rev. rev. page date 1 of 12
11/2007
PART NUMBER: VPOL16A-12-SIP
DESCRIPTION: point of load converter
features * industry standard pin out * high efficiency to 94% * 300 KHz switching frequency * 9.0-14 VDC wide input range * 0.75-5.0 VDC wide output range * over temperature protection * continuous short circuit protection * remote on/off * cost-efficient open frame design * UL/C-UL60950-1 (E222736) certified
Content
1. INTRODUCTION 2. VPOL16A-12-SIP CONVERTER FEATURES 3. GENERAL DESCRIPTION 3.1 Electrical Description 3.2 Thermal Packaging and Physical Design. 4. TECHNICAL SPECIFICATIONS 5. MAIN FEATURES AND FUNCTIONS 5.1 Operating Temperature Range 5.2 Over-Temperature Protection (OTP) 5.3 Output Voltage Adjustment 5.4 Safe Operating Area (SOA) 5.5 Over Current Protection 5.6 Remote ON/OFF 5.7 UVLO (Under-Voltage Lockout) 6. SAFETY 6.1 Input Fusing and Safety Considerations. 7. APPLICATIONS 7.1 Layout Design Challenges. 7.2 Convection Requirements for Cooling 7.3 Thermal Considerations 7.4 Power De-Rating Curves 7.5 Efficiency vs Load Curves 7.6 Input Capacitance at the Power Module 7.7 Test Set-Up 7.8 Remote Sense Compensation 7.8 VPOL16A-12-SIP Series Output Voltage Adustment. 7.9 Output Ripple and Noise Measurement 7.10 Output Capacitance 7.11 VPOL16A-12-SIP Reflow Profile 8. MECHANICAL OUTLINE DIAGRAMS 8.1 VPOL16A-12-SIP Mechanical Outline Diagrams
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2382
rev. page date 2 of 12
11/2007
The converter is also protected against over-temperature conditions. If
1. Introduction
This application note describes the features and functions of V-Infinity’s VPOL16A-12-SIP series of Non Isolated DC-DC Converters. These are highly efficient, reliable and compact, high power density, single output DC/DC converters. These “Point of Load” modules serve the needs specifically of the fixed and mobile telecommunications and computing market, employing economical distributed Power Architectures. The VPOL16A-12-SIP series provide precisely regulated output voltage range from 0.75V to 5.0Vdc over a wide range of input voltage (Vi=9.0 – 14Vdc) and can operate over an ambient temperature range of –40°C to +85°C. Ultr a-high efficiency operation is achieved through the use of synchronous rectification and drive control techniques. The modules are fully protected against short circuit and overtemperature conditions. V-Infinity’s world class automated manufacturing methods, together with an extensive testing and qualification program, ensure that all VPOL16A-12-SIP series converters are extremely reliable.
the converter is overloaded or the ambient temperature gets too high, the converter will shut down to protect the unit.
Q1
+VIN
L1
+VO
C1
Q2
D1
C2
R sense
+SENSE
COM
COM
R1
PWM IC
ON/OFF
R trim
TRIM
ERR AMP
R2
Figure 1. Electrical Block Diagram
The VPOL16A-12-SIP series uses a multi-layer FR4 PCB construction. All surface mount power components are placed on one side of the PCB, and all low-power control components are placed on the other side. Thus, the Heat dissipation of the power components is optimized, ensuring that control components are not thermally stressed. The converter is an open-frame product and has no case or case pin. The open-frame design has several advantages over encapsulated closed devices. Among these advantages are: Efficient Thermal Management: the heat is removed from the heat generating components without heating more sensitive, small signal control components. Environmental: Lead free open-frame converters are more easily re-cycled. Cost Efficient: No encapsulation. Cost efficient open-frame construction. Reliable: Efficient cooling provided by open frame construction offers high reliability and easy diagnostics.
