Additional Resources:
Product Page
3D Model
date
11/05/2021
page
1 of 12
SERIES: VPOL15A-5-SIP │ DESCRIPTION: POINT OF LOAD CONVERTER
FEATURES
industry standard pin out
high efficiency to 94%
300 KHz switching frequency
3.0-5.5 VDC input range
0.9-3.63 VDC wide output range
over temperature protection
continuous short circuit protection
remote on/off
cost-efficient open frame design
UL/C-UL 60950 (E222736) certified
MODEL
VPOL15A-5-SIP
Notes:
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
max
(A)
max
(W)
max
(mVp-p)
typ
15
15.0
18.0
22.5
27.0
30.0
37.5
49.5
50
50
50
50
50
50
50
82
84
87
88
89
92
94
typ
(Vdc)
range
(Vdc)
(Vdc)
5
3.0~5.5
3.0~5.5
3.0~5.5
3.0~5.5
3.0~5.5
3.0~5.5
4.5~5.5
1.0
1.2
1.5
1.8
2.0
2.5
3.3
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 µF ceramic and 10 µF electrolytic capacitors on the output.
PART NUMBER KEY
VPOL15A - 5 - XX - XX
Base Number
Input Voltage
Output Voltage
cui.com
Packaging Style
SIP
Product Page
3D Model
CUI Inc │ SERIES: VPOL15A-5-SIP │ DESCRIPTION: POINT OF LOAD CONVERTER
date 11/05/2021 │ page 2 of 12
INPUT
parameter
conditions/description
operating input voltage
input under-voltage lockout
turn-on voltage treshold
turn-off voltage treshold
lockout hysteresis voltage
input current
3.0~5.5 Vdc
no load input current
1.0
1.2
1.5
1.8
2.0
2.5
3.3
off converter input current
shutdown input idle current
min
typ
max
units
3.0
5.0
5.5
Vdc
2.8
2.7
0.1
15.5
output
output
output
output
output
output
output
60
60
60
70
70
70
70
5
inrush current
input reflected-ripple current
Vdc
Vdc
Vdc
P-P thru 1µH inductor, 5Hz to 20MHz
A
mA
mA
mA
mA
mA
mA
mA
10
mA
0.4
A2s
150
mA
OUTPUT
parameter
capacitive load
low ESR
min
output voltage set point
at nominal input
trim adjustment range
selected by an external resistor
line regulation
low to high
load regulation
10~100% load
0.9
units
µF
Vdc
3.63
±0.2
±0.4
25% load step change
switching frequency
Vdc
±0.5
positive logic
logic low (module off)
logic high (module on)
max
10,000
±1.5
operating current range
transient response deviation
typ
15
A
±5
300
kHz
or open circuit
Vdc
or open circuit
0.4
Vdc
leakage current
1
mA
start-up time
1
ms
remote on/off
negative logic
rise time
temperature coefficient
3.5
-40~85°C
6
±0.03
ms
%/°C
PROTECTIONS
parameter
continuous, hiccup
min
typ
max
120
units
°C
SAFETY AND COMPLIANCE
parameter
safety approvals
60950-1: UL/cUL
MTBF
as per MIL-HDBK-217F @ 25°C
RoHS
yes
min
1,500,000
cui.com
typ
max
units
hours
Product Page
3D Model
date 11/05/2021 │ page 3 of 12
ENVIRONMENTAL
parameter
min
max
units
operating temperature
see derating curve
-40
85
°C
-55
125
°C
storage temperature
DERATING CURVES
Figure 1
cui.com
typ
Product Page
3D Model
date 11/05/2021 │ page 4 of 12
MECHANICAL
parameter
dimensions
50.8 x 12.70 x 8.50 [2.00 x 0.50 x 0.335 inch]
min
weight
typ
units: inches [mm]
tolerance: x.xx ±0.02 [±0.5], x.xxx ±0.010 [0.25]
PIN CONNECTIONS
Pin
Function
1
+Vo
2
+Vo
3
+Sense
4
+Vo
5
Common
6
Common
7
+Vin
8
+Vin
9
No pin
10
Trim
11
REM
cui.com
units
mm
6.8
MECHANICAL DRAWING
max
g
Product Page
EFFICIENCY CURVES
cui.com
3D Model
date 11/05/2021 │ page 5 of 12
Product Page
3D Model
date 11/05/2021 │ page 6 of 12
THEORY OF OPERATION
A block diagram of the VPOL15A-5-SIP Series converter is shown in Figure 2. Extremely high efficiency power
conversion is achieved through the use of synchronous rectification and drive techniques. Essentially, the
powerful VPOL15A-5-SIP series topology is based on a non-isolated synchronous buck converter. The control
loop is optimized for unconditional stability, fast transient response and a very tight line and load regulation. In
a typical pre-bias application the VPOL15A-5-SIP series converters do not draw any reverse current at startup. The output voltage can be adjusted from 0.9 to 3.63Vdc, using the TRIM pin with a external resistor. The
converter can be shut down via a remote on/off input that is referenced to ground. This input is compatible
with popular logic devices; a 'positive' logic input is supplied as standard. Positive logic implies that the
converter is enabled if the remote on/off input is high (or floating), and disabled if it is low. The converter is
also protected against over-temperature conditions. If the converter is overloaded or the ambient temperature
gets too high, the converter will shut down to protect the unit.
Figure 2
cui.com
Product Page
3D Model
date 11/05/2021 │ page 7 of 12
TYPICAL APPLICATION CIRCUITS
The VPOL15A-5-SIP converters must be connected to a low AC source impedance. To avoid problems with loop
stability source inductance should be low. Also, the input capacitors should be placed close to the converter
input pins to de-couple distribution inductance. However, the external input capacitors are chosen for suitable
ripple handling capability. Low ESR polymers are a good choice. They have high capacitance, high ripple rating
and low ESR (typical
很抱歉,暂时无法提供与“VPOL15A-5-SIP”相匹配的价格&库存,您可以联系我们找货
