Additional Resources:
Product Page
date
12/22/2020
page
1 of 5
SERIES: VBM-360 Ϳ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
U
ED
up to 360 W continuous power
baseplate cooling
industry standard 3” x 5” footprint
universal input (90~264 Vac)
single output from 12 to 48V
over voltage, short circuit, and over temperature protections
built-in active PFC function
built-in remote sense function
remote on/off control function
efficiency up to 93.5%
RoHS
output
voltage
(Vdc)
VBM-360-12
12
24
48
ripple
and noise1
HϒFLHQF\
max
(A)
max
(W)
max
(mVp-p)
W\S
29.6
355
120
92.5
14.8
355
150
93.5
7.4
355
150
93.5
1. at 20 MHz bandwidth oscilloscope, each output terminated with a 47 µF electrolytic and 0.1 µF ceramic capacitors.
C
O
Notes:
output
power
N
VBM-360-24
VBM-360-48
output
current
TI
MODEL
N
D
IS
PART NUMBER KEY
VBM-360 - XX - XXX
Base Number
Output Voltage
cui.com
Chasis
“blank” = open frame
CNF = enclosed
Product Page
CUI Inc Ϳ SERIES: VBM-360 Ϳ DESCRIPTION: AC-DC POWER SUPPLY
date 12/22/2020
page 2 of 5
INPUT
conditions/description
min
frequency
inrush current
at 240 Vac
leakage current
at 264 Vac
max
units
90
264
Vac
47
63
Hz
50
A
3.5
mA
max
units
OUTPUT
min
line regulation
high line to low line, full load
load regulation
60% ±40% rated load
voltage accuracy
set at 60% rated load and 25°C
hold-up time
built in trim pot
switching frequency
WHPSHUDWXUHFRHϒFLHQW
12 Vdc / 0.3A for external fan
TI
fan drive output
PROTECTIONS
over voltage protection
recycle ac input to restart
short circuit protection
hiccup mode, recovers automatically
auto recovery
over current protection
continuous
O
SAFETY & COMPLIANCE
min
N
parameter
±1
12
ms
W\S
120
min
input to output
±5
60
kHz
W\S
%/°C
max
units
150
max
units
3,000
Vac
IEC 60950-1, EN 60950-1, UL 60950-1
D
IS
C
safety approvals
±0.05
5 Vdc / 0.5A
parameter
±1
55
standby output
isolation voltage
±0.5
N
adjustability
W\S
U
parameter
W\S
ED
parameter
voltage
EMI/EMC
EN 55022 Class B, FCC Part 15 Class B, EN 61000-6-(1,3), EN 61000-3-(2,3), EN 55024, EN 61204-3
RoHS compliant
yes
ENVIRONMENTAL
parameter
min
max
units
operating temperature
refer to derating curves for more details
-20
85
°C
-40
85
°C
93
storage temperature
operating humidity
non-condensing
cui.com
W\S
Product Page
date 12/22/2020
page 3 of 5
DERATING CURVES
VBM-360-CNF (enclosed)
Natural Convection
(Ambient Temp vs. Load)
Natural Convection
ED
VBM-360 (open frame)
220~264 Vac (360W)
100
220~264 Vac (300W)
80
90~200 Vac (240W)
Load (%)
Load (%)
100
60
40
-20
-10
40
50
60
70
-20
60
70
80 85 90
N
Natural Convection
(Input Voltage vs. Load)
40 °C
360
Load (W)
300
240
180
300
240
180
120
110
130
150
170
N
120
190
210
230
250
90
110
130
Input Voltage (Vac)
C
O
80
80
Load (%)
100
40
IS
-10
30
40
50
60
170
190
210
230
250
&)0$LUÀRZ
90~264 Vac
100
60
150
Input Voltage (Vac)
&)0$LUÀRZ
90~264 Vac
Load (%)
40
TI
360
-20
30
Ambient Temperature (°C)
Natural Convection
40 °C
Load (W)
40
90
60
U
90~200 Vac (300W)
80
60
40
-20
30
40
50
60
70
80
85 90
Power Dissipated (W)
D
Baseplate Cooling
(Ambient Temp vs. PD)
90~264 Vac
50
40
30
-20
10
40
50
60
cui.com
70
80 85 90
Product Page
date 12/22/2020
page 4 of 5
MECHANICAL
min
open frame
5.000 x 3.000 x 1.598
(127.00 x 76.20 x 40.60 mm)
enclosed
5.391 x 3.425 x 1.697
(136.94 x 87.00 x 43.10 mm)
inch
weight
470
1.04
g
lbs
550
1.21
g
lbs
U
enclosed
MECHANICAL DRAWING
Enclosed (CNF)
N
Open Frame
10 CFM min
FAN
10 CFM min
FAN
TI
0.393[10.00]
No pin
3
AC Neutral
CN1
L
PVHI Series
3 Pin, CTR Pin
N
Removed
-Vo
0.393[10.00]
2
2.551[64.80]
AC Line
N
1
3.000[76.20]
+Vo
0.224[5.70]
LED
CN1
units
inch
open frame
units: inch[mm]
tolerance: ±0.02[±0.5]
max
3.425[87.00]
dimensions
W\S
ED
parameter
0.224[5.70]
1.697[43.10]
0.062[1.60]
0.079[2.00]
C
IS
D
5.390[136.94]
CN2
PIDC254M1L Series
8 Pin
0.157[4.00]max
1.598[40.60]max
O
4.551[115.60]
5.000[127.00]
CN2
1
+S
8
-S
2
GND
7
enable
3
GND
6
+5 VBS
4
FAN
output-
5
FAN
output+
1
1
2
3
4
8
7
6
5
Note:
1. For operation, it is required to pull down enable to activate the power supply (pin 7 tied to pin 2). It is recommended to use a 2.54mm mini shunt jumper. Jumper will
need to be removed if using the 8 pin mating plug and tied together internally.
1RWH
$OOVSHFL¿FDWLRQVPHDVXUHGDW&9DFLQSXWYROWDJHDQGORDGXQOHVVRWKHUZLVHQRWHG
cui.com
Product Page
date 12/22/2020
page 5 of 5
rev.
description
date
ED
REVISION HISTORY
1.0
initial release
1.01
added baseplate cooling to features, updated derating curves
02/04/2013
1.02
corrected mounting hole sizes
05/30/2013
1.03
updated connector note
1.04
company logo updated
01/09/2013
07/15/2013
12/22/2020
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
&8,RϑHUVDWZR\HDUOLPLWHGZDUUDQW\&RPSOHWHZDUUDQW\LQIRUPDWLRQLVOLVWHGRQRXUZHEVLWH
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
DϑHFWLWVVDIHW\RUHϑHFWLYHQHVV
很抱歉,暂时无法提供与“VBM-360-12”相匹配的价格&库存,您可以联系我们找货