2. VPOL16A-12-SIP Converter Features
High efficiency topology, typically 94% at 5.0Vdc Industry standard footprint Wide ambient temperature range, -40°C to +85°C Cost efficient open frame design Programmable output voltage via external resistor from 0.75 to 5.0Vdc No minimum load requirement (Stable at all loads) Remote ON/OFF Remote sense compensation Fixed switching frequency Continuous short-circuit protection and over current protection Over-temperature protection (OTP) Monotonic Startup with pre-bias at the output. UL/IEC/EN60950 Certified.
3. General Description
A block diagram of the VPOL16A-12-SIP Series converter is shown in Figure 1. Extremely high efficiency power conversion is achieved through the use of synchronous rectification and drive techniques. Essentially, the powerful VPOL16A-12-SIP series topology is based on a non-isolated synchronous buck converter. The control loop is optimized for unconditional stability, fast transient response and a very tight line and load regulation. In a typical pre-bias application the VPOL16A-12-SIP series converters do not draw any reverse current at start-up. The output voltage can be adjusted from 0.75 to 5.0vdc, using the TRIM pin with a external resistor. The converter can be shut down via a remote ON/OFF input that is referenced to ground. This input is compatible with popular logic devices; a 'positive' logic input is supplied as standard. Positive logic implies that the converter is enabled if the remote ON/OFF input is high (or floating), and disabled if it is low.
rev. page date 3 of 12
11/2007
4. Technical Specifications
(All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) Device PARAMETER NOTES and CONDITIONS ABSOLUTE MAXIMUM RATINGS
Input Voltage Continuous Operating Temp erature See Thermal Considerations Section Storage Temperature ALL ALL ALL Min. Typical Max. Units
0 -40 -55
15 +85 +125
Vdc °C °C
INPUT CHARACTERISTICS
Operating Input Voltage Input Under-Voltage Lockout Turn-On Voltage Threshold Turn-Off Voltage Threshold Lockout Hysteresis Voltage Maximum Input Current Vin=0 to 14Vdc , Io=Io,max. Vo=0.75V Vo=1.2V Vo=1.5V Vo=1.8V Vo=2.0V Vo=2.5V Vo=3.3V Vo=5.0V Shutdown input idle current ALL ALL ALL ALL ALL 9.0 8.0 7.7 0.3 11 40 50 50 60 60 65 75 75 10 0.1 300 12 14 Vdc Vdc Vdc Vdc A
No-Load Input Current
ALL
mA
Off Converter Input Current Inrush Current (I t) Input Reflected-Ripple Current
2
ALL ALL
mA As mA
2
P-P thru 1uH inductor, 5Hz to 20MHz
ALL
OUTPUT CHARACTERISTIC
Output Voltage Set Point Output Voltage Trim Adjustment Range Output Voltage Regulation Load Regulation Line Regulation Tempera ture Coefficient Output Voltage Ripple and Noise Peak-to-Peak RMS External Capacitive Load Operating Output Current Range Output DC Current-Limit Inception Shout Circuit Protection Output Voltage =90% Nominal Output Voltage Continuous with Hiccup Mode Io=Io.min to Io.max Vin=low line to high line Ta=-40°C to 85°C 5Hz to 20MHz bandwidth Full Load, 1uF ceramic and 10uF tantalum Full Load, 1uF ceramic and 10uF tantalum Low ESR ALL ALL ALL ALL ALL ALL 0 18 23 75 30 8000 16 28 mV mV uF A A ALL ALL ALL -0.5 -0.2 -0.03 +0.5 +0.2 +0.03 % % %/°C Vin=Nominal Vin , Io=Io.max, Tc=25 Selected by an external resistor ALL ALL -1.5% Vo,set +1.5% 0.75 5.0 Vdc Vdc
rev. page date 4 of 12
11/2007
PARAMETER DYNAMIC CHARACTERISTICS
Output Voltage Transient Response Error Brand Setting Time (within 1% Vout nominal)
Device
Min.
