16
supply voltage
7. Functional description
Table 3.
Function table [1]
number of clock
pulse transitions
Input
1
D1
L
D1
X
X
X
2
D2
L
D2
D1
X
X
3
D3
L
D3
D2
D1
X
4
D4
L
D4
D3
D2
D1
[1]
CP
Output
D
MR
Q0
Q1
Q2
Q3
X
L
no change
no change
no change
no change
X
X
H
L
L
L
L
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Dn = either HIGH or LOW;
= positive-going transition; = negative-going transition.
HEF4015B
Product data sheet
3 of 15
HEF4015B
NXP Semiconductors
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
Conditions
Max
Unit
0.5
+18
V
10
mA
0.5
VDD + 0.5
V
10
mA
input/output current
10
mA
IDD
supply current
50
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
Ptot
total power dissipation
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
P
VI < 0.5 V or VI > VDD + 0.5 V
Min
VO < 0.5 V or VO > VDD + 0.5 V
Tamb = 40 C to +85 C
power dissipation
DIP16 package
[1]
750
mW
SO16 package
[2]
500
mW
100
mW
per output
[1]
For DIP16 package: Ptot derates linearly with 12 mW/K above 70 C.
[2]
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
HEF4015B
Product data sheet
Conditions
4 of 15
HEF4015B
NXP Semiconductors
10. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
HIGH-level output current
LOW-level output current
II
input leakage current
IDD
supply current
CI
input capacitance
HEF4015B
Product data sheet
Conditions
VDD
IO < 1 A
Tamb = 40 C
Tamb = 25 C
Tamb = 85 C
Min
Max
Min
Max
Min
Max
Unit
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
V
VO = 2.5 V
5V
1.7
1.4
1.1
mA
VO = 4.6 V
5V
0.52
0.44
0.36 mA
VO = 9.5 V
10 V
1.3
1.1
0.9
mA
VO = 13.5 V
15 V
3.6
3.0
2.4
mA
IO < 1 A
IO < 1 A
IO < 1 A
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
0.3
0.3
1.0
A
5V
A
10 V
40
40
300
A
15 V
80
80
600
A
7.5
pF
IO = 0 A
5 of 15
HEF4015B
NXP Semiconductors
11. Dynamic characteristics
Table 7.
VSS = 0 V; CL = 50 pF; Tamb = 25 C.
Symbol
Parameter
Conditions
tPHL
HIGH to LOW
propagation delay
nCP to Qn;
see Figure 4
nMR to Qn;
see Figure 6
LOW to HIGH
propagation delay
tPLH
transition time
tt
set-up time
tsu
hold time
th
pulse width
tW
recovery time
trec
maximum frequency
fmax
[1]
Extrapolation formula[1] Min
Typ
Max
Unit
5V
103 ns + (0.55 ns/pF)CL
130
260
ns
10 V
44 ns + (0.23 ns/pF)CL
55
110
ns
15 V
32 ns + (0.16 ns/pF)CL
40
80
ns
5V
78 ns + (0.55 ns/pF)CL
105
210
ns
10 V
34 ns + (0.23 ns/pF)CL
45
90
ns
15 V
27 ns + (0.16 ns/pF)CL
35
70
ns
5V
93 ns + (0.55 ns/pF)CL
120
240
ns
10 V
55
110
ns
15 V
40
80
ns
VDD
nCP to Qn
see Figure 4
see Figure 4
nD to nCP;
see Figure 5
nD to nCP;
see Figure 5
5V
10 ns + (1.00 ns/pF)CL
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
5V
+25
15
ns
10 V
+25
10
ns
15 V
+20
5
ns
5V
40
ns
10 V
ns
15 V
15
8
ns
nCP LOW;
minimum width;
see Figure 5
5V
60
30
ns
10 V
30
15
ns
15 V
ns
nMR HIGH;
minimum width;
see Figure 6
5V
80
40
ns
10 V
30
15
ns
15 V
24
12
ns
5V
50
ns
10 V
30
10
ns
15 V
ns
5V
7
15
MHz
10 V
15
30
MHz
15 V
22
44
MHz
pin nMR;
see Figure 6
see Figure 5
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
HEF4015B
Product data sheet
6 of 15
HEF4015B
NXP Semiconductors
Table 8.
Dynamic power dissipation PD
PD can be calculated from the formulas shown. VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol
PD
Parameter
dynamic power
dissipation
VDD
Typical formula for PD (W)
where:
5V
PD = 1500 fi + (fo CL) VDD
10 V
PD = 6300 fi + (fo CL) VDD2
fo = output frequency in MHz;
15 V
PD = 17000 fi + (fo CL)
CL = output load capacitance in pF;
2
fi = input frequency in MHz;
VDD2
VDD = supply voltage in V;
(CL fo) = sum of the outputs.
