VHK200W-Q48-S12
VHK200W-Q48-S12
    CUIDEVICES
    模块
    CONVERTER DC-DC 12V 16.7A 200W
VHK200W-Q48-S12 数据手册
rev. page page date date 1 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter description The VHK200W series of rugged DC-DC converters are designed for high reliability applications, featuring integral heat sink, over-temperature protection, over-current protection and input transient voltage protection. With an external input fuse, the converter can protect accidental input polarity reversal. The wide 4:1 input range (10-36V or 1875V) is very useful to stabilize an input source like batteries in various discharging and charging conditions. Additionally, high efficiency, fast response, tight regulations, remote sense and remote On/Off control make these converters very useful in many industrial and communications applications. features ·132-200W isolated output ·Efficiency to 87% ·RoHS Compliant ·4:1 input range ·Regulated output ·Continuous short circuit protection ·Metal enclosure with integrated heatsink ·Rugged design ·Over-temperature shutdown M ODEL VHK200W-Q24-S12 VHK200W-Q24-S15 VHK200W-Q24-S24 VHK200W-Q24-S28 VHK200W-Q24-S48 VHK200W-Q48-S12 VHK200W-Q48-S15 VHK200W-Q48-S24 VHK200W-Q48-S28 VHK200W-Q48-S48 notes: input voltage nominal range (V dc) (V dc) output voltage (V dc) output current 1 (A) input current no load full load (mA) (mA) efficiency typ. (%) 24 24 24 24 24 48 48 48 48 48 10~36 10~36 10~36 10~36 10~36 18~75 18~75 18~75 18~75 18~75 12 15 24 28 48 12 15 24 28 48 16.7 13.3 8.3 7.14 4.2 16.7 13.3 8.3 7.14 4.2 100 100 100 100 100 60 60 60 60 30 9710 9670 9540 9521 6720 4744 4723 4716 4706 4730 84 84 84 87 87 86 86 86 87 88 1. see output derating curve (page 4) I NPUT parameter input voltage range under voltage lockout conditions/description min 10 18 nom 24 48 8.8 8 9.5 8.5 17 16 max 36 75 units V dc V dc V dc V dc V dc V dc V dc V dc remote on/off control 2 input filter notes: 24 Vin power up 24 Vin power down 24 Vin power up (48V output) 24 Vin power down (48V output) 48 Vin power up 48 Vin power down section 15 in the application notes PI type 2. add suffix “N” to the model number for negative logic on/off control *V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-todate product information before placing orders. V-Infinity assumes no liability or responsibility for customer’s applications using V-Infinity products other than repair or replacing (at V-I’s option) V-Infinity products not meeting V-I’s published specifications. Nothing will be covered outside of standard product warranty. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 2 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter OUTPUT parameter voltage accuracy transient response external trim adj. range ripple & noise (20MHz BW) conditions/description 12V, 15V & 24V 28V & 48V 25% step load change 12V & 15V 24V 28V 48V temperature coefficient short circuit protection continuous line regulation 3 load regulation 4 over voltage protection trip range, % Vo nom. 12V, 15V & 24V 28V & 48V over current protection nominal output ±0.03 ±0.2 ±0.2 115 90 110 140 110 160 min nom max ±1 ±1.5 500 ±10 60 150 100 240 100 280 150 480 units % % μ sec % mV RMS mV p-p mV RMS mV p-p mV RMS mV p-p mV RMS mV p-p %/°C % % % % % GENERAL SPECIFICATIONS parameter switching frequency operating ambient temp. 5 storage temperature thermal shutdown case temp. case material conditions/description 12V, 15V & 24V 28V & 48V min nom 300 250 max units KHz KHz °C °C °C -40 -55 110 aluminum / steel 100 105 ISOLATION SPECIFICATIONS parameter isolation voltage conditions/description input/output input/case output/case min 1500 1500 1500 100 nom max units V dc V dc V dc MΩ isolation resistance notes: 3. 