PAS69278
698-960 MHz/1710-2700 MHz
Pole Mount Directional Panel Antenna
MULTI-BAND DIRECTIONAL PANEL ANTENNA
The PAS69278 antenna is a wide band dual port directional panel antenna with slant 45
polarization that covers the domestic LTE700/Cellular/PCS/AWS/MDS and global GSM900/
GSM1800/UMTS/LTE2600 bands. The antenna is ideal for both indoor and outdoor applications.
It includes a UV stable radome enclosure that provides years of use without degradation to
either mechanical properties or aesthetics.
FEATURES & BENEFITS
• Applicable for both 3G and 4G solutions
• Domestic LTE 700 band and
Global LTE 2600 band
• WiMax 2300/2500 bands
• Domestic Cellular and Global GSM
• Weatherproof UV stable radome
SPECIFICATIONS
• Wall mounting hardware included
(optional mast mount kit available)
• Conformance to RoHS
APPLICATIONS
• Wireless Terminal, Point-of-Sale,
Machine to Machine,
• Automatic Meter Reading and
Home Security
TYPICAL ELECTRICAL SPECIFICATIONS
Frequency
698 – 960 MHz / 1710 – 2700 MHz
VSWR
2.0:1 Max.
Gain
698 – 960 MHz: 7.5 – 9.0 dBi, 1700 – 2700 MHz: 5.7 – 9.5 dBi
Average Efficiency
698 – 960 MHz: 80% - 87%, 1700 – 2700 MHz: 60% - 85%
3 dB Beamwidth (Vertical plane)
698 – 960 MHz: 55° – 70°, 1700 – 2700 MHz: 50° – 80°
3 dB Beamwidth (Horizontal plane)
F/B Ratio , Co-pol
698 – 960 MHz: > 23 dB, 1700 – 2700 MHz: > 17 dB
Cross polarization, Axial
698 – 960 MHz: > 25 dB, 1700 – 2700 MHz: > 17 dB, typical 23 dB
Isolation
> 25 dB
Polarization
Slant ± 45o
Nominal Impedance
50 Ohms
Power
2 x 10 Watts
RF Connector
Dual Type N female
IP Class
IP55
Environmental Conditions
ETSI EN 300 019-2-4, class 4.1E.
Mount Style
Wall/Mast w/mounting hardware (Wall mount)
Radome and Base Plastic
UL94 V0 rated (UV resisted)
Radome & Base color:
White, Color code (SABIC) WH9B034
Material Substance Compliance
ROHS Compliant
Temperature
-40°C to +70°C
Dimensions
295 x 295 x 82 mm
Weight
1.46 kg
CABLES AND CONNECTORS
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.(0).1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
PART NUMBER
CABLE LENGTH
CONNECTOR
PAS69278-91NF
Dual 91 cm (36”)
Dual Type N- Female
PAS69278-FNF
N/A (Direct connect)
Dual Type N- Female
PAS69278
TYPICAL RADIATION PATTERNS
698 MHz
900 MHz
960 MHz
Low Band 698-960 MHz
1710 MHz
2200 MHz
2700 MHz
High Band 1710-2700 MHz
ANT-DS-PAS69278 090414
Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird
materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or
products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be liable for incidental or consequential damages of any kind. All Laird products are
sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights
Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service
names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“PAS69278-FNF2”相匹配的价格&库存,您可以联系我们找货
