6.31858.00
6.31858.00
    METABO(麦太保)
6.31858.00 数据手册
CORDLESS SCREWDRIVER + LAMP FEATURES  Lightweight for fatigue-free work  Ergonomically perfect design for any application  Ideal for processing small and medium screws  Magnetic bit holder  Forward and reverse running  Spindle stop  Exact concentricity of spindle through optimum bearing  Sturdy die cast gear housing reddot award product design 2002     With one charged battery pack, one can drive over 400 screws (3.0 mm x 20 mm). With two NiCd battery pack Charger (charging time approx. 2 hours) With “Power Grip Flashlight”: Torch with durable halogen bulb and focusable light beam Screws per battery pack recharging operation Screw size 3.0 mm x 20 mm 4.0 mm x 15 mm 4.0 mm x 30 mm 4.0 mm x 50 mm 4.0 mm x 60 mm 5.0 mm x 25 mm Screws per battery pack up to 428 up to 327 up to 240 up to 92 up to 67 up to 190 Tested in practical application. Material: soft wood Accessories Order no. Suitable bits (bit boxes 1–4) and a bit range with screw-type angle attachment are given on page 84/85 Toothed ring drill chuck with hexagonal shank 1/4" (6.35 mm) and bit clamping chuck Power Grip 6.35100 Width 0.5-6.5 mm 4.8 Volt Cordless Screwdriver Power Grip Comparable specifications of cordless screwdriver: Battery pack voltage Capacity of battery pack Speeds at no load Maximum torque, soft Maximum torque, hard Adjustable torque Weight (including battery pack) 4.8 V 1.25 Ah 230/min 3,5 Nm 5 Nm 0.3 - 3.5 Nm 0.6 kg of battery lamp: Hologen bulb Weight (including battery pack) 5.2 V 0.36 kg Standard equipment Battery lamp „Power Grip Flashlight”, 2 NiCd battery packs (4.8 V/1.25 Ah), charger, plastic case Tool and assembly belt set to suit the above: Pocket to hold the Power Grip cordless screwdriver in the tool and assembly belt 6.25378 Power Grip Flashlight 6.27000 This is to complement an existing Power Grip® cordless screwdriver. The cordless flashlight is supplied without battery pack and without charger Connecting piece for using the 4.8 Volt battery pack in the current Metabo chargers 6.31976 4.8 V NiCd rechargeable battery pack (as a spare) 6.31858 With 2-hour battery charger for connection 230/240 V, 50/60 Hz (EU) (as a spare) 230/240 V, 50/60 Hz (GB) 230/240 V, 50/60 Hz (AUS/NZ) 110/120 V, 50/60 Hz (USA/CDN) Type Order no. 6.25377 6.31869 6.31977 6.31978 6.31979 Power Grip 6.02410.51 66 | 67 CORDLESS DRILLS / SCREWDRIVERS FEATURES  New, powerful motor  Variospeed (V) electronics  20-level adjustable torque, plus drilling level  Forward and reverse running  Quick stop  Keyless drill chuck and spindle stop gear for comfortable one-hand tool change: Metabo "Quick"  T-handle for optimum centre of gravity  Fatigue-free operation due to perfect ergonomy  Rubber-coated handle Comparable specifications Battery pack voltage Maximum torque, soft Maximum torque, hard Drill diameter in - Steel - Wood Speeds at no load Spindle thread Chuck capacity Weight (including battery pack) Standard equipment Type Order no. and tool equipment (Battery charger, capacity and number of battery packs) see our current price list        3-level planetary gears Gentle gear change Built-in collector fan to prevent overheating Bit case for two bits Maximum system flexibility through free combination of chargers and battery packs (within a volt class) Easy and quick change of battery pack “AIR COOLED” Battery pack can be charged up to 2000 times (with ACS 15: 3000-times) due to gentle charging process BSZ 9.6 BSZ 12 BSZ 14.4 BSZ 18 NEW NEW NEW NEW 9.6 Volt Cordless Drill / Screwdriver BSZ 9.6 12 Volt Cordless Drill / Screwdriver BSZ 12 14.4 Volt Cordless Drill / Screwdriver BSZ 14.4 118 Volt Cordless Drill / Screwdriver BSZ 18 9.6 V 18 Nm 45 Nm 12 V 22 Nm 52 Nm 14.4 V 24 Nm 55 Nm 18 V 28 Nm 62 Nm 10 mm/5 mm 20 mm/16 mm 0 - 350/0 - 1,200/min 1/2" - 20 UNF 1.5 - 13 mm 1.9 kg 10 mm/5 mm 25 mm/20 mm 0 - 400/0 - 1,350/min 1/2" - 20 UNF 1.5 - 13 mm 2 kg 12 mm/5 mm 30 mm/22 mm 0 - 400/0 - 1,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.1 kg 12 mm/6 mm 30 mm/22 mm 0 - 450/0 - 1,450/min 1/2" - 20 UNF 1.5 - 13 mm 2.2 kg Keyless chuck, 2 battery packs and plastic case BSZ 9.6 Keyless chuck, 2 battery packs and plastic case BSZ 12 Keyless chuck, 2 battery packs and plastic case BSZ 14.4 Keyless chuck, 2 battery packs and plastic case BSZ 18 CORDLESS DRILLS / SCREWDRIVERS FEATURES  New, powerful motor  Selectable impulse mode  Variospeed (V) electronics  20-level adjustable torque, plus drilling level  Forward and reverse running  Quick stop  Keyless drill chuck and spindle stop gear for comfortable onehand tool change: Metabo "Quick"  T-handle for optimum centre of gravity  Fatigue-free operation due to perfect ergonomy  Rubber-coated handle  3-level planetary gears  Gentle gear change Comparable specifications Battery pack voltage Maximum torque, soft Pulse torque Maximum torque, hard Drill diameter in - Steel - Wood Speeds at no load Spindle thread Chuck capacity Weight (including battery pack) Standard equipment Type      Built-in collector fan to prevent overheating Bit case for two bits Maximum system flexibility through free combination of chargers and battery packs (within a volt class) Easy and quick change of battery pack “AIR COOLED” Battery pack can be charged up to 2000 times (with ACS 15: 3000-times) due to gentle charging process BSZ 9.6 Impuls BSZ 12 Impuls BSZ 14.4 Impuls BSZ 18 Impuls NEW NEW NEW NEW 9.6 Volt Cordless Drill / Screwdriver BSZ 9.6 Impuls 12 Volt Cordless Drill / Screwdriver BSZ 12 Impuls 14.4 Volt Cordless Drill / Screwdriver BSZ 14.4 Impuls 18 Volt Cordless Drill / Screwdriver BSZ 18 Impuls 9.6 V 18 Nm 22 Nm 45 Nm 12 V 22 Nm 26 Nm 52 Nm 14.4 V 24 Nm 28 Nm 55 Nm 18 V 28 Nm 32 Nm 62 Nm 10 mm/5 mm 20 mm/16 mm 0 - 350/0 - 1,200/min 1/2" - 20 UNF 1.5 - 13 mm 1.9 kg 10 mm/5 mm 25 mm/20 mm 0 - 400/0 - 1,350/min 1/2" - 20 UNF 1.5 - 13 mm 2 kg 12 mm/5 mm 30 mm/22 mm 0 - 400/0 - 1,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.1 kg 12 mm/6 mm 30 mm/22 mm 0 - 450/0 - 1,450/min 1/2" - 20 UNF 1.5 - 13 mm 2.2 kg Keyless chuck, 2 battery packs and plastic case Keyless chuck, 2 battery packs and plastic case Keyless chuck, 2 battery packs and plastic case Keyless chuck, 2 battery packs and plastic case BSZ 9.6 Impuls BSZ 12 Impuls BSZ 14.4 Impuls BSZ 18 Impuls Order no. and tool equipment (Battery charger, capacity and number of battery packs) see our current price list 68 | 69 CORDLESS DRILLS / SCREWDRIVERS FEATURES  New, powerful motor  Selectable impulse mode  Variospeed (V) electronics  High speed for optimum hole punching  20-level adjustable torque, plus drilling level  Forward and reverse running  Quick stop  Sturdy keyless drill chuck with metal bush  Keyless drill chuck and spindle stop gear for comfortable one-hand tool change: Metabo “Quick”  T-handle for optimum centre of gravity  Fatigue-free operation due to perfect ergonomy  Rubber-coated handle BSP 12 Plus Comparable specifications Battery pack voltage Maximum torque, soft Pulse torque Maximum torque, hard Drill diameter in - Steel - Wood Speeds at no load Spindle thread Chuck capacity Weight (including battery pack) Standard equipment Type Order no. and tool equipment (Battery charger, capacity and number of battery packs) see our current price list          Additional handle 3-level planetary gears Die cast aluminum gear housing Gentle gear change Built-in collector fan to prevent overheating Bit case for two bits Maximum system flexibility through free combination of chargers and battery packs (within a volt class) Easy and quick change of battery pack Battery pack can be charged up to 2000-times (with ICS 10: 3000-times) due to gentle charging process BSP 15.6 Plus BSP 18 Plus 12 Volt Cordless Drill / Screwdriver BSP 12 Plus 15.6 Volt Cordless Drill / Screwdriver BSP 15.6 Plus 18 Volt Cordless Drill / Screwdriver BSP 18 Plus 12 V 20 Nm 22 Nm 55 Nm 15.6 V 26 Nm 28 Nm 