FFTP-13-D-03.85-01-N . 数据手册
F-214
FMTP–10–D–03.85–01
(1,27 mm) .050"
FFTP, FMTP SERIES
FFTP–20–D–08.77–01–N
TIGER EYE TWISTED PAIR IDC CABLES
FFTP Mates with:
FTS, FTSH, EHF, SHF
PINS
PER ROW
FFTP
FMTP Mates with:
FLE*, SFMC*
END
ASSEMBLY
–05, –08, –10, –13,
–17, –20, –25
= Double
End
–03.85
–08.77
ASSEMBLY LENGTH
OPTION
–N
= Reverse
Connector
–R
= (222,76 mm) 8.77"
–18.00
(1,90)
.075
= (457,20 mm) 18.00"
(Standard Lengths)
No. of
positions
x
(1,27)
.050
(4,19)
.165
–R
FFTP
(1,02) .040
(3,05)
.120
Rated @ 7dB Insertion Loss
Cable
Length
–SE
3.85" (97,8 mm)
2.0 GHz / 4.00 Gbps
Performance data for other cable lengths and complete test data
available at www.samtec.com?FFTP or contact sig@samtec.com
(5,08)
.200
–D
FMTP
For complete scope of
recognitions see
www.samtec.com/quality
PINS
PER ROW
END
ASSEMBLY
ASSEMBLY
LENGTH
–D
–03.85
–05, –08, –10,
–13, –17, –20, –25
= Double End
= (97,79 mm)
3.85"
(Standard sizes)
= Transfer End
–T
–08.77
= (222,76 mm)
8.77"
TRANSFER
OPTION
01
(MOQ Required)
No. of
positions
x
(1,27)
.050
(4,19)
.165
• Other sizes
• Other cable lengths
Contact Samtec.
–18.00
= (457,20 mm)
18.00"
(Standard
Lengths)
(3,05)
.120
(5,08)
.200
–R
–D
(1,27)
.050
(0,41) .016 SQ
WWW.SAMTEC.COM
(3,07)
.121
OPTION
–R
Leave blank for
–D End Assembly.
For –T End Assembly
Specify “–N”
(Socket has notch
polarization)
ASSEMBLY LENGTH
ALSO AVAILABLE
Note: This Series is
non-standard, non-returnable.
N
= Notch
Polarization
(Standard)
= (97,79 mm) 3.85"
(Standard sizes)
RECOGNITIONS
*Note: Standard FMTP callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates wth Pin 1, etc.
01
–D
SPECIFICATIONS
For complete specifications
see www.samtec.com?FFTP
or www.samtec.com?FMTP
Insulator Material:
PBT
Contact (FFTP):
BeCu
Terminal (FMTP):
Phosphor Bronze
Plating (FFTP):
10µ" (0,25 µm)
Au over 50µ" (1,27 µm)
Ni on contact area; Sn over
50µ" (1,27 µm) Ni on balance
Plating (FMTP):
Sn over 50µ" (1,27 µm) Ni
Wire:
30 AWG 7/38,
Tinned, Twisted Pair
with PVC insulator
Operating Temp Range:
-40°C to +105°C
Lead Size Accepted:
(0,41 mm) .016" SQ
Contact Resistance:
15 mΩ
Insertion Depth (FFTP):
(2,64 mm) .104" to
(3,17 mm) .125"
Insertion Force (FFTP):
(Single contact only)
5 oz (1,39 N) avg.
Withdrawal Force (FFTP):
3 oz (0,83 N) avg.
RoHS Compliant:
Yes
ASSEMBLY
LENGTH
–T
= Reverse
Connector
