HALOGEN
16 Volt DC Radial Leaded, Resettable PPTC Devices
Pb HF
FREE
PolyTron™ PTR016V Series
Agency Information
• cURus: Recognized Card: File E343021 (Ihold 3A-15A)
• TUV File: J 50194729
Part Number System/Ordering
PT
Radial Leaded Device
Description
R 016V 0075
-TR
PolyTron™ Resettable Fuse Series
Radial Leaded Fuse
Maximum Voltage
Current Holding (Ihold)
Tape and Reel Packaging and Lead Type Code
TR - Straight Leads, TR1 - Kinked Leads
• 0.75 to 1.85 amps - 3000 fuses per reel
• 2.5 to 4 amps - 2500 fuses per reel
• 5 to 7 amps - 1500 fuses per reel
• 8 to 15 amps - 1000 fuse per reel
Resettable radial leaded thru-hole fuse
Maximum 16 volts
Current ratings from 0.75 to 15 amps
Fast time-to-trip
Low resistance
Halogen free
Lead free
RoHS compliant
Applications
• Medical equipment
• Telecommunications
• White goods
• Computers and peripherals
Specifications
Catalog
Number
PTR016V0075
PTR016V0090
PTR016V0110
PTR016V0120
PTR016V0135
PTR016V0155
PTR016V0160
PTR016V0185
PTR016V0250
PTR016V0300
PTR016V0400
PTR016V0500
PTR016V0600
PTR016V0700
PTR016V0800
PTR016V0900
PTR016V1000
PTR016V1100
PTR016V1200
PTR016V1300
PTR016V1400
PTR016V1500
Notes:
0111
Vmax
(Vdc)
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
Imax
(Amps)
40
40
40
40
40
40
40
40
40
100
100
100
100
100
100
100
100
100
100
100
100
100
Ihold
@23°C
(Amps)
0.75
0.90
1.10
1.20
1.35
1.55
1.60
1.85
2.50
3.00
4.00
5.00
6.00
7.00
8.00
9.00
10.00
11.00
12.00
13.00
14.00
15.00
Itrip
@23°C
(Amps)
1.50
1.80
2.20
2.40
2.70
3.10
3.20
3.70
5.00
5.10
6.80
8.50
10.20
11.90
13.60
15.30
17.00
18.70
20.40
22.10
23.80
25.50
Pd
Typ.
(W)
0.30
0.60
0.70
0.60
0.80
0.70
0.90
1.00
1.20
2.30
2.40
2.60
2.80
3.00
3.00
3.30
3.60
3.70
4.20
4.60
4.60
4.60
Time to
Trip (Max.)
(Amps)
(Sec)
8.00
0.40
8.00
1.20
8.00
2.30
8.00
0.50
8.00
4.50
8.00
0.60
8.00
9.00
8.00
10.00
8.00
40.00
15.00
1.00
20.00
1.70
25.00
2.00
30.00
3.30
35.00
3.50
40.00
5.00
45.00
5.50
50.00
6.00
55.00
7.00
60.00
7.50
65.00
8.50
70.00
9.00
75.00
10.00
Resistance (Ω)
Agency
Initial (Ri)
Post Trip (R1)
Information
Min.
Max.
Max.
cURus
TUV
0.110
0.175
0.230
X
0.070
0.120
0.180
X
0.050
0.095
0.140
X
0.065
0.0975
0.140
X
0.040
0.074
0.120
X
0.043
0.0705
0.100
X
0.030
0.061
0.110
X
0.030
0.051
0.090
X
0.020
0.036
0.070
X
0.038
0.065
0.098
X
X
0.021
0.038
0.060
X
X
0.010
0.023
0.034
X
X
0.006
0.018
0.028
X
X
0.006
0.013
0.020
X
X
0.005
0.011
0.018
X
X
0.005
0.009
0.014
X
X
0.004
0.007
0.010
X
X
0.003
0.006
0.009
X
X
0.003
0.006
0.009
X
X
0.002
0.006
0.008
X
X
0.002
0.005
0.007
X
X
0.002
0.005
0.007
X
X
Ihold – Hold current: Maximum current device will pass without interruption in 23°C still air.
