MBR2535CTL
Technical Data
Data Sheet N1014, Rev. A
Green Products
MBR2535CTL SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150°C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm
Symbol
A
A1
A2
b
b1
c
D
D1
E
e
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in
millimeters
Min
Typical
Max
4.42
4.57
4.72
1.17
1.27
1.37
2.59
2.69
2.89
0.71
0.81
0.96
1.27
0.36
0.38
0.61
14.94
15.24
15.54
8.85
9.00
9.15
10.01
10.16
10.31
2.54
5.06
6.04
6.24
6.44
12.7
13.56
13.78
3.5
3.74
3.84
4.04
2.54
2.74
2.94
7°
3°
4°
TO-220AB(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
MBR2535CTL
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
25
35
CTL
SSG
YY
WW
L
= Device Type
= Forward Current (25A)
= Reverse Voltage (35V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
MBR2535CTL
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Forward Current
Peak Repetitive Forward Current
Peak Repetitive Reverse Surge
Current
Peak One Cycle Non-Repetitive
Surge Current (per leg)
Controlled Avalanche Energy
Symbol
VRRM
VRWM
VR
IF(AV)
IFRM
Condition
Max.
Units
35
V
50% duty cycle @TC = 142°C,
rectangular wave form
Rated VR, square wave,
20kHz,TC=139°C
12.5 (per leg)
25 (per device)
A
25
A
IRRM
2.0μs, 1.0 kHz
1.0
A
IFSM
8.3 ms, half Sine pulse
150
A
mJ
Waval
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device
functionality should not be assumed, damage may occur and reliability may be affected.
MBR2535CTL
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current
(per leg) *
Symbol
VF1
Condition
@ 12.5A, Pulse, TJ = 25 °C
Max.
0.47
Units
V
VF2
@ 12.5A, Pulse, TJ = 125 °C
@VR = rated VR Pulse
TJ = 25 °C
@VR = rated VR , Pulse
TJ = 125 °C
0.41
V
1.0
mA
500
mA
10,000
V/μs
IR1
IR2
Voltage Rate of Change
dv/dt
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product
performance may not be indicated by the Electrical Characteristics if operated under different conditions.
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR2535CTL”相匹配的价格&库存,您可以联系我们找货
