Solenoid Locking Safety Switches
HS6E
Key features:
• Compact body: 75 × 15 × 75mm
15mm wide, thinnest solenoid interlock switch in the world
• Reversible mounting and angled cable allow four actuator insertion directions
• Energy saving: 24V DC, 110mA (solenoid: 100mA, LED: 10mA)
• Manual unlocking possible on three sides
• LED indicator shows solenoid operation
• 500N locking retention force
Interlock Switches
XW Series E-Stops
Overview
HS6E Subminiature Interlock Switches with Solenoid
Part Numbers
Mechanical Spring Lock (power solenoid to unlock)
Cable
Length
Contact Configuration
Enabling Switches
Safety Control Relays
Part Number
(Actuator inserted) (Solenoid OFF)
Cable
Length
Part Number
(Actuator inserted) (Solenoid ON)
A2
A1
A2
A1
1m
3m
5m
HS6E-L44B01-G
HS6E-L44B03-G
HS6E-L44B05-G
42
52
1m
3m
5m
HS6E-M44B01-G
HS6E-M44B03-G
HS6E-M44B05-G
41
53
42
54
1m
3m
5m
HS6E-N44B01-G
HS6E-N44B03-G
HS6E-N44B05-G
41
51
42
52
1m
3m
5m
HS6E-P44B01-G
HS6E-P44B03-G
HS6E-P44B05-G
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12
22
32
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12
22
32
41
51
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12
22
34
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12
22
34
41
53
42
54
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
Main Circuit:
Monitor
Circuit:
Main
Circuit:
MonitorCircuit:
Circuit:
Monitor
Monitor Circuit:
11
21
11
33
21
31
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12
22
32
41
53
42
54
1m
3m
5m
HS6E-M7Y4B01-G
HS6E-M7Y4B03-G
HS6E-M7Y4B05-G
12
41
22 4153
12
34 51
22
32
42
4254
52
1m
3m
5m
HS6E-N7Y4B01-G
HS6E-N7Y4B03-G
HS6E-N7Y4B05-G
42
52
1m
3m
5m
HS6E-P7Y4B01-G
HS6E-P7Y4B03-G
HS6E-P7Y4B05-G
12
22
34
41
51
12
22
34
41
53
42
54
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12
22
34
41
51
42
52
www.IDEC.com
HS6E-L7Y4B01-G
HS6E-L7Y4B03-G
HS6E-L7Y4B05-G
42
52
11
21
33
290
1m
3m
5m
41
51
12
22
32
1. Contact configuration shows the contact status when actuator is inserted and solenoid off for spring lock.
2. Contact configuration shows the contact status when actuator is inserted and solenoid on for solenoid lock.
3. Indicator LED color is green.
4. Actuator keys are not supplied with the interlock switch and must be ordered separately.
Main Circuit:
5. Standard stock items in bold.
Monitor Circuit:
Monitor Circuit:
AS-Interface Safety at Work
Light Curtains
Solenoid Lock (remove power to solenoid to unlock)
HS6E
Actuator Keys
Item
Ordering Part Number
Remarks
HS9Z-A61
The retention force of HS9Z-A61 actuator is 500N maximum.
Do not apply excessive load.
Right-angle Actuator
HS9Z-A62
The retention force of HS9Z-A62 actuator is 100N maximum.
When retention force of 100N or more is required, use the HS9Z-A62S actuator.
with Mounting Plate
HS9Z-A62S
The retention force of HS9Z-A62S actuator is 500N maximum.
Horizontal/Vertical
Angle Adjustable
Actuator
HS9Z-A65
Horizontal/Vertical
Angle Adjustable
Actuator
HS9Z-A66
XW Series E-Stops
Straight Actuator
Overview
Appearance
Interlock Switches
The HS9Z-A65 and HS9Z-A66 have their metal actuator installed in opposite directions.
Select actuator by determining the required moving direction in consideration of the door
and interlock switch.
See page 294 for more information.
The retention force of HS9Z-A65 and HS9Z-A66 500N maximum.
