PDI1284P11
3.3 V parallel interface transceiver/buffer
Rev. 03 — 25 August 2008
Product data sheet
1. General description
The PDI1284P11 parallel interface chip is designed to provide an asynchronous, 8-bit,
bidirectional, parallel interface for personal computers. The PDI1284P11 includes all 19
signal lines defined by the IEEE 1284 interface specification for Byte, Nibble, EPP, and
ECP modes. The PDI1284P11 is designed for hosts or peripherals operating at 3.3 V to
interface 3.3 V or 5.0 V devices.
The eight transceiver pairs (A/B 1 to 8) allow data transmission from the A-bus to the
B-bus, or from the B-bus to the A-bus, depending on the state of the direction pin DIR.
The B-bus and the Y9 to Y13 lines have either totem pole or resistor pull-up outputs,
depending on the state of the high drive enable pin HD. The A-bus has only totem pole
style outputs. All inputs are TTL compatible with at least 400 mV of input hysteresis at
VCC = 3.3 V.
2. Features
n
n
n
n
n
n
n
n
n
n
n
n
n
n
Asynchronous operation
8-bit transceivers
Six additional buffer/driver lines peripheral to cable
Five additional control lines from cable
5 V tolerant
ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
Latch-up current protection exceeds 500 mA per JEDEC Std 19
Input hysteresis
Low-noise operation
IEEE 1284 compliant level 1 and 2
Overvoltage protection on B/Y side for off-state
A side 3-state option
B side active or resistive pull-up option
Cable side supply voltage for 5 V or 3 V operation
PDI1284P11
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
PDI1284P11DL
0 °C to 70 °C
SSOP48
plastic shrink small outline package; 48 leads;
body width 7.5 mm
SOT370-1
PDI1284P11DGG
0 °C to 70 °C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
PDI1284P11_3
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 16
PDI1284P11
Nexperia
4. Functional diagram
HD
HD
DIR
CNTL
OEA
HD
A9
Y9
HD
A10
Y10
HD
A11
Y11
HD
A12
Y12
HD
A13
Y13
HD
A1
B1
CNTL
HD
A2
B2
CNTL
HD
A3
B3
CNTL
HD
A4
B4
CNTL
HD
A5
B5
CNTL
HD
A6
B6
CNTL
HD
A7
B7
CNTL
HD
A8
B8
CNTL
PLHI
HD
PLHO
A14
C14
A15
C15
A16
C16
A17
C17
HLHO
HLHI
001aai290
Fig 1.
Logic symbol
PDI1284P11_3
Product data sheet
3 of 16
PDI1284P11
Nexperia
5. Pinning information
5.1 Pinning
HD
1
48 DIR
A9
2
47 Y9
A10
3
46 Y10
A11
4
45 Y11
A12
5
44 Y12
A13
6
43 Y13
VCC
7
A1
8
42 VCC(B)
41 B1
A2
9
40 B2
GND 10
39 GND
A3 11
38 B3
A4 12
37 B4
PDI1284P11
A5 13
36 B5
A6 14
35 B6
GND 15
34 OEA
A7 16
33 B7
A8 17
32 B8
VCC 18
31 VCC(B)
30 PLHO
PLHI 19
A14 20
29 C14
A15 21
28 C15
A16 22
27 C16
A17 23
26 C17
HLHO 24
25 HLHI
001aai291
Fig 2.
Pin configuration
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
HD
1
high drive enable/disable input
A1 to A8
8, 9, 11, 12, 13,
14, 16, 17
data input/output
B1 to B8
41, 40, 38, 37,
36, 35, 33, 32
IEEE 1284 standard output/input[1]
A9 to A13
2, 3, 4, 5, 6
data input
Y9 to Y13
47, 46, 45, 44, 43 IEEE 1284 standard output[1]
C14 to C17
29, 28, 27, 26
control input (cable)[1]
A14 to A17
20, 21, 22, 23
control output (peripheral)
VCC
7, 18
supply voltage
GND
10, 15, 39
ground (0 V)
PLHI
19
peripheral logic high input (peripheral)
PDI1284P11_3
Product data sheet
4 of 16
PDI1284P11
Nexperia
Table 2.
Pin description …continued
Symbol
Pin
Description
HLHO
24
host logic high output (cable)
HLHI
25
host logic high input (cable)
PLHO
30
peripheral logic high output (cable)
VCC(B)
31, 42
supply voltage B (cable side 3 V/5 V)
OEA
34
A side output enable input (active LOW)
DIR
48
direction selection input
[1]
Pin with pull-up resistor to load cable.
6. Functional description
6.1 Function selection
Table 3.
