0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors
FH52 Series
Secure actuator retention
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Metal fittings are designed to hold and
stabilize the actuator
Contacts are designed to hold and
■Features
Extended metal fitting option (FH52E/FH52K/FH52T)
1. Highly reliable connection and robust structure
With the need for higher contact counts and the need for
a connector body that delivers unquestionable strength
and a reliable connection in a FPC/FFC connector, the
FH52 series has made great strides to meet this need. It
meets this need with the following:
-An FPC positioning mechanism that delivers the high
reliability requested
-A reliable and secure connection that is packed into a
well-designed, durable structure.
2. Product variations capable of meeting a range of needs
・FH52E : Long metal fittings type
Easy visual inspection of solder posts after processing.
・FH52K : Long metal fittings type, 125℃ Heat Resistant Type
125℃ heat resistant connector meets severe automotive requirements
・FH52T : Long metal fittings type, 2-Point Contact Type
Contact structure with independent springs connects with
FPC/FCC at 2 points reducing failure from dust intrusion.
The metal fittings extend out from the connector body to
enable a visual inspection of its soldering conditions.
2-Points of Contact (FH52T)
3. Simplified operations
The flip lock structure makes it easier to engage/
disengage the actuator and reduces the required force
needed to operate. A clear tactile click is delivered upon
the successful completion of the mating process.
4. Increased retention force
The side catch technology combined with tabbed FPC/FFC
increase the horizontal retention force of the FPC/FFC.
5. Accepts standard 0.3mm thick FPC/FFC
It accepts 0.3mm thick products that are easy to
manufacture and have superb insertion performance.
6. Fully molded structure aids PCB layout
The bottom of this connector is enclosed by a fully
molded structure that protects the contacts and removes
any restrictions from PCB patterning and design.
2-point contact structure with independent springs to
improve reliability.
Side catch technology designed to place a temporary
hold on the FPC/FFC before the lock is engaged.
7. Halogen-free
All materials and substances used to produce this
product comply with Halogen-free standards.* As
defined in IEC 61249-2-21. Br : 900 ppm or less, Cl : 900
ppm or less, Br+Cl : 1,500 ppm or less
8. Supports automatic pick-n-place mounting
Offered in tape and reel packaging that is compatible with
automatic machine mounting. (3,000pcs/reel)
9. Multiple packing options
The standard packaging is 3,000pcs/reel, but it is also
offered in a 500pcs/reel. (The outer diameter of the reel
will be Ø180mm in this case.)
FPC/FFC with tab increase the
retention force in horizontal direction.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.8r
1
FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors
■Product Specifications
Adaptive FPC/FFC
contact specifications
Thickness: = 0.3 ± 0.05mm Gold plated contact traces
Item
Operating temperature range : -40ç to +105°C (Note 2)(Note 4) Storage temperature range : -10ç to +50°C (Note 3)
Operating humidity range : Relative humidity 90% max.
Storage humidity range : Relative humidity 90% max.
(No condensation)
(No condensation)
Rated current 0.5A (Note 1)
Rated voltage 50V AC rms
Rating
Specification
Conditions
1. Insulation resistance
500Mø min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown
150V AC rms / 1 minute
3. Contact
resistance
50mø max.
* Including FPC/FFC conductor resistance
1mA (DC or 1000Hz)
4. Durability
(insertion / withdrawal)
Contact resistance : 50mø max.
No damage, cracks, or parts dislocation
20 cycles
5. Vibration
No electrical discontinuity of 1µs or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 directions
6. Shock
Acceleration of 981m/s2, duration of 6 ms, sine half-wave
waveform, 3 cycles in each of the 3 axes
7. Humidity
(Steady state)
Insulation resistance : 50Mø min.
96 hours at temperature of 40ç and humidity of 90% to
95%
8. Temperature
cycle
Temperature : -40°C / +15ç to +35ç / +105ç(Note 4) / +15ç to +35ç
Time :
30 /
2 to 3
/ 30 / 2 to 3 (Minutes)
5 cycles
9. Resistance to
soldering heat
No deformation of components affecting
performance
Reflow : Peak temperature 250°C max., 230°C or more, 30 seconds or less
Manual soldering: 350 ± 10°C for 5 seconds
Note 1 : When passing the current through all of the contacts, use 70% of the current rating.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation.
Note 4 : FH52K withstands up to +125°C.
■Materials / Finish
Part
Material
Insulator
LCP
Contacts
Metal fittings
Copper alloy
Brass
Finish
Remarks
Color : Grey
Color : Black
Partially gold plated
Tine plated
UL94V-0
■Product Number Structure
Refer to the chart below when datermining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 52 E − 50 (25) S B − 0.5 SH (99)
❶
w
e
r
t
y
u
q Series name : FH
w Series No. : 52
e Blank : Standard type
K : Long metal fittings type, +125°C Heat Resistant type
T : Long metal fittings type, 2-Point Contact type
r Standard type : Number of contacts
Alternating contact type : Mold size
t Standard type : No symbol
Alternating contact type : Number of contacts
2
i
o
!0
y Contact arrangement : Single (pole piece array)
u Alternating direction :
No symbol : Standard type (all contacts loaded)
A : Alternating contact type (Alternating on the polarity side)
B : Alternating contact type (Alternating on the opposite polarity side)
i Contact pitch : 0.5mm, 1mm
o Termination type
SH : SMT horizontal mounting type
!00 SpecificationBlank : Partially gold plated, 3,000pcs/reel
(99) : Partially gold plated, 500pcs/reel
■Connector Dimensions
[FH52 (Standard Type) 0.5mm Pitch product]
A±0.15
B±0.08
(0.12)
(5)
0.5±0.08
A **
Cav No.
