Daburn Electronics & Cable
44 Richboynton Road
Dover, NJ 07801
#2722 Plastic Kinkless Test Lead Wire – 5,000V*
Daburn's plastic kinkless test wire has high flexibility, obtained through the combination of special softformula PVC and high-count, extra-flexible tinned copper wire. This light weight wire has a smooth, high
gloss finish; elegant in appearance, with a high resistance to abrasion.
Although designated as test lead wire, this construction is used in non-test lead applications requiring the
high degree of flexibility offered by the 2722 series. The combination of performance, appearance, and
economy far outweighs the modestly larger wire O.D. of the 5,000 volt* rated test lead wire.
The wire is stable from -80°C to +80°C and exceeds the requirements of MIL-I-3930A, Type JP (PVC). It
is resistant to chemical corrosion, and fungus. 5,000V* rated test lead wire.
Description: One conductor stranded tinned copper, with a special formulation vinyl insulation for a
bright, smooth, glossy surface.
This series is RoHS compliant.
DABURN
Cat. No.
Size
Stranding Wall
Nom.
O.D.
2722/22
22
26/36
.032"
.100"
2722/20
.032"
.104"
2722/18
18
65/36
.032"
.112"
2722/16
16
65/34
.032"
.129"
Standard Put-Ups: 100 FT, 500 FT, 1,000 FT
Stock Colors: Black, Red, Yellow, Green. White, Blue. Additional colors available to order.
Operating Temperature: -80°C to +80°C
* For intermittent duty
Tel: 973-328-3200 Fax: 973-328-3130
www.daburn.com
Revision B
很抱歉,暂时无法提供与“2722/18R/C”相匹配的价格&库存,您可以联系我们找货