Function table[1]
DIR
OEA
HD
Input
Output
Output type
X
X
X
C14 to C17
A14 to A17
TP
X
X
X
HLHI
HLHO
TP
X
X
L
A9 to A13
Y9 to Y13
RP
X
X
H
A9 to A13
Y9 to Y13
TP
X
X
L
PLHI
PLHO
OC
X
X
H
PLHI
PLHO
TP
H
X
L
A1 to A8
B1 to B8
RP
H
X
H
A1 to A8
B1 to B8
TP
L
L
X
B1 to B8
A1 to A8
TP
L
H
X
A1 to A8
Z[2]
L
H
X
B1 to B8
RP[2]
[1]
An = side driving internal IC;
Bn = side driving external cable (bidirectional);
Cn = side receiving control signals from external cable;
H = HIGH voltage level;
L = LOW voltage level;
OC = Open Collector;
X = don’t care (control signals in);
Yn = side driving external cable (unidirectional);
Z = high impedance (high-Z) or 3-state;
TP = totem pole output;
RP = resistive pull-up: 1.4 kΩ (nominal) on B/Y/C cable side and VCC. However, while a B/Y side output is LOW as driven by a LOW
signal on the A side, that particular B/Y side resistor is switched off to stop current drain from VCC through it.
[2]
When DIR = L and OEA = H, the output signal is isolated from the input signal. Signals B1 to B8 maintain a resistive pull-up of 1.4 kΩ on
the input for this mode.
PDI1284P11_3
Product data sheet
5 of 16
PDI1284P11
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).[1]
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
pins VCC
−0.5
+4.6
V
VCC(B)
supply voltage B
pins VCC(B); cable side 3 V/5 V
−0.5
+6.5
V
IIK
input clamping current
VI < 0 V
±20
mA
IOK
output clamping current
VO < 0 V
VI
VO
±50
mA
input voltage
[2]
−0.5
+5.5
V
output voltage
[2]
−0.5
+5.5
V
−0.5
VCC + 0.5
V
−2
+7
V
200
mA
−200
mA
±50
mA
−60
+150
°C
500
mW
B/Y side
A side
Vtrt
transient voltage
ICC
supply current
IGND
ground current
IO
output current
Tstg
storage temperature
total power dissipation
Ptot
B/Y side; 40 ns transient
[3]
output HIGH or LOW
Tamb = 0 °C to +70 °C
[4]
[1]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[3]
Vtrt guarantees only that the PDI1284P11 will not be damaged by reflections in application so long as the voltage levels remain in the
specified range.
[4]
Above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
pins VCC
3.0
3.6
V
VCC(B)
supply voltage B
3.0
5.5
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
VO
output voltage
pins Bn, Yn
−0.5
+5.5
V
pins An
VCC
V
IOH
HIGH-level output current
pins Bn, Yn
−14
mA
IOL
LOW-level output current
pins Bn, Yn
14
mA
Tamb
ambient temperature
free-air
°C
PDI1284P11_3
Product data sheet
6 of 16
PDI1284P11
Nexperia
9. Static characteristics
Table 6.
Tamb = 0 °C to 70 °C; ground = 0 V; unless specified otherwise.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
An, Bn, Cn and PLHI inputs; VCC = 3.0 V to 3.6 V
0.8
V
VIL
LOW-level input
voltage
VIH
HIGH-level input An, Bn, PLHI inputs; VCC = 3.0 V to 3.6 V
voltage
Cn inputs; VCC = 3.0 V to 3.6 V
HLHI input; VCC = 3.0 V
HLHI input; VCC = 3.6 V
hysteresis
voltage
VH
LOW-level
output voltage
VOL
VOH
HIGH-level
output voltage
supply current
ICC
1.55
V
V
2.3
V
2.6
V
An, Bn inputs; VCC = 3.3 V; VIL = 0.8 V; VIH = 2.0 V
0.4
0.47 -
V
Cn inputs; VCC = 3.3 V
[1]
0.8
0.47 -
V
pins An, HLHO; IOL = 50 µA; VCC = 3.0 V
0.2
V
pins An, HLHO; IOL = 4 mA; VCC = 3.0 V
0.4
V
