HDAM-23-12.0-S-13-1-P 数据手册
HDAM–23–17.0–S–13–2
F-224 SUPPLEMENT
HDAM–11–12.0–S–13–2
(2.00 mm) .0787"
HDAM SERIES
RUGGED ELEVATED HIGH-DENSITY ARRAY
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?HDAM
Mates with:
HDAF
Open-pin-field for
Single-Ended
or Differential Pair
configurations
Intermateable with
Molex HD Mezz
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
3.4 A per pin
(6 adjacent pins powered)
Operating Temp Range:
-55 °C to +125 °C
Working Voltage:
200 VAC
Mated Cycles:
100
RoHS Compliant:
Yes
Lead-Free Solderable:
Yes
Lead-Free
Solder Charge
299, 195
and 143 pins
Elevated stack heights
of 20 mm, 25 mm,
30 mm and 35 mm
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
HDAM
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
= 30 µ"
(0.76 µm)
Gold on
contact area,
Matte Tin
on tails and
guide pins
FILE NO. E111594
DIFFERENTIAL
APPLICATIONS
—11, —15, —23
(1.20)
.0472
13
—S
SOLDER
TYPE
—2
= Lead-Free
Tin Alloy 95.5% Sn/
3.8% Ag/0.7% Cu
Solder Charge
OPTION
—P
= Pick &
Place Pad
ARRAY
11x13
15x13
23x13
(22.50)
.886
44
60
92
1A
ALSO AVAILABLE
(MOQ Required)
• Tin-Lead Solder Charge
• Other platings
Notes:
HD Mezz is a trademark of
Molex Incorporated
—TR
—FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(5.09)
.200
1M
*2:1 S:G Ratio
(2.00)
.0787
Leave blank for
tray packaging
=Tape & Reel
(2.00)
.0787
PAIR
COUNT*
PACKAGING
No. of
Pins
Per
Row
x
(2.00)
.0787
(16.06)
.632
LEAD
STYLE
No. of
Pins
Per
Row
x
(2.00)
.0787
(11.55)
.455
(1.20)
.0472
—12.0
—17.0
A
(14.41)
.567
(19.41)
.764
A
Some lengths, styles and
options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HDAM-23-12.0-S-13-1-P 价格&库存
很抱歉,暂时无法提供与“HDAM-23-12.0-S-13-1-P”相匹配的价格&库存,您可以联系我们找货
