EB3C Relay Barriers
EB3L Lamp Barriers
EB3N Safety Relay Barriers
EB3C Relay Barriers
EB3L Lamp Barriers
EB3N
Intrinsically Safe Explosion-proof System
With auxiliary
output
Power Supply
Output
Without auxiliary
output
Common
wiring
Relay output
1NO
Transistor
output
Auto
reset
Reset
Wiring condition
Separate wiring·
Common wiring
Wiring condition
Safety input
equipment need
to be installed.
AC
EB3C-∗∗AN
Relay barrier
Page 4
DC
EB3C-∗∗DN
Relay barrier
Page 4
EB3N-A2∗DN
Page 24
Manual
reset
EB3N-M2∗DN
Page 24
EB3C∗∗AN
Common
wiring
Transistor output
Source input
Sink input
Power Supply
Relay output
Input/Output
Illuminated
switch needs to
be installed.
Page 4
AC
Wiring condition
Zone 0
Zone 1
Zone 2
Relay barrier
Lamp barrier
In an hazardous area....
Contacts
need to be
installed.
Safety relay barrier
Zone 0
Zone 1
Zone 2
Relay barrier
In order to establish an intrinsically safe explosion-proof system, a barrier must be selected depending on the type of
device (such as) pushbutton, pilot light, and proximity switch that are installed in the hazardous area. See the selection
chart below.
EB3L∗∗AN
Page 12
EB3C∗∗DN
DC
Page 4
EB3L∗∗DN
2
Common
wiring
LED pilot light
Buzzer (note)
Power Supply
Separate wiring·
Common wiring
Pilot Light
Buzzer
needs to be
installed.
Wiring condition
Pilot light
needs to be
installed.
Lamp barrier
Page 12
AC
EB3L-S∗AN
DC
EB3L-S∗DN
Lamp barrier
Page 12
Lamp barrier
Page 12
Relay Barrier / Lamp Barrier Selection
Relay Barrier
EB3C-**AN
Model
EB3C-**DN
EB3N-**D
Shape
Explosion Protection
FM: Class I, II, III Div1 / Group A, B, C, D, E, F, G
Class I, Zone 0 / AEx [ia] II C
UL:
PTB (ATEX, IECEx): [Exia] II C, Exia] III C
CQST: [Exia Ga] II C
TIIS: [Exia] II C
KCS: [Exia] II C
NK: [Exia] II C
KR:
[Exia] II C
Relay Barrier: [Exia] II C
Degree of Protection
IP20
IP20
IP20
No. of Channels
1, 2, 3, 5, 6, 8, 10, 16
EB3N-£2ND: 2 safety circuits
EB3N-£2R5D: 2 safety circuits,
5 auxiliary circuits
Power Voltage
100 to 240V AC
24V DC
24V DC
Output
Relay
Transistor
(Sink/Source)
Relay
Transistor
(Sink/Source)
Relay
Connection
Screw Terminal
Screw Terminal, Connector
Screw Terminal
Mounting
35-mm-wide DIN rail
Panel mounting
35-mm-wide DIN rail
Panel mounting
35-mm-wide DIN rail / Panel mounting
Size
(excluding projections)
42W×75H×77.5D (1 channel)
65W×75H×77.5D (2, 3 channels)
110.5W×75H×77.5D (5, 6, 8 channels (common))
171.5W×75H×77.5D (8, 10, 16 channels (common))
65.0W×75.0H×77.5D
(EB3N-£2ND)
110.5W×75.0H×77.5D
(EB3N-£2R5D)
Weight (approx.)
0.38kg (EB3C-R10AN)
0.39kg (EB3C-R16CDN)
220g (EB3N-£2ND)
300g (EB3N-£2R5D)
4
Page
24
Lamp Barrier
EB3L-**AN
Model
EB3L-**DN
Shape
UL:
Class I, Zone 0 / [AEx ia] II C
TIIS: [Exia] II C
KCS: [Exia] II C
NK: [Exia] II C
KR:
[Exia] II C
IP20
IP20
No. of Channels
Power Voltage
100 to 240V AC
24V DC
Input/Output
Transistor input (sink)
Transistor input (source)
Connection
Screw Terminal
Mounting
35-mm-wide DIN rail
Panel mounting
35-mm-wide DIN rail
Panel mounting
Size
171.5W×75H×77.5D (8, 10 channels)
65W×75H×77.5D (1 channel)
Weight (approx.)
0.36kg (EB3L-S10SAN)
Page
0.36kg (EB3L-S16CSDN)
12
3
EB3C Relay Barriers
Input contacts can be used in any explosive gas and Zone 0/Class I Div. 1 areas.
Explosion
protection
Relay Barrier:
[Exia] II C
Switch (EB9Z-A): Exia II CT6
Switch (EB9Z-A1): Exia II BT6
••IEC60079 compliant.
••Wide variety of models ranging from 1-circuit to 16 circuit
models.
••8- and 16-channel are available in common wiring, ideal for
connection to PLCs. 16-circuit also available with a connector.
••No grounding required.
••IDEC’s original spring-up terminal minimizes wiring time.
••35-mm-wide DIN rail mounting or direct screw mounting.
••Global usage
IECEx
USA: FM, UL
Europe: CE marking, ATEX
China: CQST
Korea: KCS
Taiwan TS
Japan: TIIS
••Ship class: NK (Japan), KR (Korea)
Connector Model
Relay Barriers
Power
Voltage
Connection to
Non-intrinsically
Safe Circuit
Input Wiring Method
Number of
Channels
Output
Separate/Common
Wiring Compatible
Relay
Common Wiring Only
100 to 240V AC
Separate/Common
Wiring Compatible
Transistor (Sink/Source)
Transistor (Sink)
Common Wiring Only
Transistor (Source)
Screw Terminal
Separate/Common
Wiring Compatible
Relay
Common Wiring Only
24V DC
Separate/Common
Wiring Compatible
Sink
Common Wiring Only
Connector
4
Transistor
Source
Sink
Source
1
2
3
5
6
8
10
8
1
2
3
5
6
8
10
8
16
8
16
1
2
3
5
6
8
10
8
16
1
2
3
5
6
8
10
8
16
8
16
16
Part No.
EB3C-R01AN
EB3C-R02AN
EB3C-R03AN
EB3C-R05AN
EB3C-R06AN
EB3C-R08AN
EB3C-R10AN
EB3C-R08CAN
EB3C-T01AN
EB3C-T02AN
EB3C-T03AN
EB3C-T05AN
EB3C-T06AN
EB3C-T08AN
EB3C-T10AN
EB3C-T08CKAN
EB3C-T16CKAN
EB3C-T08CSAN
EB3C-T16CSAN
EB3C-R01DN
EB3C-R02DN
EB3C-R03DN
EB3C-R05DN
EB3C-R06DN
EB3C-R08DN
EB3C-R10DN
EB3C-R08CDN
EB3C-R16CDN
EB3C-T01DN
EB3C-T02DN
EB3C-T03DN
EB3C-T05DN
EB3C-T06DN
EB3C-T08DN
EB3C-T10DN
EB3C-T08CKDN
EB3C-T16CKDN
EB3C-T08CSDN
EB3C-T16CSDN
EB3C-T16CKD-CN
EB3C-T16CSD-CN
Weight (g)
150
180
190
260
270
300
380
280
140
170
180
250
260
320
340
260
260
260
260
130
170
180
250
260
260
360
270
390
120
160
170
240
250
250
320
250
350
250
350
330
330
EB3C Relay Barriers
Accessories
Name
Part No.
BAA1000
BAP1000
BNL6
EB9Z-N1
DIN Rail
End Clip
Static Electricity Caution Plate
Ordering No.
BAA1000PN10
BAP1000PN10
BNL6PN10
EB9Z-N1PN10
Explosion-Protection and Electrical
Specifications
Intrinsic safety type
IP20 (IEC60529)
Safe indoor place
(safe area: non-hazardous area)
For zone 0, 1, 2 hazardous areas
Installation Location
Relay Barrier
Switch
Non-intrinsically Safe Circuit
Maximum Voltage (Um)
Intrinsically Safe Circuits
227.2 mA
750 mW
Allowable Wiring Resistance (Rw)
300Ω
600/(N+1)Ω
(N = number of
common
channels)
16
Relay Output
Contact Resistance
50 mΩ maximum (initial value)
Turn ON Time
Turn OFF Time
12 ms maximum (rated voltage)
10 ms maximum (rated voltage)
20,000,000 operations minimum
(at 18,000 operations/hour, without
load)
100,000 operations minimum
(at 1,800 operations/hour, rated load)
None
24V DC
30V DC
100 mA (connector model: 15 mA)
0.1 mA maximum
1.5 V maximum
33V (1W)
0.5A maximum (1 sec)
0.1 ms maximum (resistive load)
0.4 ms (typical) (resistive load)
None
Inductive Load
Mechanical Life
Electrical Life
Transistor Output
0.6 mH (0.425 mH)
Minimum Applicable Load
Resistive Load
Short-circuit Protection
Rated Voltage
Maximum Voltage
Maximum Current
Leakage Current
Voltage Drop
Clamping Voltage
Inrush Current
Turn ON Time
Turn OFF Time
FM
UL
PTB (ATEX)
CQST
KCS
TIIS
490 nF (365 nF)
1NO
250V AC, 125V DC
3A (common terminal: 8A)
AC: 750 VA, DC: 72W
AC: 750 VA (cos ø = 0.3 to 0.4)
DC: 48W (L/R = 7 ms)
250V AC 3A, 24V DC 3A
250V AC 3A (cos ø = 0.3 to 0.4)
24V DC 2A (L/R = 7 ms)
0.1V DC, 0.1 mA (reference value)
Rated
Load
Certification
Organization
PTB (IECEx)
Rated Operating Voltage
Rated Operating Current
Maximum Output Voltage (Uo)
Maximum Output Current (lo)
Maximum Output Power (Po)
Maximum External
470 nF (470 nF)
Capacitance (Co)
(Note 1)
Maximum External Inductance (Lo) 87.5 mH (87.5
(Note 2) mH)
Maximum Channels per
Common Line
Contact Configuration
Rated Insulation Voltage (Ui)
Thermal Current (lth)
Resistive Load
Contact
Allowable
Inductive Load
Power
Non-intrinsically Safe Circuits
16-channel
Common Wiring
Description
Aluminum (1m long)
Steel (1m long)
For fastening EB3C units on the DIN rail.
Polyester 20 (W) x 6 (H) mm
Certification No.
250V AC
1-channel
Separate Wiring
12V DC ±10%
10 mA DC ±20%
13.2V DC
14.2 mA
46.9 mW
Wiring Method
Package Quantity
10
10
10
10
NK
KR
Class I, II, III Div. 1
Class I, Zone 0 AEx [ia] II C
Class I, II, III, Div. 1
[Exia] II C: Gas, Vapour
[Exia] III C: Dust
[Exia] III C: Dust
[Exia Ga] II C
[Exia] II C
Relay barrier:
[Exia] II C
[Exia] II C
[Exia] II C
Certification No.
3047250
E234997
PTB09 ATEX2046
IECEx PTB10.0015
CNEx14.0047
14-AV4B0-0373
TC20539
TC15758
TC15961
Type Test No. 13T606
TYK17821-EL003
Note: For details about switches, see “Switch Explosion-Protection
Specifications” on page 6 and “3. Switches in the Hazardous Area”
on page 10.
