95.11.22
95.11.22
95.11.22
95.11.22
95.11.22
95.11.22
95.11.22
SUNON
Notes
Ⅰ.SAFETY
1. DO NOT use or operate this fan in excess of the limitations set forth in this
specification. SUNON is not be responsible for the non-performance of this fan
and/or any damages resulting from its use, if it is not used or operated in
accordance with the specifications.
2. SUNON recommends adding a protection circuit to the product or application in
which this fan is installed, such as a thermo-fuse, or current-fuse or thermoprotector. The failure to use such a device may result in smoke, fire, electric
shock by insulation degradation in cases of motor lock, motor lead short circuit,
overload, or over voltage, and/or other failure.
3. SUNON recommends installing a protection device to the product or application
in which this fan is installed if there is a possibility of reverse-connection between
VDC (+) and GND (-). The failure to install such a device may result in smoke,
fire, and/or destruction, although these conditions may not manifest immediately.
4. This fan must be installed and used in compliance with all applicable safety
standards and regulations.
5. Use proper care when handling and/or installing this fan. Improper handling or
installation of this fan may cause damage that could result in unsafe conditions.
6. Use proper care during installation and/or wiring. Failure to use proper care may
cause damage to certain components of the fan including, but not limited to, the
coil and lead wires, which could result in smoke and/or fire.
7. DO NOT use power or ground PWM to control the fan speed. If the fan speed
needs to be adjusted, please contact Sunon to customize the product design for
your application.
8. For critical or extreme environments, including non stop operation, please contact
Sunon and we will gladly provide assistance with your product selection to ensure
an appropriate cooling product for your application.
SPEC.NO
A17000720G-00 REVISION DATE
建準電機工業股份有限公司
ISSUE DATE
11. 22. 2005 E D I T I O N 0
SUNONWEALTH ELECTRIC
MACHINE INDUSTRY CO., LTD.
PAGE
8 OF 11
95.11.22
SUNON
Notes
II. SPECIFICATION MODIFICATION
1. SUNON offers engineering assistance on fan installation and cooling system
design.
2. All changes, modifications and/or revisions to the specifications, if any, are
incorporated in the attached specifications.
3. No changes, modifications and/or revisions to these specifications are effective
absent agreement, by both Sunon and the customer, in writing.
4. This fan will be shipped in accordance with the attached specification unless
SUNON and the customer have agreed otherwise, in writing, as specficied in
Paragraph 3, above.
III. OTHER
1. When building your device, please examine thoroughly any variation of EMC,
temperature rise, life data, quality, etc. of this product by shock/drop/vibration
testing, etc. If there are any problems or accidents in connection with this
product, it should be mutually discussed and examined.
2. Use proper care when handling this fan. Components such as fan holders or
bearings may be damaged, if touched with fingers or other objects. Additionally,
static electricity (ESD) may damage the internal circuits of the fan.
3. DO NOT operate this fan in proximity to hazardous materials such as organic
silicon, cyanogens, formalin, phenol, or corrosive gas environments including, but
not limited to, H2S, SO2, NO2, or Cl2.
4. SUNON recommends that you protect this fan from exposure to outside elements
such as dust, condensation, humidity or insects. Exposure of this fan to outside
elements such as dust, condensation, humidity or insects may affect its
performance and may cause safety hazards. SUNON does not warrant against
damage to the product caused by outside elements.
SPEC.NO
建準電機工業股份有限公司
ISSUE DATE
PAGE
9 OF 11
95.11.22
SUNON
Notes
5. This fan must be installed properly and securely. Improper mounting may cause
harsh resonance, vibration, and noise.
6. Fan guards may prevent injury during handling or installation of the fan and are
available for sale with this fan.
7. Unless otherwise noted, all testing of this fan is conducted at 25°C ambient
temperature and sixty-five percent (65%) relative humidity.
8. DO NOT store this fan in an environment with high humidity. This fan must be
stored in accordance with the attached specifications regarding storage
temperature. If this fan is stored for more than 6 months, SUNON recommends
functional testing before using.
9. SUNON reserves the right to use components from multiple sources at its
discretion. The use of components from other sources will not affect the
specfications as described herein.
10. The “Life Expectancy” of this fan has not been evaluated for use in combination
with any end application. Therefore, the Life Expectancy Test Reports (L10 and
MTTF Report) that relate to this fan are only for reference.
VI. WARRANTY
This fan is warranted against all defects which are proved to be fault in our
workmanship and material for one year from the date of our delivery. The sole
responsibility under the warranty shall be limited to the repair of the fan or the
replacement thereof, at SUNON’s sole discretion. SUNON will not be responsible
for the failures of its fans due to improper handing, misuse or the failure to follow
specifications or instructions for use. In the event of warranty claim, the customer
shall immediately notify SUNON for verification. SUNON will not be responsible
for any consequential damage to the customer’s equipment as a result of any fans
proven to be defective.
SPEC.NO
建準電機工業股份有限公司
ISSUE DATE
PAGE
10 OF 11
95.11.22
SUNON
Declaration of RoHS
Control declaration of environment-related substances/materials
1.In accordance with the Restriction of Hazardous Substances (RoHS) Directive,
Sunon product with P/N: GN models have complied with law and discipline not to
employ the forbidden substances, and restrict the allowable concentration of some
limited substances deliberately in our components.
No
1
2
Substance
Criteria
CFCs & HCFCs (ozone depleting substances)
Forbidden
Chlorinated Organic Solvent
Forbidden
