Mains transformer
FL 10/24
Advantages
Minimum size at high output
Low height
Dual input voltage for series or parallel connection
Dual output voltage for series or parallel connection
Permanent corrosion protection, high insulation value and maximum
electrical reliability thanks to XtraDenseFill resin encapsulation
Self-extinguishing potting material
Applications
As a mains transformer for adjustment of the voltage and simple electrical
isolation.
As an isolating transformer for the safe electrical isolation of the input and
output sides. The transformer may be used to set up protective separation as a
protective measure in accordance with VDE 0100.
As a safety isolating transformer for the safe electrical isolation of the input
and output sides. The transformer is suitable for creating SELV and PELV
circuits because of the limit on the output voltage.
Sample application
Picture shows FL 42/12
Standards
Z
Mains transformer
to: VDE 0570 Teil 2-1, DIN EN 61558-2-1, EN 61558-2-1, IEC 61558-2-1, UL
5085-1/-2, CSA 22.2 No.66
Approvals
W / Z
UL 5085-1/-2, CSA 22.2 No.66
Mains transformer
FL 10/24
FL 10/24
Rated input voltage
Rated frequency
2 x 115 Vac
50 - 60 Hz
Output
Rated output voltage
Rated Power
No-load voltage (app. x factor)
No-load loss (typ.)
Efficiency
2 x 24 Vac
10 VA
1.32
1.10 W
72.0 %
Standards
Classification
Mains transformer
Type
FL 10/24
Terminal and mounting
Pins for PCB
Terminals
Measures and weights
UI 39/8
0.28 kg
Core type
Weight
5.5
16.0
15.0
2.5
0.8
PRI
SEC
Approvals
Approvals
cURus, VDE
Environment
Ambient temperature max.
40 °C
11.5
26.0
10.0
50.0
57.0
0.0
0.0
22.8
45.0
62.5
68.0
Safety and protection
Type
Insulation class
Protection index
Safety class (prepared)
Short circuit strength
Encapsulated
VDE=E, UL=class 105
IP 00
II
non-short-circuit proof
Order numbers
Order Number
FL 10/24
Subject to change.
Input
30
Type
很抱歉,暂时无法提供与“FL10/24”相匹配的价格&库存,您可以联系我们找货