4. 5. measured from high line to low line at full load measured from full load to zero load at nominal input see output derating curve (page 4) *V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-todate product information before placing orders. V-Infinity assumes no liability or responsibility for customer’s applications using V-Infinity products other than repair or replacing (at V-I’s option) V-Infinity products not meeting V-I’s published specifications. Nothing will be covered outside of standard product warranty. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com REV. A B DESCRIPTION NEW DRAWING dimension updates DATE 4/22/2008 8/27/2008 86.3 3.398 B 107.5 4.232 38.0 1.496 15.6 0.614 B (TYP) 101.76 4.006 9.70 0.382 (TYP) 91.0 3.583 (2 PLCS) 6789 18.75 0.738 (2 PLCS) B 70.0 2.756 TOLERANCE: ±0.3mm UNLESS OTHERWISE SPECIFIED RoHS 1 B 26.50 1.043 2 3 4 5 Terminal # 1 2 3 4 5 6 7 8 9 Description - V out -S Trim +S + V out Case Remote - V in + V in 9.5 0.374 B (TYP) 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: *DIN rail mounting kit available (part# VHK-DIN) VHK VHKXXW Series APPROVED BY: UNITS: REV: B PART NO. MM [INCHES] SCALE: PC FILE NAME: DRAWN BY: VHKXXW Series COPYRIGHT 2008 BY CUI INC. Material Aluminum/Steel ZRJ 1:2 page date 4 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter APPLICATION NOTES 1. OUTPUT DE-RATING The operating ambient temperature range for VHK200W is -40 ~ +100°C, with the actual output power subject to the following de-rating curves at free-air convection and at forced air conditions. To ensure long-term reliability, it is important to ensure proper cooling at the worst operating conditions. VHK200W-Q24 Power Derating Curves @ Nominal Input 120.00% Natural Convection 100.00% 0.5 m/S (100LFM) Relative Output Power - % of nominal output 80.00% 1.0 m/S (200LFM) 1.5 m/S (300LFM) 60.00% 2.0 m/S (400LFM) 40.00% 2.5 m/S (500LFM) 20.00% 3.0 m/S (600LFM) 3.5 m/S (700LFM) 0.00% 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 Ambient Temperature - degrees C F IGURE 1a. OUTPUT DERATING (24 V) 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 5 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter VHK200W-Q48 Power Derating Curves @ Nominal Input 120% Natural Convection 100% 0.5 m/S (100LFM) Relative Output Power - % of nominal output 80% 1.0 m/S (200LFM) 1.5 m/S (300LFM) 60% 2.0 m/S (400LFM) 40% 2.5 m/S (500LFM) 3.0 m/S (600LFM) 20% 3.5 m/S (700LFM) 0% -40 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 Ambient Temperature - degrees C F IGURE 1b. OUTPUT DERATING (48 V) 2. INPUT VOLTAGE RANGE It is important to ensure the input voltage measured at the converter input pins is within the range for that converter. Make sure wire losses and voltage ripples are accounted for. One possible problem is driving the converter with a linear unregulated power supply. For example, if the average voltage measured by a DMM is 9V, with a voltage ripple of 3Vpp, the actual input can swing from 7.5V to 10.5V. This will be outside the specified input range of 10-36V and the converter may not function properly. On the other end, make sure the actual input voltage does not exceed the highest voltage of 36V or 75V. 3 . LEAD WIRES Make sure the input and output wires are of adequate AWG size to minimize voltage drop, and ensure the voltage across the input terminals is above the converter's rated minimum voltage at all times. It is recommended to have the wire pairs twisted, respectively for the input pair and the output pair, so as to minimize noise pickup. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 6 of 10 08/2009 PART NUMBER: VHK200W 4. INPUT CURRENT DESCRIPTION: chassis mount dc-dc converter The input voltage source must be able to provide enough current to the converter, otherwise it may not start up or operate properly. A typical symptom is not starting or unusually low output voltage. In general, it is recommended to be able to provide at least: I peak = 150%*Pout/( η *Vmin) where Pout is the maximum output power, Vmin is the minimum input voltage and η is the converter's efficiency. As an example, for VHK200W-Q24-S12 to operate with 10~36V input, 200W output and an efficiency of 86%, the minimum source current is recommended to be: I peak = 150% * 200 / (86% * 10) = 34.88A . 5. INPUT FUSE To limit the input current and to facilitate input reversal protection and input OVP protection, a fast-acting input fuse is recommended for the input line. The fuse rating will depend on the input range and should allow for the maximum current at the lowest input voltage, as shown in this equation: I peak = 150%*Pout/( η *Vmin) . In the previous example of VHK200W-Q24-S12, the peak input current at 10V was calculated to be 34.88A. A 35A or a 40A fuse may be suitable for this application. Make sure the fuse voltage rating is higher than the maximum input voltage. 6 . INPUT OVP It is important to ensure the input voltage does not exceed the maximum rated input voltage for that model. To suppress voltage transients of short durations, the converter includes a transient voltage suppression device (TVS) at the input. The built-in TVS has a rated breakdown voltage of 39V for the VHK200W-Q24-XX models and 82V for the VHK200W-Q48 models. With small transients of short-durations, the TVS will limit the input voltage without interrupting the converters operations. For large transients, the TVS may conduct a large amount of current that may trip the input fuse. Without the input fuse, the converter may suffer permanent damages. When the fuse is open, replace it with one of same type and ratings. 7 . INPUT REVERSAL PROTECTION If the input voltage is reversed for any reason, the built-in protection circuits in the converter will limit the reverse voltage to one diode drop which is no more than 1V. With an external input fuse connected, the fuse will open and thus remove power from the converter. Check the wiring and make corrections as needed. The input fuse will need to be replaced. Make sure the new fuse is of the same type and rating. Without the input fuse, the converter may suffer permanent damages. 8. REMOTE SENSE The converter provides regulated outputs at the output terminals. When there is a large current and/or the output cable is of some length, the voltage at the end of the output cable may be noticeably lower than at the terminals. The converter can compensate up to 0.5V of voltage drop through remote sense terminals. To ensure accurate regulation, run two separate wires (twisted) from the desired regulation points to the remote sense terminals, as shown below. Even if the load current is low, still connect +Vo to +S and -Vo to -S. +Vo +S Trim (-) -S -Vo FIGURE 2. REMOTE SENSE (+) Load 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 7 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter 9. OUTPUT TRIMMING ( OPTIONAL) The output voltages are preset to nominal values as indicated by the models table at the factory. If desired, the output voltage may optionally be trimmed to a different value (+/- 10%) with external resistors and/or potentiometer as shown below. Care should be taken to ensure that the maximum ouput power of the module