HS3A - HS3M
3.0 AMPS. High Efficient Surface Mount Rectifiers SMC/DO-214AB
.126(3.20) .114(2.90)
.245(6.22) .220(5.59)
Features
Glass passivated junction chip. For surface mounted application Low forward voltage drop Low profile package Built-in stain relief, ideal for automatic placement Fast switching for high efficiency High temperature soldering: o 260 C/10 seconds at terminals Plastic material used carries Underwriters Laboratory Classification 94V0
.280(7.11) .260(6.60)
.012(.31) .006(.15)
.103(2.62) .079(2.00)
.061(1.56) .050(1.26)
.063(1.6) .039(1.0)
.320(8.13) .305(7.75)
.008(.20) .004(.10)
Mechanical Data
Cases: Molded plastic Terminals: Pure tin plated, lead free Polarity: Indicated by cathode band Packing: 16mm tape per EIA STD RS-481 Weight: 0.21 gram
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current See Fig. 1 Peak Forward Surge Current, 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method ) Maximum Instantaneous Forward Voltage @ 3.0A
o
Symbol HS
3A
HS 3B
HS 3D
HS 3F
HS 3G
HS 3J
HS 3K
HS 3M
Units
V V V A A
VRRM VRMS VDC I(AV) IFSM VF
50 35 50
100 70 100
200 140 200
300 210 300
400 280 400 3.0
600 420 600
800 1000 560 700 800 1000
150 1.0 1.3 1.7
V uA uA nS pF o C/W o C o C
Maximum DC Reverse Current @ TA =25 C 10 IR at Rated DC Blocking Voltage @ TA=125 oC 250 Maximum Reverse Recovery Time ( Note 1 ) Trr 50 Typical Junction Capacitance ( Note 2 ) Cj 80 Maximum Thermal Resistance (Note 3) RθJA 60 Operating Temperature Range TJ -55 to +150 Storage Temperature Range TSTG -55 to +150 1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A Notes: 2. Measured at 1 MHz and Applied VR=4.0 Volts. 3. Mounted on P.C.Board with 0.6” x 0.6”(16mm x 16mm) Copper Pad Area.
75 50
- 278 -
Version: B07
RATINGS AND CHARACTERISTIC CURVES (HS3A THRU HS3M)
FIG.1- MAXIMUM FORWARD CURRENT DERATING CURVE
3.0 AVERAGE FORWARD CURRENT. (A)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
1000
2.5
INSTANTANEOUS REVERSE CURRENT. ( A)
Tj=125 0C
2.0
100
1.5
1.0
10
Tj=25 0C
0.5
0 0 25 50 75 100 125
O
150
175
AMBIENT TEMPERATURE. ( C)
1
FIG.3- MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT
300 PEAK FORWARD SURGE CURRENT. (A)
0.1
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLT AGE. (%) 200
100 100
FIG.5- TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS
1
10
100
1000 INSTANTANEOUS FORWARD CURRENT. (A)
NUMBER OF CYCLES AT 60Hz
10
FIG.4- TYPICAL JUNCTION CAPACIT ANCE
175 150 JUNCTION CAPACITANCE.(pF) 125 100 75 50 25 0 0.1
HS
HS 3G
1 0.1 0.01 0.2 0.4 0.6 0.8
HS 3A
Tj=25 0C
-H
HS
1.0 1.2
S3 D
3J -H S3 M
3A-
HS
HS
3G
3J-
HS
3M
0.5
1
2
5
10
100 200
500 1000
REVERSE VOLTAGE. (V)
FORWARD VOLT AGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W NONINDUCTIVE 10W NONINDUCTIVE +0.5A (-) DUT (+) 50Vdc (approx) (-) PULSE GENERATOR (NOTE 2) 1W NON INDUCTIVE OSCILLOSCOPE (NOTE 1) (+) 0 -0.25A trr
NOTES: 1. Rise Time=7ns max. Input Impedance= NOTES: 1. 1 megohm 22pf 2. Rise Time=10ns max. Sourse Impedance= 2. 50 ohms
-1.0A 1cm SET TIME BASE FOR 5/ 10ns/ cm
Version: B07
很抱歉,暂时无法提供与“HS3M”相匹配的价格&库存,您可以联系我们找货
