F-224 WEB
BDL–110–G–F
BBL–112–T–E
BBD–130–T–B
BHS–125–G–A
(2.54 mm) .100"
BBS, BBL, BHS, BBD, BDL SERIES
BBS–116–G–C
MACHINED BOARD STACKING STRIPS
Mates with:
SS, SD, HSS, SL, SDL,
ESS, ESD
TYPE
STRIP
1
PLATING
OPTION
NO. PINS
PER ROW
LEAD
STYLE
FEATURES
• Low profile design
achieves (3.89 mm)
.153" board spacings
when mated with SL
Series.
• Approach the reliability
of a permanent
connection with the
flexibility of a separable
connection.
SPECIFICATIONS
For complete specifications
see www.samtec.com?BBS,
www.samtec.com?BBL,
www.samtec.com?BHS
www.samtec.com?BBD or
www.samtec.com?BDL
Insulator Material:
Black Liquid Crystal Polymer
(BBL, BHS)
Black Glass Filled Polyester
(BBS, BBD, BDL)
Temperature Range:
-55 °C to +125 °C
Terminal Material:
Phosphor Bronze or Brass
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Lead-Free Solderable:
Yes (BBL, BDL, BHS-S)
No, Lead Wave only
(BBS, BBD, BHS-N)
BBS
–G
(2.54) .100 x No. of Positions
= 20 µ" (0.51 µm)
Gold
(2.54)
.100
= Standard Single Row
(2.54) .100 TYP
BBL
= Low Profile Single Row
(1.27)
.050
–T
(2.54)
.100
= Tin
BHS
BBL body available with
Styles –E & –F only.
BBS
BHS
= High Temp Single Row
BBL
01 thru 32
BBD
= Standard Double Row
= BBS & BBL
(2.54)
.100
(5.08)
.200
(2.54) .100 TYP
(1.27)
.050
01 thru 36
(2.54)
.100
BDL
= Low Profile Double Row
BDL
BBD
–A
Z = (5.33 mm) .210"
= BBD, BDL & BHS
BDL body available with
–B
Z = (8.51 mm) .335"
–C
Z = (14.86 mm) .585"
–E
–F
Z = (1.78 mm) .070"
Z = (2.16 mm) .085"
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
(0.46)
.018
DIA
Style E: Style F:
(2.67)
(3.18)
.105
.125
(3.18)
.125
FILE NO. E111594
(3.18)
.125
Z
(1.78)
.070
DIA
(1.27)
.050
(3.18)
.125
(0.46)
.018
DIA
Z
(1.78)
.070
DIA
(0.46)
.018
DIA
BBL
Series
(1.27)
.050
DIA
(0.46)
.018
DIA
BBS and BHS
Series
Z
BBD
Series
BDL
Series
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“BBS-104-G-G”相匹配的价格&库存,您可以联系我们找货