Accessory
Part Number
HS9Z-T3
Enabling Switches
Description
Manual Unlock Key (long type)
Specifications
–25 to +50°C (no freezing)
Storage Temperature
–40 to +80°C (no freezing)
Operating Humidity
45 to 85% (no condensation)
Rated Insulation Voltage (Ui)
300V (between LED and ground: 60V)
Impulse Withstand Voltage (Uimp)
Main & lock monitor circuits: 1.5 KV
Door monitor circuit: 2.5 kV
Between solenoid/LED and ground: 0.5 kV
Insulation Resistance
(500V DC megger)
Between live and dead metal parts: 100 MΩ minimum
Between terminals of different poles: 100 MΩ minimum.
Contact Resistance
300 mΩ maximum (initial value, 1m cable)
500 mΩ maximum (initial value, 3m cable)
700 mΩ maximum (initial value, 5m cable)
Electric Shock Protection Class
Class II (IEC 61140)
Pollution Degree
3
Degree of Protection
IP67 (IEC 60529)
10 to 55 Hz, amplitude 0.35mm
Damage Limits
30 Hz, amplitude 1.5 mm
Shock
Resistance
Operating Extremes
100 m/s2 (10G)
Damage Limits
1000 m/s2 (100G)
Actuator Operating Speed
0.05 to 1.0 m/s
Direct Opening Travel
8.0 mm minimum
800-262-IDEC (4332) • USA & Canada
Vibration
Resistance
Operating Extremes
Light Curtains
Operating Temperature
Conforming to Standards
UL 508 (UL listed), CSA C22.2, No. 14 (c-UL listed), ISO
14119
IEC 60947-5-1, EN 60947-5-1 (TÜV approval), EN 1088 (TÜV
approval), GS-ET-19
IEC 60204-1/EN 60204-1 (applicable standards for use)
291
Interlock Switches
XW Series E-Stops
Overview
HS6E
Direct Opening Force
60N minimum
Actuator Retention Force
500N maximum (GS-ET-19)
Operating Frequency
900 operations/hour
Mechanical Life
1,000,000 operations minimum (GS-ET-19)
Electrical Life
100,000 operations minimum (rated load)
1,000,000 operations minimum (24V AC/DC, 100 mA)
(operating frequency 900 operations/hr)
Conditional Short-circuit Current
50A (250V) (Use 250V/10A fast-blow fuse for short-circuit
protection.)
Cable
22 AWG (12-core: 0.3 mm2 or equivalent/core)
Cable Diameter
ø7.6 mm
Weight
Approx. 200g
1. UL, c-UL rating: Main/Lock monitor circuit: 125V AC, 1A Pilot duty, 125V DC, 0.22A Pilot duty
Door monitor circuit:240V AC, 0.75A Pilot duty250V DC, 0.27A Pilot duty
2. TÜV rating: Main/Lock monitor circuit: AC-15 125V/1A, DC-13 125V/0.22A
Door monitor circuit: AC-15 240V/0.75A, DC-13 250V/0.27A
Solenoid/Indicator
Locking Mechanism
Spring Lock Type or Solenoid Lock Type
Rated Voltage
24V DC
Current
Enabling Switches
Solenoid
Indicator
110 mA (solenoid 100 mA, LED 10 mA)
Coil Resistance
240Ω (at 20°C)
Pickup Voltage
Rated voltage × 85% maximum (at 20°C)
Dropout Voltage
Rated voltage × 10% minimum (at 20°C)
Maximum Continuous Applicable Voltage
Rated voltage × 110%
Maximum Continuous Applicable Time
Continuous
Insulation Class
Class F
Light Source
LED
Illumination Color
Green
Contact Ratings
Operating Voltage (Ue)
Rated Operating
Current (Ie)
Main and Lock
Monitor Circuits
125V
250V
AC
Resistive load (AC-12)
Inductive load (AC-15)
2A
1A
DC
Resistive load (DC-12)
Inductive load (DC-13)
2A
1A
0.4A
0.22A
AC
2.5A
1.5A
1.5A
0.75A
DC
2.5A
2.3A
1.1A
0.55A
0.55A
0.27A
Door Monitor Circuit
Light Curtains
30V
292
www.IDEC.com
Dimensions (mm)
Interlock Switch
HS6E
Mounting Hole Layout
3-M4 S crew
(ø4.3 or M4 tapped hole
Hole for Manual Unlocking
ø12 (reference)
20.5
30
4
15
4
10.4
10.1
Overview
5.5
15
37
46.1
(22.5)
20.5
35
(22.5)
28.5
28.5
M a nua l Unlocking Key
75
30
4
1
R2.