pins Bn, Yn; IOL = 14 mA; VCC = 3.0 V
0.77
V
pin PLHO; IOL = 500 µA; VCC = 3.0 V
0.8
V
pins An, HLHO; IOH = −500 µA; VCC = 3.0 V
2.8
V
pins An, HLHO; IOH = −4 mA; VCC = 3.0 V
2.4
V
pins Bn, Yn; IOH = −14 mA; VCC = 3.0 V
2.23
V
pin PLHO; IOH = 500 µA; VCC = 3.15 V
3.1
V
5
µA
0.1
100
µA
10
15
mA
VI = 0 V or VCC; IO = 0 A
pins VCC(B); VCC = 3.6 V; VI = 0 V or VCC; pins Cn = 0 V
[1]
[2]
pin DIR = 3.6 V; VCC(B) = 3.6 V
power-off
leakage current
[1]
pins VCC and VCC(B); VCC = 3.6 V; VCC(B) = 3.6 V to 5.5 V;
VI = 0 V or VCC; pins Bn = VCC(B); pins Cn = VCC(B) or
floating
IOFF
2.0
pin DIR = 3.6 V; VCC(B) = 5.5 V
16
mA
pin DIR = 0 V; VCC(B) = 3.6 V; pins Bn = 0 V
30
40
mA
pin DIR = 0 V; VCC(B) = 5.5 V; pins Bn = 0 V
47
60
mA
pins Bn, Cn, Yn; VO = 5.5 V; VCC = 0 V
VCC(B) = 0 V
±100
µA
VCC(B) = 4.5 V
±100
µA
±1
µA
II
input leakage
current
VI = 0 V to VCC
[3]
IOZ
OFF-state
output current
3-state; VO = VCC or 0 V
[3]
±20
µA
Ro
output
resistance
VCC = 3.3 V; see Figure 9
[1]
35
45
55
Ω
[1]
1.15
1.4
1.65
kΩ
pull-up
resistance
RPU
VO = 1.65 V ± 0.1 V; B/Y side
B/Y side; VCC = 3.3 V; output in high-Z with resistive pull-up
[1]
Typical values at Tamb = 25 °C.
[2]
Includes extra ICC(B) current from pull-up resistors, i.e. ICC(B) = (total number of LOW inputs on B and C sides) × (VCC(B) / RPU).
[3]
The pull-up resistor on the B side outputs makes it impossible to test IOZ on the B side. This applies to the input current on the C side
inputs as well.
PDI1284P11_3
Product data sheet
7 of 16
PDI1284P11
Nexperia
10. Dynamic characteristics
Table 7.
VCC = 3.0 V to 3.6 V; ground = 0 V; CL = 50 pF; RL = 500 Ω; Tamb = 0 °C to 70 °C; unless specified otherwise.
Symbol
Parameter
Conditions
Min
Typ[2]
Max
Unit
tPLH
LOW to HIGH
propagation delay
An to Bn or Yn; see Figure 3 and 8
ns
tPHL
HIGH to LOW
propagation delay
23
ns
tpd
propagation delay
see Figure 4 and 8
Bn to An
ns
Cn to An
15
ns
PLHI to PLHO
ns
HLHI to HLHO
15
ns
[1]
SR
slew rate
Bn/Yn; RL = 62 Ω; see Figure 5 and 8
0.05
0.2
0.4
V/ns
tdis
disable time
HD to Yn or Bn; see Figure 6 and 8
[3]
ns
HD to PLHO; see Figure 6 and 7
[3]
ns
RL = 250 Ω; see Figure 6 and 7
[3]
DIR to Bn; TP load on B/Y side
50
ns
DIR to An
15
ns
OEA to An
enable time
ten
6
ns
HD to Yn or Bn; see Figure 6 and 7
[4]
ns
[4]
ns
[4]
30
ns
DIR to An
50
ns
OEA to An
∆tPD
[1]
propagation delay
difference
tPZH − tPHZ; HD to output
12
ns
10
ns
tpd is the same as tPLH and tPHL.
[2]
Value at Tamb = 25 °C and VCC = 3.3 V.
[3]
tdis is the same as tPHZ and tPLZ.
[4]
ten is the same as tPZH and tPZL.
PDI1284P11_3
Product data sheet
8 of 16
PDI1284P11
Nexperia
11. Waveforms
2.4 V
input
1.4 V
1.4 V
0.4 V
tPLH
tPHL
VO
output
VO − 1.4 V
1.4 V
001aai293
Fig 3.
Input An to output Bn or Yn propagation delays
VI
input
VM
GND
tPHL
tPLH
VOH
output
VM
VOL
001aai292
VM = 1.5 V.
VCC never goes below 3.0 V.
VOL and VOH are the typical voltage output levels that occur with the output load.
Fig 4.
Input Bn, Cn to output An propagation delays
2.4 V
input
0.4 V
2.4 V
0.9 V
output
1.9 V
0.4 V
t1
t2
t1
t2
001aai295
Measurement data is given in Table 8.
SR is measured for both a LOW-to-HIGH and a HIGH-to-LOW transition.
Fig 5.