(0.15)
(C)
D±0.1
c
b
6 c
1.75±0.2
a detail drawing
(3.9)
10
1
2
(1
2±0.2
a
Number of
contacts indicator
0.15MAX
Notes 1 The coplanarity of each terminal lead is within 0.1.
2 The contact terminal lead position indicates the dimension from the b surface, the bottom
surface of the insulator body.
3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details.
4 Sink mark reliefs may be added due to improvements
5 Sight variations in color of the plastic compounds do not affect form, fit or function.
After reflow, the terminal plating may change color; however this does not represent a quality issue.
6 The dimensions of 60-contact actuators are shown in the figures.
0.15MAX 1
1.4±0.1
3±0.1
2
0.45±0.1
0.7±0.2
(4.3)
5.7±0.2
Unit : mm
Part No.
FH52-4S-0.5SH(**)
FH52-5S-0.5SH(**)
FH52-6S-0.5SH(**)
FH52-8S-0.5SH(**)
FH52-10S-0.5SH(**)
FH52-11S-0.5SH(**)
FH52-12S-0.5SH(**)
FH52-15S-0.5SH(**)
FH52-16S-0.5SH(**)
FH52-18S-0.5SH(**)
FH52-20S-0.5SH(**)
FH52-22S-0.5SH(**)
FH52-24S-0.5SH(**)
FH52-25S-0.5SH(**)
FH52-26S-0.5SH(**)
FH52-28S-0.5SH(**)
FH52-30S-0.5SH(**)
FH52-32S-0.5SH(**)
FH52-40S-0.5SH(**)
FH52-42S-0.5SH(**)
FH52-45S-0.5SH(**)
FH52-50S-0.5SH(**)
FH52-60S-0.5SH(**)
HRS No.
Under planning (Note 2)
580-3304-0 **
580-3305-3 **
580-3306-6 **
580-3320-7 **
580-3307-9 **
580-3302-5 **
580-3321-0 **
580-3309-4 **
580-3317-2 **
580-3318-5 **
580-3316-0 **
580-3319-8 **
580-3324-8 **
580-3310-3 **
580-3325-0 **
580-3300-0 **
580-3329-1 **
580-3311-6 **
580-3303-8 **
580-3301-2 **
No. of contacts
A
B
C
D
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
6.3
6.8
7.3
8.3
9.3
9.8
10.3
11.8
12.3
13.3
14.3
15.3
16.3
16.8
17.3
18.3
19.3
20.3
24.3
25.3
26.8
29.3
34.3
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
2.57
3.07
3.57
4.57
5.57
6.07
6.57
8.07
8.57
9.57
10.57
11.57
12.57
13.07
13.57
14.57
15.57
16.57
20.57
21.57
23.07
25.57
30.57
4.7
5.2
5.7
6.7
7.7
8.2
8.7
10.2
10.7
11.7
12.7
13.7
14.7
15.2
15.7
16.7
17.7
18.7
22.7
23.7
25.2
27.7
32.7
Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel)
Order by number of reels.
Note 2 : Contact positions without HRS No. are currently under planning.
Please contact hirose for detailed information about product variation.
3
[FH52 (Standard Type) 1mm Pitch product]
A±0.15
(Q)
(R)
B±0.08
1±0.08
(5)
(0.12)
A **
a
Cav No.
c
(0.15)
b
(C)
D±0.1
a detail drawing
1.75±0.2
10
(1
(3.9)
2±0.2
6 c
2
(1.3) 0.15MAX
0.15MAX
1
2
0.45±0.1
1.4±0.1
0.7±0.2
3±0.1
(4.3)
5.7±0.2
the bottom surface of the insulator body.
6 The dimensions of 30-contact actuators are shown in the figures.
Unit : mm
Part No.
FH52-10(4)SA-1SH(**)
FH52-12S-1SH(**)
FH52-32(16)SB-1SH(**)
FH52-60(30)SB-1SH(**)
HRS No.
580-3330-0 **
580-3323-5 **
580-3338-2 **
580-3315-7 **
No. of contacts
4
12
16
30
4
A
9.3
16.8
20.3
34.3
B
3
11
15
29
C
5.57
13.07
16.57
30.57
D
7.7
15.2
18.7
32.7
Q
2.9
2.9
2.4
2.4
R
3.4
2.9
2.9
2.9
[FH52E (Long Metal Fittings Type) 0.5mm Pitch product]
A±0.15
B±0.08
(0.12)
(5)
0.5±0.08
A **
Cav No.
c
(C)
b
D±0.1
E±0.2
0˚
c
1
2
1.75±0.2
6
a detail drawing
(3.9)
2±0.2
a
Number of
contacts indicator
11
0.15MAX
1.55±0.2
After reflow, the terminal plating may change color ; however this does not represent a quality issue.
1.2±0.2(1.3)
0.15MAX
1
2
0.45±0.1
0.7±0.2
(4.3)
5.7±0.2
Unit : mm
Part No.
FH52E-4S-0.5SH(**)
FH52E-5S-0.5SH(**)
FH52E-6S-0.5SH(**)
FH52E-8S-0.5SH(**)
FH52E-10S-0.5SH(**)
FH52E-11S-0.5SH(**)
FH52E-12S-0.5SH(**)
FH52E-15S-0.5SH(**)
FH52E-16S-0.5SH(**)
FH52E-18S-0.5SH(**)
FH52E-20S-0.5SH(**)
FH52E-22S-0.5SH(**)
FH52E-24S-0.5SH(**)
FH52E-25S-0.5SH(**)
FH52E-26S-0.5SH(**)
FH52E-28S-0.5SH(**)
FH52E-30S-0.5SH(**)
FH52E-32S-0.5SH(**)
FH52E-40S-0.5SH(**)
FH52E-42S-0.5SH(**)
FH52E-45S-0.5SH(**)
FH52E-50S-0.5SH(**)
FH52E-60S-0.5SH(**)
FH52E-64S-0.5SH(**)
FH52E-68S-0.5SH(**)
HRS No.