XW Series E-Stops
41.8
ø4.
41.8
4
20 to 22
C1
2
(2
3)
4
ø12 (reference)
3-M4 Screw
(ø4.3 or M4 tapped hole)
1
30
20.5
Interlock Switches
1
Enabling Switches
28.5
41.8
20 to 22
(12.6±1)
Actuator Stop
Actuator(supplied)
Stop
(supplied)
0.8
0.8
Actuator Stop
Actuator(supplied)
Stop
(supplied)
48.8
0.8
(25)
48.8
(42) (Note)
Actuator Stop
(supplied)
(25)
22.6 ±1
48.8
(6.2)
22.6 ±1
(14)
(6.2)
0.8
(14)
(42) (Note)
(6.2)
0.8
Actuator Stop
(supplied)
22.6 ±1
(14)
0.8
(14)
22.6 ±1
50.8
0.8
50.8
0.8
50.8
0.8
22.6 ±1
(14)
(5)
When using horizontal/vertical
(25)
angle adjustable
actuator
22.6 ±1
(HS9Z-A65/A66)
(42) (Note)
(12.6±1)
(12.6±1)
(5)
When using right-angle actuator
(HS9Z-A62)
(14)
(5)
When using straight actuator
(HS9Z-A61)
Actuator Stop
(supplied)
Actuator Stop
Actuator(supplied)
Stop
(supplied)
Light Curtains
Actuator Mounting Reference Position
Interlock Switch
Actuator Stop
Door Stop
0.8
As shown in the figure on the right, the mounting reference position of the actuator key when inserted
in the interlock switch is:
The actuator stop on the actuator lightly touches the interlock switch.
After mounting the actuator, remove the actuator stop from the
actuator.
Door Stop
HS9Z-A61 Actuator
293
HS6E
Straight Actuator (HS9Z-A61) Right-angle
Actuator (HS9Z-A62)
43.2
The retention force of the HS9Z-A62 actuator is 100N. Note: See page 297 for actuator installation.
When tensile force exceeding 100N is expected, use
When mounted (33.8)
(15.8)
0.8
8.4
0.8
3.5
1.2
10.4
When
mounted (5.6)
When
mounted (5)
When mounted (10.2)
14
13.1
Rubber Bushing
3.5
14
3.5
1.2
4.2
1.2
13.1
Rubber Bushing
14
Mounting Plate (supplied)
2-ø
Rubber Bushing 2-ø4
.3
34
2-ø9
When mounted (5)
2-ø9
When mounted (6.2)
Note 1
Actuator Stop (supplied)
ø2-9
XW Series E-Stops
14
When mounted (6.2)
When mounted (33.8)
14
0.8
41.1
15
8.4
.3
14
with Mounting Plate (HS9Z-A62S)
8.4
20.9
ø4
2-
Overview
Actuator Key Dimensions (mm)
The actuator stop is used to adjust the actuator position. Remove after the actuator position is mounted.
Angle Adjustable Actuator
(HS9Z-A65)
Horizontal Adjustment
3.5
Enabling Switches
Actuator Adjustment
Orientation
metal actuator inserted in opposite directions.
The orientation of actuator adjustment (horizontal/vertical) can be changed using the orienting
insert (white plastic) installed on the back of the
actuator.
