ISOLATED
POWER SYSTEMS
FEATURES & BENEFITS
• Individually shrouded contacts for electrical and
mechanical protection
• .100" (2.54 mm) and .165" (4.19 mm) pitch
• Surface mount or through-hole
• Vertical and right-angle for parallel, perpendicular
and coplanar applications
• Locking clip, key polarization and guide post options
• Discrete wire assemblies with 16-30 AWG PVC or
Teflon™ fluoropolymer wire (see pages 243-245).
• Metal or plastic rugged latching system
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec
Selectively loading
contacts achieves customer
specific creepage and
clearance requrements.
CREEPAGE & CLEARANCE
Flexible standard or
high-power stacking systems
with Power Eye three-finger
BeCu contacts for reliable
connection. For available series,
visit samtec.com/flexiblestrips
CREEPAGE
CLEARANCE
IPT1/IPS1
MMSS(T)/MMSD(T)
2.54 mm
1.91 mm
IPBT/IPBS
PMSS(T)/PMSD(T)
4.27 mm
3.05 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
PITCH
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
IPT1/IPS1
.100"
(2.54 mm)
Black LCP
Phosphor Bronze
Sn or Au over
50 µ" (1.27 µm) Nickel
-55 °C to +125 °C
5.9 A
(1 pin powerd)
775 VAC
Yes
IPBT/IPBS
.165"
(4.19 mm)
Black LCP
High Copper Alloy (IPBT)
Phospher Bronze (IPBS)
Sn over 50 µ"
(1.27 µm) Nickel
-55 °C to +105 °C
10.3 A
(2 pins powerd)
400 VAC
Yes
F-224
VOLTAGE LEAD-FREE
RATING SOLDERABLE
samtec.com/minimate or samtec.com/powermate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
10.3
A
(4.19 mm) .165" PITCH • ISOLATED POWER CONNECTOR SET
IPBT
NO. OF POSITIONS
PER ROW
1
LEAD
STYLE
02, 03, 04, 05, 08, 10
PLATING
OPTION
–H1
OPTIONS
–RA
= Single Row
= Right-angle
(Lead Style –H1 only)
–D
= Surface Mount
(Standard Sizes)
s
–S
= Matte Tin
–H2
(–D Only)
p
ROW
OPTION
–T
= Through-hole
15
m
–GP
= Double Row
= Guide Post Holes
(Not available with –K)
–K
= Keyed Polarization
(Not available
with –GP option,
is required callout if
–GP not called out)
IPBT
Board Mates:
IPBS
Cable Mates:
PMSD, PMSS
–H1–S
–H1–D
1RRI3RVLWLRQV[
–H2–S
–GP
–H1–S–RA
1
NO. OF POSITIONS
PER ROW
10.3 A
4
8.4 A
6
7.6 A
8
7.1 A
30
6.0 A
IPBS
2
–H2–D
1RRI3RVLWLRQV[
IPBT/IPBS
CURRENT
PINS
POWERED (PERRATING
CONTACT)
LEAD
STYLE
–01
= Standard Power
15
–H1–D–RA
PLATING
OPTION
–T
–S
= Matte Tin
= Guide Post
–D
= Standard Power
Surface Mount
(Standard Sizes)
OPTION
–GP
= Single Row
–02
(–D Only)
ROW
OPTION
= Double Row
MATED HEIGHT
IPBS
IPBS
Board Mates:
IPBT
–01–S
–01–D
1RRI3RVLWLRQV[
1RRI3RVLWLRQV[
F-224
MATED
HEIGHT
–02–S
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
IPBT
–GP
–02–D
IPBT/IPBS
LEAD STYLE
MATED
HEIGHT*
H1/–01
(15.25) .600
–H2/–02
(16.84) .663
*Processing conditions
will affect mated height.
View complete specifications at: samtec.com?IPBT & samtec.com?IPBS
很抱歉,暂时无法提供与“IPBT-102-H2-TM-D-K”相匹配的价格&库存,您可以联系我们找货