580-3349-0 **
580-3346-0 **
580-3337-0 **
580-3331-3 **
580-3357-0 **
580-3343-2 **
580-3340-4 **
580-3347-3 **
580-3334-1 **
580-3335-4 **
580-3339-5 **
580-3333-9 **
580-3332-6 **
No. of contacts
A
B
C
D
E
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
6.3
6.8
7.3
8.3
9.3
9.8
10.3
11.8
12.3
13.3
14.3
15.3
16.3
16.8
17.3
18.3
19.3
20.3
24.3
25.3
26.8
29.3
34.3
36.3
38.3
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
31.5
33.5
2.57
3.07
3.57
4.57
5.57
6.07
6.57
8.07
8.57
9.57
10.57
11.57
12.57
13.07
13.57
14.57
15.57
16.57
20.57
21.57
23.07
25.57
30.57
32.57
34.57
4.55
5.05
5.55
6.55
7.55
8.05
8.55
10.05
10.55
11.55
12.55
13.55
14.55
15.05
15.55
16.55
17.55
18.55
22.55
23.55
25.05
27.55
32.55
34.55
36.55
7.1
7.6
8.1
9.1
10.1
10.6
11.1
12.6
13.1
14.1
15.1
16.1
17.1
17.6
18.1
19.1
20.1
21.1
25.1
26.1
27.6
30.1
35.1
37.1
39.1
Note 2 : Contact positions without HRS No. are currently under planning.Please contact hirose for detailed information about product variation.
5
[FH52E (Long Metal Fittings Type) 1mm Pitch product]
A±0.15
(Q)
(R)
B±0.08
(0.12)
(5)
1±0.08
A **
a
Cav No.
c
(C)
b
D±0.1
a detail drawing
2±0.2
E±0.2
1.75±0.2
10
(1
(3.9)
6 c
2
0.15MAX
1.2±0.2
(1.3) 0.15MAX
0.45±0.1
1.55±0.2
0.7±0.2
1
2
(4.3)
5.7±0.2
Unit : mm
Part No.
FH52E-8(4)SB-1SH(**)
FH52E-20(10)SA-1SH(**)
FH52E-20(10)SB-1SH(**)
FH52E-50(25)SA-1SH(**)
FH52E-50(25)SB-1SH(**)
FH52E-60(30)SB-1SH(**)
HRS No.
580-3351-0 **
580-3352-0 **
580-3353-0 **
580-3354-0 **
580-3355-0 **
580-3358-0 **
No. of contacts
4
10
10
25
25
30
6
A
8.3
14.3
14.3
29.3
29.3
34.3
B
3
9
9
24
24
29
C
4.57
10.57
10.57
25.57
25.57
30.57
D
6.55
12.55
12.55
27.55
27.55
32.55
E
9.1
15.1
15.1
30.1
30.1
35.1
Q
2.4
2.9
2.4
2.9
2.4
2.4
R
2.9
2.4
2.9
2.4
2.9
2.9
[FH52K (Long Metal Fittings Type, 125°C Heat Resistant Type) 0.5mm Pitch product]
A±0.15
B±0.08
(0.12)
(5)
0.5±0.08
Cav No.
a
Number of contacts indicator
c
(C)
b
D±0.1
a detail drawing
E±0.2
10
2±0.2
(1
1.75±0.2
6 c
(3.9)
A **
2
0.15MAX
1.2±0.2
0.15MAX
1.55±0.2
Unit : mm
HRS No.
No. of contacts
A
B
C
D
E
580-4613-0 **
580-4611-0 **
580-4606-0 **
6
8
10
12
15
18
24
25
26
30
32
34
40
50
60
64
68
7.3
8.3
9.3
10.3
11.8
13.3
14.3
15.3
16.3
16.8
17.3
19.3
20.3
21.3
24.3
29.3
34.3
36.3
38.3
2.5
3.5
4.5
5.5
7.0
8.5
9.5
10.5
11.5
12.0
12.5
14.5
15.5
16.5
19.5
24.5
29.5
31.5
33.5
3.57
4.57
5.57
6.57
8.07
9.57
10.57
11.57
12.57
13.07
13.57
15.57
16.57
17.57
20.57
25.57
30.57
32.57
34.57
5.55
6.55
7.55
8.55
10.05
11.55
12.55
13.55
14.55
15.05
15.55
17.55
18.55
19.55
22.55
27.55
32.55
34.55
36.55
8.1
9.1
10.1
11.1
12.6
14.1
15.1
16.1
17.1
17.6
18.1
20.1
21.1
22.1
25.1
30.1
35.1
37.1
39.1
580-4604-0 **
580-4600-9 **
580-4601-0 **
580-4614-0 **
2
0.7±0.2
(4.3)
5.7±0.2
Part No.
FH52K-6S-0.5SH(**)
FH52K-8S-0.5SH(**)
FH52K-10S-0.5SH(**)
FH52K-12S-0.5SH(**)
FH52K-15S-0.5SH(**)
FH52K-18S-0.5SH(**)
FH52K-20S-0.5SH(**)
FH52K-22S-0.5SH(**)
FH52K-24S-0.5SH(**)
FH52K-25S-0.5SH(**)
FH52K-26S-0.5SH(**)
FH52K-30S-0.5SH(**)
FH52K-32S-0.5SH(**)
FH52K-34S-0.5SH(**)
FH52K-40S-0.5SH(**)
FH52K-50S-0.5SH(**)
FH52K-60S-0.5SH(**)
FH52K-64S-0.5SH(**)
FH52K-68S-0.5SH(**)
1
0.45±0.1
Note 2 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation.
