Sensors
Magnetic: DPRI
Magnetic: DPRI
Magnetic Proximity Switches
PLCs
Operator Interfaces
• Lightweight, compact design reduces mounting space
requirements
• Compact size allows units to be mounted in close
proximity to each other
• Sealed reed contact can be used in dusty locations
• Long life and high reliability
Automation Software
The DPRI magnetic proximity switch incorporates a sealed reed switch and four magnets inside a compact housing. This self-contained proximity switch requires no external power supply and can detect the
presence of magnetic objects without contact.
Dimensions
0.7"
(5mm)
(18mm)
Single Mounting
0.39"
Power Supplies
0.39"
(10mm)
0.2"
(10mm)
0.73"
(18.5mm)
M3 or 3, 2-3, 6 dia
1.46"
39.37"
Close Mounting of 2 units
(28.5mm)
0.35"
0.39"
0.39"
Sensors
0.24"
(6mm)
0.47"
(12mm)
(1000mm)
(37mm)
1.12"
(9mm) (10mm)
(10mm)
P
P = 0.75" (19mm)
Communication & Networking
USA: 800-262-IDEC
Canada: 888-317-IDEC
227
Sensors
Magnetic: DPRI
Specifications
Operator Interfaces
PLCs
DPRI-01
Normal Switching Distance
5mm ±10%
Operating Distance
0 to 4mm
Release Distance
Over switching distance, 9mm (maximum)
Repeat Error ON
0.05mm (maximum)
Repeat Error OFF
0.15mm (maximum)
Temperature Error (–10 to 50˚C)
±0.5mm or less (20˚C as standard)
Response Speed
Output
300Hz or less (bounce 0.4ms or less)
Contact Configuration
1NO
Switching Capacity
AC: 10VA (maximum)
DC: 10W (maximum)
Operating Voltage
AC: 100V (maximum)
DC: 100V (maximum)
Operating Current
AC: 0.25A (maximum)
DC: 0.25A (maximum)
Power Supplies
Automation Software
Initial Contact Resistance
20G or less
Ambient Temperature Range
–10 to +50˚C
Sensing Object
Magnetic materials: Fe, Ni, Cu, Ferrite, etc.
Standard Sensing Object
Life Expectancy
Electrical
Mechanical
30 x 20 x 1mm, Ferromagnetic soft iron plate
20,000,000 operations
1,000,000,000 operations
Lead Wire
Cable type: 5mm 2-core vinyl cabtyre cable, 3-1/3’ (1m)
long
Weight
Approximately 40g
Part Number
Description
Part Number
DPRI-01
For information on accessories,
see page 229.
Operation Principle
Sensors
0.35Ω (maximum)
Shock Resistance
228
www.idec.com
很抱歉,暂时无法提供与“DPRI-01.”相匹配的价格&库存,您可以联系我们找货
