1/3
VHS1-SIP Series Dc-Dc Converter
Rev. 01-2011
Description
Designed to convert fixed voltages into an isolated voltage, the VHS1-SIP series is well suited for providing board-mount local supplies in a wide range of applications, including mixed analog/digital circuits, test & measurement equip., process/machine controls, datacom/telecom fields, etc... The semi-regulated output can be followed by 3-terminal regulators to provide output protection, in addition to output regulation.
Features
·Isolated 1 W output ·Temperature range: -40°C~+85°C ·Unregulated ·High efficiency to 78% ·Single voltage output ·Small footprint ·SIP package style ·Industry standard pinout ·UL94-V0 package ·No heatsink required ·6K Vdc isolation ·Power density 0.85 W/cm³ ·No external component required ·Low cost
Model Number VHS1-S5-S5-SIP VHS1-S5-S9-SIP VHS1-S5-S12-SIP VHS1-S5-S15-SIP VHS1-S12-S5-SIP VHS1-S12-S9-SIP VHS1-S12-S12-SIP VHS1-S12-S15-SIP
Input Voltage Nominal Range 5 Vdc 4.5~5.5 Vdc 5 Vdc 4.5~5.5 Vdc 5 Vdc 4.5~5.5 Vdc 5 Vdc 4.5~5.5 Vdc 12 Vdc 10.8~13.2 Vdc 12 Vdc 10.8~13.2 Vdc 12 Vdc 10.8~13.2 Vdc 12 Vdc 10.8~13.2 Vdc
Output Voltage 5 Vdc 9 Vdc 12 Vdc 15 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc
Output Current Max. Min. 200 mA 20 mA 111 mA 12 mA 84 mA 9 mA 67 mA 7 mA 200 mA 20 mA 111 mA 12 mA 84 mA 9 mA 67 mA 7 mA
Efficiency 72% 72% 75% 75% 75% 76% 78% 78%
Package Style SIP SIP SIP SIP SIP SIP SIP SIP
Output Specifications
Item Output power Line Regulation Load Regulation Output voltage accuracy Temperature drift Output ripple Switching frequency Note: 1. All specifications measured at TA=25°C, humidity
很抱歉,暂时无法提供与“VHS1-S12-S9-SIP”相匹配的价格&库存,您可以联系我们找货