7
[FH52T (Long Metal Fittings Type, 2-Point Contact Type) 0.5mm Pitch product]
A±0.15
(2.35)
B±0.08
0.5±0.08
(2.45)
(5)
(0.08)
A **
Cav No.
a
c
(C)
b
D±0.1
a detail drawing
E±0.2
1.75±0.2
2±0.2
10
(1
(3.9)
6 c
1
2
0.15MAX
(1.6)
0.45±0.1
0.15MAX
1.2±0.2
1.55±0.2
2 The contact terminal lead position indicates the dimension from the b surface, (4.2)
5.7±0.2
1
2
0.7±0.2
Unit : mm
Part No.
FH52T-4S-0.5SH(**)
FH52T-5S-0.5SH(**)
FH52T-6S-0.5SH(**)
FH52T-8S-0.5SH(**)
FH52T-10S-0.5SH(**)
FH52T-11S-0.5SH(**)
FH52T-12S-0.5SH(**)
FH52T-15S-0.5SH(**)
FH52T-16S-0.5SH(**)
FH52T-18S-0.5SH(**)
FH52T-20S-0.5SH(**)
FH52T-22S-0.5SH(**)
FH52T-24S-0.5SH(**)
FH52T-25S-0.5SH(**)
FH52T-26S-0.5SH(**)
FH52T-28S-0.5SH(**)
FH52T-30S-0.5SH(**)
FH52T-32S-0.5SH(**)
FH52T-40S-0.5SH(**)
FH52T-42S-0.5SH(**)
FH52T-45S-0.5SH(**)
FH52T-50S-0.5SH(**)
FH52T-60S-0.5SH(**)
FH52T-64S-0.5SH(**)
FH52T-68S-0.5SH(**)
HRS No.
580-4503-0 **
580-4500-0 **
580-4502-0 **
580-4501-7 **
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
A
6.3
6.8
7.3
8.3
9.3
9.8
10.3
11.8
12.3
13.3
14.3
15.3
16.3
16.8
17.3
18.3
19.3
20.3
24.3
25.3
26.8
29.3
34.3
36.3
38.3
B
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
31.5
33.5
C
2.57
3.07
3.57
4.57
5.57
6.07
6.57
8.07
8.57
9.57
10.57
11.57
12.57
13.07
13.57
14.57
15.57
16.57
20.57
21.57
23.07
25.57
30.57
32.57
34.57
D
4.55
5.05
5.55
6.55
7.55
8.05
8.55
10.05
10.55
11.55
12.55
13.55
14.55
15.05
15.55
16.55
17.55
18.55
22.55
23.55
25.05
27.55
32.55
34.55
36.55
E
7.1
7.6
8.1
9.1
10.1
10.6
11.1
12.6
13.1
14.1
15.1
16.1
17.1
17.6
18.1
19.1
20.1
21.1
25.1
26.1
27.6
30.1
35.1
37.1
39.1
8
BRecommended PCB Mounting Pattern and Metal Mask Dimensions
Recommended metal mask thickness : 0.12mm
B±0.05
Connector image
0.3±0.03(Land pattern)
0.25±0.03(Metal mask)
2±0.05
0.5±0.05
E±0.05
0.8±0.03
* The recommended PCB mounting pattern for the FH12 Series (horizontal
mounting type) can be used as well.
BRecommended FPC/FFC Dimensions
G±0.05
B±0.03
0.5±0.07
0.5±0.03
0.5±0.07
0.35±0.03(FPC)
0.3±0.03(FFC)
0.3±0.05
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.05
1
(1MIN)
1.35±0.1 1
3.5MIN
2-R0.2±0.05
F±0.1
4.5MIN
1
1 3.1±0.1
4.6±0.05
0.85±0.05
Notes 1 FFC/FPC without tabs can also be used.
In that case, the specified portions are not necessary.
Part No.
FH52-4S-0.5SH(**)
FH52-5S-0.5SH(**)
FH52-6S-0.5SH(**)
FH52-8S-0.5SH(**)
FH52-10S-0.5SH(**)
FH52-11S-0.5SH(**)
FH52-12S-0.5SH(**)
FH52-15S-0.5SH(**)
FH52-16S-0.5SH(**)
FH52-18S-0.5SH(**)
FH52-20S-0.5SH(**)
FH52-22S-0.5SH(**)
FH52-24S-0.5SH(**)
FH52-25S-0.5SH(**)
FH52-26S-0.5SH(**)
FH52-28S-0.5SH(**)
FH52-30S-0.5SH(**)
FH52-32S-0.5SH(**)
FH52-40S-0.5SH(**)
FH52-42S-0.5SH(**)
FH52-45S-0.5SH(**)
FH52-50S-0.5SH(**)
FH52-60S-0.5SH(**)
HRS No.
Under planning (Note 1)
580-3304-0 **
580-3305-3 **
580-3306-6 **
580-3320-7 **
580-3307-9 **
580-3302-5 **
580-3321-0 **
580-3309-4 **
580-3317-2 **
580-3318-5 **
580-3316-0 **
580-3319-8 **
580-3324-8 **
580-3310-3 **
580-3325-0 **
580-3300-0 **
580-3329-1 **
580-3311-6 **
580-3303-8 **
580-3301-2 **
Unit : mm
No. of contacts
B
E
F
G
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
2.5
3.0
3.5
4.5
5.5
6.0
6.5
8.0
8.5
9.5
10.5
11.5
12.5
13.0
13.5
14.5
15.5
16.5
20.5
21.5
23.0
25.5
30.5
Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation.
9
0.85±0.05
B±0.05
1±0.05
0.3±0.03
(Land pattern)
4.6±0.05
0.25±0.03
(Metal mask)
2±0.05
(Connector image)
S±0.05
T±0.05
E±0.05
0.8±0.03
1
F±0.1
G±0.07
0.3±0.05
0.6±0.03
1±0.05
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.1
1
1.35±0.1
2-R0.2±0.05
4.5MIN
1
1
1
3.1±0.1
(1MIN)
3.5MIN
2-R0.2±0.05
V±0.1
B±0.05
U±0.1
Unit : mm
Part No.