General Specifications
Power Voltage
Rated Power Voltage
Allowable Voltage
Range
AC Power
100 to 240V AC
24V DC
DC Power
–15 to +10%
±10%
50/60 Hz (allowable range:
47 to 63 Hz)
10A (100V AC)
Inrush Current
10A
20A (200V AC)
Between intrinsically safe circuit and non-intrinsically
safe circuit: 1526.4V AC
Dielectric Strength
Between AC power and output terminal: 1500V AC
(1 minute, 1 mA)
Between DC power and transistor output terminal:
1000V AC (screw terminal model only)
Operating Temperature –20 to +60°C (no freezing)
Storage Temperature
Operating Humidity
45 to 85% RH (no condensation)
Atmosphere
800 to 1100 hPa
Pollution Degree
2 (IEC60664)
10 MΩ minimum (500V DC megger, between the same
Insulation Resistance
poles as the dielectric strength)
Panel mounting: 10 to 55 Hz, amplitude 0.75 mm
Vibration Resistance
(damage limits)
DIN rail mounting: 10 to 55 Hz, amplitude 0.35 mm
Panel mounting: 500 m/s2 (3 times each on X, Y, Z)
Shock Resistance
(damage limits)
DIN rail mounting: 300 m/s2 (3 times each on X, Y, Z)
Terminal Style
M3 screw terminal
Mounting
35-mm-wide DIN rail or panel mounting (M4 screw)
Power Consumption
9.6 VA (EB3C-R10AN at 200V AC)
(approx.)
4.8W (EB3C-R16CDN at 24V DC)
Rated Frequency
Note: Values in ( ) are those approved by TIIS (Technology Institution of
Industrial Safety, Japan).
5
EB3C Relay Barriers
Switch Explosion-Protection Specifications (Japan only)
Simple apparatuses in accordance with relevant standards of each country can be installed in the hazardous area and connected to the
EB3C located in the safe area. In Japan, any switches, though regarded as simple apparatuses, must be certified for explosion-proof
devices. EB9Z-A and EB9Z-A1 are IDEC’s generic Part No. of any single apparatuses certified by TIIS for use with the EB3C, therefore
simple apparatuses with specifications shown below can be used as those approved by the Japanese explosion-proof certification.
Switch Part No.
Explosion Proof (Note 1)
Operating Humidity
Dielectric Strength
EB9Z-A
EB9Z-A1
Exia II CT6
Exia II BT6
IP20
500V AC, 1 mA
16-channel Common Wiring
1-channel Separate Wiring
Maximum input voltage (Ui): 13.2V
Maximum input current (Ii): 227.2 mA
Maximum input current (Ii): 14.2 mA
Maximum input power (Pi): 750 mW
Maximum input power (Pi): 46.9 mW
Internal capacitance (Ci): ≤ 32 nF
Internal capacitance (Ci): ≤ 2 nF
Internal inductance (Li):
≤ 80 µH
≤ 5 µH
Metallic: Magnesium content must be 7.5% or less (steel and aluminum are acceptable)
Intrinsic Safety Ratings and
Parameters
Caution
Plastic: Switch operator exposed area
IIC: 20 cm2 maximum
IIB: 100 cm2 maximum
When the switch has a wider exposed area, attach a
caution label as shown at right.
Enclosure Material
To prevent electrostatic
charges, do not rub the
switch surface during
operation. Use a soft
cloth dipped with water
for cleaning.
Caution Label Example
Contact rating:
Ui, Ii minimum
Contact resistance:
0.5Ω maximum
Cross sectional area of wire: 0.000962 mm2 minimum
Printed circuit board:
Thickness 0.5 mm minimum
Copper foil width 0.15 mm minimum
Thickness 18 µm minimum one/both side(s)
A resistor to prevent contact welding and an LED can be connected to 1-channel separate wiring circuits.
Consult IDEC for details.
Switch Ratings (Note 2)
Note 1: See “Precautions for Operation” on page 10.
Note 2: For details, see “3. Switches in the Hazardous Area” on page 10.
Internal Circuit Block Diagram
AC Power, Relay Output
DC Power, Transistor Output
Connector Wiring, Sink Output
Hazardous Area
P1 N1 P2 N2 P3 N3
P1 N1 P2 N2 P3 N3
Yellow
Green
Yellow
Yellow
Green
Yellow
Yellow
Green
L
Yellow
P1 • • • • P16 N1
N A1 C1 A2 C2 A3 C3
Yellow
N2
Safe Area
(Non-hazardous Area)
Yellow
A1 C1 A2 C2 A3 C3
A1 • • • • A16 C1 C2
Dimensions
Connector Model
EB3C-T16C-CN
M3
ø6
Applicable Crimping Terminal
Solid Wire
97
Mounting Hole Layout
6 to 8 mm
65
(4)
77.5
97
10
5.4 min.
Stripping the Wire End
4-M4
or
4-4.5 holes
6
6
3 max.
83.5
10
ø3.2 min.
6 max.
75
4- 4.5 hole
65
171.5
Stranded Wire (Ferrule)
6 to 8 mm
All dimensions in mm.
EB3C Relay Barriers
EB3C-∗03N
EB3C-∗02N
110.5
77.5
171.5
65
65
EB3C-∗10N
EB3C-∗08N
EB3C-∗16CN
61
75
42
EB3C-∗06N
EB3C-∗05N
EB3C-∗08CN
ø4.4
Screw Terminal
EB3C-∗01N
4
6
77.5
(4)
M3
ø6 hole
10
10
10
10
10
2-M4 tapped or
2-ø4.5 mounting holes
28
2-M4 tapped or
4-M4 tapped or
4-ø4.5 mounting holes
97
97
51
65
2-M4 tapped or
65
Mounting Hole Layout (Screw Mounting)
External Wiring Examples
Transistor Output
(Ex.: EB3C-T06AN)
Transistor Sink Output
(Ex.: EB3C-T08CKDN)
Transistor Source Output
(Ex.: EB3C-T08CSDN)
P1 N1 P2 N2 P3 N3 P4 N4 P5 N5 P6 N6
P4
P5
P6
P7
P8
N1
N2
P9 P10 P11 P12 P13 P14 P15 P16 N3
N4
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
A9 A10 A11 A12 A13 A14 A15 A16 C3
C4
Load
P3
Load
P2
Load
Load
P1
24V DC
Load
Load
A1 A2 A3 A4 A5 A6 A7 A8 C1 C2
Load
Load Power
24V DC
Load
Load
Load
Load
Load
24V DC
Load
Load
Power
24V DC
Load
Load
Load
Load
Load
Load
100 to
240V AC
A1 C1 A2 C2 A3 C3 A4 C4 A5 C5 A6 C6
Load
N
Load
L
P1 P2 P3 P4 P5 P6 P7 P8 N1 N2
Load
Load Power
24V DC
Note: On the sink/source transistor output model,
terminals A can be used as a positive
common line.
Relay Output
(Ex.: EB3C-R06AN)
Relay Output Common Wiring
(Ex.: EB3C-R16CDN)
Load
Load
Load
Load
Load
Load
Load
Load
Load
Load
Load
24V DC
Load
Load
Load
Load
Load
Load
Load
100 to
240V AC
Load
Load
Power
AC/DC
Load
Load
N
Load
L
Load
Power
AC/DC
7
EB3C Relay Barriers
Connector Model Output Wiring Diagram
EB3C-T16CKD-CN (Sink)
Wiring Example with IDEC’s MicroSmart PLC Input Modules
CH9 CH10 CH11 CH12 CH13 CH14 CH15 CH16
A9 A10 A11 A12 A13 A14 A15 A16 NC NC
CHn
19
1
A8
C1
C2
CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8
+V
COM
A1
A2
A3
A4
A5
A6
A7
EB3C
COM
PLC
COM
Internal Circuit
Internal Circuit
+V (C1)
An
A1-A16
Input
I0-I15
COM (C2)
EB3C-T16CSD-CN (Source)
19
1
A8
C1
C2
–V
COM
A1
A2
A3
A4
A5
A6
A7
EB3C
CHn
An
COM
PLC
EB3C-T16CSD-CN
FC4A-N16B3
Input
Terminal
Terminal Output
Input
Terminal
A1
I0
A1
I0
A9
I10
19
19
A9
I10
19
18
A2
I1
18
18
A2
I1
18
17
A10
I11
17
17
A10
I11
17
16
A3
I2
16
16
A3
I2
16
15
A11
I12
15
15
A11
I12
15
14
A4
I3
14
14
A4
I3
14
13
A12
I13
13
13
A12
I13
13
12
A5
I4
12
12
A5
I4
12
11
A13
I14
11
11
A13
I14
11
10
A6
I5
10
10
A6
I5
10
9
A14
I15
9
9
A14
I15
9
8
A7
I6
8
8
A7
I6
8
7
A15
I16
7
7
A15
I16
7
6
A8
I7
6
6
A8
I7
6
5
A16
I17
5
5
A16
I17
5
4
+V
COM
4
4
–V
COM
4
3
NC
COM
3
3
NC
COM
3
2
COM
NC
2
2
COM
NC
2
1
NC
NC
1
1
NC
NC
1
Input
I0-I15
Internal Circuit
Internal Circuit
A1-A16
FC4A-N16B3
Note: The wiring in dashed line does not affect the operation of the EB3C.
Applicable connector is IDEC’s JE1S-201.
Input power for PLC inputs is supplied by the EB3C, therefore the PLC
input does not need an external power supply.
COM (C2)
EB3C-T16CKD-CN
Terminal Output
COM
Wiring Example of Intrinsically Safe External Inputs
1. Common Wiring (Maximum 16 circuits)
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
A1
C1
A2
C2
A3
C3
A4
C4
A5
C5
A6
C6
N
N
N
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P1
N1
P2
N2
P3
N3
L
N
A1
C1
A2
C2
A3
C3
N
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
P1
N1
N2
L
N
A1
C1
C2
N
L
N
A1
P1
C1
N1
A2
P2
C2
N2
A3
P3
C3
N3
A4
P4
C4
N4
A5
P5
C5
N5
A6
P6
C6
N6
A7
P7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
A9
A10
A11
A12
A13
A14
A15
A16
C3
C4
All input lines are wired to a common line inside the intrinsically safe switch (one common line per intrinsically safe circuit).
N
N
N
N
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
A1
C1
A2
C2
A3
C3
A4
C4
A5
C5
A6
C6
N
L
N
A1
P1
C1
N1
A2
P2
C2
N2
A3
P3
C3
N3
A4
P4
C4
N4
A5
P5
C5
N5
A6
P6
C6
N6
A7
P7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
P1
N1
P2
N2
P3
N3
P1
N1
N2
L
N
A1
C1
C2
N
L
N
A1
C1
A2
C2
A3
C3
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
A9
A10
A11
A12
A13
A14
A15
A16
C3
C4
Some input lines are wired to a common line inside the intrinsically safe switches, while others are outside switches
N
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
A1
C1
A2
C2
A3
C3
A4
C4
A5
C5
A6
C6
N
2. Separate Wiring
8
Each input line of the EB3C makes up one independent intrinsically safe circuit.
N
N
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P1
N1
P2
N2
P3
N3
L
N
A1
C1
A2
C2
A3
C3
N
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
P1
N1
N2
L
N
A1
C1
C2
N
L
N
A1
P1
C1
N1
A2
P2
C2
N2
A3
P3
C3
N3
A4
P4
C4
N4
A5
P5
C5
N5
A6
P6
C6
N6
A7
P7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
A9
A10
A11
A12
A13
A14
A15
A16
C3
C4
All input lines are wired to a common line outside the intrinsically safe switch (one common line per intrinsically safe circuit).
