Additional Resources:
Product Page
3D Model
date
05/09/2022
page
1 of 7
SERIES: VHK200W │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 200 W isolated output
rugged metal enclosure with integrated heat sink
4:1 input range (10~36 Vdc, 18~75 Vdc)
single output from 12~48 Vdc
1,500 Vdc isolation
over current, over temperature, over voltage,
and short circuit protections
• remote on/off
• efficiency up to 88%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
and noise1
efficiency
range
(Vdc)
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
VHK200W-Q24-S12
10 ~ 36
12
16.7
200
150
84
VHK200W-Q24-S15
10 ~ 36
15
13.3
200
150
84
VHK200W-Q24-S24
10 ~ 36
24
8.3
200
240
84
VHK200W-Q24-S28
10 ~ 36
28
7.14
200
280
87
VHK200W-Q24-S48
10 ~ 36
48
4.2
200
480
87
VHK200W-Q48-S12
18 ~ 75
12
16.7
200
150
86
VHK200W-Q48-S15
18 ~ 75
15
13.3
200
150
86
VHK200W-Q48-S24
18 ~ 75
24
8.3
200
240
86
VHK200W-Q48-S28
18 ~ 75
28
7.14
200
280
87
VHK200W-Q48-S48
18 ~ 75
48
4.2
200
480
88
Note:
1. Ripple and noise are measured at full load, 20 MHz BW with 10µF tantalum capacitor and 1µF ceramic capacitor across output. The 48 Vdc output models require a 10uF
aluminum capacitor and 1uF ceramic capacitor across the output.
2. An external input capacitor of 470μF for 24 Vdc input models and 47μF for 48 Vdc input models is recommended to reduce input ripple voltage.
PART NUMBER KEY
VHK200W - QXX - SXX X
Base Number
Input Voltage
Output Voltage
cui.com
Remote On/Off Control
"blank" = positive logic
N = negative logic
Product Page
3D Model
CUI Inc │ SERIES: VHK200W │ DESCRIPTION: DC-DC CONVERTER
date 05/09/2022 │ page 2 of 7
INPUT
parameter
conditions/description
operating input voltage
24 Vdc input models
48 Vdc input models
typ
max
units
10
18
24
48
36
75
Vdc
Vdc
24 Vdc input
power up
power down
9.5
8.5
Vdc
Vdc
48 Vdc input
power up
power down
17
16
Vdc
Vdc
under voltage shutdown
positive logic
remote on/off1
negative logic
models ON (>3.5 Vdc or REM pin open circuit)
models OFF (REM pin 0~1.2 Vdc)
models ON (REM pin 0~1.2 Vdc)
models OFF (>3.5 Vdc or REM pin open circuit)
filter
pi filter
input fuse
40A time delay fuse for 24 Vin models,
20A time delay fuse for 48 Vin models
Note:
min
1. Open collector refer to -Vin
OUTPUT
parameter
maximum capacitive load
12, 15, & 24 V output models
28 V output models
48 V output models
line regulation2
load regulation2
min
typ
max
units
2,200
2,200
2,200
μF
μF
μF
measured from low line to high line
±0.2
measured from zero load to full load
±0.2
±1.5
100
47
voltage accuracy
adjustability
±10
switching frequency
transient response
250
25% step load change
kHz
500
temperature coefficient
Note:
±0.03
µs
%/°C
2. A 100 μF aluminum capacitor is required on the output for the 28 Vdc output models. A 47 μF aluminum capacitor is required on the output for 48 Vdc output models.
PROTECTIONS
parameter
continuous
over current protection
at 90% output voltage
min
110
over voltage protection
over temperature protection
typ
115
shutdown
max
units
160
140
110
°C
SAFETY AND COMPLIANCE
parameter
isolation voltage
for 1 minute: input to output; input to case;
output to case
min
isolation resistance
safety approvals
certified to 62368-1: EN, IEC
RoHS
2011/65/EU
typ
max
units
1,500
Vdc
10
MΩ
ENVIRONMENTAL
parameter
min
operating temperature
see derating curve
storage temperature
cui.com
typ
max
units
-40
85
°C
-55
105
°C
Product Page
3D Model
date 05/09/2022 │ page 3 of 7
MECHANICAL
parameter
dimensions
4.23 x 4.01 x 1.50 [107.5 x 101.8 x 38.0 mm]
min
case material
steel and aluminum extrusion
typ
max
inch
weight
502
g
MECHANICAL DRAWING
units: inch[mm]
general tolerance: ±0.04[±1.0]
wire range: 22~12 AWG
screw size: #6-32
connector tightening torque: 1.4 N∙m (max)
PIN CONNECTIONS
2
-S
3
trim
+S
5
+Vo
6
case
7
REM
8
-Vin
9
+Vin
4.23[107.5]
4.09[104.0]
4.23[107.5]
4.23[107.5]
4.09[104.0]
4.09[104.0]
4.006[101.76]
4.006[101.76]
4
1.50[38.0]
1.50[38.0]
1.50[38.0]
Jumper
Jumper
2.76[70.0]
Jumper
2.76[70.0]
2.76[70.0]
cui.com
3.58[91.0]
-Vo
3.58[91.0]
3.58[91.0]
FUNCTION
1
4.006[101.76]
PIN
units
Product Page
3D Model
date 05/09/2022 │ page 4 of 7
DERATING CURVES
TEST CONFIGURATION
Figure 1
Table 1
External components
L1
1.2μH
Cin
470μF, ESR < 0.2Ω at 100 KHz
Note:
Input reflected-ripple current is measured with an inductor L1 to simulate source impedance.