FH52-12S-1SH(**)
10
HRS No.
580-3330-0 **
580-3323-5 **
580-3338-2 **
580-3315-7 **
No. of contacts
4
12
16
30
B
3
11
15
29
E
7.1
14.6
18.1
32.1
F
7.1
14.6
18.1
32.1
G
5.5
13.0
16.5
30.5
S
1.8
1.8
1.3
1.3
T
2.3
1.8
1.8
1.8
U
1.5
1
1
1
V
1
1
0.5
0.5
Connector image
(0.2)
B±0.05
(0.3)
(0.3)
1.8±0.05
5.85±0.05
0.5±0.05
F±0.05
(0.225)
(0.5)
2±0.03
1
G±0.1
H±0.05
B±0.03
0.5±0.07
2-R0.2±0.05
0.5±0.03
0.5±0.07
0.3±0.05
0.35±0.03(FPC)
0.3±0.03(FFC)
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.05
1
3.1±0.1
1.35±0.1
1
1
4.5MIN
(1MIN)
3.5MIN
(0.2)
0.85±0.05
Part No.
FH52E-4S-0.5SH(**)
FH52E-5S-0.5SH(**)
FH52E-6S-0.5SH(**)
FH52E-8S-0.5SH(**)
FH52E-10S-0.5SH(**)
FH52E-11S-0.5SH(**)
FH52E-12S-0.5SH(**)
FH52E-15S-0.5SH(**)
FH52E-16S-0.5SH(**)
FH52E-18S-0.5SH(**)
FH52E-20S-0.5SH(**)
FH52E-22S-0.5SH(**)
FH52E-24S-0.5SH(**)
FH52E-25S-0.5SH(**)
FH52E-26S-0.5SH(**)
FH52E-28S-0.5SH(**)
FH52E-30S-0.5SH(**)
FH52E-32S-0.5SH(**)
FH52E-40S-0.5SH(**)
FH52E-42S-0.5SH(**)
FH52E-45S-0.5SH(**)
FH52E-50S-0.5SH(**)
FH52E-60S-0.5SH(**)
FH52E-64S-0.5SH(**)
FH52E-68S-0.5SH(**)
HRS No.
580-3349-0 **
580-3346-0 **
580-3337-0 **
580-3331-3 **
580-3357-0 **
580-3343-2 **
580-3340-4 **
580-3347-3 **
580-3334-1 **
580-3335-4 **
580-3339-5 **
580-3333-9 **
580-3332-6 **
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
Unit : mm
B
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
31.5
33.5
F
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
34.1
36.1
G
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
34.1
36.1
H
2.5
3.0
3.5
4.5
5.5
6.0
6.5
8.0
8.5
9.5
10.5
11.5
12.5
13.0
13.5
14.5
15.5
16.5
20.5
21.5
23.0
25.5
30.5
32.5
34.5
11
0.85±0.05
B±0.05
1±0.05
0.3±0.03
(Land pattern)
(Connector image)
T±0.05
S±0.05
1.8±0.05
5.85±0.05
0.25±0.03
(Metal mask)
F±0.05
2±0.03
1
G±0.1
H±0.07
B±0.05
0.6±0.03
1±0.05
0.3±0.05
2-R0.2±0.1
1
1.35±0.1
2-R0.2±0.1
2-R0.2±0.05
1
1
1
1
1
3.1±0.1
3.5MIN
2-R0.2±0.1
4.5MIN
2-R0.2±0.05
V±0.1
(1MIN)
U±0.1
Unit : mm
Part No.
12
HRS No.
580-3351-0 **
580-3352-0 **
580-3353-0 **
580-3354-0 **
580-3355-0 **
580-3358-0 **
No. of contacts
4
10
10
25
25
30
B
3
9
9
24
24
34.3
F
6.1
12.1
12.1
27.1
27.1
32.1
G
6.1
12.1
12.1
27.1
27.1
32.1
H
4.5
10.5
10.5
25.5
25.5
30.5
S
1.3
1.8
1.3
1.8
1.3
1.3
T
1.8
1.3
1.8
1.3
1.8
1.8
U
1
0.5
1
0.5
1
1
V
0.5
1
0.5
1
0.5
0.5
(0.2)
(0.3)
(0.3)
1.8±0.05
5.85±0.05
0.5±0.05
F±0.05
(0.225)
(0.5)
2±0.03
1
0.5±0.07
2-R0.2±0.05
0.5±0.03
G±0.1
H±0.05
B±0.03
0.35±0.03(FPC)
0.3±0.03(FFC)
0.3±0.05
0.5±0.07
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.05
1
3.1±0.1
1.35±0.1
1
1
4.5MIN
(1MIN)
3.5MIN
(0.2)
0.85±0.05
Connector image
B±0.05
Unit : mm
Part No.
FH52K-6S-0.5SH(**)
FH52K-8S-0.5SH(**)
FH52K-10S-0.5SH(**)
FH52K-12S-0.5SH(**)
FH52K-15S-0.5SH(**)
FH52K-18S-0.5SH(**)
FH52K-20S-0.5SH(**)
FH52K-22S-0.5SH(**)
FH52K-24S-0.5SH(**)
FH52K-25S-0.5SH(**)
FH52K-26S-0.5SH(**)
FH52K-30S-0.5SH(**)
FH52K-32S-0.5SH(**)
FH52K-34S-0.5SH(**)
FH52K-40S-0.5SH(**)
FH52K-50S-0.5SH(**)
FH52K-60S-0.5SH(**)
FH52K-64S-0.5SH(**)
FH52K-68S-0.5SH(**)
HRS No.