Itrip – Trip current: Minimum current that will switch the device from low resistance to high resistance in 23°C still air.
Vmax: Maximum continuous voltage device can withstand without damage at rated current.
Imax: Maximum fault current device can withstand without damage at rated voltage.
Pd: Power dissipated from device when in the tripped state in 23°C still air.
Ri (min.): Minimum resistance of device as supplied at 23°C unless otherwise specified.
Ri (max.): Maximum resistance of device as supplied at 23°C unless otherwise specified.
R1(max.): Maximum resistance of device when measured one hour post reflow (SMD) or one hour post trip (radial-leaded device) at 23°C unless otherwise specified.
BU-SB11018
Page 1 of 4
Data Sheet 4399
Dimensions - mm
Part
Number
PTR016V0075
PTR016V0090
PTR016V0110
PTR016V0120
PTR016V0135
PTR016V0155
PTR016V0160
PTR016V0185
PTR016V0250
PTR016V0300
PTR016V0400
PTR016V0500
PTR016V0600
PTR016V0700
PTR016V0800
PTR016V0900
PTR016V1000
PTR016V1100
PTR016V1200
PTR016V1300
PTR016V1400
PTR016V1500
A
Max.
7.0
7.4
7.4
7.0
8.9
6.9
8.9
10.2
11.4
7.1
8.9
10.4
10.7
11.2
12.7
14.0
16.5
17.5
17.5
21.6
23.5
25.1
B Max
Lead Type
Straight Kink
(-TR) (-TR1)
11.4
12.2 12.2
14.2 14.2
11.7
13.5 13.5
11.7
15.2 15.2
15.7 15.7
18.3 20.5
11.0 14.0
12.8 14.8
14.3 16.0
17.1 19.0
19.7 22.0
20.9 23.0
21.9 24.0
25.2 28.0
26.0 29.0
28.0 31.0
29.2 32.0
27.9 30.0
29.0 32.0
D
Min.
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
C
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
5.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
10.0±0.8
E
Max.
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
F
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.5±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
0.8±0.02
1.0±0.02
1.0±0.02
1.0±0.02
1.0±0.02
Figure/
Lead Style
Straight Kink
TR
TR1
3
2
1
2
1
3
2
1
3
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
2
1
Style 1
Style 2
Style 3
Time-to-Trip Curves at 23°C - 0.75-2.5A
B
1000
D
E
G
H
I
A:PTR016V0075
B:PTR016V0090
100
A
c
C :PTR016V0110
F
TIM E IN S E C O N D S
10
D :PTR016V0120
E:PTR016V0135
1
F :PTR016V0155
G :PTR016V0160
0.1
H :PTR016V0185
I:PTR016V0250
0.01
0.001
1
10
100
Fa u lt Cu rre n t (A )
0111
BU-SB11018
Page 2 of 4
Data Sheet 4399
Time-to-Trip Curves at 23°C - 3.0-15A
J
1000
K
L
M
N
O
P
Q R S T
U V
J :PTR016V0300
K:PTR016V0400
100
L:PTR016V0500
M :PTR016V0600
N :PTR016V0700
10
TIM E IN S E CO ND S
O :PTR016V0800
P:PTR016V0900
Q :PTR016V1000
1
R :PTR016V1100
S:PTR016V1200
0 .1
T :PTR016V1300
U :PTR016V1400
V:PTR016V1500
0 .0 1
0 .0 0 1
1
10
100
F ault Current (A )
Thermal Derating Curve
P erc entage of D erated C urrent
200.0
180.0
160.0
140.0
120.0
100.0
80.0
60.0
40.0
20.0
0.0
-40
-20
Tem perature (°C)
Recommended Wave Solder Profile
P re h e a tin g
So ld e rin g
Co o lin g
T e m p e ra ture
No te 2
Solvent Resistance
Humidity Age Test
No te 3
130 ± 200°C
No te 1
T am b
Notes:
t
很抱歉,暂时无法提供与“PTR016V0155-BK1”相匹配的价格&库存,您可以联系我们找货