20°
20°
Angle Adjustment
(M3 Hexagon Socket Head Screw)
Horizontal Adjustment Vertical Adjustment
28.2
2
7.5
5.5
Orienting Insert
Vertical Adjustment
Angle Adjustment
16.8
13
(Note)
Angle Adjustment
(M3 Hexagon Socket
Head Screw)
(HS9Z-A65)
(M R2.1
4H
ole
s)
Manual Unlock Key (plastic)
Manual Unlock Key, HS9Z-T3 (metal)
3
(supplied with switch, not replaceable)
18
6.5
(24.5)
294
ø4
ø10
(24)
ø10
(24)
15 9
15 9
3
2-M4 Screw
(ø4.3 or M4 tapping screw)
www.IDEC.com
18
(24.5)
6.5
130
ø4
2.5
15
15
20°
34
25
20°
(Note 1)
Actuator Stop (Supplied)
25
Light Curtains
Orienting Insert
Angle Adjustment
Vertical Adjustment
1.2
0.8
Orienting Insert
(HS9Z-A66)
15
Interlock Switches
(Note) Actuator Stop (supplied)
4
130
4
HS6E
Circuit Diagrams and Operating Characteristics
Status 1
Status 2
Door closed
Machine ready to
operate
Solenoid de-energized
Interlock Switch Status
Status 3
Door opened
Machine cannot be
operated
Solenoid energized
Status 4
Door open
Machine cannot be
operated
Solenoid energized
Door open
Machine cannot be
operated
Unlocking Using
Manual Unlock Key
Overview
Spring Lock Type
Door closed
Machine cannot be
operated
XW Series E-Stops
Door Status
UNLOCK
LOCK
Manually
Unlocked
A2
Circuit Diagram (Example: HS6E-N4)
HS6E-L4
Door
Lock
Monitor Monitor
A2
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12 41
22 53
32
A1
42
54
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12 41
22 51
32
42
52
HS6E-N4
Main Circuit:
Monitor Circuit:
12 41
22 53
34
42
54
HS6E-P4
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12 41
22 51
34
42
52
A1
A2
A1
11
12
41
42
11
12
41
42
11
12
41
42
11
12
41
42
21
22
53
54
21
22
53
54
21
22
53
54
21
22
53
54
33
34
33
34
33
34
33
34
Closed (locked)
Closed (unlocked)
Open
Open
Closed (unlocked)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door closed) 31-32
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
Lock Monitor Circuit
(unlocked) 53-54
OFF (open)
ON (closed)
ON (closed)
ON (closed)
ON (closed)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door closed) 31-32
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(locked) 51-52
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door open) 33-34
OFF (open)
OFF (open)
ON (closed)
ON (closed)
OFF (open)
(unlocked) 53-54
OFF (open)
ON (closed)
ON (closed)
ON (closed)
ON (closed)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door open) 33-34
OFF (open)
OFF (open)
ON (closed)
ON (closed)
OFF (open)
(locked) 51-52
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
OFF (de-energized)
ON (energized)
ON (energized)
OFF (de-energized)
OFF (de-energized)
Solenoid Power A1-A2 (all types)
Monitor Circuit:
11
21
33
A2
Enabling Switches
Part Number and Circuit Diagram
HS6E-M4
A1
Interlock Switches
Door
A2
A1
Light Curtains
Main circuit: Connected to the machine drive control circuit, sending the interlock signals of the protective door.
Monitor circuit: Sends the monitoring signals of open/closed and lock/unlocked statuses of the protective door.
Operation Characteristics (reference)
Main Circuit
Door Monitor Circuit (door open, NO)
Door Monitor Circuit (door closed, NC)
Lock Monitor Circuit (unlocked, NO)
Lock Monitor Circuit (locked, NC)
0 (Actuator Insertion Position)
1.1 (Locked Position)
4.7 5.0
27.4 (stroke in mm)
: Contacts ON (closed)
: Contacts OFF (open)
The characteristics shown in the chart above are of the HS9Z-A61, -A62, -A65, and -A66 actuators. For the HS9Z-A62S actuator, subtract 0.6 mm.
The characteristics show the contact status when the actuator enters an entry slot of an interlock switch.
