2106-12S
2106-12S
    TECHSPRAY
    Conformal
    FINE-L-KOTE HT CONFORMAL COATING
2106-12S 数据手册
Rev. D (3/21) Page 1 of 2 Fine-L-Kote HT High-Temp Silicone Conformal Coating Product# 2106 Product Description High Temperature Silicone Coating is designed to prevent thermal breakdown at high temperatures. Silicone Conformal Coating is the most universal coating, offering protection for a wide variety of environments. Features / Benefits • Designed for high temperature environments • Fast-drying silicone 1-step process • Thermal resistance - to 662°F (350°C) • Dielectric strength - 560 volts/mil • IPC-CC-830B Certified • UL94 V-0 rated • Moisture resistant • Vibration resistant - flexible • UV indicator for black light inspection Usage Instructions For industrial use only. Read MSDS carefully prior to use. Before applying Fine-L-KoteTM conformal coatings, clean circuit boards to remove contamination and allow to dry. Cleaning may be performed with Techspray G3, E-LINETM and Precision-V defluxers. Spray Application: Apply top to bottom, allowing coating to flow evenly around components. Rotate PCB 90º and repeat application. Rotate and apply coating two additional times, then allow board to cure. If additional thickness is desired, apply additional coatings. When using liquid spray with automatic dispensing equipment, adjustments may be required in application rate and viscosity. Typical Product Data and Physical Properties Physical State: Odor: Color: Percent volatile: Vapor Density: Boiling Point: Flashpoint and method: Solubility in water Density: VOC: Shelf life: Liquid Aromatic odor Colorless 80 >1 (Air=1) 230ºF (110ºC) 40ºF (TAG CC) Insoluble 0.92 724 g/L 1 year Dip Application: Using automatic equipment or hand immersion technique, slowly immerse PCB into the coating and remove slowly. Use an average rate of approximately 1 foot per minute. After allowing the board to cure, process may be repeated to achieve desired thickness. Brush Application: Evenly apply coating to areas desired at thickness required. Allow time for curing before reapplying to achieve a thick coating. Use WonderMASK to protect components during conformal coating process. After application, cured Fine-L-KoteTM may be removed using Techspray Conformal Coating Removal Pen (2510-N or 2510-P). 800-858-4043 • www.techspray.com Rev. D (3/21) Page 2 of 2 Fine-L-Kote HT High-Temp Silicone Conformal Coating Product# 2106 Performance & Application Data Cure type Packaging and Availability Thermal/air Tack-free time (min) 45 Accelerated cure time/temp Ambient cure time Viscosity (bulk) 1 Step: 15 Min. @ 49°C 24 hr. 10-30 cps Operating temperature range Dielectric strength Insulation resistance (ohms) -40° to 350°C 560 V/Mil 1.33 x 1016 Coverage (1 mil dry film) 1 aerosol can = 20ft2 (1.9M2) 1 gal. liquid = 880ft2 (81.8M2) 2106-12S 2106-G 12oz. Liquid 1 Gallon Liquid Environmental Policy Techspray® is committed to developing products to ensure a safer and cleaner environment. We will continue to meet and sustain the regulations of all federal, state and local government agencies. Resources Techspray® products are supported by global sales, technical and customer services resources. For additional technical information on this product or other Techspray® products in the United States, call the technical sales department at 800-858-4043, email tsales@techspray.com or visit our web site at: www.techspray.com. Important Notice to Purchaser/User: The information in this publication is based on tests that we believe are reliable. The results may vary due to differences in tests type and conditions. We recommend that each user evaluate the product to determine its suitability for the intended application. Conditions of use are outside our control and vary widely. Techspray’s only obligation and your only solution is replacement of product that is shown to be defective when you receive it. In no case will Techspray® be liable for any special, incidental, or consequential damages based on breach of warranty, negligence or any other theory. Corporate Office 8125 Cobb Center Drive Kennesaw, GA 30152 800-858-4043 tsales@techspray.com Europe ITW Contamination Control BV Saffierlaan 5, 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 info@itw-cc.com China ITW Specialty Materials (Suzhou) Co., Ltd Hengqiao Road, Wujiang Economic Development Zone, Suzhou, Jiangsu Province, China 215200 +6019-2184801 chinasales@itwsms.com
2106-12S 价格&库存
很抱歉,暂时无法提供与“2106-12S”相匹配的价格&库存,您可以联系我们找货
