AL2M-M11PG.
AL2M-M11PG.
    IDEC
    IDEC - AL2M-M11PG. - SWITCH, PUSHBUTTON, SPDT, 3A, 250V
AL2M-M11PG. 数据手册
A2 Series Miniature Control Units ø12 Short 22-mm-long body miniature control unit series with bright LED illumination face and snap-action switching. • Available in enclosed (IP40) and waterproof (IP65), and oiltight types. • 12-mm mounting holes • All series have terminals on the same plane. • UL recognized, CSA certified Contact Ratings (Contact Block) Specifications Rated Insulation Voltage 250V Operating Temperature –25 to +55°C (no freezing) Rated Thermal Current 3A Storage Temperature –30 to +80° 45 to 85% RH (no condensation) 24V 110V 220V Operating Humidity Resistive Load – 1.0A 0.5A Contact Resistance 50 mΩ maximum (initial value) Inductive Load – 0.7A 0.5A Insulation Resistance 100 MΩ minimum (500V DC megger) Operating Voltage (AC/DC) AC 50/60 Hz DC Resistive Load 1.0A 0.2A – Inductive Load 0.7A 0.1A – Contact Material Silver Dielectric Strength • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Weight Switch Unit Between live and dead metal parts: 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Between terminals of the same pole: 1,000V AC, 1 minute Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Unit Between live part and ground: 2,000V AC, 1 minute AL2M-M11: 4g Weight (approx.) AL2M-P1: 4g AB2M-M1: 4g Vibration Resistance Operating extremes: 5 to 55 Hz, amplitude 0.75 mm Shock Resistance Damage limits: 500 m/s2 (50G) Operating extremes: 200 m/s2 (20G) Mechanical Durability (minimum operations) Momentary: 200,000 operations Maintained: 100,000 operations Electrical Durability (minimum operations) Momentary: 100,000 operations Maintained: 50,000 operations (Switching frequency 1200 operations/h) Degree of Protection Enclosed (IP40) Waterproof, dust-tight (IP65) LED Lamp Ratings (LAD-S Type) Type No. LAD-SA Lamp Base LAD-SG LAD-SR LAD-SY Exclusive for A series control units Forward Current (If) 20 mA Forward Voltage (Vf) (nominal) 2.2V 2.1V 1.7V Reverse Voltage (Vr) 2.2V 4V Illumination Color A G R Y LED Lamp Color Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Applicable Lens Color Base Plastic Color Red LED Lamp Life (reference value) Approx. 50,000 hours (The illuminance reduces to 50% the initial intensity when used on complete DC.) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit 5V DC: 6V DC: 12V DC: 24V DC: 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If • LED lamps do not have a current-limiting resistor, and external resistors of recommended values for each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. Because no protection diode is contained, ensure the correct polarity is observed. 24 (+) (–) Current Limiting Resistor Lamp Terminal (+) Lamp Terminal (–) (06/11/10) ø12 A2 Series Miniature Control Units AL2 LED Illuminated Pushbuttons & Pilot Lights Type No. Operation Type Shape Round AL2M Contact IP40 IP65 SPDT AL2M-M11➁ AL2M-M11P➁ DPDT AL2M-M21➁ AL2M-M21P➁ SPDT AL2M-A11➁ AL2M-A11P➁ DPDT AL2M-A21➁ AL2M-A21P➁ — AL2M-P1➁ AL2M-P1P➁ SPDT AL2Q-M11➁ AL2Q-M11P➁ DPDT AL2Q-M21➁ AL2Q-M21P➁ SPDT AL2Q-A11➁ AL2Q-A11P➁ DPDT AL2Q-A21➁ AL2Q-A21P➁ — AL2Q-P1➁ AL2Q-P1P➁ SPDT AL2H-M11➁ AL2H-M11P➁ DPDT AL2H-M21➁ AL2H-M21P➁ SPDT AL2H-A11➁ AL2H-A11P➁ DPDT AL2H-A21➁ AL2H-A21P➁ — AL2H-P1➁ AL2H-P1P➁ ➁ Lens Color Code LED Lamp Type No., Rated Current (External Resistor Recommended Value) Momentary Maintained Marking plate size: ø10 mm Engraving area: ø8.2 mm (Depth: 0.5 mm max.) Square AL2Q Pilot Light Momentary Maintained Marking plate size: 10 mm Engraving area:  8.2 mm (Depth: 0.5 mm max.) Rectangular AL2H Pilot Light Specify a color code in place of ➁ in the Type No. A: amber G: green R: red W: white Y: yellow A: G: R: W/Y: LAD-SA LAD-SG LAD-SR LAD-SY Rated Current: 20 mA 5V DC: 6V DC: 12V DC: 24V DC: 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W Momentary Maintained Marking plate size: 10 × 14 mm Engraving area: 8.2 × 12.2 mm Pilot Light (Depth: 0.5 mm max.) • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • External current-limiting resistor is not necessary when an optional socket with built-in resistor is used (see page 27). LED Lamp • AP2M series pilot lights (round bezel only) with built-in current-limiting resistors are also available. Internal Circuit (+) (–) Dimensions Panel Thickness 0.5 to 6 Rubber Gasket Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) c14 ø14 2.8 5 5.5 ø14 14 9.2 2.8 Terminal Width 1.8×0.4t 0.6 7 Terminal Arrangement 22 0.6 9 18 9 Mounting Hole Layout • Round/Square Units Lamp Terminal (+) 5.5 (TOP) ø12 • Rectangular Units +0.2 0 ø12 +0.2 0 NC1 NC2 C1 C2 Note: Determine mounting centers to ensure easy operation. 