12. Waveforms
VI
VM
nCP input
VSS
tPHL
VOH
tPLH
90 %
VM
10 %
nQn output
VOL
tt
tt
001aaj464
Measurement points are given in Table 9.
Fig 4.
Waveforms showing nCP propagation delays and nQn transition times
tW
VI
nCP input
VM
VM
VM
VSS
1/fmax
th
th
VI
nD input
VM
VM
VM
VM
VSS
tsu
tsu
001aae563
The shaded area indicates where the input is permitted to change for predictable output performance.
Set-up and hold times are shown as positive values but may be specified as negative values;
Fig 5.
Waveforms showing set-up times, hold times, and minimum clock pulse width
HEF4015B
Product data sheet
7 of 15
HEF4015B
NXP Semiconductors
VI
VM
nMR input
VM
VSS
tW
trec
VI
nCP input
VM
VSS
tPHL
VOH
nQn output
VM
VOL
001aae564
Fig 6.
Waveforms showing MR recovery time, propagation delay and minimum pulse width
Table 9.
Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
HEF4015B
Product data sheet
8 of 15
HEF4015B
NXP Semiconductors
tW
VI
90 %
90 %
negative
pulse
VM
VM
10 %
0V
VI
10 %
tf
tr
tr
tf
90 %
positive
pulse
90 %
VM
VM
10 %
0V
10 %
tW
001aaj781
a. Input waveforms
VDD
VI
VO
G
DUT
CL
RT
001aag182
b. Test circuit
Test data is given in Table 10.
Definitions for test circuit:
DUT = Device Under Test;
CL = load capacitance including jig and probe capacitance;
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
Fig 7.
Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Input
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
20 ns
50 pF
HEF4015B
Product data sheet
Load
9 of 15
HEF4015B
NXP Semiconductors
13. Package outline
DIP16: plastic dual in-line package; 16 leads (300 mil)
SOT38-4
ME
seating plane
D
A2
A
A1
L
c
e
Z
w M
b1
(e 1)
b
b2
MH
9
16
pin 1 index
E
1
8
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
min.
A2
max.
b
b1
b2
c
D (1)
E (1)
e
e1
L
ME
MH
w
Z (1)
max.
mm
4.2
0.51
3.2
1.73
1.30
0.53
0.38
1.25
0.85
0.36
0.23
19.50
18.55
6.48
6.20
2.54
7.62
3.60
3.05
8.25
7.80
10.0
8.3
0.254
0.76
inches
0.17
0.02
0.13
0.068
0.051
0.021
0.015
0.049
0.033
0.014
0.009
0.77
0.73
0.26
0.24
0.1
0.3
0.14
0.12
0.32
0.31
0.39
0.33
0.01
0.03
Note
1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
ISSUE DATE
95-01-14
03-02-13
SOT38-4
Fig 8.
EUROPEAN
PROJECTION
Package outline SOT38-4 (DIP16)
HEF4015B
Product data sheet
10 of 15
HEF4015B
NXP Semiconductors
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
HEF4015B
Product data sheet
11 of 15
HEF4015B
NXP Semiconductors
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
HEF4015B v.8
20111121
Product data sheet
HEF4015B v.7
Modifications:
Legal pages updated.
Changes in “General description” and “Features and benefits”.
HEF4015B v.7
20110914
Product data sheet
HEF4015B v.6
HEF4015B v.6
20091103
Product data sheet
HEF4015B v.5
HEF4015B v.5
20090624
Product data sheet
HEF4015B v.4
HEF4015B v.4
20090127
Product data sheet
HEF4015B_CNV v.3
HEF4015B_CNV v.3
19950101
Product specification
HEF4015B_CNV v.2
HEF4015B_CNV v.2
19950101
HEF4015B
Product data sheet
12 of 15
HEF4015B
NXP Semiconductors
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
HEF4015B
Product data sheet
13 of 15
HEF4015B
NXP Semiconductors
Non-automotive qualified products — Unless this data sheet expressly
states that this specific NXP Semiconductors product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. NXP
non-automotive qualified products in automotive equipment or applications.
NXP Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies NXP Semiconductors for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond NXP Semiconductors’
standard warranty and NXP Semiconductors’ product specifications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without NXP Semiconductors’ warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
HEF4015B
Product data sheet
14 of 15
HEF4015B
NXP Semiconductors
17. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2011.
Date of release: 21 November 2011
Document identifier: HEF4015B
