MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
Long life forφ5 toφ8 product, 105℃
LE
Series
・Suitable for long life products
・Downsize and long life
・Endurance with ripple current:10,000 hours at 105℃
・Case size range:φ5×11L to φ8×11.5L
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
◆SPECIFICATION
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
10 to 100Vdc
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
10V 16V 25V 35V 50V 63V 100V
tanδ (Max.)
0.45 0.35 0.30 0.22 0.19 0.17 0.15
Rated voltage (Vdc)
Z(-25℃)/Z(20℃)
8
6
4
4
3
3
3
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 2 minutes)
(at 20℃,120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours at 105℃.
Capacitance change
≦±25% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃
without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C
5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
Code : E
φd
Sleeve (PET : Brown)
F±0.5
●Terminal
φD
φd
φD'
F
φD'
L'
L'
15min.
5
0.5
2.0
8
6.3
0.6
0.5
3.5
2.5
φD+0.5max.
L+1.5max.
4min.
Gas escape end seal
Vent
(Except φ5)
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E L E- AAA E AA AAA M AAA D
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7, 10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 16V:160, 100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
LESeries
◆STANDARD RATINGS
WV
(Vdc)
10
16
25
35
50
63
100
Cap
(µF)
Case size
φD×L(mm)
tanδ
Rated ripple current
(mArms/105℃, 100kHz)
Part No.
100
220
330
47
100
220
33
47
100
33
47
100
1.0
2.2
3.3
4.7
10
22
33
47
100
10
22
33
47
1.0
2.2
3.3
4.7
10
22
5 ×11
6.3 × 11
8 × 11.5
5×11
6.3 ×11
8 ×11.5
5× 11
5 × 11
6.3×11
5× 11
6.3 ×11
8×11.5
5× 11
5× 11
5× 11
5× 11
5 ×11
5 ×11
6.3 ×11
6.3 ×11
8×11.5
5 × 11
6.3 ×11
6.3 ×11
8 ×11.5
5 × 11
5× 11
5× 11
5× 11
6.3 ×11
8 ×11.5
0.45
0.45
0.45
0.35
0.35
0.35
0.30
0.30
0.30
0.22
0.22
0.22
0.19
0.19
0.19
0.19
0.19
0.19
0.19
0.19
0.19
0.17
0.17
0.17
0.17
0.15
0.15
0.15
0.15
0.15
0.15
130
210
330
130
210
330
130
130
210
130
210
330
25
35
70
80
90
110
190
190
270
80
170
170
240
40
50
60
70
150
230
ELE-100E□□101ME11D
ELE-100E□□221MF11D
ELE-100E□□331MHB5D
ELE-160E□□470ME11D
ELE-160E□□101MF11D
ELE-160E□□221MHB5D
ELE-250E□□330ME11D
ELE-250E□□470ME11D
ELE-250E□□101MF11D
ELE-350E□□330ME11D
ELE-350E□□470MF11D
ELE-350E□□101MHB5D
ELE-500E□□1R0ME11D
ELE-500E□□2R2ME11D
ELE-500E□□3R3ME11D
ELE-500E□□4R7ME11D
ELE-500E□□100ME11D
ELE-500E□□220ME11D
ELE-500E□□330MF11D
ELE-500E□□470MF11D
ELE-500E□□101MHB5D
ELE-630E□□100ME11D
ELE-630E□□220MF11D
ELE-630E□□330MF11D
ELE-630E□□470MHB5D
ELE-101E□□1R0ME11D
ELE-101E□□2R2ME11D
ELE-101E□□3R3ME11D
ELE-101E□□4R7ME11D
ELE-101E□□100MF11D
ELE-101E□□220MHB5D
□□ : Enter the appropriate lead forming or taping code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
1.0 to 10
22 to 33
47 to 330
120
0.42
0.55
0.70
1k
0.60
0.75
0.85
10k
0.80
0.90
0.95
100k
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
很抱歉,暂时无法提供与“ELE-250ETD101MF11D”相匹配的价格&库存,您可以联系我们找货