N
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
A1
C1
A2
C2
A3
C3
A4
C4
A5
C5
A6
C6
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P1
N1
P2
N2
P3
N3
L
N
A1
C1
A2
C2
A3
C3
EB3C Relay Barriers
N
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
P1
N1
N2
L
N
A1
C1
C2
N
N
L
N
A1
P1
C1
N1
A2
P2
C2
N2
A3
P3
C3
N3
A4
P4
C4
N4
A5
P5
C5
N5
A6
P6
C6
N6
A7
P7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
L
N
A1
A2
A3
A4
A5
A6
A7
A8
C1
C2
A9
A10
A11
A12
A13
A14
A15
A16
C3
C4
N
N
N
2. Separate Wiring
P1
N1
P2
N2
P3
N3
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
A1
C1
A2
C2
A3
C3
L
N
A1
C1
A2
C2
A3
C3
A4
C4
A5
C5
A6
C6
N
L
N
A1
P1
C1
N1
A2
P2
C2
N2
A3
P3
C3
N3
A4
P4
C4
N4
A5
P5
C5
N5
A6
P6
C6
N6
A7
P7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
P1
N1
N2
L
N
A1
C1
C2
N
N
Diagram Symbols
N
Serial-Parallel Connection of Switches
Contacts in one switch
(EB9Z-A or EB9Z-A1)
Notes
• As shown in the diagram on the left, a required number of “contacts
in one switch” (3 contacts in the example at left) can be added to the
“contacts in one switch” connected to one input channel.
• Similarly, a required number of “contacts in one switch” can be added
to a common line connected to multiple input channels.
• The capacitance and inductance of the added “contacts in one
switch” must be included in the calculation of the wiring capacitance
and inductance in “Precautions for Operation, 5. Wiring for Intrinsic
Safety, (7)” on page 11.
• In addition, a required number of contacts can be added in the
enclosure of “contacts in one switch.” In this case, however, do not
include the capacitance and inductance in the calculation of the
wiring capacitance and inductance on page 11. Instead, make sure
that the internal capacitance (Ci) and internal inductance (Li) are
within the values shown in the table “Switch Explosion-Protection
Specifications (Japan only)” on page 6.
L
N
A1
C1
C2
P1
N1
N2
One intrinsically safe circuit
(maximum 16 circuits)
Recommended Connector Cable for Connector Models
Description
No. of Poles
With Shield
I/O
Terminal
Cable
Without Shield
Cable with Crimping Terminal
Length (m)
Part No.
0.5
FC9Z-H050A20
1
FC9Z-H100A20
2
FC9Z-H200A20
3
FC9Z-H300A20
0.5
FC9Z-H050B20
1
FC9Z-H100B20
2
FC9Z-H200B20
3
FC9Z-H300B20
1
BX9Z-H100E4
2
BX9Z-H200E4
shape
Applicable Model
IDEC MicroSmart
I/O Module
IDEC MicroSmart
I/O Module
200
Screw Terminal
2
1
40-pin Cable for PLC
FC9Z-HA, FC9Z-HB
Internal Connection
Fujitsu Connector
IDEC Connector
FCN-367J024-AU/F
JE1S-201
19
17
15
16
13
14
11
12
9
10
7
8
5
6
3
4
1
2
(Connecting Side)
IDEC Connector
IDEC
Connector
JE1S-20111
JE1S-201
19
18
15
16
13
14
3
BX9Z-H300E4
1
BX9Z-H100L
2
BX9Z-H200L
3
BX9Z-H300L
IDEC Connector
JE1S-201
IDEC Connector
JE1S-201
1
2
3
4
5
6
7
8
9
10
12
11 12
9
10
13 14
7
8
15 16
5
6
17 18
3
4
2
(Connecting Side)
19 20
Connector A
Mitsubishi A Series
Input Module
(positive common)
EB3C-T16CKD-CN
BX9Z-HL Internal Connection
Fujitsu Connector
FCN-367J040-AU/F
B A
Y-shaped Compresion
Terminal
Y-shaped
Compresion
(Marking
Tube No.)Terminal
1
1
2
2
3
3
2
4
4
4
5
5
6
6
6
7
7
8
8
9
9
(Marking Tube No.)
1
3
5
7
9
11
13
15
17
19
8
10
12
Connector A
IDEC
JE1S-201
14
2
1
16
4
3
18
6
5
7
10 9
(Connecting Side)
Connector B
10
BX9Z E4
Internal Connection
11
1
350
12 11
14 13
16 15
18 17
20 19
(Connecting Side)
Connector B
IDEC
JE1S-201
10 10
11 11
2
1
12 12
4
3
13 13
6
5
14 14
8
7
15 15
10 9
16 16
12 11
17 17
14 13
18 18
16 15
19 19
18 17
20 20
20 19
(Connecting Side)
(Connecting Side)
9
EB3C Relay Barriers
1. Installation of EB3C Relay Barriers
(1) The EB3C can be installed in any direction.
(For Japan application only)
(2) Install the EB3C relay barrier in a safe area (non-hazardous
area) in accordance with intrinsic safety ratings and param
eters. To avoid mechanical shocks, install the EB3C in an
enclosure which suppresses shocks.
(1) A switch contains the switch contact, enclosure, and
internal wiring. A switch contact refers to an ordinary
switching device which consists of contacts only, such as a
pushbutton switch. See below.
(3) When installing or wiring the EB3C, prevent
electromagnetic and electrostatic inductions in the
intrinsically safe circuit. Also prevent the intrinsically safe
circuits from contacting with another intrinsically safe circuit
and any other circuits.
Maintain at least 50 mm clearance, or provide a metallic
separating board between the intrinsically safe circuit and
non-intrinsically safety circuit. When providing a metallic
separating board, make sure that the board fits closely
to the enclosure (top, bottom, and both sides). Allowable
clearance between the enclosure and board is 1.5 mm at
the maximum.
The clearance of 50 mm between the intrinsically safe cir
cuit and non-intrinsically safe circuit may not be sufficient
when a motor circuit or high-voltage circuit is installed
nearby. In this case, provide a wider clearance between
the circuits referring to 5 (3) “Minimum Parallel Distance
between the Intrinsically Safe Circuit and Other Circuits.”
(4) In order to prevent contact between intrinsically safe
circuits and non-intrinsically safe circuits, mount EB3C
units with terminals arranged in the same direction.
EB3C
EB3C
EB3C
Control
Switches
Sensing
Switches
Push-pull Switches
Pushbutton, Foot, Trigger, Rocker, Grip
Twisting Switches
Rotary, Selector, Cam, Drum, Thumb
wheel
Lever and Slide
Switches
Toggle, Multidirectional, Wobble stick,
Lever, Slide switch
Displacement
Switches
Microswitch, Limit, Magnetic proximity,
Door, Reed, Mercury
Level Switches
Liquid level
Others
Pressure, Temperature
Note: For installation in hazardous areas and connection to the EB3C, use
switches which are certified, approved, or considered to be simple
apparatus in relevant standards in each country.
(2) When the switch has internal wiring or lead wire, make sure
that the values of internal inductance (Li) and capacitance
(Ci) are within the certified values.
(3) Enclose the switch contact’s bare live part in an enclosure
of IP20 or higher protection.
(4) Depending on the explosion-protection specifications
according to TIIS, the exposed area of plastic switch opera
tor is limited as follows:
• Exia II CT6 (EB9Z-A): 20 cm2 maximum
• Exia II BT6 (EB9Z-A1): 100 cm2 maximum
(5) Attach the certification mark supplied with the EB3C on the
EB9Z-A or EB9Z-A1 switch (for Japan application).
(6) When the switch operator of plastic enclosure has a wider
exposed area than the following limits, attach a caution
label as shown below.
Caution
EB3C
Non-intrinsically
Safe Circuit
Applicable Switches
EB3C
(5) Maintain at least 6 mm (or 3 mm according to IEC60079-11:
1999) clearance between the terminal of intrinsically safe
circuit and the grounded metal part of a metal enclosure,
and between the relay terminal block of an intrinsically safe
circuit and the grounded metal part of a metal enclosure.
(6) For installing the EB3C, mount on a 35-mm-wide DIN rail
or directly on a panel using screws. Make sure to install
securely to withstand vibration. When mounting on a DIN
rail, push in the clamp completely. Use the BNL6 end
clips on both sides of the EB3C to prevent from moving
sideways.
(7) Excessive extraneous noise may cause malfunction and
damage to the EB3C. When extraneous noise activates the
voltage limiting circuit (thyristor), remove the noise source
and restore the power.
(7) For the 1-circuit separate wiring, a resistor to prevent reed
switch contact welding and an LED miniature pilot lights
can be connected in series with the contact. See below.
Use the terminal screw of M3 or larger.
Applicable Resistor Ratings
Resistance
100Ω maximum
Rated Wattage
0.5 to 3W
Model
Metal (oxide) film resistors
R
2. Terminal Wiring
Reed Switch
(1) Using a ø5.5 mm or smaller screw driver, tighten the termi
nal screws (including unused terminal screws) to a torque
of 0.6 to 1.0 N·m (recommended value).
Terminal Block
(2) Make sure that IP20 is achieved when wiring. Use
insulation tubes on bare crimping terminals.
(3) To prevent disengaged wires from contacting with other
intrinsically safe circuits, bind together the wires of one
(4) When the adjacent terminal is connected to another intrinsi
cally safe circuit, provide an insulation distance of at least 6
mm.
10
charges, do not rub the switch
surface during operation.
Use a soft cloth dipped with
water for cleaning.
II C: 20 cm2 maximum
II B: 100 cm2 maximum
EB3C
Applicable LED
IDEC’s IPL1 series LED miniature pilot lights. See pages 14
and 17.
EB3C Relay Barriers
4. Output Specifications
(1) When wiring the output from the EB3C, connect the nonintrinsically safe circuit to terminals A and C. The EB3C
output circuit is not equipped with short-circuit protection.
If required, provide a protection in the external circuit.
(2) Relay Output
Some types of loads generate reverse emf (such as sole
noids) or cause a large inrush current (incandescent
lamps), resulting in a shorter operation life of output relay
contacts. The operation life of contacts can be extended by
preventing the reverse emf using a diode, RC, or varistor, or
by suppressing the inrush current using a resistor or RL.
Contacts are made of gold-clad silver. When using at a
small current and a low voltage (reference value: 0.1 mA,
0.1V), test the contact on the actual circuit in advance.
(3) Transistor Output
When connecting a small load, the load may not turn off
because of a leakage current, even though the transistor
output is turned off. If this is the case, connect a resistor in
parallel with the load to bypass the leakage current.
When an excessively high voltage (clamps at 33V, 1W) or
a reverse voltage is applied to the output terminals, the
clamping circuit or output transistor may be damaged.
When driving an inductive load, be sure to connect a diode
across the load to absorb reverse emf.
Load
An
Cn
∗: Surge Absorber
Example of Overvoltage Absorption Circuit
(4) In the common wiring only models, the output terminals are
not isolated from each other.
(5) When connecting the connector model EB3C’s in parallel,
use one power supply to power the EB3C’s. Do not
connect any wiring to the C1 and C2 terminals.
5. Wiring for Intrinsic Safety
(1) The voltage applied on the general circuit connected to
the non-intrinsically safe circuit terminals of the EB3C relay
barrier must be 250V AC, 50/60Hz, or 250V DC at the maxi
mum under any conditions, including the voltage of the
input power and the internal circuit.
(2) When wiring, take into consideration the prevention of
electromagnetic and electrostatic charges on intrinsically
safe circuits. Also, prevent intrinsically safe circuits from
contacting with other circuits.
