AW-05-03-G-D-200-075-A 数据手册
SMT MICRO
BOARD STACKER
(0.80 mm) .0315" PITCH • AW SERIES
AW
AW
Mates:
CLE
SPECIFICATIONS
Insulator Material:
Top: Black LCP
Bottom: Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
NO. PINS
PER ROW
05 thru 90
- 03 -
PLATING
OPTION
-D-
–G
STACKER
HEIGHT
–“XXX”
= 10 µ"
(0.25 µm)
Gold
= Stacker
Height
(in inches)
(3.09 mm)
.122" to
(5.84 mm)
.230"
Example:
–175
= (4.45 mm)
.175"
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (05-40)
(0.15 mm) .006" max (41-90)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
POST
HEIGHT
–“XXX”
= Post
Height
(in inches)
(1.91 mm)
.075"
minimum
Example:
–075
= (1.91 mm)
.075"
OTHER
OPTION
–ES
= End Shroud
11 pins/row min.
(–075 Post
Height only)
–EP
= End Shroud
with Guide Post
(–075 Post
Height only)
11 pins/row min.
–A
= Alignment Pin
(4 positions min.)
(Available for
board stacks
between
(4.06 mm) .160" to
(5.84 mm) .230")
(Metal or plastic at
Samtec discretion.)
No. of positions x (0.80) .0315
(3.05)
.120
–P
= Pick & Place Pad
(8 positions min.)
–TR
= Tape & Reel
(84 positions max.)
OPTIONS
–EP OPTION
–P OPTION
POST
HEIGHT
(7.75)
.305
MAX
OVERALL
LENGTH
STACKER
HEIGHT
(3.09)
.122
to
(5.84)
.230
(1.91)
.075
MIN
(1.40)
.055
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(84 positions max.)
(1.70)
.067
(4.57)
.180
–ES OPTION
(4.17)
.164
(3.56)
.140
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with
gold or selective gold
plated connectors.
Contact ipg@samtec.com
for more information.
Some lengths, styles and
options are non-standard,
non-returnable.
–EP OPTION
–ES OPTION
–P OPTION
samtec.com?AW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
AW-05-03-G-D-200-075-A 价格&库存
很抱歉,暂时无法提供与“AW-05-03-G-D-200-075-A”相匹配的价格&库存,您可以联系我们找货