Typical Max.
Units
50% Step Load Change, di/dt=0.1A/us 50% Step Load Change, di/dt=0.1A/us
ALL ALL
200 200
mV us
EFFICIENCY
Vo=0.75V Vo=1.2V Vo=1.5V Vo=1.8V Vo=2.0V Vo=2.5V Vo=3.3V Vo=5.0V Non-isolation 77 83 86 88 89 90 92 94 0
100% Load
ALL
ISOLATION CHARACTERISTICS
Input to Output ALL Vdc
FEATURE CHARACTERISTICS
Switching Frequency ON/OFF Control, Positive Logic Remote On/Off Logic Low (Module Off) Logic High (Module On) ALL 0 Vin 0 2.8 0.4 Vin 1 1 3.5 3.5 3.5 130 0.98 10 300 0.4 KHz Vdc Vdc Vdc Vdc mA mA ms ms ms °C M hours grams
or Open Circuit
VPOL16A-12-SIP
ON/OFF Control, Negative Logic Remote On/Off or Open Circuit Logic Low (Module On) Logic High (Module Off) ON/OFF Current (for both remote on/off logic) Leakage Current (for both remote on/off logic) Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time Over Temperature Protection Ion/off at Von/off =0.0V Logic High, Von/off=14V Von/off to 10%Vo,set Vin,min. to 10%Vo,set 10%Vo,set to 90%Vo,set
VPOL16A-12-SIP ALL ALL ALL ALL ALL ALL ALL ALL
GENERAL SPECIFICATIONS
MTBF Weight Dimensions VPOL16A-12-SIP packages Io=100%of Io.max;Ta=2 5°C per MIL-HDBK217F 2x0.512x0.327 inches (50.8x13.0x8.3 mm)
rev. page date 5 of 12
11/2007
+Vin Remote ON/OFF
+Vo
7. Applications
In optimizing thermal design the PCB is utilized as a heat sink. Also some heat is transferred from the VPOL16A-12-SIP module to the main board through connecting pins. The system designer or the end user must ensure that other components and metal in the vicinity of the VPOL16A-12-SIP series meet the spacing requirements to which the system is approved. Low resistance and low inductance PCB layout traces are the norm and should be used where possible. Due consideration must also be given to proper low impedance tracks between power module, input and output grounds. The recommended VPOL16A-12-SIP footprint is shown as figure 5.
ON/OFF Control
Q1
VPOL16A-12-SIP
Common Common
Figure 3. Positive Remote ON/OFF Input Drive Circuit
+Vin +Vo
Q1
ON/OFF Control
VPOL16A-12-SIP
Remote ON/OFF
0.29(7.4)
Common
Common
LAYOUT PATTERN TOP VIEW
0.33(8.4)
Figure 4. Negative Remote ON/OFF Input Drive Circuit
All Dimmension In Inches(mm) Tole rance : .XX= ± 0.04 .XXX= ± 0.010
1.1mm PLATED THROUGH HOLE 1.6mm PAD SIZE
The voltage on the Vcc pin determines the start of the operation of the Converter. When the input Vcc rises and exceeds about 8.0V the converter initiates a soft start. The UVLO function in the converter has a hysteresis (about 300mV) built in to provide noise immunity at start-up.
Figure 5. Recommended VPOL16A-12-SIP Footprint
6. Safety
Agency Approvals: The power Supply shall be submitted to and receive formal approval from the following test agencies. 1.The power supply shall be approved by a nationally recognized testing laboratory to UL/CSA 60950 3 Edition (North America) and EN60950 (International) 2. CB Certificate from an internationally recognized test house in accordance with EN 60950. The VPOL16A-12-SIP series converters do not have an internal fuse. However, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a time-delay fuse with a maximum rating of 20A.
rd
rev. page date 6 of 12
11/2007
To predict the ap proximate cooling needed for the module, refer to the Power De-rating curves in Figures 8 & 9 . These de-rating curves are approximations of the ambient temperatures and airflows required to keep the power module temperature below its maximum rating. Once the module is assembled in the actual system, the module’s temperature should be checked as shown in Figure 6 to ensure it does not exceed 120°C. Proper cooling can be verified by measuring the power module’s temperature at Q1-pin 6 as shown in Figure 7.