remains at or below the maximum rated power (Maximum rate power = V o,set x l o,max). +Vin +Vo +S 47KΩ 10KΩ Trimpot 470KΩ R load FIGURE 3. TRIMMING WITH EXTERNAL POTENTIOMETER Trim -S -Vin -Vo To trim the output voltage with fixed resistors, the output voltage can be calculated as follows. Trim-Down +Vin +Vo +S Trim R trim-down R load Trim-Up +Vin +Vo +S R trim-up Trim -S -Vin -Vo R load -S -Vin -Vo FIGURE 4: TRIM-DOWN VOLTAGE SETUP The value of R trim-down is defined as: FIGURE 5: TRIM-UP VOLTAGE SETUP The value of R trim-up is defined as: Rtrim-down % B % Vo,nom - Vo Vo,nom C x 100 Rtrim-up A(Vo)(100+Δ%) B -C 1.225 x Δ% Δ% % Vo - Vo,nom Vo,nom x 100 Where: R trim-down is the external resistor in K Ω . V o,nom is the nominal output voltage. V o is the desired output voltage. B and C values are defined in Table 1. For example, to trimdown the 24V module (VHK200W-Q24-S24) by 8% to 22.08V, R trim-down is calculated: Where: R trim-up is the external resistor in K Ω . V o,nom is the nominal output voltage. V o is the desired output voltage. A, B and C values are defined in Table 1. For example, to trimdown the 24V module (VHK200W-Q24-S24) by 8% to 25.92V, R trim-up is calculated: B = 511, C = 10.22 Δ% = 8 Rtrim-down = 511 - 10.22 KΩ 8 Rtrim-up = A = 5.11, B = 511, C = 10.22 Δ% = 8 511 (25.92) (100 + 8) 511 - 10.22 KΩ 1.225 + 8 8 Rtrim-up = 1476.55 KΩ Output Voltage(V) A 5.11 20 B 511 2000 C 10.22 40 Rtrim-down = 53.66 KΩ Table 1 12, 15, 24, 28V 48V 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 8 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter 10. OUTPUT OCP AND SHORT-CIRCUIT PROTECTION Output overload and short circuit conditional will cause the output voltage to decline or shutdown altogether. If the case temperature is not over 105°C, the output recovers automatically when the short or OCP conditions are removed. In the case of slight overloading, the output voltage may not shut down, but the converter may build up heat over time, causing over-temperature shutdown. 11. OVER-TEMPERATURE PROTECTION When the case temperature reaches about 105°C, the converter's built-in protection circuit will shut down the output. When the temperature is reduced enough to a safe operating level, the converter will recover to normal operations automatically. 1 2. OUTPUT OVP In case the output voltage exceeds the OVP threshold, the converter shuts down. 1 3. OUTPUT PARALLEL CONNECTIONS The converter is not designed for load share on the output. However, for redundancy, the outputs of two or more converters can be connected in parallel through OR-ING diodes, as shown below. The standard version defaults to positive logic. For negative logic, indicate the selection when ordering. +Vin +Vo FIGURE 6. OUTPUT PARALLEL CONNECTIONS -Vin -Vo +Vin +Vo -Vin -Vo 14. OUTPUT SERIES CONNECTIONS Two or more converters can be connected in series to obtain a higher output voltage. To prevent output reverse biasing each other in case of a short, add a Schottky diode on each output in reverse polarity, as shown in the diagram. In the event of a short, the converters will forward-bias the diodes and the output reversal will be limited to one diode drop (about 0.5V) only, so as not to damage the converters. The forward current will cause each converter to go into short-circuit protection. +Vo For proper diode selection, +Vin FIGURE 7. OUTPUT SERIES CONNECTIONS -Vin -Vo +Vin +Vo -Vin -Vo 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 9 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter 15. REMOTE OUTPUT ON/OFF CONTROL The converter output can be enabled or disabled through the On/Off pin. The control