14 min. 14 min. NO1 NO2 SPDT has NC1, NO1, and C1 only. Lamp Terminal (–) 14 min. 18 min. All dimensions in mm. (06/11/10) 25 ø12 A2 Series Miniature Control Units AB2 Pushbuttons Shape Operation Type Button Type Round AB2M Momentary Button Maintained Momentary Illumination Lens Maintained Square AB2Q Momentary Button Maintained Momentary Illumination Lens Maintained Rectangular AB2H Type No. Contact Momentary Button Maintained Momentary Illumination Lens Maintained IP40 IP65 SPDT AB2M-M1➀ AB2M-M1P➀ DPDT AB2M-M2➀ AB2M-M2P➀ SPDT AB2M-A1➀ AB2M-A1P➀ DPDT AB2M-A2➀ AB2M-A2P➀ SPDT AB2M-M1L➁ AB2M-M1PL➁ DPDT AB2M-M2L➁ AB2M-M2PL➁ SPDT AB2M-A1L➁ AB2M-A1PL➁ DPDT AB2M-A2L➁ AB2M-A2PL➁ SPDT AB2Q-M1➀ AB2Q-M1P➀ DPDT AB2Q-M2➀ AB2Q-M2P➀ SPDT AB2Q-A1➀ AB2Q-A1P➀ DPDT AB2Q-A2➀ AB2Q-A2P➀ SPDT AB2Q-M1L➁ AB2Q-M1PL➁ DPDT AB2Q-M2L➁ AB2Q-M2PL➁ SPDT AB2Q-A1L➁ AB2Q-A1PL➁ DPDT AB2Q-A2L➁ AB2Q-A2PL➁ SPDT AB2H-M1➀ AB2H-M1P➀ DPDT AB2H-M2➀ AB2H-M2P➀ SPDT AB2H-A1➀ AB2H-A1P➀ DPDT AB2H-A2➀ AB2H-A2P➀ SPDT AB2H-M1L➁ AB2H-M1PL➁ DPDT AB2H-M2L➁ AB2H-M2PL➁ SPDT AB2H-A1L➁ AB2H-A1PL➁ DPDT AB2H-A2L➁ AB2H-A2PL➁ Color Code ➀➁ B: G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B: G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B: G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow • Specify a color code in place of ➀ or ➁ in the Type No. Dimensions Panel Thickness 0.5 to 6 Rubber Gasket Locking Ring Square (TOP) Round (TOP) c14 ø14 5 0.6 5.5 22 Terminal Arrangement (TOP) 0.6 9 18 • Round/Square Units ø12 • Rectangular Units +0.2 0 14 min. C1 C2 9 Mounting Hole Layout NC1 NC2 NO1 NO2 5.5 ø12 +0.2 0 14 min. 2.8 14 2.8 Rectangular (TOP) SPDT has NC1, NO1, and C1 only. 14 min. 18 min. Note: Determine mounting centers to ensure easy operation. 26 All dimensions in mm. (06/11/10) ø12 A2 Series Miniature Control Units Accessories Shape Material Type No. Ordering Type No. Package Quantity Locking Ring Wrench ø14 Dimensions (mm) Metal (nickel-plated brass) MT-002 MT-002 1 • Used to tighten the locking ring when installing the A2 control units into a panel. • Tighten the locking ring to a torque of 0.78 N·m maximum. Stainless Steel MT-101 MT-101 1 • Used to remove lens and button. Rubber OR-66 OR-66 1 • Used to remove and install LED lamps. AL-K2 AL-K2 1 AL-KH2 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 Switch Guard For round/ square Unit 90° open For rectangular AL-KH2 unit • Degree of protection: IP40 • Used to protect pushbuttons from inadvertent operation. • See page 28 for dimensions. (remains 90° open) Socket Solder Terminal AL-C2 AL-C2 1 PC Board Terminal AL-C2V AL-C2V 1 5V DC AL-C21 AL-C21 1 Blue 6V DC AL-C22 AL-C22 1 Green 12V DC AL-C23 AL-C23 1 24V DC AL-C24 AL-C24 1 5V DC AL-C21V AL-C21V 1 6V DC PC Board Terminal 12V DC AL-C22V AL-C22V 1 AL-C23V AL-C23V 1 Yellow 24V DC AL-C24V AL-C24V 1 Red Solder Terminal Terminal Cover Nylon AL-V2 AL-V2PN10 10 For round units AL-D2 AL-D2 1 For square units AL-DQ2 AL-DQ2 1 For rectangular units AL-DH2 AL-DH2 1 Nitryl rubber (black) AL-B2 AL-B2PN05 5 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR Illumination color: yellow LAD-SY LAD-SA LAD-SAPN10 LAD-SG LAD-SGPN10 LAD-SR LAD-SRPN10 LAD-SY LAD-SYPN10 1 10 1 10 1 10 1 10 Dust Cover Socket Bottom Color Socket with Built-in Resistor • Snaps on the rear of the A2 series control units. (see page 28 for dimensions) Yellow Red Blue Green • A current limiting resistor is contained, eliminating the need for external resistors. • When using the socket with a built-in resistor, make sure that the continuous current is 1A maximum and the operating temperature is –25 to +40°C. In collective mounting, keep center-to center-spacing of 20 mm or more between adjacent units in consideration of built-in resistor heating. • See page 28 for dimensions. • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. • When mounting the control units with the dust covers installed, refer to mounting hole layout on page 29. • Operating temperature: –10 to +55°C • Material Front part: Elastomer (transparent) Rear part: Polypropylene (black) • See page 29 for dimensions and mounting hole layout. Mounting Hole Plug 5.3 9.0 All dimensions in mm. (06/11/10) Amber LED color: amber clear Lens color Current-limiting resistor is not contained. ø4.0 LED Lamp • Degree of protection: IP65 Green LED color: yellow diffused Red LED color: clear red White/ LED color: yellow clear Yellow 27 ø12 A2 Series Miniature Control Units Maintenance Parts