295
HS6E
Overview
Solenoid Lock Type
Status 1
Status 2
Door closed
Machine ready to
operate
Solenoid energized
Status 3
Door closed
Machine cannot be
operated
Status 4
Door open
Machine cannot be
operated
Door open
Machine cannot be
operated
Unlocking Using
Manual Unlock Key
Door open
Machine cannot be
operated
UNLOCK
LOCK
XW Series E-Stops
Door Status
Manually
Unlocked
A2
Circuit Diagram (Example: HS6E-N7Y)
Interlock Switches
Door
HS6E-L7Y
Door
Lock
Monitor Monitor
A2
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12 41
22 53
32
A1
42
54
Enabling Switches
HS6E-M7Y
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
31
12 41
22 51
32
42
52
HS6E-N7Y
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12 41
22 53
34
42
54
HS6E-P7Y
Main Circuit:
Monitor Circuit:
Monitor Circuit:
11
21
33
12 41
22 51
34
42
52
Light Curtains
A1
A2
A1
11
12
41
42
11
12
41
42
11
12
41
42
11
12
41
42
22
53
54
21
22
53
54
21
22
53
54
21
22
53
54
33
34
33
34
33
34
33
34
Closed (unlocked)
Open
Open
Closed (unlocked)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door closed) 31-32
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(unlocked) 53-54
OFF (open)
ON (closed)
ON (closed)
ON (closed)
ON (closed)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door closed) 31-32
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(locked) 51-52
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door open) 33-34
OFF (open)
OFF (open)
ON (closed)
ON (closed)
OFF (open)
(unlocked) 53-54
OFF (open)
ON (closed)
ON (closed)
ON (closed)
ON (closed)
Main Circuit 11-42
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
(door closed) 21-22
ON (closed)
ON (closed)
OFF (open)
OFF (open)
ON (closed)
(door open) 33-34
OFF (open)
OFF (open)
ON (closed)
ON (closed)
OFF (open)
(locked) 51-52
ON (closed)
OFF (open)
OFF (open)
OFF (open)
OFF (open)
ON (energized)
OFF (de-energized)
OFF (de-energized)
ON (energized)
(Note 2)
OFF (de-energized)
to ON (re-energized)
(Note 1) (Note 2)
Note 1: Do not attempt manual unlocking while the solenoid is energized.
Note 2: Do not energize the solenoid for a long period of time while the door is open
or while the door is unlocked manually using the manual unlock key.
4.7 5.0
27.4 (stroke in mm)
296
A2
21
Main Circuit
A1
Closed (locked)
A2
A1
www.IDEC.com
HS6E
Operating Instructions
Actuator Angle Adjustment for the HS9Z-A65/HS9Z-A66
• When using the interlock switch on hinged doors, refer to the minimum radius
of doors shown below. When using on doors with small minimum radius, use
the angle adjustable actuator (HS9Z-A65 and HS9Z-A66).
• Using the angle adjustment screw, the actuator angle can be adjusted (see
figures on page 370).
Adjustable angle: 0 to 20°
• The larger the adjusted angle of the actuator, the smaller the applicable
radius of the door opening.
Note: Because deviation or dislocation of hinged doors may occur in actual applications, make sure
of the correct operation before installation.
• When door hinge is on the extension line of the interlock switch surface:
• After installing the actuator, open the door. Then adjust the actuator so that
its edge can enter properly into the actuator entry slot of the interlock switch.
• After adjusting the actuator angle, apply Loctite to the adjustment screw so
that the screw will not become loose.
XW Series E-Stops
When Using the HS9Z-A62/A62S Right-angle Actuator
Overview
Minimum Radius of Hinged Door
Mounting Examples
Application on Hinged Doors
Application on Sliding Doors
M
in
M
in
Door Hinge
s
im
u
16 m R
a
m diu
m
s
HS9Z-A62S Actuator
Door
Door Hinge
Interlock Switches
im
16 um
0 Ra
m
m diu
HS9Z-A61 Actuator
• When door hinge is on the extension line of the actuator mounting surface:
HS6E
Interlock Switch
Latch
Door Stop
Enabling Switches
Note: When mounting the actuator, make sure that the actuator enters
the slot in the correct direction, as shown on the right.