logic is shown in this table. A common control circuit is shown below. REM SW +Vo REM (pin 2) SW High signal here disable output -Vin -Vo -Vin (pin 4) FIGURE 9. REMOTE ON/OFF CONTROL WITH TRANSISTOR SWITCH FIGURE 8. REMOTE ON/OFF CONTROL Logic Table Negative logic Output on SW Closed (V REM 3.5~75 V or Open Circuit) Output off 16. ISOLATION Positive logic Output off Output on The input and output of the converter are electrically isolated. If needed, an output terminal can be connected to an input terminal, resulting in the converter non-isolated. 1 7. INPUT FILTERING AND EMI INTERFERENCE The VHK200W converters have input capacitors that control input current ripple and the associated EMI interference. However, they have not been tested to a formal standard for conducted emissions. Additional filtering may be needed to ensure compliance to an EMI standard. Refer to FIGURE 10 (next page) for a reference circuit. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com page date 10 of 10 08/2009 PART NUMBER: VHK200W DESCRIPTION: chassis mount dc-dc converter CY3 CY1 L1 C1 C2 L2 C3 -Vin +Vin +Vo Rload CASE -Vo CY2 FIGURE 10. EMI FILTER FOR VHK200W Model No. VHK200W-Q24-S5 VHK200W-Q24-S12 VHK200W-Q24-S24 VHK200W-Q24-S28 VHK200W-Q24-S28 VHK200W-Q24-S48 VHK200W-Q24-S48 VHK200W-Q48-S5 VHK200W-Q48-S12 VHK200W-Q48-S24 VHK200W-Q48-S28 VHK200W-Q48-S28 VHK200W-Q48-S48 VHK200W-Q48-S48 Class B Class B Class B Class A Class B Class A Class B Class B Class B Class B Class A Class B Class A Class B C1 82uF/100V KY 82uF/100V KY 120uF/100V KY 100uF/100V KY 120uF/100V KY 100uF/100V KY 82uF/100V KY 82uF/100V KY 120uF/100V KY 120uF/100V KY 150uF/100V KY 120uF/100V KY 100uF/100V KY 82uF/100V KY C2 82uF/100V KY 82uF/100V KY 120uF/100V KY 100uF/100V KY 120uF/100V KY 100uF/100V KY 82uF/100V KY 82uF/100V KY 120uF/100V KY 120uF/100V KY 150uF/100V KY 120uF/100V KY 100uF/100V KY 82uF/100V KY C3 10uF/50V X7R 2220 10uF/50V X7R 2221 10uF/50V X7R 2220 NC 470uF/100V KY 100uF/100V KY 4.7uF/100V 2220 4.7uF/100V X7R 2220 4.7uF/100V X7R 2220 4.7uF/100V X7R 2220 NC 470uF/100V KY 100uF/100V KY 4.7uF/100V 2220 CY4 CY1 NC 1000pF/2KV 1000pF/2KV NC 1000pF/2KV 680pF/2KV 1000pF/2KV NC 1000pF/2KV 1500pF/2KV NC 1000pF/2KV 680pF/2KV 2200pF/2KV CY2 1000pF/2KV 1000pF/2KV 1000pF NC NC 680pF/2KV 1000pF/2KV 680pF/2KV 680pF/2KV 680pF/2KV NC NC 680pF/2KV 2200pF/2KV L1 CY3 CY4 0.5mH NC NC 0.5mH NC NC 0.5mH NC NC 0.5mH NC NC 0.45mH 1000pF/2KV NC 1.0mH NC NC 0.45mH 680pF/2KV 680pF/2KV 0.5mH NC NC 0.5mH NC NC 0.5mH NC NC 0.5mH NC NC 0.45mH 1000pF/2KV 680pF/2KV 1.0mH NC NC 0.45mH NC 680pF/2KV NOTE: The recommended components are a starting point but not guaranteed for meeting EMI requirements. More or less filtering may be required for a specific application or to meet other EMI standards. 18. OUTPUT FILTERING The converter has built-in capacitors at the output to control ripple and noise. If desired, additional output capacitance can be introduced at the input to the powered equipment. Recommended starting point: one 10μF tantalum and one 1μF ceramic capacitor in parallel at the output. 19. OUTPUT NOISE MEASUREMENT SCHEMATIC For proper output ripple and noise measurement, connect a 10μF tantalum and a 1μF ceramic capacitor across the output. Set the scope bandwidth to 20MHz. Probe directly off of one of the capacitors, using a small ground clip to minimize measurement error. +Vin +Vo +S Trim -S Ceramic 1.0µF + Resistor Load -Vin -Vo Solid Tantalum 10µF To Scope FIGURE 11. OUTPUT NOISE MEASUREMENT CIRCUIT 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax www.v-infinity.com
VHK200W-Q48-S12 价格&库存
很抱歉,暂时无法提供与“VHK200W-Q48-S12”相匹配的价格&库存,您可以联系我们找货
