QSS-025-01-H-D-RA-SP 数据手册
(0.635 mm) .025" PITCH • QTS/QSS SERIES
QTS
QTS
Board Mates:
QSS
NO. OF
POSITIONS
PER ROW
QSS
–025, –050,
–075
Board Mates:
QTS
D
A
OTHER
OPTIONS
–K
= Gold flash
on contact,
Matte Tin on tail
= (7.00 mm)
.275" DIA
Polyimide film
Pick & Place Pad
–L
–C
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
1.8 A per pin (2 pins powered)
Ground Plane:
23.1 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
285 VAC
Max Cycles:
100
PROCESSING
Lead–Free Solderable:
Yes
QTS SMT Lead Coplanarity:
(0.10 mm) .004" max
(025-075)
QSS SMT Lead Coplanarity:
(0.10 mm) .004" max
(025-050)
(0.15 mm) .006" max (075)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Board Stacking:
For applications requiring
more than two connectors
contact ipg@samtec.com
(No. of Positions per Row/25) x (20.00) .7875
(5.97)
.235
(7.11)
.280
QTS
LEAD
STYLE
(0.76)
.030
A
Leave blank for
Tray Packaging
–TR
= Tape & Reel
= Full Reel
Tape & Reel
must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
SPECIFICATIONS
“X”R
–FR
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
Cable Mates:
SQCD
Standoffs:
SO
MATED
HEIGHT
WITH QSS
A
–01
(4.27) .168
(5.00) .197
–02
(7.26) .286
(8.00) .315
*Processing conditions will affect mated height.
See SO Series for board space tolerances.
View complete specifications at: samtec.com?QTS
QSS
NO. OF
POSITIONS
PER ROW
PLATING
OPTION
01
–025,
–050, –075
(50 total positions
per bank)
- - D
–F
= Gold flash
on contact,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(20.00) .7875 + (10.90) .429
10 YEAR MFG
(20.00) .7875 + (5.72) .225
(20.00) .7875
+ (10.90) .429 LIFE
EXTENDED
PRODUCT
HIGH MATING
CYCLES
–C
A
OTHER
OPTIONS
–GP
= Guide Holes
for mating
with QTS-RA
–K
= (8.25 mm) .325"
DIA Polyimide
Film Pick &
Place Pad
= 50 µ" (1.27 µm)
Electro-Polished
Selective Gold
on contact,
Matte Tin on tail
(passes 10 year
MFG testing)
(20.00) .7875 + (1.27) .050
(3.63)
.143
(7.24)
.285 (0.76)
.030
(7.49)
.295
“X”R
Leave blank for
Tray Packaging
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(20.00) .7875 + (10.90) .429 (7.24)
.285
(7.49)
.295
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
PLATING
OPTION
–F
Specify
LEAD
STYLE
from
Chart
(50 total positions
per bank)
QTS/QSS
LEAD
STYLE
25
(0.76)
.030
–GP OPTION
(3.63)
.143
View complete specifications at: samtec.com?QSS
(7.49)
.295
samtec.com/QStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(3.63)
.143
F-224
QSS-025-01-H-D-RA-SP 价格&库存
很抱歉,暂时无法提供与“QSS-025-01-H-D-RA-SP”相匹配的价格&库存,您可以联系我们找货