W ind Tunnel Bakelite
The power module operates in a variety of thermal environments; however, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. The thermal data presented is based on measurements taken in a set-up as shown in Figure 6. Figures 8 & 9 represent the test data. Note that the airflow is parallel to the long axis of the module as shown in Fig 6 for the VPOL16A-12-SIP. The temperature at either location should not exceed 120 °C. The output power of the module should not exceed the rated power for the module (VO, set x IO, max). The VPOL16A-12-SIP thermal data presented is based on measurements taken in a wind tunnel. The test setup shown in Figure 7 and EUT need to solder on 33mm x 40.38mm(1.300'' x 1.59'') test pcb. Note that airflow is parallel to the long axis of the module as shown in Fig 6.
2 5.4(1.0)
Power Module
76.2(3.0)
Thermocuple Location for measuring ambient temperature and airflow 12.7(0.5)
A ir flow
Note : Dimensions are in millimeters and (inches)
Figure 6. Thermal Test Setup
Figure 7. Temperature Measurement Location for VPOL16A12-SIP
rev. page date 7 of 12
11/2007
TYPICAL POWER DERATING FOR 5 Vin 3.3 Vout
18 16 14 Output Current(A) 12 10 8 6 4 2 0 0 10 20 30 40 50 60 70 80 90 100 0LFM 100LFM 200LFM 300LFM
Ambient Temperature( oC)
NOTE:
1. specific input & output derating curves available, please contact V-Infinity for detail
rev. page date 8 of 12
11/2007
7.5 Efficiency vs Load Curves (Fig. 9)
VPOL16A-12-SIP Vo=5.0V (Eff Vs Io)
100% 95% 100% 95%
VPOL16A-12-SIP Vo=3.3V (Eff Vs Io)
Efficincy (%)
90% 85% 80% 75% 70% 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Efficincy (%)
9.0V 12V 14V
9.0V 12V 14V
Current Load (A)
VPOL16A-12-SIP Vo=2.5V (Eff Vs Io)
100% 95% 100% 95% 90%
Current Load (A)
VPOL16A-12-SIP Vo=2.0V (Eff Vs Io)
Efficincy (%)
Efficincy (%)
85% 80% 75% 70% 65% 60% 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
9.0V 12V 14V
9.0V 12V 14V
Current Load (A)
Current Load (A)
rev. page date 9 of 12
11/2007
VPOL16A-12-SIP Vo=1.8V (Eff Vs Io)
100% 95% 90% 100% 95% 90%
VPOL16A-12-SIP Vo=1.5V (Eff Vs Io)
Efficincy (%)
Efficincy (%)
9.0V 12V 14V
9.0V 12V 14V
Current Load (A)
VPOL16A-12-SIP Vo=1.2V (Eff Vs Io)
100% 95% 90% 100% 95% 90% 85% 80% 75% 70% 65% 60% 55% 50% 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 0 1 2 3 4
Current Load (A)
VPOL16A-12-SIP Vo=0.75V (Eff Vs Io)
Efficincy (%)
9.0V 12V 14V
Efficincy (%)
9.0V 12V 14V
Current Load (A)
Current Load (A)
rev. page date 10 of 12
11/2007
Where:
The VPOL16A-12-SIP converters must be connected to a low AC source impedance. To avoid probl ems with loop stability source inductance should be low. Also, the input capacitors should be placed close to the converter input pins to de-couple distribution inductance. However, the external input capacitors are chosen for suitable ripple handling capability. Low ESR polymers are a good choice. They have high capacitance, high ripple rating and low ESR (typical
