DATASHEET
IEC Inlet Filters FN 9260
General Purpose Power Entry Module with Fuses
Rated currents up to 10 A
For one or two fuses
Approvals
Optional safety version (A type)
Complies with IEC/EN 60601-1
Snap-in versions (S type)
The FN 9260 power entry module combines an IEC
inlet, mains filter with excellent filter attenuation and
fuses in a small form factor. Choosing FN 9260
product line brings you rapid availability of a
standard filter associated with the necessary safety
acceptances. Standard IEC connector filters are a
practical solution helping you to pass EMI system
approval in a short time. A wide selection on
amperage ratings, output connections, mounting
possibilities and filters for medical applications are
designed to offer you the desired solution.
Features and Benefits
Technical specifications
Maximum continuous operating voltage
Operating frequency
Rated currents
High potential test voltage
250 VAC, 50/60 Hz
dc to 400 Hz
1 to 10 A @ 40 °C max.
P –> PE 2000 VAC for 2 sec (standard types)
P –> PE 2500 VAC for 2 sec (B types)
P –> N 760 VAC for 2 sec (standard types)
Protection category
P –> N 1700 VDC for 2 sec (B types)
IP40 according to IEC 60529
Flammability corresponding to
MTBF @ 40°C/230V (Mil-HB-217F)
UL 94 V-2 or better
2,200,000 hours
Temperature range (operation and storage)
Design corresponding to
Fuse holder
-25 °C to +85 °C (25/85/21)
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
1 or 2 fuses (Ø 5 x 20 mm)
Exceptional conducted attenuation performance,
based on chokes with high saturation resistance
and excellent thermal behavior.
B types comply with the requirements of IEC/EN
60601-1 for creepage and clearance, leakage current
and high potential testing.
Versions up to 10 A are available with fuse holder for
one or two fuses.
Custom-specific versions are available on request.
Typical applications
Portable electrical and electronic equipment
Medical equipment
Small to medium-sized machines and household
equipment
Single-phase power supplies, switch-mode power
supplies
Test and measurement equipment
Typical electrical schematic
2
EMC/EMI Products
Schaffner Group
Datasheets
2014
Filter selection table
Filter
Rated current
Leakage current*
Inductance
[A]
[μA]
2 (2.3)
373
@ 40 °C (25 °C)
FN 9260x-1-06-y
1 (1.2)
FN 9260x-4-06-y
4 (4.6)
FN 9260x-2-06-y
FN 9260x-6-06-y
FN 9260x-10-06-y
@ 230 VAC/50 Hz
6 (6.9)
10 (11.5)
373
373
373
373
L
Capacitance
Resistance
Cx
Cy
[mH]
[μF]
[nF]
[kΩ]
2.7
0.1
2.2
1000
5.3
1.0
0.3
0.2
0.1
0.1
0.1
0.1
2.2
2.2
2.2
2.2
R
Input/Output
connections
1000
-06
1000
-06
1000
1000
-06
-06
-06
Fuses
Weight
[Qty]
[g]
2
55
2
2
2
2
55
55
55
55
FN 9260xA1-1-06-y
1 (1.2)
37
5.3
0.1
0.22
1000
-06
2
55
FN 9260xA-4-06-y
4 (4.6)
74
1.0
0.1
0.47
1000
-06
2
55
FN 9260xA-2-06-y
FN 9260xA-6-06-y
FN 9260xA-10-06-y
2 (2.3)
6 (6.9)
10 (11.5)
74
74
74
2.7
0.3
0.2
0.1
0.1
0.1
0.47
0.47
0.47
1000
1000
1000
-06
-06
-06
2
2
2
55
55
55
FN 9260xB-1-06-y
1 (1.2)
2
5.3
0.1
1000
-06
2
55
FN 9260xB-4-06-y
4 (4.6)
2
1.0
0.1
1000
-06
2
55
FN 9260xB-2-06-y
FN 9260xB-6-06-y
FN 9260xB-10-06-y
2 (2.3)
6 (6.9)
10 (11.5)
2
2
2
2.7
0.3
0.2
0.1
1000
0.1
1000
0.1
1000
-06
-06
-06
2
2
2
55
55
55
FN 261x-1-06-y
1 (1.2)
373
5.3
0.1
2.2
1000
-06
1
55
FN 261x-4-06-y
4 (4.6)
373
1.0
0.1
2.2
1000
-06
1
55
FN 261x-2-06-y
FN 261x-6-06-y
FN 261x-10-06-y
2 (2.3)
6 (6.9)
10 (11.5)
373
373
373
2.7
0.3
0.2
0.1
0.1
0.1
2.2
2.2
2.2
1000
1000
1000
* Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
Product selector