580-4613-0 **
580-4611-0 **
580-4606-0 **
580-4604-0 **
580-4600-9 **
580-4601-0 **
580-4614-0 **
No. of contacts
6
8
10
12
15
18
24
25
26
30
32
34
40
50
60
64
68
B
2.5
3.5
4.5
5.5
7.0
8.5
9.5
10.5
11.5
12.0
12.5
14.5
15.5
16.5
19.5
24.5
29.5
31.5
33.5
F
5.1
6.1
7.1
8.1
9.6
11.1
12.1
13.1
14.1
14.6
15.1
17.1
18.1
19.1
22.1
27.1
32.1
34.1
36.1
G
5.1
6.1
7.1
8.1
9.6
11.1
12.1
13.1
14.1
14.6
15.1
17.1
18.1
19.1
22.1
27.1
32.1
34.1
36.1
H
3.5
4.5
5.5
6.5
8.0
9.5
10.5
11.5
12.5
13.0
13.5
15.5
16.5
17.5
20.5
25.5
30.5
32.5
34.5
13
0.85±0.05
B±0.05
0.3±0.03
(Land pattern)
0.5±0.05
(Connector image)
1.8±0.05
5.85±0.05
0.25±0.03
(Metal mask)
F±0.05
2±0.03
1
0.5±0.07
0.5±0.03
0.3±0.05
0.5±0.07
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.1
1
2-R0.2±0.05
1
3.1±0.1
1.35±0.1
1
1
4.5MIN
(1MIN)
3.5MIN
2-R0.2±0.05
G±0.1
H±0.05
B±0.03
0.35±0.03(FPC)
0.3±0.03(FFC)
Part No.
FH52T-4S-0.5SH(**)
FH52T-5S-0.5SH(**)
FH52T-6S-0.5SH(**)
FH52T-8S-0.5SH(**)
FH52T-10S-0.5SH(**)
FH52T-11S-0.5SH(**)
FH52T-12S-0.5SH(**)
FH52T-15S-0.5SH(**)
FH52T-16S-0.5SH(**)
FH52T-18S-0.5SH(**)
FH52T-20S-0.5SH(**)
FH52T-22S-0.5SH(**)
FH52T-24S-0.5SH(**)
FH52T-25S-0.5SH(**)
FH52T-26S-0.5SH(**)
FH52T-28S-0.5SH(**)
FH52T-30S-0.5SH(**)
FH52T-32S-0.5SH(**)
FH52T-40S-0.5SH(**)
FH52T-42S-0.5SH(**)
FH52T-45S-0.5SH(**)
FH52T-50S-0.5SH(**)
FH52T-60S-0.5SH(**)
FH52T-64S-0.5SH(**)
FH52T-68S-0.5SH(**)
HRS No.
580-4503-0 **
580-4500-0 **
580-4502-0 **
580-4501-7 **
Unit : mm
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
B
1.5
2.0
2.5
3.5
4.5
5.0
5.5
7.0
7.5
8.5
9.5
10.5
11.5
12.0
12.5
13.5
14.5
15.5
19.5
20.5
22.0
24.5
29.5
31.5
33.5
F
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
34.1
36.1
G
4.1
4.6
5.1
6.1
7.1
7.6
8.1
9.6
10.1
11.1
12.1
13.1
14.1
14.6
15.1
16.1
17.1
18.1
22.1
23.1
24.6
27.1
32.1
34.1
36.1
H
2.5
3.0
3.5
4.5
5.5
6.0
6.5
8.0
8.5
9.5
10.5
11.5
12.5
13.0
13.5
14.5
15.5
16.5
20.5
21.5
23.0
25.5
30.5
32.5
34.5
14
BFH52 Series FPC/FFC Construction (Recommended Specifications)
1. Using Single-Sided FPC
FPC : Flexible Printed Circuit
Material name
Covering film layer
Material
Polyimide
1mil
Cover adhesive
3
Surface treatment
0.2 µm thick gold plated over 1 to 5 µm thick nickel underplating
Copper foil
Cu
Base adhesive
Thermosetting adhesive
25
Base film
Polyimide
1mil thick
25
Reinforcement material adhesive
30
Stiffener
Polyimide
1oz
7mil thick
35
175
293
Material name
Covering film layer
Material
Polyimide
1mil
Thickness (µm)
(25)
(25)
Cover adhesive
3
Surface treatment
Through-hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polyimide
25
Base adhesive
Copper foil
Cu
Cover adhesive
25
Covering layer film
Polyimide
25
Stiffener
Polyimide
* To prevent release of the FPC due to its bending, use of the double sided
FPC with copper foil on the back side is not recommended.
3. Using FFC
(25)
(25)
Total
2. Using Double-Sided FPC
Thickness (µm)
15
1/2oz
1mil thick
1/2oz
1mil thick
4mil thick
18
18
(18)
50
100
297
Total
FFC : Flexible Flat Cable
Material name
Material
Polyester film
Adhesive
(12)
Thermoplastic polyester
(30)
35
Gold plated annealed copper foil
Adhesive
Thickness (µm)
Polyester
30
12
Polyester
Adhesive
Polyester
30
Stiffener
Polyester
188
Total
295
* Typical thickness tolerance is about ±20µm
1. This specification is a recommendation for the construction of the FH52 Series FPC and FFC (t = 0.3 ± 0.05mm).
2. For details about the construction, please contact the FPC/FFC manufacturers.
15
BPackaging Specification
●Embossed carrier tape dimensions
1.7 +0.15
(2.4)
(0.3)
(J)
K±0.1
M±0.1
L±0.3
(4.65)
(6.4)
Unreeling direction
1.75±0.1
2±0.1
12±0.1
Ø1
.5 +
4±0.1
(tape width 32mm or more)
(2.4)
(0.3)
(J)
K±0.1
L±0.3
Ø1
.5 +
2±0.1
12±0.1
4±0.1
1.75±0.1
(tape width 24mm or less)
1.5+0.1
Unreeling direction
●Reel Dimensions
(4.65) (6.4)
1±
Ø80±1
Ø2
N±1: Reel outside width
Ø380±2
0.8
a detail drawing
2±0.5
Ø13±0.2
P±1: Reel inside width
R1
a
End section
Mounting section
Blank section
Lead section (400mm min.)