Shape Specification Marking Plate Type No. Ordering Type No. Round AL2M-W AL2M-WPN05 Square AL2Q-W AL2Q-WPN05 Rectangular AL2H-W AL2H-WPN05 Round AL2M-LK1-➁ AL2M-LK1-➁PN02 Square AL2Q-LK1-➁ AL2Q-LK1-➁PN02 Rectangular AL2H-LK1-➁ AL2H-LK1-➁PN02 Round AL2M-LK2-➁ AL2M-LK2-➁ Square AL2Q-LK2-➁ AL2Q-LK2-➁ Lens Unit For IP40 units For IP65 illuminated pushbuttons Rectangular AL2H-LK2-➁ AL2H-LK2-➁ Round AL2M-LK3-➁ AL2M-LK3-➁ Square AL2Q-LK3-➁ AL2Q-LK3-➁ Rectangular AL2H-LK3-➁ AL2H-LK3-➁ Package Quantity 5 • White 2 • Specify a color code in place of ➁ in the Type No. A (amber) G (green) R (red) W (white) Y (yellow) 1 For IP65 pilot lights Button Unit For IP40 pushbuttons For IP65 pushbuttons Round AB2M-BK1-➀ AB2M-BK1-➀PN02 Square AB2Q-BK1-➀ AB2Q-BK1-➀PN02 Rectangular AB2H-BK1-➀ AB2H-BK1-➀PN02 Round AB2M-BK2-➀ AB2M-BK2-➀ Square AB2Q-BK2-➀ AB2Q-BK2-➀ Rectangular AB2H-BK2-➀ AB2H-BK2-➀ Color Code ➀➁ • Specify a color code in place of ➀ in the Type No. B (black) G (green) R (red) S (blue) W (white) Y (yellow) 2 1 Dimensions • Switch Guard 11 22.5 min. 19.5 22.5 min. Rubber Gasket 12.5 Panel Thickness 0.5 to 5 26.5 18 11 8.5 15 min. Rubber Gasket 12.5 19 min. • Socket (AL-C2, AL-C2V, AL-C2 ) 6 1 33 6 1 6.5 13 2.8 17 Solder Terminal Type (AL-C2) 1 NC1 NC2 17 4.5 8-1.0 +0.2 0 C1 C2 Lamp Terminal (–) Holes Panel Cut-out Bottom View PC Board Terminal (AL-C2V) 6 NO1 NO2 36 1 6 20 Solder Terminal Type with Built-in Resistor (AL-C2 c ) 2.8 2.8 10.2 5.3 4.9 6.5 7.3 13 2.8 5.5 7 10.5 6.5 7.3 2.8 36 Lamp Terminal (+) (TOP) 10.5 10.5 2.8 2.8 33 Terminal Arrangement Terminal 0.8 × 0.3t 2.8 19.5 For Rectangular Units (AL-KH2) Panel Thickness 0.5 to 5 26.5 14 8.5 For Round/Square Units (AL-K2) 3.5 20 5 PC Board Terminal Type with Built-in Resistor (AL-C2 c V) 8-1.0 +0.2 0 Holes Panel Cut-out Bottom View All dimensions in mm. 28 (06/11/10) A2 Series Miniature Control Units ø12 Dimensions • Terminal Cover (AL-V2) ø12.8 17.3 Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. 33.5 • Dust Cover For Square Units (AL-DQ2) For Rectangular Units (AL-DH2) c 20 24 20 ø20 ø12 12 (Rectangular Units) Waterproof Gasket for Dust Cover ø12 20 min. 6.5 Waterproof Gasket for Dust Cover 0.3 6.5 Waterproof Gasket for Dust Cover 0.3 12 12 20 min. 6.5 0.3 Mounting Hole Centers (Round Units, Square Units) 20 min. For Round Units (AL-D2) 24 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. (06/11/10) 29 ø12 A2 Series Miniature Control Units Safety Precautions • Turn off the power to A series control units before starting installation, removal, wiring, maintenance, and inspection of the control units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Wiring • Removal Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu type is recommended when using leadfree solder. When soldering, do not touch the control unit with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use non-corrosive rosin flux. Remove the lens assembly (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Latches Installing the Socket Install the socket on the control unit with the TOP markings on the control unit and the socket placed in the same direction. Engraving Area Color Lens Marking Plate Operating Voltage of LED Lamps Lens Holder • Installation Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. • Installing Non-illuminated Button Non-illuminated pushbuttons contain a marking plate like illuminated units. Be sure to install the marking plate when replacing the button. Replacing the LED Lamp • Removal Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. • Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) For removing lamps For installing lamps The operating voltage is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Other Notes • Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the control units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. • Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. • Operating and Storage Environment 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units (IP40) in an environment subject to oil, water or dust accumulation. In such an area, use the waterproof/oiltight units (IP65). • Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. Panel Mounting • IP65 Type Units When mounting the control units onto a panel, use the optional locking ring wrench (MT-002) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.78 N·m. Excessive tightening will damage the locking ring. IP65 type units are evaluated by conventional cutting and cooling oils, and can not be used with some special oils. Contact IDEC for resistance against special oils. 30 (06/11/10) A1 Series Miniature Control Units ø10 Short 22-mm-long body miniature control unit series with LED illumination face and snap-action switching. • • • • Bright and clear LED illumination. 