F-224 WEB
BKS–125–01–L–V
BKS–115–01–L–V
BKS–155–01–L–V–P
BKT–111–01–L–V
BKT–127–01–L–V–S–P
BKT–133–03–L–V
BKT–131–05–L–V–S
(1.00 mm) .0394"
BKT, BKS SERIES
POLARIZED MICRO HEADER & SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?BKT or
www.samtec.com?BKS
BODY
STYLE
NO. OF
POSITIONS
1
BKT
Mates with:
Insulator Material:
BKS
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
(Odd lead counts only)
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
02
2.8 A per pin
02
(2 pins powered)
BODY
(5.08)
Operating Temp Range:
STYLE
.200
(2.54) (5.59)
(5.08)
-55 °C to +125 °C
.100 .220
.200
Insertion Depth:
(2.54) (5.59)
.100 .220
(1.40 mm) .055" minimum
–01
Normal Force:
40 grams (0.39 N) average
(1.00)
01
.03937
–02
Max Cycles:
(0.50) .020 TYP
(1.00)
01
100 with 10 µ" (0.25 µm) Au
.03937
(0.50) .020 TYP
(0.31) .012 SQ TYP
RoHS Compliant:
–03
Yes
(0.31) .012 SQ TYP
(1.65)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
.065
A
A
(1.19)
.047
(0.89)
BOARD
SPACE
B
(Mated
with BKS)
OPTIONS
–S
= Shrouded
(15 positions minimum)
–A
= Alignment Pin
(Metal or plastic at
Samtec discretion)
(13 positions minimum)
–P
(2.29) (4.27) (4.50)
.090 .168
.177
= Pick & Place Pad
(2.79) (4.78) (5.00)
.110 .188
.197
(6.35)
.250
(3.78) (5.77) (6.00)
.149 .227
.236
–TR
(6.35)
.250
= Tape & Reel Packaging
–FR
(0.50) .0197 x
(No. of positions +1)
(0.50) .0197 +x(2.44) .096
= Full Reel Tape & Reel
(must order max. quantity
+ (2.44) .096
(4.17 x 5.71)
.164 x .225
–S OPTION
(0.20)
.008
(0.20)
.008
(0.89)
.035 DIA
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(1.93) (3.91) (4.14)
.076 .154
.163
(4.17 x 5.71)
.164 x .225
(1.19)
.047
= Gold flash on post,
Matte Tin on tail
(4.80) (6.78) (7.00)
.189 .267
.276
–05
(0.50) .0197 x
(0.50) .0197 +x (0.25) .010
+ (0.25) .010
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–04
A
V
–F
Specify
BODY
STYLE
from
chart
07 thru 69
(1.65)
.065
PLATING
OPTION
B
B
per reel; Contact Samtec
for quantity breaks)
(3.61)
.142
(3.61)
.142
–P OPTION
DIA
–A.035
OPTION
FILE NO. E111594
APPLICATIONS
BKT
1
BKS
MATED
HEIGHT
BKS
BKT
LEAD STYLE
–01
–02
–03
–04
–05
MATED
HEIGHT*
(4.14) .163
(4.50) .177
(5.00) .197
(6.00) .236
(7.00) .276
*Processing conditions will
affect mated height.
Mates with:
BKT
NO. OF
POSITIONS
PLATING
OPTION
01
V
–F
07 thru 69
(07 positions available with –TR only)
–A
=Pre-plated
Gold flash on contact,
Matte Tin on tail
02
=Alignment Pin
(Metal or plastic at Samtec discretion)
(11 positions minimum)
–L
(4.11)
.162
01
–P
=Pre-plated
10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
(2.54) (5.59)
.100 .220
=Pick & Place Pad
Not always necessary for auto placement.
–TR
(0.36) .014
(1.00) .03937
=Tape & Reel Packaging
(0.50) .020 TYP
(0.50) .0197 x
No. of positions
+ (0.81) .032
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(2.12)
.084
OPTIONS
(5.26 x 6.07)
.207 x .239
(1.07)
.042
(2.21)
.087
(0.89)
.035
DIA
(0.20)
.008
–P OPTION
–A OPTION
–FR
=Full Reel Tape & Reel
(must order max. quantity per reel;
Contact Samtec for quantity breaks)
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BKS-125-01-L-V-P-TR 价格&库存
很抱歉,暂时无法提供与“BKS-125-01-L-V-P-TR”相匹配的价格&库存,您可以联系我们找货
