HIF3E-30PA-2.54DSA(71) 数据手册
Ribbon Cable Connector (Pin Header)
HIF3E Series
■Features
1. Product Variation
The straight type connector is connected vertical to the
printed board, and the right angle type connector is
connected horizontal to the printed board.
2. Compatibility
May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
This pin header is compatible with HIF3B series.
■Applications
Computers, terminal equipment, PPC, various kinds of
electronic equipment, business machines, etc.
■Product Specifications
Operating Temperature Range:–55 to +85ç (Note 1)
Operating Moisture Range:40 to 80%
Current rating: 1A
Voltage rating: 200V AC
Rating
Item
Storage Temperature Range:–10 to +60ç (Note 2)
Storage Humidity Range:40 to 70% (Note 2)
Specification
Condition
1. Insulation Resistance
1000M ohms min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
15m ohms max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
(–55ç: 30 minutes ➝15 to 35ç: 5 minutes max.
125ç: 30 minutes ➝15 to 35ç: 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
500 cycles
7. Durability (Mating/un-mating) Contact resistance: 15m ohms max.
8. Resistance to Soldering heat
No deformation of components affecting performance.
Solder Bath: 260ç for 10 seconds
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series.Contact us for the drawings and
specifications for a specific part number shown.
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Contact
Brass
Selective gold plating over nickel underplated
■Ordering Information
HIF3E
1
- * P A - 2.54 DS
2
3
4
5
6
1 Series Name: HIF3E
5 Contact Pitch: 2.54mm
2 Number of contacts: 8, 10, 12, 16, 18, 20,
6 Contact type DSS: Right angle type
26, 30, 34, 40, 50, 60
DSA: Straight type
3 P: Pin header
4 A: Selective gold plating
B51
HIF3E Series●Ribbon Cable Connector (Pin Header)
■Right Angle Pin Header
Unit: mm
CL No.
Number of Contacts
A
B
RoHS
HIF3E-10PA-2.54DS(71) 614-0041-0-71
10
13.7
10.16
HIF3E-12PA-2.54DS(71) 614-0050-0-71
12
16.24
12.7
HIF3E-16PA-2.54DS(71) 614-0042-2-71
16
21.3
17.78
HIF3E-18PA-2.54DS(71) 614-0051-3-71
18
23.86
20.32
HIF3E-20PA-2.54DS(71) 614-0043-5-71
22.86
HIF3E-26PA-2.54DS(71) 614-0044-8-71
26
34.0
30.48
HIF3E-30PA-2.54DS(71) 614-0045-0-71
30
39.1
35.56
HIF3E-34PA-2.54DS(71) 614-0046-3-71
34
44.2
40.64
HIF3E-40PA-2.54DS(71) 614-0047-6-71
40
51.8
48.26
HIF3E-50PA-2.54DS(71) 614-0048-9-71
50
64.5
60.96
HIF3E-60PA-2.54DS(71) 614-0049-1-71
60
77.2
73.66
YES
2.54±0.05
Part Number
C±0.1
2.54±0.05
Ø0.8
+0.1
Ø0.8
+0.1
■Dip Pin Header
Unit: mm
CL No.
A
8
11.2
7.62
B
HIF3E-10PA-2.54DSA(71) 614-0061-7-71
10
13.7
10.16
HIF3E-12PA-2.54DSA(71) 614-0070-8-71
12
16.24
12.7
HIF3E-16PA-2.54DSA(71) 614-0062-0-71
16
21.3
17.78
HIF3E-18PA-2.54DSA(71) 614-0071-0-71
18
23.86
20.32
HIF3E-20PA-2.54DSA(71) 614-0063-2-71
22.86
HIF3E-26PA-2.54DSA(71) 614-0064-5-71
26
34.0
30.48
HIF3E-30PA-2.54DSA(71) 614-0065-8-71
30
39.1
35.56
HIF3E-34PA-2.54DSA(71) 614-0066-0-71
34
44.2
40.64
HIF3E-40PA-2.54DSA(71) 614-0067-3-71
40
51.8
48.26
HIF3E-50PA-2.54DSA(71) 614-0068-6-71
50
64.5
60.96
HIF3E-60PA-2.54DSA(71) 614-0069-9-71
60
77.2
73.66
RoHS
YES
2.54±0.05
Part Number
B52
Number of Contacts
HIF3E- 8PA-2.54DSA(71) 614-0072-3-71
C±0.1
2.54±0.05
HIF3E-30PA-2.54DSA(71) 价格&库存
很抱歉,暂时无法提供与“HIF3E-30PA-2.54DSA(71)”相匹配的价格&库存,您可以联系我们找货