10-mm mounting holes All series have terminals on the same plane. UL recognized, CSA certified Contact Ratings (Contact Block) Specifications Rated Insulation Voltage 250V Operating Temperature –25 to +55°C (no freezing) Rated Thermal Current 3A Operating Humidity 45 to 85% RH (no condensation) Operating Voltage (AC/DC) AC 50/60 Hz DC 24V 110V 220V Contact Resistance 50 mΩ maximum (initial value) Insulation Resistance 100 MΩ minimum (500V DC megger) Resistive Load – 1.0A 0.5A Inductive Load – 0.7A 0.5A Resistive Load 1.0A 0.2A – 0.7A 0.1A – Inductive Load Contact Material Dielectric Strength Silver • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Weight AL1M-M11: 3g Weight (approx.) AL1M-P1: 3g AB1M-M1: 3g Switch Unit Between live and dead metal parts: 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Between terminals of the same pole: 1,000V AC, 1 minute Between contact and lamp terminals: 1,500V AC, 1 minute Illumination Unit Between live part and ground: 2,000V AC, 1 minute Vibration Resistance Operating extremes: 5 to 55 Hz, amplitude 0.75 mm Shock Resistance Damage limits: 500 m/s2 (50G) Operating extremes: 200 m/s2 (20G) Mechanical Durability (minimum operations) Momentary: 200,000 operations Maintained: 100,000 operations Electrical Durability (minimum operations) Momentary: 100,000 operations Maintained: 50,000 operations (Switching frequency 1200 operations/h) Degree of Protection Enclosed (IP40) LED Lamp Ratings (LAD-S Type) Type No. LAD-SA Lamp Base LAD-SG LAD-SR LAD-SY Exclusive for A series control units Forward Current (If) 20 mA Forward Voltage (Vf) (nominal) 2.2V 2.1V 1.7V Reverse Voltage (Vr) 2.2V 4V Illumination Color A G R Y LED Lamp Color Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Applicable Lens Color Base Plastic Color Red LED Lamp Life (reference value) Approx. 50,000 hours (The illuminance reduces to 50% the initial intensity when used on complete DC.) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit 5V DC: 6V DC: 12V DC: 24V DC: 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If • LED lamps do not have a current-limiting resistor, and external resistors of recommended values for each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. Because (+) no protection diode is contained, ensure the correct polarity is observed. Current Limiting Resistor (06/11/10) (–) Lamp Terminal (+) Lamp Terminal (–) 31 ø10 A1 Series Miniature Control Units AL1 LED Illuminated Pushbuttons & Pilot Lights Type No. Operation Type Shape Round AL1M Marking plate size: ø8.5 mm Engraving area: ø7 mm (Depth: 0.5 mm max.) Square AL1Q Marking plate size:  8.5 mm Engraving area:  7 mm (Depth: 0.5 mm max.) Rectangular AL1H ➁ Lens Color Code IP40 Momentary SPDT AL1M-M11➁ Maintained SPDT AL1M-A11➁ Pilot Light — AL1M-P1➁ Momentary SPDT AL1Q-M11➁ Maintained SPDT AL1Q-A11➁ Pilot Light Marking plate size: 8.5 × 12.5 mm Engraving area: 7 × 11 mm (Depth: 0.5 mm max.) Contact — AL1Q-P1➁ SPDT AL1H-M11➁ Maintained SPDT AL1H-A11➁ Pilot Light — AL1H-P1➁ (External Resistor Recommended Value) A: G: Specify a color code in R: place of ➁ in the Type W/Y: No. A: G: R: W: Y: Momentary LED Lamp Type No., Rated Current amber green red white yellow LAD-SA LAD-SG LAD-SR LAD-SY Rated Current: 20 mA 5V DC: 6V DC: 12V DC: 24V DC: • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • AP1M series pilot lights (round bezel only) with built-in current-limiting resistor are also available. 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W LED Lamp Internal Circuit (+) (–) Dimensions Panel Thickness 0.5 to 6 Rectangular (TOP) 2.8 Locking Ring Square (TOP) Round (TOP) c12 ø12 2.8 12 Terminal Width 1.8×0.4t ø12 6 5.5 5.5 22 16 9 Terminal Arrangement (bottom view) Mounting Hole Layout • Round/Square Units (TOP) ø10 • Rectangular Units +0.2 0 ø10 +0.2 0 Lamp Terminal (+) COM Lamp Terminal (–) 12 min. NO 12 min. NC 12 min. 16 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. 