Table 8.
tr
3 ns
Slew rate on B/Y side
Slew rate measurements
tf
3 ns
tW
150 ns < tW < 10 µs
RL
VO transition (see Figure 8)
62 Ω
Rising
Falling
from VO = 0.4 V to VO = 0.9 V
from VO = 2.4 V to VO = 1.9 V
PDI1284P11_3
Product data sheet
9 of 16
PDI1284P11
Nexperia
DIR to A
VM
DIR to B
VM
VI
HD to B
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
tPZH
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
001aai294
Test circuit is shown in Figure 7.
Measurement points are given in Table 9.
Fig 6.
Enable and disable times
VEXT
VCC
VI
RL
VO
G
DUT
RT
CL
RL
mna616
Test conditions are given in Table 9.
Fig 7.
Test circuit for measuring enable and disable times
Table 9.
Test data for test circuit measuring enable disable times Bn to An
Parameter
VCC
Input
Output
VEXT
VI
VM
VM
VX
VY
tPZH, tPHZ
tPZL, tPLZ
DIR to Bn, An;
OEA to An
< 2.7 V
VCC
1.5 V
1.5 V
VOL ± 0.3 V
VOH − 0.3 V
GND
2VCC
2.7 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL ± 0.3 V
VOH − 0.3 V
GND
2VCC
HD to Yn or Bn;
HD to PHLO
< 2.7 V
VCC
1.5 V
1.5 V
VOH − 0.3 V
open
2.7 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOH − 0.3 V
open
PDI1284P11_3
Product data sheet
10 of 16
PDI1284P11
Nexperia
VI
tW
90 %
90 %
negative
pulse
VM
0V
10 %
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
90 %
VM
VM
10 %
10 %
tW
001aai298
a. Input pulse definition
VCC
CL
G
VI
VO
VEXT
DUT
GND
RT
RL
001aai296
b. Test circuit
CL = load capacitance includes jig and probe capacitance.
RL = load resistance.
RT = termination resistance should be equal to the output impedance of the pulse generator.
Test conditions for propagation delays are given in Table 10, test conditions for slew rate are given in Table 8
Fig 8.
Table 10.
Output
Test circuit for An, Bn and Yn outputs; slew rate B/Y side
Test conditions for An, Bn and Yn outputs
VI
VM
Repetition
rate
tW
tr
tf
Switch position
tPLH, tPZH
tPHL, tPHZ
An
3.0 V
1.5 V
1 MHz
500 ns
3 ns
3 ns
GND
GND
Bn, Yn
3.0 V
1.5 V
1 MHz
500 ns
3 ns
3 ns
GND
VEXT = 2.8 V
VCC
IO
DUT
VCC / 2
001aai299
IO is measured by forcing 0.5VCC on the output. The output impedance can then be calculated as Ro = 0.5VCC / |IO|.
Fig 9.
Output impedance
PDI1284P11_3
Product data sheet
11 of 16
PDI1284P11
Nexperia
12. Package outline
SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm
SOT370-1
D
E
A
X
c
y
HE
v M A
Z
25
48
Q
A2
A1
A
(A 3)
θ
pin 1 index
Lp
L
24
1
detail X
w M
bp
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2.8
0.4
0.2
2.35
2.20
0.25
0.3
0.2
0.22
0.13
16.00
15.75
7.6
7.4
0.635
10.4
10.1
1.4
1.0
0.6
1.2
1.0
0.25
0.18
0.1
0.85
0.40
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT370-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-118
Fig 10. Package outline SOT370-1 (SSOP48)
PDI1284P11_3
Product data sheet
12 of 16
PDI1284P11
Nexperia
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
E
D
A
X
c
HE
y
v M A
Z
48
25
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
detail X
24
w M
bp
e
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
12.6
12.4
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.8
0.4
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT362-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 11. Package outline SOT362-1 (TSSOP48)
PDI1284P11_3
Product data sheet
13 of 16
PDI1284P11
Nexperia
13. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ECP
Extended Capability Port
EPP
Enhanced Parallel Port
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
TTL
14. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PDI1284P11_3
20080825
Product data sheet
PDI1284P11_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors
Legal texts have been adapted to the new company name where appropriate.
Quick reference table removed.
Table 7, tPHL: Maximum value of 20 ns replaced by 23 ns.
Table 11: Abbreviations list added.
PDI1284P11_2
19990917
Product specification
PDI1284P11_1
PDI1284P11_1
19970915
PDI1284P11_3
Product data sheet
14 of 16
PDI1284P11
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PDI1284P11_3
Product data sheet
15 of 16
Nexperia
PDI1284P11
17. Contents
1
2
3
4
5
5.1
5.2
6
6.1
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Function selection. . . . . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 25 August 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PDI1284P11DL,112 PDI1284P11DL,118 PDI1284P11DGG,112 PDI1284P11DGG,118