(3) The intrinsically safe circuits must be separated from nonintrinsically safe circuits. Contain intrinsically safe circuits
in a metallic tube or duct, or separate the intrinsically safe
circuits referring to the table below.
Note: Cables with a magnetic shield, such as a metallic sheath,
prevent electromagnetic induction and electrostatic induction,
however, a non-magnetic shield prevents electrostatic induction
only. For non-magnetic shields, take a preventive measure
against electromagnetic induction.
Voltage and Current of
Other Circuits
Over 440V
440V or less
220V or less
110V or less
60V or less
Over
100A
2000
2000
2000
2000
2000
100A or
less
2000
600
600
600
500
50A or
less
2000
600
600
500
300
10A or
less
2000
600
500
300
150
(4) When identifying intrinsically safe circuits by color, use light
blue terminal blocks and cables.
(5) When using two or more EB3C’s to set up one intrinsically
safe circuit in the common wiring configuration,
interconnect two neutral terminals (N1 through N10) on
each EB3C between adjacent EB3C’s in parallel.
(6) Make sure that the power of the EB3C and contact are
turned off before starting inspection or replacement.
(7) When wiring the intrinsically safe circuit, determine the dis
tance to satisfy the wiring parameters shown below. Note
that parameters are different between separate wiring and
common wiring.
a) Wiring capacitance Cw ≤ Co – (Ci + N × 2 nF)
Co: Maximum external capacitance of the EB3C
Ci: Internal capacitance of the switch
N: The number of switches connected in series or
parallel (the number is infinite)
b) Wiring inductance Lw ≤ Lo – (Li + N × 5 µH)
Lo: Maximum external inductance of the EB3C
Li: Internal inductance of the switch
c) Wiring resistance ≤ Rw
Rw: Allowable wiring resistance
d) Allowable wiring distance D (km) is the smallest value of
those calculated from the capacitance, inductance, and
resistance.
D ≤ Cw/C C (nF/km): Capacitance of cable per km
D ≤ Lw/L L (mH/km): Inductance of cable per km
D ≤ Rw/2R R (Ω/km): Resistance of cable per km
Note: For the details of wiring the intrinsically safe circuits, refer to a
relevant test guideline for explosion-proof electric equipment in
each country.
(8) Applicable Wire Size
0.5 to 2.0 mm2 (AWG20 to AWG14): two wires
However, one wire for 2.0 mm2 (AWG14)
Mounting Bracket
The following mounting brackets can be used to install the EB3C
relay barriers and EB3L lamp barriers on the mounting holes of IBRC
contact signal transducer, IBPL pilot relay barrier, and IBZ buzzer.
No. of Channels
Part No.
1
2
3
5
6
10
EB9Z-K01
EB9Z-K02
EB9Z-K03
EB9Z-K05
EB9Z-K06
EB9Z-K10
Dimensions
C
B
A
Finely twisted pair cables prevent electromagnetic induc
tion. Adding shields to the twisted pair cables provides pro
tection against electrostatic induction.
Dimension (mm)
A
B
C
28.0
44.0
61.0
51.0
59.5
76.0
51.0
75.0
91.5
97.0
105.0
122.0
97.0
120.0
137.0
97.0
181.0
198.0
ø5 (four)
7
M4
(two or four)
140
126
90
65
Minimum Parallel Distance between the Intrinsically
Safe Circuit and Other Circuits (mm)
∗: EB9Z-K10 only
11
EB3L Lamp Barriers
126 types of pilot lights and buzzers can be connected and used in Zone 0 areas.
Illuminated pushbuttons and illuminated selector switches can be connected
by combining with the EB3C relay barrier.
Explosion protection
Lamp Barrier
[Exia] II C
Pilot Light (separate wiring)
Exia II CT6
Pilot Light (common wiring)
Exia II CT4
Illuminated Pushbutton
Exia II CT4
Illuminated Selector Switch
Exia II CT4
Exib II CT6
Buzzer (separate wiring)*
••Universal AC power voltage (100 to 240V AC)
••Installation
••ø6, ø8, ø10, ø22 and ø30 pilot lights available.
••Illuminated pushbuttons and illuminated selector switches
can be connected by combining with the EB3C relay barrier.
Illumination colors: Amber, blue, green, red, white, and yellow (pushlock turn reset: red only)
Connector Model
••Buzzers are available in intermittent and continuous sounds.
ø30 mounting hole.
••Global usage
IECEx
USA: FM, UL
* Buzzers are certified by TIIS only. Other ex-proof
certifications pending.
* Buzzers cannot be used in Zone 0 areas.
China: CQST
Korea: KCS
Taiwan: TS
Japan: TIIS
12
EB3L Lamp Barriers
Lamp Barriers
Power Voltage
Connection to
Non-intrinsically
Safe Circuit
Input
Source
100 to 240V AC
Input Wiring Method
(Note)
Number of
Channels
Separate/Common
Wiring Compatible
Common Wiring Only
Screw Terminal
Sink
Screw Terminal
24V DC
Sink
Connector
Source
Sink
Common Wiring Only
180
3
EB3L-S03SAN
190
5
EB3L-S05SAN
250
6
EB3L-S06SAN
260
8
EB3L-S08SAN
330
10
EB3L-S10SAN
360
EB3L-S08CSAN
260
EB3L-S01KAN
150
2
EB3L-S02KAN
180
3
EB3L-S03KAN
190
5
EB3L-S05KAN
250
6
EB3L-S06KAN
260
8
EB3L-S08KAN
330
10
EB3L-S10KAN
360
260
EB3L-S01SDN
130
2
EB3L-S02SDN
160
3
EB3L-S03SDN
170
5
EB3L-S05SDN
240
6
EB3L-S06SDN
250
8
EB3L-S08SDN
310
10
EB3L-S10SDN
250
8 (∗)
EB3L-S08CSDN
340
16 (∗)
1
EB3L-S16CSDN
350
EB3L-S01KDN
130
2
EB3L-S02KDN
160
3
EB3L-S03KDN
170
5
EB3L-S05KDN
240
6
EB3L-S06KDN
250
8 (∗)
10
EB3L-S08KDN
310
EB3L-S10KDN
340
8
EB3L-S08CKDN
250
16 (∗)
EB3L-S16CKDN
350
16 (∗)
EB3L-S16CSD-CN
350
16 (∗)
EB3L-S16CKD-CN
350
Separate/Common
Wiring Compatible
Common Wiring Only
150
EB3L-S02SAN
EB3L-S08CKAN
Separate/Common
Wiring Compatible
Common Wiring Only
EB3L-S01SAN
2
8 (∗)
1
Common Wiring Only
Source
Weight (g)
1
8 (∗)
1
Separate/Common
Wiring Compatible
Part No.
∗ Buzzers cannot be connected in common wiring.
Note: Source input model can be connected with sink output PLC. Sink input model can be connected with source output PLC.
Accessories
Name
DIN Rail
End Clip
Part No.
BAA1000
BAP1000
BNL6
Ordering No.
BAA1000PN10
BAP1000PN10
BNL6PN10
Package Quantity
10
10
10
Description
Aluminum (1m long)
Steel (1m long)
For fastening EB3L units on the DIN rail.
13
EB3L Lamp Barriers
Pilot Lights, Illuminated Pushbuttons, Illuminated Selector Switches, and Buzzers
Unit
Size
Pilot Light
ø30
Series
(Note 1)
N
TW
ø22
HW
Miniature Pilot Light
LW
ø10
ø8
ø6
ø30
UP
Shape
Operation Mode
Contact
Dome
Square
Rectangular w/Metal Bezel
Dome w/Diecast Sleeve
Flush
Flush (Marking Type)
Dome
Square Flush (Marking Type)
Round Flush
Dome
Square Flush
Round
Square
Round w/Square Bezel
Extended
Coned
Flush
Extended
Coned
Flush
Extended
Coned
N
Mushroom
ø22
HW
Round
Round
LW
Square
(Note 3)
Buzzer
Momentary
1NO-1NC EB3P-LBAN211-∗
Maintained
1NO-1NC EB3P-LBAON211-∗
Pushlock Turn Reset
1NO-1NC EB3P-LBAVN311-R
Momentary
1NO-1NC EB3P-LBAW211-∗
Maintained
1NO-1NC EB3P-LBAOW211-∗
Pushlock Turn Reset
Momentary
Maintained
Momentary
Maintained
Momentary
Maintained
2-position
3-position
2-position
2-position, return from right
3-position
3-position, return from right
3-position, return from left
3-position, 2-way return
2-position
3-position
2-position
3-position
1NO-1NC
1NO
1NO
DPDT
DPDT
DPDT
DPDT
1NO-1NC
2NO
1NO-1NC
1NO-1NC
2NO
2NO
2NO
2NO
1NO-1NC
2NO
DPDT
DPDT
Extended
TW
N
Round
TW
Round
HW
Round
LW
Round
ø22
ø30
EB3P-LAN1-∗
EB3P-LUN3B-∗
EB3P-LUN4-∗
EB3P-LAD1-∗
EB3P-LAW1-∗
EB3P-LAW1B-∗
EB3P-LAW2-∗
EB3P-LUW1B-∗
EB3P-LHW1-∗
EB3P-LHW2-∗
EB3P-LHW4-∗
EB3P-LLW1-∗
EB3P-LLW2-∗
EB3P-LLW3-∗
IPL1-18-∗
IPL1-19-∗
IPL1-87-∗
IPL1-88-∗
IPL1-89-∗
IPL1-67-∗
IPL1-68-∗
IPL1-69-∗
Extended
Mushroom
ø30
Lens Color/
Ordering No. (Note 2) Illumination
Color Code∗
EB3P-LBAVW411-R
Continuous sound
EB3P-LBH1W110-∗
EB3P-LBHA1W110-∗
EB3P-LBL1W1C2-∗
EB3P-LBLA1W1C2-∗
EB3P-LBL2W1C2-∗
EB3P-LBLA2W1C2-∗
EB3P-LSAN211-∗
EB3P-LSAN320-∗
EB3P-LSAW211-∗
EB3P-LSAW2111-∗
EB3P-LSAW320-∗
EB3P-LSAW3120-∗
EB3P-LSAW3220-∗
EB3P-LSAW3320-∗
EB3P-LSHW211-∗
EB3P-LSHW320-∗
EB3P-LSL1W2C2-∗
EB3P-LSL3W3C2-∗
EB3P-ZUN12CN
Intermittent sound (approx. 3 Hz)
EB3P-ZUN12FN
Operation
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
A: Amber
G: Green
R: Red
W: White
Y: Yellow
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Red only
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
Red only
A: Amber
G: Green
R: Red
S: Blue
W: White
Y: Yellow
(Note 3)
(Note 4)
(Note 5)
(Note 3)
(Note 4)
(Note 5)
(Note 3)
(Note 4)
(Note 3)
(Note 4)
(Note 3)
(Note 4)
Maintained
Maintained
Maintained
Spring return from right
Maintained
Spring return from left
2-way spring return
Maintained
Maintained
Maintained
Maintained
Approx. 3 Hz
Note 1: Codes N, TW, HW, LW, and UP are the series names of IDEC’s switches and pilot lights.
Note 2: Specify a color code in place of ∗.
Note 3: Momentary operation mode—the contact operates when the button is pressed. When the button is released, the contact goes back to the original position.
Note 4: Maintained operation mode—the contact operates when the button is pressed, and maintains the position even when the button is released.
Re-pressing the button releases the contact.
Note 5: Pushlock turn reset operation mode—the button is held depressed when pressed, and released by turning clockwise.
Note 6: Illuminated selector switches have a knob operator.
