ICA-308-JGG
ICA-308-JGG
    SAMTEC(申泰)
    Conn DIP Socket SKT 8 POS 2.54mm Solder ST Thru-Hole Tube
ICA-308-JGG 数据手册
F-211-1 SUPPLEMENT ICA–320–SGT (2,54mm) .100" ICA–624–ZEGG ICA SERIES AUTOMATED INSERTION DIP SOCKETS Mates with: APA ROW SPACING & NO. OF CONTACTS ICA PLATING OPTION STYLE OPTION • Side & end stackable • Great for auto insertion • Open body design Row Space (2,54) .100 X No. of Spaces Row Spacing +(2,41) .095 except –H is + (2,54) .100 (7,64) .300 (10,16) .400 or (15,24) .600 (2,54) .100 X No. of Positions (2,54) .100 *–322 has no cross bar on one end. SPECIFICATIONS For complete specifications see www.samtec.com?ICA Insulator Material: Black Glass Filled Polyester except -328 is LCP Contact: BeCu Shell: Brass Plating: Au or Sn over 50µ" Ni Flammability Rating: UL 94V-O Insulation Resistance: 5000 MΩ min Temperature Range: -55°C to +105°C with Tin -55°C to +125°C with Gold. Withstanding Voltage: 1000 VRMS Current Rating: 1A Contact Resistance: 10mΩ max Lead Size Range: .015" (0,38mm) to .022" (0,56mm) DIA and most IC leads Insertion Force: (Single contact only) Standard = 9 oz avg, 16 oz max; Low Insertion Force = 2.5 oz avg, 5.5 oz max Withdrawal Force: (Single contact only) Standard = 2.5 oz avg, 1.5 oz min; Low Insertion Force = 2.0 oz avg, 0.35 oz min Lead-Free Solderable: Wave only RoHS Compliant: Yes (2,54) .100 –2 GG Specify from chart below = 30µ" (0,76µm) Gold contact, 10µ" (0,25µm) Gold Shell No. of Contacts –308 –314 –316 –318 –320 .300 (7,62) –322 * –324 –328 –422 .400 (10,16) –624 –628 –632 .600 (15,24) –640 –648 08 14 16 18 20 22 24 28 22 24 28 32 40 48 OPTION (Leave Blank for Standard Version) Wire-Wrap = .360 (9,14) Option Tail Requires Style –W or –ZW Specify desired = .260 (6,60) suffix for shorter Wire-Wrap tail. Tail –3 GT = 30µ" (0,76µm) Gold contact, Tin Shell Requires Style –S or –ZS –L = Locking Socket ST Requires GT Plating Option = 10µ" (0,25µm) Gold contact, Tin shell (Styles –S & –ZS only) Note: Some sizes, styles and options are non-standard, non-returnable. –S, –ZS, –ZA –W, –ZW –ZE = Printed Circuit -ZS & -ZA = Low Insertion Force = Wire-Wrap ZW = Low Insertion Force = Elevated Low Insertion Force (4,90) .193 (1,32) .052 DIA Z (12,95) .510 Y (0,64) .025 SQ X X Y DIA TAIL –S or –ZS (0,51) .020 (3,18) .125 –ZA (0,51) .020 (4,57) .180 LEAD STYLE (1,32) .052 DIA Z (7,62) .300 (8,89) .350 Locking lead available with –S and –ZS. See OPTION. Shorter wire-wrap tail lengths available. See OPTION. (3,43) .136 Insertion Depth = .095" (2,41) to .145" (3,68): Style S Component Part No. = SC-1P1 Style ZS Component Part No. = EZ-1P1 Style ZA Component Part No. = EZ-6P1 Option L Component Part No. = SC-1L1 or EZ-1L1 –L Option Insertion Depth = .125" (3,18) to .157" (3,99) Style W Component Part No. = SC-1W1(1) Style ZW Component Part No. = EZ-1W1(1) Style W-2 Component Part No. = SC-1W1(2) Style ZW-2 Component Part No. = EZ-1W1(2) Style W-3 Component Part No. = SC-1W1(3) Style ZW-3 Component Part No. = EZ-1W1(3) WWW.SAMTEC.COM (1,32) .052 DIA (0,89) .035 DIA (13,77) .542 (8,86) .349 (4,32) .170 (0,51) .020 Insertion Depth = .125" (3,18) to .170" (4,32) Style ZE Component Part No. = EZ-2P3
ICA-308-JGG 价格&库存
很抱歉,暂时无法提供与“ICA-308-JGG”相匹配的价格&库存,您可以联系我们找货