Embossed carrier tape Blank section
(15 pockets min.)
Top cover tape
(10 pockets min.)
Part No.
FH52-4S-0.5SH(**)
FH52-5S-0.5SH(**)
FH52-6S-0.5SH(**)
FH52-8S-0.5SH(**)
FH52-10S-0.5SH(**)
FH52-11S-0.5SH(**)
FH52-12S-0.5SH(**)
FH52-15S-0.5SH(**)
FH52-16S-0.5SH(**)
FH52-18S-0.5SH(**)
FH52-20S-0.5SH(**)
FH52-22S-0.5SH(**)
FH52-24S-0.5SH(**)
FH52-25S-0.5SH(**)
FH52-26S-0.5SH(**)
FH52-28S-0.5SH(**)
FH52-30S-0.5SH(**)
FH52-32S-0.5SH(**)
FH52-40S-0.5SH(**)
FH52-42S-0.5SH(**)
FH52-45S-0.5SH(**)
FH52-50S-0.5SH(**)
FH52-60S-0.5SH(**)
HRS No.
580-3304-0 **
580-3305-3 **
580-3306-6 **
580-3320-7 **
580-3307-9 **
580-3302-5 **
580-3321-0 **
580-3309-4 **
580-3317-2 **
580-3318-5 **
580-3316-0 **
580-3319-8 **
580-3324-8 **
580-3310-3 **
580-3325-0 **
580-3300-0 **
580-3329-1 **
580-3311-6 **
580-3303-8 **
580-3301-2 **
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
Unit : mm
J
6.6
7.1
7.6
8.6
9.6
10.1
10.6
12.1
12.6
13.6
14.6
15.6
16.6
17.1
17.6
18.6
19.6
20.6
24.6
25.6
27.1
29.6
34.6
K
7.5
L
16.0
M
N
21.4
P
17.4
11.5
24.0
29.4
25.4
14.2
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
Part No.
FH52-12S-1SH(**)
HRS No.
580-3330-0 **
580-3323-5 **
580-3338-2 **
580-3315-7 **
Unit : mm
No. of contacts
4
12
16
30
J
9.6
17.1
20.6
34.6
K
11.5
14.2
20.2
26.2
L
24.0
32.0
44.0
56.0
M
28.4
40.4
52.4
N
29.4
37.4
49.4
61.4
P
25.4
33.4
45.4
57.4
16
Part No.
FH52E-4S-0.5SH(**)
FH52E-5S-0.5SH(**)
FH52E-6S-0.5SH(**)
FH52E-8S-0.5SH(**)
FH52E-10S-0.5SH(**)
FH52E-11S-0.5SH(**)
FH52E-12S-0.5SH(**)
FH52E-15S-0.5SH(**)
FH52E-16S-0.5SH(**)
FH52E-18S-0.5SH(**)
FH52E-20S-0.5SH(**)
FH52E-22S-0.5SH(**)
FH52E-24S-0.5SH(**)
FH52E-25S-0.5SH(**)
FH52E-26S-0.5SH(**)
FH52E-28S-0.5SH(**)
FH52E-30S-0.5SH(**)
FH52E-32S-0.5SH(**)
FH52E-40S-0.5SH(**)
FH52E-42S-0.5SH(**)
FH52E-45S-0.5SH(**)
FH52E-50S-0.5SH(**)
FH52E-60S-0.5SH(**)
FH52E-64S-0.5SH(**)
FH52E-68S-0.5SH(**)
HRS No.
580-3349-0 **
580-3346-0 **
580-3337-0 **
580-3331-3 **
580-3357-0 **
580-3343-2 **
580-3340-4 **
580-3347-3 **
580-3334-1 **
580-3335-4 **
580-3339-5 **
580-3333-9 **
580-3332-6 **
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
J
6.6
7.1
7.6
8.6
9.6
10.1
10.6
12.1
12.6
13.6
14.6
15.6
16.6
17.1
17.6
18.6
19.6
20.6
24.6
25.6
27.1
29.6
34.6
36.6
38.6
Unit : mm
K
7.5
L
16.0
M
N
21.4
P
17.4
11.5
24.0
29.4
25.4
14.2
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
K
L
N
P
11.5
24.0
M
29.4
25.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
Part No.
HRS No.
580-3351-0 **
580-3352-0 **
580-3353-0 **
580-3354-0 **
580-3355-0 **
580-3358-0 **
No. of contacts
4
10
10
25
25
30
Unit : mm
J
8.6
14.6
14.6
29.6
29.6
34.6
Part No.
FH52K-6S-0.5SH(**)
FH52K-8S-0.5SH(**)
FH52K-10S-0.5SH(**)
FH52K-12S-0.5SH(**)
FH52K-15S-0.5SH(**)
FH52K-18S-0.5SH(**)
FH52K-20S-0.5SH(**)
FH52K-22S-0.5SH(**)
FH52K-24S-0.5SH(**)
FH52K-25S-0.5SH(**)
FH52K-26S-0.5SH(**)
FH52K-30S-0.5SH(**)
FH52K-32S-0.5SH(**)
FH52K-34S-0.5SH(**)
FH52K-40S-0.5SH(**)
FH52K-50S-0.5SH(**)
FH52K-60S-0.5SH(**)
FH52K-64S-0.5SH(**)
FH52K-68S-0.5SH(**)
HRS No.
