EVK-CONNECT-020
EVK-CONNECT-020
    DENSITRON
    Module
EVK-CONNECT-020 数据手册
OLED DISPLAY MODULE Application Notes PRODUCT NUMBER DD-128128FC-5B with EVK board Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data TABLE OF CONTENTS 1 SCHEMATIC ................................................................................................................... 4 1.1 1.2 EVK SCHEMATIC ........................................................................................................ 4 DC-DC SCHEMATIC .................................................................................................... 6 2 SYMBOL DEFINITION ................................................................................................. 7 3 TIMING CHARACTERISTICS .................................................................................... 9 4 CONNECTION BETWEEN OLED AND EVK ......................................................... 13 5 POWER DOWN AND POWER UP SEQUENCE ...................................................... 15 6 HOW TO USE THE DD-128128FC-5B ....................................................................... 16 6.1 RECOMMENDED INITIAL CODE .................................................................................. 17 Product No. DD-128128FC-5B REV. B Page 2 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data REVISION RECORD Rev. Date A 27 June 08 First Issue B 06 May 09 Updated Schematic Product No. Page Chapt. DD-128128FC-5B Comment REV. B ECR no. Page 3 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 1 Schematic 1.1 EVK Schematic Product No. DD-128128FC-5B REV. B Page 4 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Product No. DD-128128FC-5B REV. B Page 5 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 1.2 DC-DC Schematic Product No. DD-128128FC-5B REV. B Page 6 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 2 Symbol Definition : D0-D17 These pins are 18-bit bi-directional data bus to be connected to the MCU’s data bus. : BS0, BS1, BS2, BS3 These input pins are used to configure MCU interface selection by appropriate logic setting, which is described in the following table. User can fix these pins by jumper (J2, J3). Unlike BS0,BS1 which are controlled by hardware, BS2,BS3 is controlled by software command 0x36. Table 1 – MCU Interface Selection Setting : E/RD# This pin is MCU interface input. When interfacing to a 6800-series microprocessor, this pin is used as the Enable (E) signal. Read/write operation is initiated when this pin is pulled high and the chip is selected. When connecting to an 8080-microprocessor, this pin receives the Read (RD) signal. Data read operation is initiated when this pin is pulled low and the chip is selected. When serial interface is selected, this pin E(RD) must be connected to VSS. : R/W# This pin is MCU interface input. When interfacing to a 6800-series microprocessor, this pin is used as Read/Write (R/W) selection input. Read mode will be carried out when this pin is pulled high and write mode when low. When 8080 interface mode is selected, this pin is the Write (WR) input. Data write operation is initiated when this pin is pulled low and the chip is selected. When serial interface is selected, this pin R/W must be connected to VSS. : D/C# This pin is Data/Command control pin. When the pin is pulled high, the data at D0-D8 is treated as display data. When the pin is pulled low, the data at D0-D8 is transferred to the command register. For detail relationship to MCU interface signals, please refer to the timing characteristics diagrams at following pages and datasheet. :This pin is reset signal input. When the pin is low, initialization of the chip is executed. CS#:This pin is the chip select input. The chip is enabled for MCU communication only when CS is RES# pulled low. : VDD:Power supply pin for logic operation of the driver. VCC This is the most positive voltage supply pin