M
in
M
in
im
23
um
m
Ra
m
di
us
Door Hinge
im
u
23 m R
m adiu
m
s
For Manual Unlocking
Door Hinge
When using the HS9Z-A65/HS9Z-A66 Angle Adjustable Actuator
When using the manual unlock key
Manual Unlocking
(installed on both sides)
UNLOCK
Horizontal Mi
Adjustment
nimum
HS9Z-A65
Radius
nimumDoor Hinge
mm
50Mi
Radius
Door Hinge
50 mm
HS9Z-A65
Vertical Adjustment
Minimum
Radius
umDoor Hinge
Minim
mm
50
Radius
Door Hinge
mm
50
Label
HS9Z-A65
HS9Z-A65
HS9Z-A66
HS9Z-A66
HS9Z-A66
Vertical
Adjustment
Vertical Adjustment
LOCK
Horizontal
Adjustment
Manual Unlocking
Position
HS9Z-A66
50 mm
Door Hinge
Minimum
50 mm
Radiu
s
Door Hinge
Minimum
Radius
Horizontal
Adjustment
s
u Door Hinge
adi
mR
s
imu 70 mmadiu Door Hinge
Min
mR m
u
m
m
i
70
Min
Vertical
Adjustment
Vertical
Adjustment
us Door Hinge
Vertical Adjustment
adi
mR
s
imu 70mmadiu Door Hinge
R
Min
um mm
m
i
70
Min
Label
HS9Z-A65
HS9Z-A66
HS9Z-A66
M
Rainimu
diu m Door Hinge
70 M
isni
mR
mad mum
Door Hinge
70 ius
mm
Manual Unlock Key
(supplied with the interlock switch)
Label
HS9Z-A66
HS9Z-A66
• Do not apply excessive force (0.45 N·m or more) to the manual unlock part,
otherwise the manual unlock part will become damaged.
M
Rainimu
diu m Door Hinge
sin
70m M
R
mad imum
Door Hinge
70m ius
m
HS9Z-A65
HS9Z-A65
• Using the interlock switch with the actuator not fully turned (less than 90°)
may cause damage to the interlock switch or operation failures (when manually unlocked, the switch will keep the main circuit disconnected and the door
unlocked).
See instruction manual for full details.
Light Curtains
Door Hinge
50 mm
Door Hinge
Min50
imu
m
Radiumm
s
Minimum
Radius
HS9Z-A65
Normal Position
Label
297
Overview
HS6E
Recommended Tightening Torque of Mounting Screws
Terminal Number Identification
• Interlock switch: 1.0 to 1.5 N·m (three M4 screws)
• When wiring, identify the terminal number of each contact by the color of the
insulation.
• Actuators: 1.0 to 1.5 N·m (two M4 screws)
• The following table shows the identification of terminal numbers.
Cables
• When wiring, cut unused wires to avoid incorrect wiring.
XW Series E-Stops
• Do not fasten or loosen the gland at the bottom of the interlock switch.
• When bending the cable during wiring, make sure that the cable radius is kept
at 30 mm minimum.
• When wiring, make sure that water or oil does not enter from the end of the
cable.
Type
Door Monitor
Main circuit: Blue
Monitor circuit: Brown
Monitor circuit: Orange
Main circuit: Blue
HS6E-M
HS6E-N
Main circuit: Blue
Gland
HS6E-P
A1 Black
White A2
HS6E-L
• The solenoid has polarity. Make sure of the correct polarity when wiring.
dius
Minimum Ra
30 mm
(70)
Lock Monitor
• Do not open the lid of the interlock switch. Otherwise the interlock switch will
be damaged.
Interlock Switches
Contact Arrangement
Main circuit: Blue
11
21
31
12
22
32
Brown/White Pink 53
41
11
21
31
12
22
32
Brown/White Pink 51
11
21
33
12
22
34
Brown/White Pink 53
11
21
33
12
22
34
Brown/White Pink 51
42
54
Blue/White
42
52
Blue/White
42
54
Blue/White
42
52
Blue/White
Pink/White
Orange/White
41
Pink/White
Orange/White
41
Pink/White
Orange/White
41
Pink/White
Orange/White
(50)
Min
im
Rad um
30 ius
mm
Enabling Switches
Note: The contact arrangements show the contact status when the actuator is inserted and locked.
Gland
• Wires can be identified by color and or a white line printed on the wire.
No.
Insulation Color
No.
Insulation Color
1
Blue/White
7
White
2
Gray
8
Black
3
Pink
9
Pink/White
4
Orange
10
Brown/White
5
Orange/White
11
Brown
6
Gray/White
12
Blue
Light Curtains
Wire Identification
298
www.IDEC.com