32 (06/11/10) A1 Series Miniature Control Units ø10 AB1 Pushbuttons Shape Button Type Round AB1M Type No. IP40 Operation Type Contact Momentary SPDT AB1M-M1➀ Maintained SPDT AB1M-A1➀ Momentary SPDT AB1M-M1L➁ Maintained SPDT AB1M-A1L➁ Momentary SPDT AB1Q-M1➀ Maintained SPDT AB1Q-A1➀ Momentary SPDT AB1Q-M1L➁ Maintained SPDT AB1Q-A1L➁ Momentary SPDT AB1H-M1➀ Maintained SPDT AB1H-A1➀ Momentary SPDT AB1H-M1L➁ Maintained SPDT AB1H-A1L➁ Button Illumination Lens Square AB1Q Button Illumination Lens Rectangular AB1H Button Illumination Lens Color Code ➀➁ B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow • Specify a color code in place of ➀ or ➁ in the Type No. Dimensions Panel Thickness 0.5 to 6 2.8 Locking Ring Rectangular (TOP) Square (TOP) Round (TOP) c12 ø12 2.8 12 Terminal Width 1.8×0.4t 6 5.5 5.5 22 16 9 Terminal Arrangement (bottom view) Mounting Hole Layout • Round/Square Units (TOP) ø10 • Rectangular Units +0.2 0 ø10 +0.2 0 COM 12 min. NO 12 min. NC 12 min. 16 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. (06/11/10) 33 ø10 A1 Series Miniature Control Units Accessories Shape Material Type No. Ordering Type No. Package Quantity Locking Ring Wrench ø12 Dimensions (mm) Metal (nickel-plated brass) MT-003 MT-003 1 • Used to tighten the locking ring when installing the A1 control units into a panel. • Tighten the locking ring to a torque of 0.29 N·m maximum. Stainless Steel MT-101 MT-101 1 • Used to remove lens and button. Rubber OR-66 OR-66 1 • Used to remove and install LED lamps. AL-K1 AL-K1 1 AL-KH1 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 Switch Guard For round/ square Unit 90° open For rectangular AL-KH1 unit • Used to protect pushbuttons from inadvertent operation. • See page 35 for dimensions. (remains 90° open) Socket Solder Terminal AL-C1 AL-C1 1 PC Board Terminal AL-C1V AL-C1V 1 • Snaps on the rear of the A1 series control units. (see page 35 for dimensions) Terminal Cover Nylon AL-V1 AL-V1PN10 10 • Degree of protection: IP65 AL-B1 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR Illumination color: yellow LAD-SY AL-B1PN05 5 ø12 4.4 Nitryl rubber (black) 2 Mounting Hole Plug • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. 5.3 9.0 ø4.0 Current-limiting resistor is not contained. All dimensions in mm. 34 LAD-SA 1 LAD-SAPN10 10 LAD-SG 1 LAD-SGPN10 10 LAD-SR 1 LAD-SRPN10 10 LAD-SY 1 LAD-SYPN10 10 Amber LED color: amber clear Lens color LED Lamp Green LED color: yellow diffused Red LED color: clear red White/ LED color: yellow clear Yellow (06/11/10) A1 Series Miniature Control Units ø10 Maintenance Parts Shape Marking Plate Lens Unit Type No. Package Quantity Ordering Type No. Round AL1M-W AL1M-WPN05 Square AL1Q-W AL1Q-WPN05 Rectangular AL1H-W AL1H-WPN05 Round AL1M-LK1-➁ AL1M-LK1-➁PN02 Square AL1Q-LK1-➁ AL1Q-LK1-➁PN02 Rectangular AL1H-LK1-➁ AL1H-LK1-➁PN02 Round AB1M-BK1-➀ AB1M-BK1-➀PN02 Square AB1Q-BK1-➀ AB1Q-BK1-➀PN02 Rectangular AB1H-BK1-➀ AB1H-BK1-➀PN02 5 Color Code ➀➁ • White Specify a color code in place of ➁ in the Type No. A (amber), G (green), R (red) W (white), Y (yellow) 2 Button Unit Specify a color code in place of ➀ in the Type No. B (black), G (green), R (red) S (blue), W (white), Y (yellow) Dimensions • Switch Guard For Round/Square Units (AL-K1) For Rectangular Units (AL-KH1) 10 20.5 min. 17.5 20.5 min. Panel Thickness 0.5 to 5 24.5 7.5 10 16 7.5 17.5 12 13 min. 12.5 17 min. • Socket (AL-C1, AL-C1V) Terminal 0.8 × 0.3t 33 Terminal Arrangement (TOP) 7.3 2.8 7.3 2.8 33 NC 5 11 17 2.8 17 2.8 NO 3 5-1.0 Solder Terminal (AL-C1) PC Board Terminal (AL-C1V) +0.2 0 Holes Lamp Terminal (+) (PC Board Terminal Mounting Hole Layout) COM Lamp Terminal (–) (Bottom View) • Terminal Cover ø10.8 17.3 33.5 (06/11/10) Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. All dimensions in mm. 35 ø10 A1 Series Miniature Control Units Safety Precautions • Turn off the power to A series control units before starting installation, removal, wiring, maintenance, and inspection of the control units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper gauge to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Wiring • Removal Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu type is recommended when using leadfree solder. When soldering, do not touch the control unit with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use non-corrosive rosin flux. Remove the lens assembly (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Latches Installing the Socket Install the socket on the control unit with the TOP markings on the control unit and the socket placed in the same direction. Color lens Engraving Area Marking Plate Spring Lens Retaining Holder Groove Spring Note: Make sure that the spring is inserted in the correct direction. The base of spring must fit the groove in the holder. • Installation Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. • Installing Non-illuminated Button Non-illuminated pushbuttons contain a marking