RUGGED HIGH-SPEED STRIPS
FEATURES & BENEFITS
Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications,
and enabled by Samtec's signal integrity-optimized Edge Rate® contact system.
• Up to 1.5 mm contact wipe for a reliable connection
• 20 to 200 positions
• Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch
• 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch
• 0.635 mm pitch system with extremely slim 2.5 mm body width
• Rugged latching, extended guide posts and 360° shielding
Signal integrity-optimized
Edge Rate® contact
system reduces
broadside coupling
• Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302.
Visit samtec.com/set
EDGE RATE® STACK HEIGHT FLEXIBILITY
(shown in mm)
5
7
8
ERM6/
ERF6
10
9
12
11
ERM5/ERF5
13
14
15
16
18
17
ERM8/ERF8
Rugged 360º shielding
reduces EMI
KEY SPECIFICATIONS
SERIES
PITCH
ERM5 / ERF5
0.50 mm
ERM6 / ERF6
0.635 mm
ERM8 / ERF8
0.80 mm
F-224
INSULATOR
MATERIAL
TERMINAL MATERIAL
Phosphor Bronze or BeCu (ERM5),
BeCu (ERF5)
Black LCP
Copper Alloy
Phosphor Bronze or BeCu (ERM8),
BeCu (ERF8)
PLATING
Au or Sn
over 50 µ"
(1.27 µm)
Ni
OPERATING
TEMP RANGE
-55 °C to +125 °C
CURRENT
RATING
VOLTAGE
RATING
1.5 A
190 VAC
1.4 A
155 VAC
1.4 A
225 VAC
LEAD-FREE
SOLDERABLE
Yes
samtec.com/EdgeRate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • RUGGED HIGH-SPEED HEADERS & SOCKETS
TYPE
POSITIONS PER ROW
–005, –010, –011,
–013, –020, –025,
–030, –035, –040,
–049, –050, –060,
–070, –075, –100
ERM8
= Header
ERF8
= Socket
LEAD
STYLE
PLATING
OPTION
DV
–L
SPECIFY
LEAD
STYLE
FROM
CHART
–DS
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–S
= Tape & Reel
(100 Positions N/A)
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity per reel;
contact Samtec for
quantity breaks)
(100 Positions N/A)
–L
ERM8
= Latching
(ERM8 –03.0, –05.0 & –09.0
Lead Styles only & –EGP
Option not available)
(ERF8 –05.0,–07.0 & –09.0
Lead Style only, –L & –EGP
Options not available)
Cable Mates:
ERCD, ERDP
= Extended Guide Post
(ERM8 –05.0 & ERF8 –07.0
Lead Style Only & –L
Board Mates:
ERF8
"X"R
–TR
= Differential Pair
(ERM8 –05.0 Lead Style
with –010, –013, –025,
–049 Positions only)
(–P not available)
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
(100 Position Only Available
with ERM8–09.0 & ERF8–05.0
Lead Styles; –L or –EGP N/A)
OPTIONS
–EGP
1RRI3RVLWLRQV[
²/ ²(*3 1RRI3RVLWLRQV[
ERM8
LEAD
STYLE
A
–02.0
(5.97) .235
N/A
–03.0
(6.97) .274
(1.60) .063
–DSP
B
–05.0
(8.91) .351
(1.17) .046
–08.0
(11.91) .469
N/A
-09.0
(12.91) .508
(1.60) .063
= Differential Pair with
Extended Guide Post
(ERM8 –05.0 Lead Style with
–013 and –025 Positions only)
–K
= Polyimide Film
Pick & Place Pad
(–02.0 Lead Style not available)
–P
= Pick & Place Pad
(ERM8 –02.0, –03.0 &
–05.0 Lead Styles only)
(–DS not available)
–L
–EGP
MATED HEIGHT*
View complete specifications at: samtec.com?ERM8
(1.50 mm)
.059"
Nominal
Wipe
ERF8
Board Mates:
ERM8
ERF8
Cable Mates:
ERCD, ERDP
1RRI3RVLWLRQV[
ERF8
LEAD
STYLE
C
D
–05.0
(5.34) .210
(1.60) .063
–07.0
(7.25) .285
(1.17) .046
-09.0
(9.34) .368
(1.60) .063
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Some lengths, styles and
options are non-standard,
non-returnable.
–L
–05.0
–07.0
–09.0
–02.0
(7.00)
.276
(9.00)
.354
(11.00)
.433
–03.0
(8.00)
.315
(10.00)
.394
(12.00)
.472
–05.0
(10.00)
.394
(12.00)
.472
(14.00)
.551
–08.0
(13.00)
.512
(15.00)
.591
(17.00)
.669
–09.0
(14.00)
.551
(16.00)
.630
(18.00)
.709
*Processing conditions will affect
mated height.
ERF8 LEAD STYLE
ERM8
LEAD
STYLE
–EGP
View complete specifications at: samtec.com?ERF8
samtec.com/EdgeRate
F-224
很抱歉,暂时无法提供与“ERF8-100-05.0-S-DV”相匹配的价格&库存,您可以联系我们找货
