Sealed Subminiature Switches Series 83 180 DIN 41 635 B
Types
General specifications
Layout
Components
Part numbers for standard products with
connection of type
Material
- Case : UL 94VO glass-filled polyester
- Button : Polyester
- Membrane : silicon
- Contacts : AgCdO
AgNi (dual current),
- Terminals : tinned brass
- Cable : PVC (IP 67)
- Leads : PVC
1
2
FD0
Features
Electrical characteristics
Current rating at 250 V
Nominal
Hp
Mechanical characteristics
Operating force - max.
Release force - min.
Total travel force - max.
Permitted overtravel force - max.
Rest position - max.
Tripping point
Differential travel
Overtravel - min.
Ambient operating
for tag version
temperature
for lead / cable version
Mechanical durability
Contact gap
Weight (tag version)
Actuators
- flat : stainless steel
- roller : stainless steel with polyamide roller
Approvals 83 180/83 186 : NF. UL - cUL on request
Operating curve 250 Va
Operations
Resistive circuit
A
1/ 2
N (oz.)
N (oz.)
N (oz.)
N (oz.)
mm (in.)
mm (in.)
mm (in.)
mm (in.)
°C (°F)
°C (°F)
Operations
mm (in.)
g (oz.)
Contact Type
C (Form C) SPDT
B (Form B) SPNC not available in PC terminals
A (Form A) SPNO not available in PC terminals
Connections
A
2
1
3
4
Actuators and mounting positions
Part numbers for standard actuators
Actuators - Length
Switch rating with DC supply
12 V
24 V
Resistive load
Inductive
L/R 5 ms
Resistive load
Inductive
L/R 5 ms
83 180
10 A
83 181
6A
83 183
3A
83 186
6A
10 A
6A
3A
6A
10 A
6A
3A
6A
5A
5A
3A
5A
mm (in.)
Mounting position
Coefficient
Tripping point
83 180
83 181/183/186
mm (in.)
Model 83 181 is designed to operate equally well on dual-current
(1 mA 4 V minimum) or medium-current (6 A maximum) circuits.
However, a given product should only be used to switch one type of
circuit during its working life.
Actuators - Length
Degree of protection
- Tag version :
Mounting positions
Coefficient
Tripping point
Except where otherwise indicated, actuators are supplied unmounted.
For factory mounting, specify fixing position L or R.
- To calculate force : take the force quoted for the switch and divide by
the coefficient given in the table.
- To calculate travel : take the travel quoted for the switch and multiply
by the same coefficient.
- Lead / cable version :
casing
terminals
outlet / casing
= IP67
= IP00
= IP67
mm (in.)
Mounting accessories for PCB mounting : 5 / 6 / 7 / 8
See page 3/9.
Other information
For other forces, actuators, connections and temperatures,
please consult us.
3/10
Normally stocked items
Catalog products produced
to order
1
83180
831800C1.0
831800C2.0
831800CFD0.0
83181
831810C1.0
831810C2.0
831810CFD0.0
83183
831830C1.0
831830C2.0
831830CFD0.0
83186
831860C1.0
831860C2.0
831860CFD0.0
High current
Dual current
Medium current
Standard
10
12.5
6
7.5
3
4
6
7.5
3.4 (12)
1 (3.5)
5 (17.6)
10 (35.3)
9.3 (.37)
8.4 ±0.3 (.33 ±0.012)
0.10 (.004)
0.6 (.024)
-40 +125 (-40 +257)
-40 +105 (-40 +221)
106
0.4 (.016)
2 (.07)
2.5 (8.8)
0.8 (2.8)
4.2 (14.1)
10 (35.3)
9.3 (.37)
0.10 (.004)
0.6 (.024)
-40 +125 (-40 +257)
-40 +105 (-40 +221)
2 x 106
0.4 (.016)
2 (.07)
2.5 (8.8)
0.8 (2.8)
4.2 (14.1)
10 (35.3)
9.3 (.37)
0.10 (.004)
0.6 (.024)
-40 +125 (-40 +257)
-40 +105 (-40 +221)
2 x 106
0.4 (.016)
2 (.07)
2.5 (8.8)
0.8 (2.8)
4.2 (14.1)
10 (35.3)
9.3 (.37)
0.10 (.004)
0.6 (.024)
-40 +125 (-40 +257)
-40 +105 (-40 +221)
2 x 106
0.4 (.016)
2 (.07)
C
B
A
C
B
A
C
B
A
C
B
A
2
3
3
5
6
7
8
FD0
FB0
FG0
CD0**
CB0**
CG0**
4
A 79 253 327
Flat 170A R18.3 (.72)
B 79 253 326
Flat 170A R24 (.94)
C 79 253 328
Flat 170A R41 (1.61)
L
R
3
1.5
10.4 ±1.2 (.41±.05) 9.2 ±0.6 (.36±.24)
L
4
11.1±1.2 (.44±.05)
L
7
13.2 ±2.5 (.52 ±.1)
F 79 253 329
Dummy roller 170F R19.5 (.77)
D *
Screw 170D
L
3
13±1.2 (.51±.05)
R
2
9.6±0.6 (.38±.024)
R
3.5
10.7 ±1.2 (.42±.05)
L
R
3
1.5
15.4 ±1.2 (.61±.05) 14.5±0.6 (.57±.24)
L *
Transverse roller 170EL *
Ø No
Actuator
R
1.5
12±0.6 (.47 ±.24)
** Special order, contact us for part number
** Cable version for types 83 181, 83 183 and 83 186
1
E 79 218 454
Roller 170E R20 (.79)
Switch Type
831810
831830
831860
831800
2
Contact Type
A
B
C
To order actuators separately, use the 8 digit P/N
5
To order please specify :
3
Example : 831810 C 2 • Ø
Connection
Actuators
1
6
Ø
2
7
A
3
8
B
4
FDØ
CDØ
C
5
FGØ
CBØ
D
FBØ
CGØ
E
4
F
L
5
Actuator Position
L - Left (Standard)
R - Right
Example P/N is 831810 SPDT solder terminals with no actuator.
Sealed Subminiature Switches DIN 41635 B
Dimensions
Asymmetric
OL
Symmetric
Fixed by 2 x M2 screws
Torque for
screw alone: 0.2 Nm (1.75 in. lbs.)
screw + washer: 0.3 Nm (2.65 in. lbs.)
Connections
Terminals
2
Solder
1
Faston 2.8 x 0.5
.110˝ Quick Connects
Printed circuit board mounting
Asymmetric
Symmetric
3, 5, 7
4, 6, 8
3-4
Straight PCB output
5-6
Side output,
PCB rear
7-8
Side output,
PCB front
Mounting on a printed circuit board with mounting pins
Asymmetric
Symmetric
(.11±.004)
Lead output
Cable output
CG0 cable
output on left
CD0 cable
output on right
CB0 cable
output on bottom
Conductor cross-section :
83181 / 83183 / 83186 = 3 x 0.5 mm2
(.12 x .02 in2)
Common = black
NC
= brown
NO
= blue
mm (in.)
Actuators
Mounting positions
3
A, B, C
Flat
E
Roller
mm (in.)
Recommendations for operation from the side
F
Dummy roller
很抱歉,暂时无法提供与“831860CFG0.EL”相匹配的价格&库存,您可以联系我们找货