Note 7: Lamp barrier and relay barrier need to be connected when using the illuminated pushbutton and illuminated selector switch.
Accessories
Name
Ordering No.
Package Quantity
Remarks
LED Lamp
EB9Z-LDS1-∗
1
Specify a color code in place of ∗ in the Ordering No.
A: amber, G: green, R: red, S: blue, W: white
EB9Z-N1PN10
10
Note: Use a pure white (PW) LED lamp for yellow (Y) illumination.
14
EB3L Lamp Barriers
Specifications of Lamp Barrier
General Specifications of Pilot Light,
Illuminated Pushbutton, Illuminated
Selector Switch, and Buzzer
Operating Humidity
Pilot Light, Illuminated Switch
Buzzer
For zone 1, 2 hazardous areas
Dielectric Strength
(1 mA, 1 minute)
EB3P: 1000V AC
IPL1: 500V AC
(between intrinsically safe circuit and dead parts)
250V AC 50/60Hz, 250V DC
same poles as the dielectric strength)
Operation
Input ON, Output ON (1:1)
1-channel
Separate Wiring
12V DC
10 mA DC ±20%
13.2V DC
14.2 mA
227.2 mA
46.9 mW
750 mW
Maximum External
Capacitance (Co)
470 (470) nF
490 (365) nF
87.5 (87.5) mH
0.6 (0.425) mH
(Note)
(Lo) (Note)
16-channel
Common Wiring
200/(n+1)Ω
(n = number of common channels)
Common Line
8 (16 maximum)
Voltage and Current when
Connecting Control Units
Pilot light:
3.5V, 8.5 mA
Miniature pilot light: 2V, 10 mA
Illuminated switch: 3.5V, 8.5 mA
Buzzer:
6.5V, 5.5 mA
Rated voltage: 24V DC
Rated current: 5 mA
(connector model: 4 mA)
(Signal Input)
Illuminated Switch
Intrinsically Safe Circuits (Output)
Wiring Method
Pilot Light and Miniature Pilot Light
Safe indoor place (non-hazardous area)
Installation
Location
IP20 (IEC60529)
Lamp Barrier
IP65 (IEC60529) (except for terminals)
EB3P-LU/IPL1: IP40
Lens/Illumination
Color
Pilot light: Amber, blue, green, red, white, yellow
Miniature pilot light: Amber, green, red, white, yellow
≤ 2 nF
Intrinsic Safety
≤ 5 µH
Ratings and
Parameters
≤ 80 µH
EB3P-LSAW∗∗: IP54
Illumination Color
Contact
Voltage/Current
12V DC ±10%, 10 mA ±20%
(when connecting to the EB3C)
Intrinsic Safety
Ratings and
Parameters
≤ 80 µH
Degree of Protection IP20 (IEC60529) (except for terminals)
Sound Volume
75 dB minimum (at 1 m)
General Specifications of Lamp Barrier
Sound Source
Piezoelectric oscillator (continuous or intermittent)
Intrinsic Safety
Ratings and
Parameters
≤260 nF
≤80 mH
Weight
100g
Power Voltage Type
AC Power
DC Power
Rated Power Voltage
100 to 240V AC (–15 to +10%) 24V DC (±10%)
Allowable Voltage
Range
85 to 264V AC
Rated Frequency
47 to 63 Hz)
Inrush Current
10A (100V AC)
20A (200V AC)
21.6 to 26.4V DC
10A
Between AC power and signal input: 1500V AC
Dielectric Strength
(1 minute, 1 mA)
Buzzer
safe circuit: 1526.4V AC (except for DC power and
signal input)
Note: Connect buzzers in separate wiring. Buzzers cannot be used in
common wiring.
Certification No.
Certification Organization
FM
Storage Temperature
Operating Humidity
Atmosphere
800 to 1100 hPa
Pollution Degree
2 (IEC60664)
CQST
(2 hours each on X, Y, Z)
KCS
(damage limits)
UL
PTB (ATEX)
Shock Resistance
(damage limits)
Terminal Style
M3 screw terminal
Mounting
Power Consumption
(approx.)
8.8 VA (EB3L-S10SAN at 200V AC)
5.2 W (EB3L-S16CSDN at 24V DC)
TIIS
NK
KR
Class I, Zone 0 [AEx ia] II C
Lamp barrier:
[Exia] II C
Certification No.
3047250
(buzzer: pending)
E234997
(except buzzer)
PTB09 ATEX2046
Buzzer:
Exib II CT6
Lamp barrier:
[Exia Ga] II C CNEX 14.0047
Pending
Buzzer:
Exib II CT6
Pending
Lamp barrier:
[Exia] II C
14-AV4B0-0375
Buzzer:
Exib II CT6
Pending
Lamp barrier:
[Exia] II C
Pilot light/Miniature pilot light:
(separate wiring:) Exia II CT6
(common wiring:) Exia II CT4
Illuminated switch: Exia II CT4
TC20541
Buzzer:
Exib II CT6
Lamp barrier:
[Exia] II C
Buzzer:
Exib II CT6
TC20797
Type Test No.
13T606
Pending
Lamp barrier:
[Exia] II C
TYK17821-EL003
Buzzer:
Exib II CT6
Pending
TC16361
TC16360
TC16362
Note: Illuminated switches, pilot lights, and miniature pilot lights are certified
by TIIS and NK only. Other certification organizations regard these
units as simple apparatus, and require no certification.
Buzzers are certified by TIIS only. Other ex-proof certifications
pending.
15
EB3L Lamp Barriers
AC Power
Source Input
DC Power
Sink Input
Connector Wiring
Source Input
Hazardous Area
P1 N1 P2 N2 P3 N3
Yellow
Green
Yellow
P1 N1 P2 N2 P3 N3
Yellow
Green
Yellow
Yellow
N S1 C1 S2 C2 S3 C3
Safe Area
Yellow
N2
P16 N1
Yellow
Green
L
Yellow
P1
S1 C1 S2 C2 S3 C3
S1
S16 C1 C2
Dimensions
Terminal
EB3L–S01 N
65
EB3L–S08 N
EB3L–S10 N
EB3L–S16C N
110.5
Intrinsic Safety Side:
Light Blue
77.5
171.5
61
75
65
42
EB3L–S05 N
EB3L–S06 N
EB3L–S08C N
N
N
ø4.4
EB3L–S02
EB3L–S03
(4)
ø6 hole
4
6
77.5
Non-Intrinsic Safety Side:
Yellow
10
10
10
10
10
2-M4 tapped or
28
2-M4 tapped or
4-M4 tapped or
97
97
51
65
2-M4 tapped or
2-ø4.5 mounting
holes
65
Connector
EB3L-T16C-CN
3 max.
4-M4 or 4-ø4.5 holes
5.4 min.
65
4- ø4.5 holes
65
75
(4)
83.5
ø3.2 min.
6 max.
M36
ø
171.5
Solid Wire
97
6 to 8 mm
77.5
6
6 to 8 mm
10
16
97
10
EB3L Lamp Barriers
Pilot Lights
28.5
34.3
13
17
30
28.5
34.3
13
17
EB3P-LHW1/EB3P-LHW2/EB3P-LHW4
ø22
Flush
Dome
36
52.2
34
ø40
13
25
28.5
34.3
30
13
16
30
Marking Plate:
22
Terminal cover attached.
Panel Thickness 0.8 to 6
Gasket
7.2
Square
Round/Dome
M3.5
Terminal
Screw
EB3P-LLW1/EB3P-LLW2/EB3P-LLW3
ø22
Gasket
M3.5 Terminal Screw
Locking Ring
28.5
34.3
30
Marking Plate: ø15.5
EB3P-LUW1B
ø22
Terminal Cover (supplied)
Panel Thickness 1 to 6
APS-PVL
APS-PVL
M3.5
Terminal
Screw
40
44
37
37
M3.5
Terminal
Screw
40
EB3P-LAW2
ø22
Panel Thickness 0.8 to 5.5
25
30
EB3P-LAW1B
ø22
9
21.4
29.8
APS-PVL
ø29
ø24
M3.5
Terminal
Screw
40
44
10.5
Terminal Cover: APN-PVL
(sold separately)
M3 Terminal
Screw
37
EB3P-LAW1
ø22
APS-PVL
Panel Thickness 0.8 to 7.5
36
52.2
34×40
29.5
40
37
23.5
ø29
21.5
36
ø35
M3.5 Terminal
Screw
Panel Thickness 0.8 to 4.5
EB3P-LUN3B
ø30
Terminal Cover: APD-PVL
(sold separately)
ø24.8
ø35
M3 Terminal
Screw
EB3P-LAD
ø30
(sold separately)
ø24
M3 Terminal
Screw
EB3P-LUN4
ø30
(sold separately)
ø23.6
ø29
EB3P-LAN1
ø30
Square Round w/square bezel
Round
Locking Ring
29
ø
0.5
43.3
17.5
7
M3 Terminal
Screw
29.6
19
26.8
7.7
9
5.8
X1
25.8
ø2
4.5
X2
25.8
Miniature Pilot Lights (Terminal cover not available)
ø6
Panel Thickness 0.6 to 4
11.5
6.1
M6 P0.75
+ Terminal
9.2
9.2
20.3
5
4.5
IPL1-69
ø6
M6 P0.75
+ Terminal
2.5
7
11.3
19.8
4.6
7
10
4.6
7
11.8
4.6
11.8
19.8
3
IPL1-68
ø6
11.5
9
6.1
11.5
IPL1-67
M6 P0.75
+ Terminal
ø8.1
ø10
+ Terminal
5
9
11.5
19.5
9.2
IPL1-89
M8 P0.75
9
13.8
21.8
ø6
ø7.5
5.5
ø8
12.8
20.8
M8 P0.75
+ Terminal
ø12
13.8
7
ø12
13.8
7
9
9
12
IPL1-88
ø8
M8 P0.75
+ Terminal
ø9.9
+ Terminal
+ Terminal
IPL1-87
ø8
ø10
M10 P1.0
ø10
IPL1-19
ø10
6.1
P1.0
ø7.5
M10
ø7.5
IPL1-18
ø10
3.5
18.5
3
EB3P-LBAN211/LBAON211
EB3P-LBAVN311-R
ø30
Terminal cover: N-VL4 (2 pcs.) (sold separately)
M3.5 Terminal Screw
M3.5 Terminal Screw
40
5.5
EB3P-LBAVW411-R
Adjustment
Ring
Panel Thickness
1 to 6
ø22
36
Locking Ring
LO
CK
Lever Stop
9
ø2
49.4
13
29.4
EB3P-LBL2W1C2/LBLA2W1C2
Terminal cover: LW-VL2M (sold separately)
23.2
23.2
K
K
C
C
LO
M3 Terminal
Screw
M3.5 Terminal
Screw
13
22.5
R18
EB3P-LBL1W1C2/LBLA1W1C2
R18
ø40
37
ø24
ø29
69.4
LO
M3 Terminal
Screw
13
19.5
30
Reset 75°
EB3P-LBH1W110/LBHA1W110
41.4
30
ø22
37
ø22
M3.5 Terminal
Screw
4
Panel Thickness
1 to 6
ø2
Adjustment
Ring
40
23.5
63
69.4
ø22
23
23.5
EB3P-LBAW211/LBAOW211
M3.5 Terminal
Screw
ø40
ø40
9
63
ø22
ø35
ø24
23
5.5
M3 Terminal Screw
M3 Terminal Screw
25
ø30
5.