cui.com
L1
12μH
Cin
47μF, ESR < 0.7Ω at 100 KHz
Product Page
3D Model
date 05/09/2022 │ page 5 of 7
EMC RECOMMENDED CIRCUITS
EN55022 CLASS A
Figure 2
Recommended Circuit for EN55022 Class A
(for all 12, 15, 24, & 28 Vdc output models)
Figure 3
(for all 48 Vdc output models)
Table 2
Class A Recommended Components
Model
VHK200W-Q24-S12
C11
C21
C31
CY12
CY22
L1
L2
120 μF/100 V
120 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q24-S15
47 μF/100 V
47 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q24-S24
100 μF/100 V
100 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q24-S28
100 μF/100 V
100 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q24-S48
100 μF/100 V
100 μF/100 V
100 μF/100 V
680 pF/2 KV
680 pF/2 KV
1.0 mH
NC
VHK200W-Q48-S12
82 μF/100 V
82 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q48-S15
82 μF/100 V
82 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q48-S24
82 μF/100 V
82 μF/100 V
NC
NC
NC
0.7 mH
SHORT
VHK200W-Q48-S28
150 μF/100 V
150 μF/100 V
NC
NC
NC
0.5 mH
SHORT
VHK200W-Q48-S48
100 μF/100 V
100 μF/100 V
100 μF/100 V
680 pF/2 KV
680 pF/2 KV
1.0 mH
NC
Notes:
1. Aluminum capacitors.
2. Ceramic capacitors.
cui.com
Product Page
3D Model
date 05/09/2022 │ page 6 of 7
APPLICATION NOTES
1. Output Voltage Trimming
Leave open if not used.
Figure 4
Application Circuit for Trim pin
Formula for Trim Resistor
Trim-Up
Trim-Down
Trim-Up Formula
(for all 12, 15, 24, & 281 Vdc Output Models)
Trim-Down Formula
Rtrim - up = (
5.11VO, nom(100 + ∆%) 511
- 10.22)(KΩ)
1.225 x ∆%
Rtrim - down = (
Trim-Up Formula
(for all 48 Vdc Output Models)
Rtrim - up = (
511
- 10.22)(KΩ)
Trim-Down Formula
20VO, nom(100 + ∆%) 2000
- 40)(KΩ)
1.225 x ∆%
Rtrim - down = (
2000
- 40)(KΩ)
Note: Rtrim-up is the external resistor in KΩ
Rtrim-down is the external resistor in KΩ
VO, nom is the nominal output voltage
VO is the desired output voltage
Notes:
1. For the 28 Vdc output models, a minimum input voltage of 10.8 Vdc is required to trim the 24 Vdc input models up 10%, and a minimum input voltage of 19 Vdc is
required to trim the 48 Vdc input models up 10%.
2. All specifications are measured at Ta=25°C, nominal input voltage and full output load unless otherwise specified.
cui.com
Product Page
3D Model
date 05/09/2022 │ page 7 of 7
REVISION HISTORY
rev.
description
date
1.0
initial release
10/11/2006
1.01
new template applied
12/21/2011
1.02
misc. updates and corrections
03/13/2012
1.03
updated mechanical drawing
03/27/2012
1.04
V-Infinity branding removed
06/27/2012
1.05
updated spec
03/18/2013
1.06
updated spec
05/08/2013
1.07
added trimming and EMI information
12/16/2013
1.08
trim equation updated
11/13/2020
1.09
derating curves updated
03/04/2021
1.10
pin connection table & remote on/off updated
05/20/2021
1.11
circuit figures updated
09/07/2021
1.12
safety approvals updated
03/02/2022
1.13
mechanical tolerance updated
05/09/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“VHK200W-Q48-S48”相匹配的价格&库存,您可以联系我们找货
