0.5mmピッチ
Emboss Tape
FY CONNECTOR
NON-
0.5mm pitch/Connectors for FFC
Specifications –––––––––––––––––––
0.5mm pitch non-ZIF snap-in type FFC
connector.
• Heat resisting design suitable for surface
mounting
• One-sided contact construction
• Solder tabs
• Embossed tape for automatic mounting
• Current rating: 0.3A AC, DC
• Voltage rating: 30V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/50m Ω max.
After environmental testing/70m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 200V AC/minute
• Applicable FFC: Conductor pitch/0.5mm
Conductor width/0.3mm
Mating part thickness/0.3±0.03mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout (viewed from component side) and Assembly layout
Top entry type
4.05
1.5
0.5±0.03
Side entry type
0.3±0.05
5.2
1.7
2.6
3.9
0.2
1.0
0.3±0.05
0.5±0.03
1.5
1.0
0.2
1.7
Note: 1. Tolerances are non-cumulative: ±0.03mm for all centers.
2. The dimensions above should serve as a guideline. Contact JST for details.
1
3.0
5.1
6.4
5.2
FY CONNECTOR
Connector
Top entry type
Side entry type
A
A
5.5
0.5
Circuit No.1
0.2
Circuit No.1
0.2
0.5
(0.7)
C
B
4.05
C
B
5.2
3.0
5.2
(0.7)
Circuits
Model No.
Q'ty / reel
Dimensions (mm)
Top entry type
Side entry type
A
B
C
30
30FY-BMT-TB
30FY-SMT-TF
14.5
15.5
17.7
1,250
2,000
40
40FY-BMT-TB
40FY-SMT-TF
19.5
20.5
22.7
1,250
2,000
50
50FY-BMT-TB
50FY-SMT-TF
24.5
25.5
27.7
1,250
2,000
Top entry type
Side entry type
Material and Finish
Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: PPS, UL94V-0
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Lead section dimensions of FFC
±0.05
0.5(N +1)
±0.08
0.5
±0.03
0.5(N –1)
±0.03
±0.03
0.3
0.3
3.3 min
0.5
±0.03
Cover layer
Reinforcing layer
Note: N --- Number of circuits
2
50FY-BMT-TB(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“50FY-BMT-TB(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