of the chip. Product No. DD-128128FC-5B REV. B Page 7 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data :Power supply ground. GND VDDIO: :This pin is a power supply pin of I/O buffer. It should be connected to VDD or external source (1.8V). All I/O signal should have VIH reference to VDDIO. When I/O signal pins (BS01, 2,3, M/S, CLS, D0-D17, control signals) pull high, they should be connected to VDDIO. In the EVK PCB board which is use a jump (J1) connect to VDD (Default). Customer can put out the jump and input the 1.8V through this jump VSL: :This is segment voltage reference pin. For reduce power consumption, we suggest add a resistor and Zenor diode between this pin and GND. VCOMH: :This pin is the input pin for the voltage output high level for COM signals. It can be supplied externally or internally. When VCOMH is generated internally, a capacitor should be connected between this pin and GND. Product No. DD-128128FC-5B REV. B Page 8 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 3 Timing characteristics Table 2 6800-Series MPU Parallel Interface Timing Characteristics Figure 1 6800-series MPU parallel interface characteristics Product No. DD-128128FC-5B REV. B Page 9 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Table 3 8080-Series MPU Parallel Interface Timing Characteristics Figure 2 8080-series MPU parallel interface characteristics Product No. DD-128128FC-5B REV. B Page 10 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Table 4: 4-bit SPI-Series Timing Characteristics Figure 3: 4-bit SPI-Series characteristics Product No. DD-128128FC-5B REV. B Page 11 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Table 5: 3-bit SPI-Series Timing Characteristics Figure 4: 3-bit SPI-Series characteristics Product No. DD-128128FC-5B REV. B Page 12 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 4 Connection Between OLED and EVK Figure 5 EVK PCB and DD-128128FC-5B Module Figure 6 the DD-128128FC-5B and EVK assembled (Top view) Product No. DD-128128FC-5B REV. B Page 13 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data Because the package of DD-128128FC-5B is COF, the connect pads are on the top of the module, and the connector which on the EVK PCB board is double size connect type. So when assemble the module with EVK, the module must face up first and plug into the connector. When finished assembling the module and EVK, then push the locking pad to lock the module. See figure 6. When finished assembling the module and EVK, the user can use leading wire to connect the EVK with customers system. Example shown in figure 7. Figure 7 control MCU (not supplied) connected with EVK Note 1:It is the external most positive voltage supply. In this sample is connected to power supply. Product No. DD-128128FC-5B REV. B Page 14 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 5 Power Down and Power up Sequence To protect OLED panel and extend the panel life time, the driver IC power up/down routine should include a delay period between high voltage and low voltage power sources during turn on/off. Such that the panel has enough time to charge up or discharge before/after operation. Power up Sequence: 1. Power up VDD 2. Send Display off command 3. Driver IC Initial Setting 4. Clear Screen 5. Power up VDDH 6. Delay 100ms (when VDD is stable) 7. Send Display on command Power down Sequence: 1. Send Display off command 2. Power down VDDH 3. Delay 100ms (when VDDH is reach 0 and panel is completely discharges) 4. Power down VDD Product No. DD-128128FC-5B REV. B Page 15 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 6 How to use the DD-128128FC-5B Reset Set RES#=0; Delay 100ms; RES#=1 Initial IC code Suggest all registers set again Clear RAM Display on Start sending data Product No. DD-128128FC-5B REV. B Page 16 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data 6.1 Recommended Initial code write_c(0xfd); //Command Lock