Cree® P4 LED CP41B-BFS/GFS
Data Sheet
This revolutionary package design allows the lighting designer to reduce the number of LEDs required and provide a more uniform and unique illuminated appearance than with other LED solutions. This is possible through the efficient optical package design and high current capabilities. The low profile package can be easily coupled with reflectors or lenses to efficiently distribute light and provide the desired lit appearance. This product family employs green and blue LED materials, which allow designers to match the color of many lighting applications like vehicle signal lamps and amusement lighting.
FEATURES • Size (mm): 7.6 x 7.6 • Color and Typical Dominant Wavelength (nm): Green (527) Blue (470) • Luminous Flux (mlm) Green (4400 - 8730) Blue (1650 - 3300) • Lead-Free • RoHS Compliant
APPLICATIONS • Channel Letter • Amusement
LD-CT868.001 Data Sheet: C
Subject to change without notice. www.cree.com/ledlamps
1
Absolute Maximum Ratings (TA = 25°C)
Items Symbol Absolute Maximum Rating Blue/Green Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Lead Soldering Temperature
Note
Unit
IF IFP VR PD Topr Tstg Tsol
35 100 5 154 -40 ~ +100 -40 ~ +100
mA mA V mW °C °C
Max. 260°C for 5 sec. max. (3 mm from the base of the epoxy bulb)
Note: Pulse width ≤0.1 msec, duty ≤1/10.
Typical Electrical & Optical Characteristics (TA = 25°C)
Characteristics Forward Voltage Reverse Current Dominant Wavelength Color Blue/Green Blue/Green Blue Green Blue Green Blue/Green Symbol VF IR λD λD Φv Φv 2θ½ Condition IF = 30 mA VR = 5 V IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA Unit V μA nm nm mlm mlm deg 460 515 1650 4400 470 527 2500 6500 70 Minimum Typical 3.6 Maximum 4.4 100 475 535
Luminous Flux 50% Power Angle
Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree LED are registered trademarks of Cree, Inc.
2
CLD-CT868.001
Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
Flux Bin Limit (IF = 30 mA)
Blue
Bin Code F0 G0 H0 Min.(mlm) 1650 2200 2750 Max.(mlm) 2200 2750 3300
Green
Bin Code L0 M0 N0 Min.(mlm) 4400 5500 6600 Max.(mlm) 5500 6600 8730
• Tolerance of measurement of luminous Flux is ±15%
Color Bin Limit (IF = 30 mA)
Blue
Bin Code B3 B4 B5 Min.(nm) 460 465 470 Max.(nm) 465 470 475
Green
Bin Code G6 G7 G8 G9 Min.(nm) 515 520 525 530 Max.(nm) 520 525 530 535
• Tolerance of measurement of dominant wavelength is ±1 nm
VF Bin Limit (IF = 30 mA)
Blue
Bin Code 27 28 29 2a 2b 2c 2d 2e Min.(V) 2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 Max.(V) 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4
Green
• Tolerance of measurement of VF is ± 0.05V
3
CLD-CT868.001
Order Code Table*
Luminous Flux (mlm) Color Blue Blue Blue Kit Number CP41B-BFS-CF0H0354 CP41B-BFS-CF0H0454 CP41B-BFS-CG0H0454 Viewing Angle 70 70 70 Min. 1650 1650 2200 Max. 3300 3300 3300 Color Bin B3 B4 B4 Dominant Wavelength Min. (nm) 460 465 465 Color Bin B5 B5 B5 Max. (nm) 475 475 475
Luminous Flux (mlm) Color Green Green Green Green Green Kit Number CP41B-GFS-CL0N0694 CP41B-GFS-CL0N0674 CP41B-GFS-CL0N0784 CP41B-GFS-CM0N0674 CP41B-GFS-CM0N0784 Viewing Angle 70 70 70 70 70 Min. 4400 4400 4400 5500 5500 Max. 8730 8730 8730 8730 8730 Color Bin G6 G6 G7 G6 G7
Dominant Wavelength Min. (nm) 515 515 520 515 520 Color Bin G9 G7 G8 G7 G8 Max. (nm) 535 525 530 525 530
Notes: 1. The above kit numbers represent order codes which include multiple flux-bin and color-bin codes. Only one flux-bin code and one color-bin code will be shipped on each reel. And single flux-bin code,single color bin-codes will not be orderable. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely.
4
CLD-CT868.001
Graphs
The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.
5
CLD-CT868.001
Mechanical Dimensions
All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max.
Notes
RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
6
CLD-CT868.001
Kit Number System
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
7
CLD-CT868.001
Package
Features:
• • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water resistant, and they must be kept away from water and moisture. The Tube Pack type of packaging. Max 60 pcs per tube.
R
xxx xxx
R
C OL OR LED LAMP
T YPE LXXXXX XXX-XXX LOT QT Y RANK Iv Vf Hu e X XX XX J OWAXXXXX -XX-XXX P CS
AX XXX XXX XXX X
8
CLD-CT868.001
很抱歉,暂时无法提供与“CP41B-BFS-CG0H0454”相匹配的价格&库存,您可以联系我们找货