plate like illuminated units. Be sure to install the marking plate when replacing the button. Replacing the LED Lamp • Removal Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. • Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) For removing lamps Operating Voltage of LED Lamps The operating voltage is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Other Notes • Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the control units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. • Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. • Operating and Storage Environment 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units in an environment subject to oil, water or dust accumulation. • Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. For installing lamps Panel Mounting When mounting the control units into a panel, use the optional locking ring wrench (MT-003) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.29 N·m. Excessive tightening will damage the locking ring. 36 (06/11/10) A8 Series Miniature Control Units ø8 Short 22-mm-long body miniature control unit series with LED illumination face and snap-action switching. • • • • Bright and clear LED illumination. 8-mm mounting holes All series have terminals on the same plane. UL recognized, CSA certified Contact Ratings (Contact Block) Rated Insulation Voltage 250V Rated Thermal Current 3A Operating Voltage (AC/DC) AC 50/60 Hz DC Specifications 24V 110V 220V Resistive Load – 1.0A 0.5A Inductive Load – 0.7A 0.5A Resistive Load 1.0A 0.2A – Inductive Load 0.7A 0.1A – Contact Material Operating Temperature Operating Humidity Contact Resistance Insulation Resistance Dielectric Strength Silver • Minimum applicable load: 5V AC/DC, 3 mA (applicable range may vary with operating conditions and load types) Switch Unit Illumination Unit Weight Vibration Resistance AL8M-M11: 2g Weight (approx.) –25 to +55°C (no freezing) 45 to 85% RH (no condensation) 50 mΩ maximum (initial value) 100 MΩ minimum (500V DC megger) Between live and dead metal parts 2,000V AC, 1 minute Between terminals of different poles: 2,000V AC, 1 minute Between terminals of the same pole: 1,000V AC, 1 minute Between contact and lamp terminals: 1,500V AC, 1 minute Between live part and ground: 2,000V AC, 1 minute Operating extremes: 5 to 55 Hz, amplitude 0.75 mm Damage limits: 500 m/s2 (50G) Operating extremes: 200 m/s2 (20G) Momentary: 200,000 operations Maintained: 100,000 operations Momentary: 100,000 operations Maintained: 50,000 operations (Switching frequency 1200 operations/h) Enclosed (IP40) AL8M-P1: Shock Resistance 2g Mechanical Durability (minimum operations) AB8M-M1: 2g Electrical Durability (minimum operations) Degree of Protection LED Lamp Ratings (LAD-S Type) Type No. LAD-SA Lamp Base LAD-SG LAD-SR LAD-SY Exclusive for A series control units Forward Current (If) 20 mA Forward Voltage (Vf) (nominal) 2.2V 2.1V 1.7V Reverse Voltage (Vr) 2.2V 4V Illumination Color A G R Y LED Lamp Color Amber Clear Yellow Diffused Red Clear Yellow Clear Amber Green Red Yellow and White Applicable Lens Color Base Plastic Color Red LED Lamp Life (reference value) Approx. 50,000 hours (The illuminance reduces to 50% the initial intensity when used on complete DC.) Operating Voltage & External Current-limiting Resistor (recommended value) (Note) Internal Circuit 5V DC: 6V DC: 12V DC: 24V DC: 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W (+) (–) Note: When LED lamps are used on voltages other than the above, external resistor value R is determined by the following formula: R = (operating voltage – Vf) / If • LED lamps do not have a current-limiting resistor, and external resistors of recommended values for each voltage must be provided. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. Because no protection (+) diode is contained, ensure the correct polarity is observed. Current Limiting Resistor (06/11/10) (–) Lamp Terminal (+) Lamp Terminal (–) 37 ø8 A8 Series Miniature Control Units AL8 LED Illuminated Pushbuttons & Pilot Lights Type No. Operation Type Shape Round AL8M Marking plate size: ø6 mm Engraving area: ø4.5 mm (Depth: 0.5 mm max.) Square AL8Q Marking plate size:  6 mm Engraving area:  4.5 mm (Depth: 0.5 mm max.) Rectangular AL8H Marking plate size: 6 × 9 mm Engraving area: 4.5 × 7.5 mm (Depth: 0.5 mm max.) Contact IP40 Momentary SPDT AL8M-M11➁ Maintained SPDT AL8M-A11➁ Pilot Light — AL8M-P1➁ Momentary SPDT AL8Q-M11➁ Maintained SPDT AL8Q-A11➁ Pilot Light — AL8Q-P1➁ Momentary SPDT AL8H-M11➁ Maintained SPDT AL8H-A11➁ Pilot Light — AL8H-P1➁ LED Lamp ➁ Lens Color Code Specify a color code in place of ➁ in the Type No. A: amber G: green R: red W: white Y: yellow • LED lamps do not have a current-limiting resistor. Connect a current-limiting resistor in series, otherwise LED lamps will be damaged. • AP8M series pilot lights (round bezel only) with built-in current-limiting resistor are also available. Type No., Rated Current (External Resistor Recommended Value) A: G: R: W/Y: LAD-SA LAD-SG LAD-SR LAD-SY Rated Current: 20 mA 5V DC: 6V DC: 12V DC: 24V DC: 150Ω, 1/2W 200Ω, 1/2W 510Ω, 1W 1.1 kΩ, 1W LED Lamp Internal Circuit (+) (–) Dimensions Panel Thickness 0.5 to 6 Rectangular (TOP) Locking Ring Square (TOP) Round (TOP) c9 ø9 2.5 9 2.5 Terminal Width 1.8 × 0.4t ø9 5 5.5 7 5.5 22 Terminal Arrangement 12 9 Mounting Hole Layout • Round/Square Units (TOP) ø8 Lamp Terminal (+) Lamp Terminal (–) ø8 +0.2 0 9 min. NO COM 9 min. NC • Rectangular Units +0.2 0 9 min. Note: Determine mounting centers to ensure easy operation. 38 12 min. All dimensions in mm. (06/11/10) A8 Series Miniature Control Units ø8 AB8 Pushbuttons Shape Button Type Type No. IP40 Operation Type Contact Momentary SPDT AB8M-M1➀ Maintained SPDT AB8M-A1➀ Momentary SPDT AB8M-M1L➁ Maintained SPDT AB8M-A1L➁ Momentary SPDT AB8Q-M1➀ Maintained SPDT AB8Q-A1➀ Momentary SPDT AB8Q-M1L➁ Maintained SPDT AB8Q-A1L➁ Momentary SPDT AB8H-M1➀ Maintained SPDT AB8H-A1➀ Momentary SPDT AB8H-M1L➁ Maintained SPDT AB8H-A1L➁ Rectangular (TOP) Square (TOP) Round (TOP) c9 ø9 Round AB8M Color Code ➀➁ Button Illumination Lens Square AB8Q Button Illumination Lens Rectangular AB8H Button Illumination Lens B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow B G: R: S: W: Y: black green red blue white yellow A: G: R: W: Y: amber green red white yellow • Specify a color code in place of ➀ or ➁ in the Type No. Dimensions Panel Thickness 0.5 to 6 Locking Ring 2.5 9 2.5 Terminal Width 1.8 × 0.4t 5.5 7 5.5 22 12 9 Terminal Arrangement (bottom view) Mounting Hole Layout • Round/Square Units (TOP) ø8 • Rectangular Units +0.2 0 ø8 +0.2 0 9 min. NO COM 9 min. NC 9 min. 12 min. Note: Determine mounting centers to ensure easy operation. All dimensions in mm. (06/11/10) 39 ø8 A8 Series Miniature Control Units Accessories Shape Material Type No. Ordering Type No. Package Quantity Dimensions (mm) Locking Ring Wrench ø9 Metal (nickel-plated brass) MT-004 MT-004 1 • Used to tighten the locking ring when installing the A8 series control units into a panel. • Tighten the locking ring to a torque of 0.29 N·m maximum. Stainless Steel MT-101 MT-101 1 • Used to remove the lens and button. Rubber OR-66 OR-66 1 • Used to remove and install the LED lamps. AL-K8 AL-K8 1 AL-KH8 1 60 Lens Removal Tool 60 Lamp Holder Tool 70 Switch Guard For round/ square Unit 90° open For rectangular AL-KH8 unit • Used to protect pushbuttons from inadvertent operation. • See page 41 for dimensions. (remains 90° open) Socket Solder Terminal AL-C8 AL-C8 1 PC Board Terminal AL-C8V AL-C8V 1 Terminal Cover • Snaps on the rear of the A8 series control units. (see page 41 for dimensions) Nylon AL-V8 AL-V8PN10 10 • When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. • Terminal cover is not attached and must be ordered separately. Nitryl rubber (black) AL-B8 AL-B8PN05 5 • Degree of protection: IP65 Illumination color: amber LAD-SA Illumination color: green LAD-SG Illumination color: red LAD-SR Illumination color: yellow LAD-SY Mounting Hole Plug 5.3 9.0 ø4.0 Current-limiting resistor is not contained. All dimensions in mm. 40 LAD-SA 1 LAD-SAPN10 10 LAD-SG 1 LAD-SGPN10 10 LAD-SR 1 LAD-SRPN10 10 LAD-SY 1 LAD-SYPN10 10 Amber LED color: amber clear Lens color LED Lamp Green LED color: yellow diffused Red LED color: clear red White/ LED color: yellow clear Yellow (06/11/10) A8 Series Miniature Control Units ø8 Maintenance Parts Shape Marking Plate Lens Unit Type No. Package Quantity Ordering Type No. Round AL8M-W AL8M-WPN05 Square AL8Q-W AL8Q-WPN05 Rectangular AL8H-W AL8H-WPN05 Round AL8M-LK1-➁ AL8M-LK1-➁PN02 Square AL8Q-LK1-➁ AL8Q-LK1-➁PN02 Rectangular AL8H-LK1-➁ AL8H-LK1-➁PN02 Round AB8M-BK1-➀ AB8M-BK1-➀PN02 Square AB8Q-BK1-➀ AB8Q-BK1-➀PN02 Rectangular AB8H-BK1-➀ AB8H-BK1-➀PN02 5 Color Code ➀➁ • White Specify a color code in place of ➁ in the Type No. A (amber), G (green), R (red) W (white), Y (yellow) 2 Button Unit Specify a color code in place of ➀ in the Type No. B (black), G (green), R (red) S (blue), W (white), Y (yellow) Dimensions • Switch Guard For Round/Square Units (AL-K8) For Rectangular Units (AL-KH8) Panel Thickness 0.5 to 5 8.5 17.5 min. 14.5 17.5 min. 6 8.5 6 14.5 21.5 12 10 12.5 13 min. 11 min. • Socket (AL-C8, AL-C8V) Terminal 0.8 × 0.3t Terminal Arrangement (TOP) 6.3 2.5 33 6.3 2.5 33 NC 5 8.8 Solder Terminal (AL-C8) 17 3 PC Board Terminal (AL-C8V) 2.5 17 2.5 NO 5-1.0 +0.2 0 Holes Lamp Terminal (+) (PC Board Terminal Mounting Hole Layout) COM Lamp Terminal (–) (Bottom View) • Terminal Cover (AL-V8) ø9.1 17.3 Note: When wiring the terminals, insert the lead wires into the terminal cover holes before soldering. 