9
ø2
53.5
8
8.5 11.7
25.4
8.5 11.7
25.4
53.5
25.8
9
17
EB3L Lamp Barriers
EB3P-LSAN211/EB3P-LSAN320
M3.5 Terminal
Screw
69.4
40
CK
9
Panel Thickness
0.8 to 6
23.2
41.4
25
K
ø2
M3 Terminal
Screw
.8
LO
C
LO
Panel Thickness
0.8 to 6
30
EB3P-LSL1W2C2/EB3P-LSL3W3C2
ø22
25
ø2
5
28
EB3P-LSHW211/EB3P-LSHW320
M3.5 Terminal
Screw
37
ø24
13
9
63
R18
23
ø29
9
ø25
ø35
5.5
ø22
M3.5 Terminal
Screw
M3 Terminal
Screw
EB3P-LSAW∗∗∗
ø22
ø40
ø30
8.5 11.7
25.4
7
69.4
17.5
21
Buzzer
ø30
9
53.5
29.4
LED Lamp
EB3P-ZUN12CN/EB3P-ZUN12FN
Terminal cover: AZ-VL5 (sold separately)
EB9Z-LDS1
Panel Thickness
0.8 to 3.5
20.4
Illumination Color
10.6
IDEC Exi
ø50
M3.5 Terminal Screw
Intrinsic Safety Identification: Light Blue
41
35.5
Illumination color is marked on the terminal.
Polarity Identification
Panel Cut-out
Pilot Lights/Illuminated Pushbuttons/Illuminated
Selector Switches
Positive terminal: X1
Negative terminal: X2
Selector Switches/Buzzers
ø22
R0.8 max.
0.5
R0.8 max.
∗4.8
+0.2
∗3.2
ø22
+0
0 .5
.3
+0.2
33
Pin Terminals
+0.4
ø3
+0.5
Positive terminal: Long pin terminal
Negative terminal: Short pin terminal
ø30
Positive Terminal
Light Blue Marking
Negative Terminal
Buzzer
Positive terminal: +
Negative terminal: –
LED Lamp
ø10
.3
+0 0
.3
+0 0
1
8.
1
0.
ø1
ø8
ø
ø6
.3
+0 0
.1
ø6
+ Positive
− Negative
∗ The 4.8 or 3.2 recess is needed only when using an antirotation ring or a nameplate with an anti-rotation projec
tion.
EB3P-LHW does not have an anti-rotation groove.
Lamp Test
When checking the lamp lighting without using the EB3L
lamp barrier, first make sure that the atmosphere is free from
explosive gases. Connect a 12V DC power supply and a
protection resistor of 1 kΩ in series to turn on the pilot light.
18
1 kΩ
Pilot Light
12V DC
EB3L Lamp Barriers
Non-intrinsically Safe External Input Wiring Examples
6-channel Source
(Ex.: EB3L-S06SAN)
8-channel Common Wiring, Source
(Ex.: EB3L-S08CSDN)
L
N
100 to
240V AC
L
S1 S2 S3 S4 S5 S6 S7 S8 C1 C2
P2
P3
P4
S1
S2
S3
S4
P5
P6
P7
P8
S5 S6
S7
S8
N2
C1
C2
S9 S10 S11 S12 S13 S14 S15 S16 C3
S1 C1 S2 C2 S3 C3 S4 C4 S5 C5 S6 C6
16-channel Common Wiring, Sink
(Ex.: EB3L-S16CKDN)
N1
N
100 to
240V AC
24V DC
16-channel Common Wiring, Source
(Ex.: EB3L-S16CSDN)
P1
6-channel Sink
(Ex. EB3L-S06KAN)
N4
P1
P2
P3
P4
P5
P6
P7
P8
S1
S2
S3
S4
S5 S6
S7
S8
N1
C4
C1
N2
N4
C2
C4
24V DC
24V DC
Note: Source input model can be connected to PLC sink output model
C terminal is the negative common line.
Note: Sink input model can be connected to PLC source output model
C terminal is the positive common line.
Connector Wiring Terminal Arrangement
Wiring Example with IDEC’s MicroSmart PLC Output Modules
EB3L-S16CSD-CN
FC4A-T16K3
Terminal Output
S9 S10 S11 S12 S13 S14 S15 S16 NC NC
19
1
S1
S2
S3
S4
S5
S6
S7
S8
C1
CHn
Sn COM
C2
CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8 COM +V
EB3L
PLC
Output
Q0-Q15
S1-S16
Internal Circuit
Internal Circuit
+V (C2)
COM (C1)
COM
EB3L-S16CKD-CN
19
1
S1
S2
S3
S4
S5
S6
S7
S8
C1
CHn
Sn COM
C2
CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8 COM –V
PLC
Internal Circuit
COM (C1)
COM
S1-S16
Output
Q0-Q15
Internal Circuit
EB3L
EB3L-S16CSD-C
Input
Terminal
FC4A-T16S3
Terminal Output
EB3L-S16CKD-C
Input
Terminal
Q0
S1
Q0
S1
Q10
S9
19
19
Q10
S9
19
18
Q1
S2
18
18
Q1
S2
18
17
Q11
S10
17
17
Q11
S10
17
16
Q2
S3
16
16
Q2
S3
16
15
Q12
S11
15
15
Q12
S11
15
14
Q3
S4
14
14
Q3
S4
14
13
Q13
S12
13
13
Q13
S12
13
12
Q4
S5
12
12
Q4
S5
12
11
Q14
S13
11
11
Q14
S13
11
10
Q5
S6
10
10
Q5
S6
10
9
Q15
S14
9
9
Q15
S14
9
8
Q6
S7
8
8
Q6
S7
8
7
Q16
S15
7
7
Q16
S15
7
6
Q7
S8
6
6
Q7
S8
6
5
Q17
S16
5
5
Q17
S16
5
4
COM
COM
4
4
COM
COM
4
3
COM
NC
3
3
COM
NC
3
2
+V
+V
2
2
–V
–V
2
1
+V
NC
1
1
–V
NC
1
Note: The wiring in dashed line does not affect the operation of the EB3L.
Output power for PLC outputs is supplied by the EB3L, therefore the
PLC output does not need an external power supply.
19
EB3L Lamp Barriers
Wiring Example of Intrinsically Safe External Outputs
1. Common Wiring (Maximum 16 circuits) (Buzzers cannot be wired in a common line.)
N
N
N
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
L
N
S1
S2
S3
S4
S5
S6
S7
S8
C1
C2
L
N
P1
S1
N1
C1
P2
S2
N2
C2
P3
S3
N3
C3
P4
S4
N4
C4
P5
S5
C5
N5
S6
P6
C6
N6
P7
S7
C7
N7
S8
P8
C8
N8
S9
P9
C9
N9
S10 P10
C10 N10
S3
C3
S4
C4
S5
C5
S6
C6
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
L
N
S1
C1
S2
C2
L
N
S1
C1
S2
C2
S3
C3
P1
N1
P2
N2
P3
N3
P1
N1
N2
S1
C1
C2
L
N
L
N
S1
S2
S3
S4
S5
S6
S7
S8
C1
C2
S9
S10
S11
S12
S13
S14
S15
S16
C3
C4
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
All output lines are wired to a common line inside the intrinsically safe equipment (one common line per intrinsically safe circuit).
N
N
N
N
N
N
2. Separate Wiring
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
N
N
L
N
P1
S1
N1
C1
P2
S2
N2
C2
P3
S3
N3
C3
P4
S4
N4
C4
P5
S5
C5
N5
S6
P6
C6
N6
P7
S7
C7
N7
S8
P8
C8
N8
S9
P9
C9
N9
S10 P10
C10 N10
L
N
S1
C1
S2
C2
S3
C3
L
N
S1
C1
C2
L
N
S1
C1
S2
C2
S3
C3
S4
C4
S5
C5
S6
C6
P1
N1
N2
P1
N1
P2
N2
P3
N3
Each output line of the EB3L makes up one independent intrinsically safe circuit of a pilot light or buzzer.
N
(A maximum of 16 channels of EB3L and EB3C can be wired to a common line.)
The following example illustrates the wiring for a total of 10 contacts used by three illuminated
pushbuttons (LB1 to LB3) and three illuminated selector switches (LS1 to LS3).
LS1
LS2
LS3
L
N
S1
C1
S2
C2
S3
C3
S4
C4
S5
C5
S6
C6
(+)(ñ)
N
LB1
LB2
LB3
LS1
LS2
LS3
L
N
P1
A1
N1
C1
P2
A2
N2
C2
P3
A3
N3
C3
P4
A4
N4
C4
P5
A5
C5
N5
A6
P6
C6
N6
P7
A7
C7
N7
A8
P8
C8
N8
A9
P9
C9
N9
A10 P10
C10 N10
LB3
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
LB2
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
N
Note:
When using two or more EB3L's
to set up one intrinsically safe circuit
(N1 through N10) on each EB3L
between adjacent EB3L's in parallel.
N
3. Wiring Illuminated Pushbuttons and Illuminated Selector Switches
LB1
N
L
N
S1
S2
S3
S4
S5
S6
S7
S8
C1
C2
L
N
P1
S1
N1
C1
P2
S2
N2
C2
P3
S3
N3
C3
P4
S4
N4
C4
P5
S5
C5
N5
S6
P6
C6
N6
P7
S7
C7
N7
S8
P8
C8
N8
S9
P9
C9
N9
S10 P10
C10 N10
L
N
S1
C1
S2
C2
S3
C3
S4
C4
S5
C5
S6
C6
L
N
S1
C1
S2
C2
S3
C3
N
P1
N1
P2
N2
P3
N3
P4
N4
P5
N5
P6
N6
P1
N1
P2
N2
P3
N3
L
N
S1
C1
C2
L
N
S1
S2
S3
S4
S5
S6
S7
S8
C1
C2
S9
S10
S11
S12
S13
S14
S15
S16
C3
C4
P1
N1
N2
P1
P2
P3
P4
P5
P6
P7
P8
N1
N2
P9
P10
P11
P12
P13
P14
P15
P16
N3
N4
All input lines are wired to a common line outside the intrinsically safe equipment (one common line per intrinsically safe circuit).
(+)(ñ)
N
Diagram Symbols
EB3P consisting of one
enclosure
One intrinsically safe circuit is a connection
consisting of one or more illuminated units
connected to a common line.
EB3L Lamp Barriers
Description
No. of Poles
Length (m)
Part No.
0.5
FC9Z-H050A20
1
FC9Z-H100A20
2
FC9Z-H200A20
With Shield
I/O
Terminal
Cable
Without Shield
shape
Applicable Model
IDEC MicroSmart
I/O Module
3
FC9Z-H300A20
0.5
FC9Z-H050B20
1
FC9Z-H100B20
2
FC9Z-H200B20
3
FC9Z-H300B20
1
BX9Z-H100E4
200
2
BX9Z-H200E4
2
IDEC MicroSmart
I/O Module
Screw Terminal
1
3
BX9Z-H300E4
1
BX9Z-H100B
2
BX9Z-H200B
3
BX9Z-H300B
350
10
BX9Z-HB Internal Connection
IDEC Connector
JE1S-201
B A
2
1
4
3
6
5
8
7
10 9
12 11
14 13
16 15
18 17
20 19
(Connecting Side)
1
1
2
2
1 2
3
3
3 4
4
4
5 6
5
5
7 8
6
6
9 10
7
7
8
8
9
9
Connector B
IDEC
JE1S-201
10 10
1
5
7
9
11
11 12
13
13 14
15
15 16
17
11 11
2
1
12 12
4
3
19 20
13 13
6
5
14 14
8
7
15 15
10 9
16 16
12 11
17 17
14 13
18 18
16 15
19 19
18 17
20 20
20 19
(Connecting Side)
Y-shaped Crimping Terminal
(marking tube number)
3
17 18
(Connecting Side)
Connector A
Mitsubishi A Series
Output Module (sink)
EB3L-S16CSD-CN
FC9Z-HE
Internal Connection
Fujitsu Connector
FCN-367J040-AU/F
Connector A
IDEC
JE1S-201
Connector B
19
(Connecting Side)
2
4
6
8
10
12
14
16
18
(Connecting Side)
(Straight wire connection BX9Z-HB: number of
cable with crimping terminal)
FC9Z-HA, FC9Z-HB
Internal Connection
IDEC Connector
JE1S-201
19
18
15
16
13
14
11
12
9
10
7
8
5
6
3
4
1
2
(Connecting Side)
IDEC Connector
JE1S-201
19
18
15
16
13
14
11
12
9
10
7
8
5
6
3
4
1
2
(Connecting Side)
21
EB3L Lamp Barriers
1. Installation of EB3L Lamp Barriers
2. Terminal Wiring
(1) The EB3L can be installed in any direction.