write_d(0xb3); write_c(0xd3); //Function Selection write_d(0x01); write_c(0xd6); //High Power protection write_d(0x07); write_c(0xcc); //Enable External VSL write_d(0xb0); write_d(0x16); write_c(0x35); //Enable Tearing Effect write_d(0x00); write_c(0xca); //Set MUX Ratio write_d(0x7f); write_c(0xba); //Set Contrast For Color A write_d(0x1c); write_c(0xbb); //Set Contrast For ColorB write_d(0x15); write_c(0xbc); //Set Contrast For ColorC write_d(0x23); write_c(0xcf); //Set Second Precharge Speed write_d(0x03); write_c(0xcd); //Set Phase Length write_d(0x32); write_c(0xd2); //Set Display Clock Divider/Oscillator Frequency write_d(0x10); write_c(0xce); //Set Second Precharge Period write_d(0x0b); write_c(0xbd); //Set First Precharge Voltage write_d(0x09); write_c(0xe3); //Low Gray Scale Enhancement write_d(0x02); write_c(0x51); //Write Lumimance write_d(0xf0); write_c(0xd3); //Set VcomH write_d(0x04); write_c(0xd1); //contrast compensation write_d(0x00); write_d(0x00); write_c(0xd0); //First Per-charge Compensation write_d(0x04); write_d(0x3f); write_c(0x36); //Memory Access Control write_d(0x00); write_d(0x01); write_c(0x11); //Sleep out write_c(0x3a); //Interface Pixel Format write_d(0x06); write_c(0x2a); //Set Column Address write_d(0x00); write_d(0x7f); write_c(0x2b); //Set Row Address write_d(0x00); write_d(0x7f); write_c(0xbe); //Gamma Lock UpTable write_d(1); //1 write_d(6); //3 Product No. DD-128128FC-5B REV. B Page 17 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data write_d(7); //5 write_d(8); //7 write_d(10); //9 write_d(12); //11 write_d(13); //13 write_d(13); //15 write_d(14); //17 write_d(14); //19 write_d(15); //21 write_d(16); //23 write_d(17); //25 write_d(18); //27 write_d(19); //29 write_d(23); //31 write_d(28); //33 write_d(33); //35 write_d(34); //37 write_d(38); //39 write_d(41); //41 write_d(49); //43 write_d(50); //45 write_d(53); //47 write_d(65); //49 write_d(67); //51 write_d(79); //53 write_d(85); //55 write_d(96); //57 write_d(106); //59 write_d(116); //61 write_d(127); //63 write_d(1); //1 write_d(8); //3 write_d(10); //5 write_d(13); //7 write_d(15); //9 write_d(16); //11 write_d(17); //13 write_d(18); //15 write_d(18); //17 write_d(19); //19 write_d(20); //21 write_d(29); //23 write_d(32); //25 write_d(33); //27 write_d(34); //29 write_d(35); //31 write_d(39); //33 write_d(43); //35 write_d(49); //37 write_d(50); //39 write_d(53); //41 write_d(58); //43 write_d(65); //45 write_d(67); //47 write_d(72); //49 write_d(80); //51 write_d(84); //53 write_d(94); //55 Product No. DD-128128FC-5B REV. B Page 18 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data write_d(99); //57 write_d(110); //59 write_d(116); //61 write_d(127); //63 write_d(1); //1 write_d(4); //3 write_d(6); //5 write_d(9); //7 write_d(10); //9 write_d(12); //11 write_d(13); //13 write_d(13); //15 write_d(14); //17 write_d(14); //19 write_d(15); //21 write_d(16); //23 write_d(17); //25 write_d(18); //27 write_d(19); //29 write_d(22); //31 write_d(28); //33 write_d(32); //35 write_d(34); //37 write_d(36); //39 write_d(43); //41 write_d(49); //43 write_d(50); //45 write_d(55); //47 write_d(64); //49 write_d(68); //51 write_d(80); //53 write_d(87); //55 write_d(97); //57 write_d(106); //59 write_d(116); //61 write_d(127); //63 write_c(0x29); //Disable All Pixels On/Off Sub function for 80 interface: void write_c(unsigned char out_command) { bD_C=0; bCS=0; bR_W=0; P1=out_command; bR_W=1; bCS=1; bD_C=1; } Product No. DD-128128FC-5B REV. B Page 19 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data void write_d(unsigned char out_data) { bD_C=1; bCS=0; bR_W=0; P1=out_data; bR_W=1; bCS=1; } : Note 1. For 80 series CPU interface. 2. For 8 Bbit Ttiple Transfer 252K support. Product No. DD-128128FC-5B REV. B Page 20 / 20 Copyright ©2008 DENSITRON TECHNOLOGIES plc. All rights reserved. – Proprietary Data
EVK-CONNECT-020 价格&库存
很抱歉,暂时无法提供与“EVK-CONNECT-020”相匹配的价格&库存,您可以联系我们找货