For example: FN 9260-1-06-10, FN 9260SB-10-06-20, FN 261S-6-06-30
-06
-06
-06
1
1
1
55
55
55
EMC/EMI Products
3
Schaffner Group
Datasheets
2014
Typical filter attenuation
Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym
FN 9260: 1 to 4 A types
FN 261: 6 and 10 A types
FN 261: 1 to 4 A types
Mechanical data
FN 9260 / FN 261
FN 9260S / FN 261S
Dimensions
FN 261
A
B
C
D
FN 261S
FN 9260
FN 9260S
Tolerances
35
35
±0.3
46
36
41
34
41
±0.3
±0.3
±0.3
E
27.8
27.8
+0.3/-0
G
32
32
+0.3/-0
F
H
5.5
Ø 3.2
5.5
13.8
13.8
M
R ≤ 3.5
R ≤ 3.5
P
29
29.5
I
J
N
R
S
T*
12.5
33
M3
90°
T*
T*
* For selecting the panel thickness, please refer to the filter selector table.
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m / EN 22768-m
Please visit www.schaffner.com to find more details on filter connections.
±0.3
±0.1
12.5
±0.3
33
+0.3/-0
0.6-1.5
1.6-2.5
2.6-3.5
±0.3
4
EMC/EMI Products
Headquarters, global
innovation and development
center
Switzerland
Schaffner Group
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 630
info@schaffner.com
http://www.schaffner.com
Schaffner Group
Sales and application centers
China
Schaffner EMC Ltd. Shanghai
T20-3, No 565 Chuangye Road
Pudong New Area
201201 Shanghai
T +86 21 3813 9500
F +86 21 3813 9501 / 02
cschina@schaffner.com
http://www.schaffner.com.cn/
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 19 35 72 71
finlandsales@schaffner.com
France
Schaffner EMC S.A.S.
112, Quai de Bezons
Boîte postale 133
95103 Argenteuil
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
F +49 721 569110
germanysales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Galileo Galilei 47
20092 Cinisello Balsamo (MI)
T +39 02 66 04 30 45/47
F +39 02 61 23 943
italysales@schaffner.com
To nd your local partner within Schaffner‘s
global network: www.schaffner.com
© 2014 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published speci cations are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never be
operated
outside
their
published
speci cations. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Datasheets
Japan
Schaffner EMC K.K.
1-32-12, Kamiuma, Setagaya-ku
7F Mitsui-seimei Sangenjaya Bldg.
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
http://www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1
05-09 Kampong Ubi Industrial Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93
Miniparc III, Edificio E
El Soto de la Moraleja
Alcobendas
28109 Madrid
T +34 618 176 133
spainsales@schaffner.com
Sweden
Schaffner EMC AB
Turebergstorg 1, 6
19147 Sollentuna
T +46 8 5792 1121 / 22
F +46 8 92 96 90
swedensales@schaffner.com
Switzerland
Schaffner EMV AG
Nordstrasse 11
4542 Luterbach
T +41 32 6816 626
F +41 32 6816 641
sales@schaffner.ch
Taiwan R.O.C.
Schaffner EMV Ltd.
6 Floor, No. 413
Rui Guang Road
114 Neihu District Taipei City
T +886 2 87525050
F +886 2 87518086
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
UK
Schaffner Ltd.
5 Ashville Way
Molly Millars Lane
Wokingham
RG41 2PL Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
http://www.schaffner.uk.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
08837 Edison, New Jersey
T +1 800 367 5566
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
http://www.schaffner.com/us
Schaffner MTC LLC
6722 Thirlane Road
24019 Roanoke, Virginia
T +1 276 228 7943
F +1 276 228 7953
http://www.schaffner-mtc.com
Schaffner Trenco LLC
2550 Brookpark Road
44134 Cleveland, Ohio
T +1 216 741 5282
F +1 216 741 4860
www.schaffner-trenco.com
2014
很抱歉,暂时无法提供与“FN9260B-2-06.”相匹配的价格&库存,您可以联系我们找货