33.5 All dimensions in mm. (06/11/10) 41 ø8 A8 Series Miniature Control Units Safety Precautions • Turn off the power to A series control units before starting installation, removal, wiring, maintenance, and inspection of the control units. Failure to turn power off may cause electrical shocks or fire hazard. • To avoid burning your hand, use the lamp holder tool when replacing lamps. • For wiring, use wires of a proper size to meet the voltage and current requirements. Failure to tighten terminal screws may cause overheating and create a fire hazard. Operating Instructions Replacement of Lens and Marking Plate Panel Mounting • Removal When mounting the control units onto a panel, use the optional locking ring wrench (MT-004) to tighten the locking ring. Do not use pliers. Tightening torque must not exceed 0.29 N·m. Excessive tightening will damage the locking ring. Remove the operator (color lens, marking plate, lens holder, and spring) by holding the color lens recesses with the Lens Removal Tool (MT-101) and pulling it out. Remove the marking plate by disengaging the latches between the color lens and lens holder. The marking plate must be engraved on the front side as shown below. Latches Color lens Engraving Area Marking Plate Spring Lens Retaining Holder Groove Spring • Note: Make sure that the spring is inserted in the correct direction. The base of spring must fit the groove in the holder. Wiring Solder the terminal at 350°C within 3 seconds using a 60W soldering iron. Sn-Ag-Cu type is recommended when using leadfree solder. When soldering, do not touch the enabling switch with the soldering iron. Also ensure that no tensile force is applied to the terminal. Do not bend the terminal or apply excessive force to the terminal. Use a non-corrosive rosin flux. Installing the Socket Install the socket on the control unit with the TOP markings on the control unit and the socket placed in the same direction. Operating Voltage of LED Lamps Installation Place the marking plate on the lens holder in the correct direction, and press the color lens onto the lens holder to engage the latches. Put the spring on the lens holder and insert the lens holder into the housing in the correct direction. • Installing Non-illuminated Button Non-illuminated pushbuttons contain a marking plate like illuminated units. Be sure to install the marking plate when replacing the button. Replacing the LED Lamp • Removal Use the lamp holder tool (OR-66) to remove lamps. Do not use pliers. • Installation Use the lamp holder tool (OR-66) to install lamps. Note the correct side of the tool for removal or installation. The operating voltage of 5V DC is measured at complete DC. When using a pulsating voltage such as a full-wave rectification voltage, keep peak currents within the forward current If. Peak currents exceeding the If may shorten the LED lamp life. Other Notes • Close Proximity Mounting When mounting pilot lights or illuminated pushbuttons collectively or lighting them continuously, heat may cause the ambient temperature to rise above the rated operating temperature. When the mounting panel is not made of metal or when the control units are mounted in an enclosed panel, provide for ventilation or lower the operating voltage. • Replacement of Buttons (Illuminated/Non-illuminated) Do not replace buttons of maintained action units while the button is in the locked position. Replacing the button in the locked position may damage the internal mechanism. Be sure to release the button before replacing. • Operating and Storage Environment Lamp Holder Tool OR-66 (ø8, ø10, ø12 series) For removing lamps For installing lamps 1. Make sure that the operating/storage temperature and humidity are within the ratings. 2. Do not use enclosed type units in an environment subject to oil, water or dust accumulation. • Microswitch Contacts Do not connect NO and NC contacts of the microswitch to different voltages or different power sources to prevent a dead short-circuit. 42 (06/11/10)
AL2M-M11PG. 价格&库存
很抱歉,暂时无法提供与“AL2M-M11PG.”相匹配的价格&库存,您可以联系我们找货