60 Nm 18 V 30 Nm 32 Nm 65 Nm 13 mm/8 mm 40 mm/20 mm 0 - 400/0 - 1,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.5 kg 13 mm/8 mm 45 mm/25 mm 0 - 400/0 - 1,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.7 kg 13 mm/8 mm 50 mm/25 mm 0 - 400/0 - 1,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.8 kg Futuro Plus keyless chuck with metal bush, additional handle, plastic case Futuro Plus keyless chuck with metal bush, additional handle, plastic case Futuro Plus keyless chuck with metal bush, additional handle, plastic case BSP 12 Plus BSP 15.6 Plus BSP 18 Plus CORDLESS IMPACT DRILLS FEATURES  New, powerful motor  Selectable impulse mode  Variospeed (V) electronics  High speed for optimum hole punching  5-level adjustable torque, plus drilling level, plus impact drilling level  Forward and reverse running  Quick stop  Sturdy keyless drill chuck with metal bush  Keyless drill chuck and spindle stop gear for comfortable one-hand tool change: Metabo “Quick”  Spindle with hexagon recess for screwdriver bits  T-handle for optimum centre of gravity            Fatigue-free operation due to perfect ergonomy Rubber-coated handle Additional handle 3-level planetary gears Die cast aluminum gear housing Gentle gear change Built-in collector fan to prevent overheating Bit case for two bits Maximum system flexibility through free combination of chargers and battery packs (within a volt class) Easy and quick change of battery pack Battery pack can be charged up to 2000-times (with ICS 10: 3000-times) due to gentle charging process SBP 12 Plus 12 Volt Cordless Impact Drill SBP 12 Plus Comparable specifications Battery pack voltage Maximum torque, soft Pulse torque Maximum torque, hard Drill diameter in - Concrete - Steel - Wood Speeds at no load Maximum impact rate Spindle thread Chuck capacity Weight (including battery pack) Standard equipment Type SBP 18 Plus 18 Volt Cordless Impact Drill SBP 18 Plus 12 V 20 Nm 22 Nm 55 Nm 18 V 30 Nm 32 Nm 65 Nm 14 mm 13 mm/8 mm 40 mm/20 mm 0 - 400/0 - 1,400/min 20,800/min 1/2" - 20 UNF 1.5 - 13 mm 2.8 kg 16 mm 13 mm/8 mm 50 mm/25 mm 0 - 400/0 - 1,400/min 22,400/min 1/2" - 20 UNF 1.5 - 13 mm 2.9 kg Futuro Plus keyless chuck with metal bush, additional handle, 2 NiCd battery packs, plastic case Futuro Plus keyless chuck with metal bush, additional handle, 2 NiCd battery packs (18 V/2.0 Ah), plastic case SBP 12 Plus SBP 18 Plus Order no. and tool equipment (Battery charger, capacity and number of battery packs) see our current price list 70 | 71 CORDLESS IMPACT SCREWDRIVER FEATURES  Compact cordless impact screwdriver for tough applications  High torque machine with low Kick-Back torque  T-handle for optimum centre of gravity compensation, especially for screws  A vibration absorbing rubber-coated handle provides a comfortable non-slip grip for the user  Variospeed (V) Electronics for adjustable speed change  Ergonomic fwd/rev switch for comfortable, hassle free operation  Aluminium die cast gearbox case for optimum heat dissipation and long life  Bit case  Maximum system flexibility through free combination of chargers and battery packs (within a volt class) SSP 12 NEW 12 Volt Cordless Impact Screwdriver SSP 12 Comparable specifications Battery voltage Speeds at no load Impacts when idle Maximum tightening torque Bit retainer Weight Standard equipment Type Order no. and tool equipment (Battery charger, capacity and number of battery packs) see our current price list 12 V 0 - 2,500/min 3,000/min 100 Nm Hexagon socket 1/4" (6.35 mm) 1.7 kg 2 NiCd battery packs (12 V/2.0 Ah), plastic case SSP 12    Easy and quick change of battery pack The “AIR COOLED” Battery pack can be charged up to 2000 times (with ACS 15: 3000-times) due to a diagnostic charging process The “AIR COOLED” quick charger AC 30 reduces the charging time of warm battery packs by up to 50%. Charge time approx. 30 minutes (at 1.4 Ah).
6.31858.00 价格&库存
很抱歉,暂时无法提供与“6.31858.00”相匹配的价格&库存,您可以联系我们找货