(2) Install the EB3L lamp barrier in a safe area (non-hazard
ous area) in accordance with intrinsic safety ratings and
parameters. To avoid mechanical shocks, install the
EB3L in an enclosure which suppresses shocks.
(3) When installing or wiring the EB3L, prevent electromag
netic and electrostatic inductions in the intrinsically safe
circuit. Also prevent the intrinsically safe circuits from
contacting with another intrinsically safe circuit and any
other circuits.
and non-intrinsically safety circuit. When providing a
metallic separating board, make sure that the board fits
closely to the enclosure (top, bottom, and both sides).
Allowable clearance between the enclosure and board
is 1.5 mm at the maximum.
circuit and non-intrinsically safe circuit may not be
sufficient when a motor circuit or high-voltage circuit is
installed nearby. In this case, provide a wider clearance
between the circuits referring to 6. (3) “Minimum Parallel
Distance between the Intrinsically Safe Circuit and
Other Circuits.”
circuits and non-intrinsically safe circuits, mount EB3L
terminal screws (including unused terminal screws) to a
torque of 0.6 to 1.0 N·m (recommended value).
(2) Make sure that IP20 is achieved when wiring. Use insu
intrinsically safe circuit, provide an insulation distance
of at least 6 mm.
EB3L
EB3L
EB3L
EB3L
Non-intrinsically
Safe Circuit
EB3L
IEC60079-11: 1999) clearance between the terminal of
intrinsically safe circuit and the grounded metal part of
a metal enclosure, and between the relay terminal block
of an intrinsically safe circuit and the grounded metal
(6) For installing the EB3L, mount on a 35-mm-wide DIN
rail or directly on a panel using screws. The EB3L
can be installed in any direction. Make sure to install
DIN rail, push in the clamp completely. Use the BNL6
end clips on both sides of the EB3L to prevent from
moving sideways.
damage to the EB3L. When extraneous noise activates
the voltage limiting circuit (thyristor), remove the noise
source and restore the power.
22
3. Signal Input
(1) Connect the EB3L to the switches or output equipment
which have a low leakage current (0.1 mA maximum).
(2) The EB3L is equipped with power supply. Do not apply
external power to the EB3L.
(3) When connecting the EB3L’s of connector model in
parallel, make sure that the same power supply is used.
When using C1 and C2 terminals to supply power to
outside equipment, maintain the current at 50 mA maxi
mum.
4. Power Voltage
(1) Do not apply an excessive power voltage, otherwise the
EB3L may be damaged.
(2) The EB3L of AC power type may operate at a low volt
age (approx. 20V).
5. Pilot Lights, Illuminated Switches, and Buzzers
(1) EB3P and IPL1 units shown on page 14 can be used
with the EB3L. Buzzers cannot be connected in
common wiring.
(2) Install the EB3P and IPL1 units on enclosures of IP20 or
higher protection. Use a metallic enclosure with magne
sium content of 7.5% or less (steel and aluminum are
acceptable).
(3) When wiring, make sure of correct polarities of the
EB3P and IPL1.
(4) Certification mark is supplied with the units. Attach it on
the visible area of the EB3P or IPL1 (for Japan applica
tion).
(5) When connecting illuminated switches to the EB3L
lamp barrier and the EB3C relay barrier, a maximum of
16 channels can be connected in common wiring.
EB3L Lamp Barriers
6. Wiring for Intrinsic Safety
the non-intrinsically safe circuit terminals of the EB3L
lamp barrier must be 250V AC, 50/60Hz, or 250V DC
at the maximum under any conditions, including the
voltage of the power line and the internal circuit.
of electromagnetic and electrostatic charges on
intrinsically safe circuits. Also, prevent intrinsically safe
circuits from contacting with other circuits.
non-intrinsically safe circuits. Contain intrinsically
safe circuits in a metallic tube or duct, or separate the
intrinsically safe circuits referring to the table at right.
Note: Cables with a magnetic shield, such as a metallic sheath, prevent
electromagnetic induction and electrostatic induction, however, a
non-magnetic shield prevents electrostatic induction only. For nonmagnetic shields, take a preventive measure against electromagnetic
induction.
induction. Adding shields to the twisted pair cables
provides protection against electrostatic induction.
Voltage and
Current of Other
Circuits
Over 100A
100A or
less
50A or less
the distance to satisfy the wiring parameters shown
below. Note that parameters are different between
separate wiring and common wiring and depend on
the connected units, such as pilot lights, illuminated
pushbuttons, and buzzers.
a) Wiring capacitance Cw ≤ Co – Ci
Co: Maximum external capacitance of the EB3L
Ci: Internal capacitance of the connected unit
b) Wiring inductance Lw ≤ Lo – Li
Lo: Maximum external inductance of the EB3L
Li: Internal inductance of the connected unit
value of those calculated from the capacitance,
inductance, and resistance.
to a relevant test guideline for explosion-proof electric
equipment in each country.
10A or less
Over 440V
2000
2000
2000
2000
440V or less
2000
600
600
600
220V or less
2000
600
600
500
110V or less
2000
600
500
300
60V or less
2000
500
300
150
light blue terminal blocks and cables.
(5) When using two or more EB3L’s to set up one intrinsi
cally safe circuit in the common wiring configuration,
each EB3L between adjacent EB3L’s in parallel.
(6) Make sure that the power of the EB3L, pilot lights, and
other connected units are turned off before starting
Safety Precautions
• Do not use the EB3C Relay Barrier and EB3L Lamp Barrier for other than explosion protection purposes.
• Read the user’s manual to make sure of correct operation before starting installation, wiring, operation, maintenance, and
inspection of the EB3C Relay Barrier and EB3L Lamp Barrier.
23
Build a safety system in an explosive atomosphere.
Explosion
Protection
Safety relay barrier [Exia] II C
Switch (EB9Z-A)
Exia II CT6
Switch (EB9Z-A1) Exia II BT6
Safety
Performance
Performance level e
Category 4
• Ensures explosion protection safety and machine safety in an
explosive atmosphere.
• Machine safety system can be built in compliance with
ISO13849-1 Category 4, Performance level e.
• Safety input devices applicable in any explosive gas and
hazardous areas are available.
• Available with auxiliary inputs (5 points) used to monitor the
operating status of safety input devices.
• A wide variety of Japan TIIS-rated emergency stop switches and
interlock switches are available.
• Global usage
Explosion protection: Japan (TIIS), USA (UL), Europe (ATEX),
China (CQST), IEC Ex
Machine safety:
TÜV Rheinland
• No grounding required.
IEC Ex
Safety Input
Points
Safety Output
Points
Auxiliary Input Points
(Note 1)
Auxiliary Output Points
(Relay Output)
2
2NO
Without
Without
2
2NO
5 (1 common)
5NO (1 common)
Reset (Start)
(Note 2, Note 3)
Part No.
Auto reset (Auto start)
Manual reset (Manual start)
EB3N-A2ND
EB3N-M2ND
EB3N-A2R5D
EB3N-M2R5D
Note 1: A maximum of five monitor contacts from safety input devices can be connected to the auxiliary input terminals. In addition, non-safety input devices
can also be connected to the auxiliary input terminals.
Note 2: On auto reset (auto start) models, when the safety condition is met (two safety inputs are both on), safety outputs are turned on automatically.
Connect the reset (start) input terminals Y1 and Y2 together except for the following cases:
When connecting a contactor or force guided relay to the safety output of the EB3N, connect the NC contacts of the contactor or force guided relay to
the reset (start) input terminals Y1 and Y2 of the EB3N for use as a backcheck input signal.
Note 3: On manual reset (manual start) models, while the safety condition is met (two safety inputs are both on), safety outputs are turned on at the falling
edge of the reset switch (start switch) signal (OFF→ON→OFF) (start off check).
Manual reset (manual start) models have a monitoring function of reset switch contacts (detection of welded contacts). Use NO contacts of a
momentary switch for the reset (start) input.
Selection Guide
1. Selecting the reset (start) function
Auto reset (auto start):
Select this model when connecting safety control devices, such as safety relay modules or safety controllers, to the EB3N
safety outputs to set up a safety system, using the reset (start) function of the safety control device.
Select this model when connecting contactors or force guided relays to the EB3N safety outputs to set up a safety system,
and a risk assessment on the entire system has not found any safety problem in using auto reset (auto start).
Manual reset (manual start):
and a risk assessment on the entire system has found that manual reset (manual start) is necessary.
2. Selecting the auxiliary outputs
Without auxiliary outputs:
Select this model when the operating status of safety input devices are not monitored.
With auxiliary outputs:
Select this model when the operating status of safety input devices are monitored or when non-safety input devices are
also connected.
Rated Power Voltage
Power Voltage Range
Operating Humidity
Power
Consumption
Safety
Output
Auxiliary
Output
Contacts
13-14, 23-24
Resistive
Rated Load
Inductive
Turn on
Response
(rated voltage) Turn off
Contacts
A* - C1
Rated Load
Turn on
Response
Mounting
*: Channel Nos. 1 to 5
24
Resistive
24V DC
20.4 to 26.4V DC
UL: –20 to +40°C
(no freezing)
45 to 85% RH
(no condensation)
5.5W maximum
7.0W maximum
2NO
30V DC, 1A
DC-13, 24V, 1A
100 ms maximum
20 ms maximum
5NO/1 common
24V DC, 3A,
common terminal 5A max.
15 ms maximum
10 ms maximum
Non-intrinsically Safe Circuit Maximum Voltage (Um)
Intrinsically Safe Circuit Maximum Voltage (Uo)
Intrinsically Safe Circuit Maximum Current (Io)
Intrinsically Safe Circuit Maximum Power (Po)
Intrinsically Safe Circuit Allowable Capacitance (Co)
[Exia] II C
250V (UL: 125V)
13.2V
227.2 mA
750 mW
0.49 µF (TIIS: 0.28 μF)
0.60 mH
Intrinsically Safe Circuit Allowable Inductance (Lo)
(TIIS: 0.56 mH)
Safety circuit
(Note 1)
Auxiliary circuit
(Note 2)
Note 1: 10Ω maximum (500m maximum using a 1.25 mm2 cable)
Note 2: 600/(N+1)Ω maximum, where N = the number of common channels
Safety Specifications
Category
4
Performance Level (PL)
e
Mean Time to Dangerous Failure (MTTFd)
100 years
Diagnostic Range
99% minimum
Calculation conditions for MTTFd
tcycle: Mean operation cycle = 1 hour
hop: Mean operation hours per day = 24 hours
dop: Mean operation days per year = 365 days
Note: When tcycle is shorter than 1 hour, MTTFd will decrease.