580-4613-0 **
580-4611-0 **
580-4606-0 **
580-4604-0 **
580-4600-9 **
580-4601-0 **
580-4614-0 **
No. of contacts
6
8
10
12
15
18
24
25
26
30
32
34
40
50
60
64
68
J
7.6
8.6
9.6
10.6
12.1
13.6
14.6
15.6
16.6
17.1
17.6
19.6
20.6
21.6
24.6
29.6
34.6
36.6
38.6
K
L
11.5
24.0
14.2
32.0
20.2
26.2
M
Unit : mm
N
P
29.4
25.4
28.4
37.4
33.4
44.0
40.4
49.4
45.4
56.0
52.4
61.4
57.4
17
Part No.
FH52T-4S-0.5SH(**)
FH52T-5S-0.5SH(**)
FH52T-6S-0.5SH(**)
FH52T-8S-0.5SH(**)
FH52T-10S-0.5SH(**)
FH52T-11S-0.5SH(**)
FH52T-12S-0.5SH(**)
FH52T-15S-0.5SH(**)
FH52T-16S-0.5SH(**)
FH52T-18S-0.5SH(**)
FH52T-20S-0.5SH(**)
FH52T-22S-0.5SH(**)
FH52T-24S-0.5SH(**)
FH52T-25S-0.5SH(**)
FH52T-26S-0.5SH(**)
FH52T-28S-0.5SH(**)
FH52T-30S-0.5SH(**)
FH52T-32S-0.5SH(**)
FH52T-40S-0.5SH(**)
FH52T-42S-0.5SH(**)
FH52T-45S-0.5SH(**)
FH52T-50S-0.5SH(**)
FH52T-60S-0.5SH(**)
FH52T-64S-0.5SH(**)
FH52T-68S-0.5SH(**)
HRS No.
580-4503-0 **
580-4500-0 **
580-4502-0 **
580-4501-7 **
No. of contacts
4
5
6
8
10
11
12
15
16
18
24
25
26
28
30
32
40
42
45
50
60
64
68
J
6.6
7.1
7.6
8.6
9.6
10.1
10.6
12.1
12.6
13.6
14.6
15.6
16.6
17.1
17.6
18.6
19.6
20.6
24.6
25.6
27.1
29.6
34.6
36.6
38.6
K
7.5
L
16.0
11.5
24.0
14.2
Unit : mm
M
N
21.4
P
17.4
29.4
25.4
32.0
28.4
37.4
33.4
20.2
44.0
40.4
49.4
45.4
26.2
56.0
52.4
61.4
57.4
BRecommended Temperature Profile
MAX 250ç
Temperature
250
230ç
200
200ç
150
150ç
(ç)
100
50
25℃ (60sec.) 90sec. to 120sec.
Preheating time
(30sec.)
Soldering time
Start
180
Time (seconds)
18
HRS test condition
Solder method
Reflow furnace atmosphere
Solder composition
: Reflow, IR
: Atmosphere
: Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry's Part Number : M705221CM5-32-10.5)
Test board
: Material and size
Glass epoxy
: 80mm × 100mm × 1.6mm thick
Land dimensions
: 0.3 × 0.85mm
Metal mask dimensions
: 0.12mm thick
Opening dimensions
: 0.25 × 0.85mm
The temperature profiles are based on the above conditions.
In individual applications the actual temperature may vary, depending on
solder paste type, volume/thickness and board size/thickness. Consult your
solder paste and equipment manufacturer for specific recommendations.
BOperation and Precautions
Operation
1. FPC/FFC insertion procedure
qLift up the actuator to release the lock.
You can easily pop it up with the thumbnail
or index-finger nail.
Precautions
qThe FH52 Series is equipped with an actuator that
rotates approximately 110°. Do not apply a force to
open it beyond its fully open position. The actuator
may come off or be permanently damaged.
wInsert the FPC or FFC with the exposed conductive
traces facing down. When connecting a tabbed FPC or
FFC, securely insert it to the bottom, perpendicular to
the connector with an angle of 10° with respect to the
PCB surface, using the FFC/FPC positioning guide.
wInsert the FPC or FFC properly to the opening
of the connector. Improper insertion may lead
to a break or poor continuity of the FPC or FFC.
eRotate down the actuator until firmly closed.
eThe connector does not have a strong upward
tensile strength owing to its structure. Secure the
FPC or FFC when it is subjected to a tensile force.
2. FPC/FFC removal
qLift up the actuator to release the lock. Pull up the FPC
or FFC a little and then withdraw it from the connector.
rWhen inserting an FPC or FFC, do not rub it vigorously against the
bottom side of the connector opening. Excessive contact between
the contacts and the FPC or FFC may result in the deformation of
contacts, peeling of conductive traces, or other faults.
FFC positioning guide
19
BPrecautions (Mating/Un-Mating FPC/FFC with the Retention Tabs)
Operation
Precautions
1. How to insert
Powered by TCPDF (www.tcpdf.org)
wAvoid “ride on”
Insert the cable into the
) between
interspace (
at
the mold walls (
both ends of entrance
where the connector is
inserted and the guide walls
) at both ends of
interior connector so the
cable tabs are properly
located.
Avoid insertion so the cables ride on any guide. Be sure
NOT to close the actuator as the cables ride on any guide. It
may cause conduction failure.
Ride on the both guides
2. Precautions when mating/un-mating
qAvoid insertion in
Diagonal insertion
diagonal direction.
Ride on the right guide
Do not insert the cable in
diagonal direction.
A part of the connector may
touches the contacts resulting
in deformation of the contacts.
Correct insertion
Be sure to insert the FPC
or FFC straight into the
connector opening until the
bottom of the connector.
Perpendicular to the connector
FFC/FPC retention tab
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2017. Contents are subject to change without notice for the purpose of improvements.