EB3N Safety Relay Barriers
Certification No.
Certification
Organization
Explosion Protection
Certification No.
Safety Relay Barriers [Exia] II C
Switch (EB9Z-A)
[Exia] II CT6
Switch (EB9Z-A1)
[Exia] II BT6
[Exia] II C, [Exia D]
II (1) G [Exia] II C
II (1) D [Exia D]
[Exia] II C
Class I, Zone 0, [AExia] II C
Class I, II, III, Div. 1, Grps A, B, C, D, E, F and G
TIIS
PTB
CQST
UL
TC18753
TC15758
T15961
IEC Ex PTB 10.0015
PTB 09 ATEX 2046
CNEx 11.0038
E234997
Dimensions
Terminal Functions
EB3N-A2ND
EB3N-M2ND
M3
24V DC
110.5
Y1-Y2
77.5
M3
11-12
21-22
N1, N2
P*-N3
13-14
23-24
A*-C1
75.0
75.0
65.0
EB3N-A2R5D
EB3N-M2R5D
*: 1 to 5
2-M4 tapped or
2-ø4.5 drilled holes
65
2-M4 tapped or
EB3N-A2R5D
EB3N-M2R5D
65
EB3N-A2ND
EB3N-M2ND
Power
Reset input
(Start input)
Safety input 1
Safety input 2
Signal ground
Auxiliary input
Safety output 1
Safety output 2
Auxiliary output
97
51
EB3N System Configuration Examples
1:1 connection with a safety input device, compliant with Category 4
Hazardous Area
Safety Input Device
Non-hazardous Area
EB3N-A2ND
Barrier Safety Output Safety Control Device
Safety Output
Safety Contactor
• A safety relay module or safety controller
is used to set up a safety circuit, using
relay module or safety controller.
Backcheck Input
Reset (Start) Input
Safety Input Device
EB3N-M2ND
• The reset (start) function is used to set
up a safety circuit, without using a safety
Barrier Safety Output Safety Contactor
Backcheck Input
Reset (Start) Input
Connection with multiple safety input devices, capable of monitoring up to 5 contact operations, compliant with Category 3
For monitoring operating statuses of safety input devices located in a non-hazardous area
Hazardous Area
Non-hazardous Area
Safety Output
EB3N-A2R5D
Safety Input Devices
Connected in Series
Backcheck Input
Safety Contactor
PLC
Connected in Series
Reset (Start) Input
Auxiliary Output
(Monitor Output)
Monitor
Safety Contactor
EB3N-M2R5D
Backcheck Input
Reset (Start) Input
Monitor
PLC
• The manual reset (manual start) function
of the EB3N is used to set up a safety
circuit, without using a safety control
device.
Auxiliary Output
(Monitor Output)
25
Installing a reset switch in a hazardous area, using auxiliary input and output
Hazardous Area
Non-hazardous Area
Safety Output
Safety Contactor
EB3N-A2R5D
Reset (Start) Switch
Reset (Start) Output
Backcheck Input
PLC
Other Input Device
Other Output
Safety Contactor
EB3N-M2R5D
Backcheck Input
PLC
Other Input Device
Reset (Start) Input
Other Output
Safety Input Devices Connectable to Safety Input Terminals (Examples)
Emergency stop switch:
Safety switch:
(Non-illuminated) XW1E-BV402MFRH, XN4E-BL412MRH
HS6B-02B05, HS1B-02R
Instructions
Notes for Operation
1. Do not disassemble, repair, or modify the EB3N safety relay barrier,
otherwise the safety characteristics may be impaired.
2. Use the EB3N within its specification values.
3. The EB3N can be mounted in any direction.
4. Mount the EB3N on a 35-mm-wide DIN rail or directly on a panel surface
using screws. When mounting on a DIN rail, push in the clamp and
use end clips to secure the EB3N. When mounting on a panel surface,
tighten the screws firmly.
5. Excessive noise may cause malfunction or damage to the EB3N. When
the internal voltage limiting circuit (thyristor) has shut down the power
due to noise, remove the cause of the noise before powering up again.
6. The internal power circuit contains an electronic fuse to suppress overcurrents. When the electronic fuse has tripped, shut down the power,
remove the cause of the overcurrent before powering up again.
7. Use crimping terminals with insulation sheath for wiring. Tighten the terminal screws, including unused terminal screws, to a recommended tightening torque of 0.6 to N·m using a screwdriver of ø5.5 mm in diameter.
8. Before inspecting or replacing the EB3N, turn off the power.
Notes for Machine Safety
1. Operate the safety input device to check the EB3N functionality everyday.
2. For safety input devices, such as safety switches or emergency stop
switches, connected to the EB3N, use safety standard-compliant devices
with direct opening action and 2NC contacts.
3. Do not use the auxiliary input as a safety input.
4. For safety control devices connected with the EB3N, use machine safety
standard-compliant devices with a disparity detection function.
5. Use safety inputs and safety outputs in a circuit configuration compliant
with safety requirements.
6. To calculate the safety distance, take into consideration the response
time of all devices comprising the system, such as the EB3N and safety
devices connected to the EB3N.
2. Install and wire the EB3N so that the EB3N is not subject to electromagnetic and electrostatic induction and does not contact with other circuits.
For example, keep a minimum spacing of 50 mm between intrinsically
safe and non-intrinsically safe circuits, or provide a metallic separating
board between the intrinsically safe circuit and non-intrinsically safe
circuit. When providing a metallic separating board, make sure that the
board fits closely to the enclosure (top, bottom, and both sides). Allowable clearance between the board and the enclosure is 1.5 mm at the
maximum.
When a motor circuit or high-voltage circuit is installed nearby, keep a
wider spacing than 50 mm between intrinsically safe and non-intrinsically
safe circuits.
3. Keep a minimum spacing of 3 mm between the terminal or relay terminal
block of the intrinsically safe circuit and the grounded metal parts of the
metal enclosure.
4. Connect the terminals so that IP20 is ensured.
5. To prevent disengaged wires from contacting with other intrinsically safe
circuits, bind together the end of wires.
6. Make sure that the voltage of the power supply for the devices connected to the non-intrinsically safe circuit or the internal voltage of such
devices does not exceed 250V AC/DC 50/60 Hz or 250V DC under any
normal and abnormal conditions.
7. Make sure that the wiring of intrinsically safe circuits does not contact
with other circuits or is not subject to electromagnetic and electrostatic
inductions, otherwise explosion protection is not ensured.
8. When identifying intrinsically safe circuits by color, use light blue terminal
blocks and cables.
9. When wiring the intrinsically safe circuit, determine the distance to satisfy
Co: Intrinsically safe circuit allowable capacitance
Ci: Internal capacitance of switches
Lo: Intrinsically safe circuit allowable inductance
Li: Internal inductance of switches
7. Separate the input and output wiring from power lines and motor lines.
8. When using multiple EB3N safety relay barriers, do not connect one
switch to more than one EB3N. Use separate switches for each EB3N.
1. A switch contains the switch contact, enclosure, and internal wiring. A
switch contact refers to an ordinary switching device which consists of
contacts only.
9. To ensure EMC, use shielded cables for safety inputs and auxiliary
inputs. Connect the shield to the FG of the control panel on which the
EB3N is mounted.
10. For protection against overcurrents, connect an IEC60127-2-compliant
2A fast-blow fuse (5 × 20 mm).
11. Evaluate the ISO 13849-1 category and performance level in consideration of the entire system.
Notes for Explosion Protection Safety
1. Install the EB3N in an enclosure capable of protecting against mechanical shocks at a hazardous location in accordance with intrinsic safety
ratings and parameters.
26
2. When the switch has internal wiring or lead wire, make sure that the
values of internal capacitance (Ci) and inductance (Li) are within the
certified values.
3. Enclose the bare live part of the switch contact in an enclosure of IP20
4. Depending on the explosion-protection specifications of TIIS, the exposed area of plastic switch operator, when installed in Japan, is limited
as follows:
Certification
TC15758
TC15961
Exia II CT6
Exia II BT6
Exposed Area
20 cm2 maximum
100 cm2 maximum
27
Specifications and other descriptions in this brochure are subject to change without notice.
6-64, Nishi-Miyahara 2-Chome, Yodogawa-ku, Osaka 532-0004, Japan
Tel: +81-6-6398-2527, Fax: +81-6-6398-2547
E-mail: marketing@idec.co.jp
IDEC CORPORATION (USA)
IDEC IZUMI (H.K.) CO., LTD.
Heselstruecken 8, 22453 Hamburg, Germany
Tel: +49-40-25 30 54 - 0, Fax: +49-40-25 30 54 - 24
E-mail: service@eu.idec.com
IDEC CANADA LIMITED
Room 701-702 Chong Hing Finance Center,
No. 288 Nanjing Road West, Shanghai 200003, PRC
Tel: +86-21-6135-1515
Fax: +86-21-6135-6225 / +86-21-6135-6226
E-mail: idecS@cn.idec.com
3155 Pepper Mill Court, Unit 4
Mississauga, Ontario, L5L 4X7, Canada
Tel: +1-905-890-8561, Toll Free: (888) 317-IDEC (4332)
Fax: +1-905-890-8562
E-mail: sales@ca.idec.com
IDEC AUSTRALIA PTY. LTD.
Unit 17, 104 Ferntree Gully Road,
Oakleigh, Victoria 3166, Australia
Tel: +61-3-8523-5900, Toll Free: 1800-68-4332
Fax: +61-3-8523-5999
E-mail: sales@au.idec.com
www.idec.com
IDEC ELEKTROTECHNIK GmbH
1175 Elko Drive, Sunnyvale, CA 94089-2209, USA
Tel: +1-408-747-0550 / (800) 262-IDEC (4332)
Fax: +1-408-744-9055 / (800) 635-6246
E-mail: opencontact@idec.com
IDEC (SHANGHAI) CORPORATION
Unit G & H, 26/F., MG Tower, No. 133 Hoi Bun Road,
Kwun Tong, Kowloon, Hong Kong
Tel: +852-2803-8989, Fax: +852-2565-0171
E-mail: info@hk.idec.com
IDEC TAIWAN CORPORATION
8F-1, No. 79, Hsin Tai Wu Road, Sec. 1,
Hsi-Chih District, 22101 New Taipei City, Taiwan
Tel: +886-2-2698-3929, Fax: +886-2-2698-3931
E-mail: service@tw.idec.com
IDEC IZUMI ASIA PTE. LTD.
IDEC (BEIJING) CORPORATION
No. 31, Tannery Lane #05-01,
HB Centre 2, Singapore 347788
Tel: +65-6746-1155, Fax: +65-6844-5995
E-mail: info@sg.idec.com
IDEC (SHENZHEN) CORPORATION
20th Fl., Sorachai Bldg., No.23/78,
Soi Sukhumvit 63, Sukhumvit Rd.,
Klongton-nua, Wattana, Bangkok 10110
Tel: +662-392-9765, Fax: +662-392-9768
E-mail: sales@th.idec.com
Room 211B, Tower B, The Grand Pacific Building,
8A Guanghua Road, Chaoyang District,
Beijing 100026, PRC
Tel: +86-10-6581-6131, Fax: +86-10-6581-5119
IDEC ASIA (THAILAND) CO.,LTD.
Unit AB-3B2, Tian Xiang Building, Tian’an Cyber Park,
Fu Tian District, Shenzhen, Guang Dong 518040, PRC
Tel: +86-755-8356-2977, Fax: +86-755-8356-2944
Cat. No. EP1597-0 FEBRUARY 2016 PDF
